Keresés
  • ƵøŁĭ
    AVG PC TuneUp 2015® available for BETA testing!
    What's new in AVG PC TuneUp 2015?
    With this generation of PC TuneUp we’re happy to introduce...
    -AVG Disk Cleaner with improved cleaning definitions to help remove the wasteful files of 35 additional programs, such as the gaming platforms Steam® and Origin™ and popular applications like Skype™ and Picasa™.
    -A new AVG Cleaner™ for iOS® through which you are able to clean unwanted junk and hidden leftover files from your iPhone®, iPad® or iPod® touch.
    -Improved Duplicate Finder which automatically recommends which file versions to remove.
    -Various other tweaks and improvements.
  • ƵøŁĭ
    válasz #41133696 #24 üzenetére
    http://download.tune-up.com/TUU2012/1002978/TuneUpUtilities2012_en-US.exe
    (direkt linkeltem így) Külföldi fórumon linkelték be .
  • ƵøŁĭ
    AVG PC Tuneup 2014 14.0.1001.38 Beta
    AVG PC Tuneup 2014 - is a set of tools designed for diagnostics, configuration and optimization of Windows. AVG PC Tuneup is a shell that provides the user with a great set of tools for working with the registry, disk, file system and services, deleting and restoring files, system settings. All the tools included in AVG PC Tuneup, designed to perform three types of problems: the control parameters of the system and its configuration, removal of unnecessary objects and optimization of system parameters.
    The new interface running AVG PC TuneUp offers a centralized development of all the functions and capabilities of adjustment. The main area of ​​the interface running AVG PC TuneUp is divided into five categories, which are open to you fast and grouped by subject access to the most important functions of AVG PC TuneUp.
    Optimization of the system:
    • Deactivation of programs
    • Disabling startup programs
    • Uninstall
    • Configure Live-optimization
    • Cleanup
    • Defragment registry
    • Removal of non-working shortcuts
    • Faster startup and shutdown
    Defragmenting the hard drive
    Freeing up disk space
    • Clean up your hard disk
    • Find and delete large amounts of data
    • Secure data deletion
    Troubleshooting
    • Elimination of common problems
    • Check the hard disk for errors
    • Recover deleted files
    • Display and completion of ongoing processes
    • Display information about the system
    Customize Windows
    • Customizing options and environment
    • Configure the individual design of Windows
    Gathering information about your system and hardware
    AVG PC Tuneup 2014 provides information on the characteristics of the computer hardware, installed programs, running applications, and services, startup settings, updates, operating system, file locations on the disk. The information obtained will help build a more complete mental model of your system, find out about her "thin" places and decide to upgrade iron or acquisition of new software.
    • Disk Cleanup
    AVG PC Tuneup 2014 allows you to clean the hard disk from temporary files on the system and application installation files, duplicate files, unnecessary applications. Purification of the disk space is becoming more and increases the manageability of data. The program will help you to fight the increasing entropy (the measure of uncertainty and confusion in the information) in a single computer.
    • Defragment and troubleshooting on disks
    The built-in AVG PC Tuneup Utilities 2014 can defragment and fix disk errors. And if cleaning can keep in order the data structure that enables optimum defragmentation post these data on the drives and increase data access.
    • Working with the registry
    AVG PC Tuneup 2014 corrects structural defects and errors in the device registry, defragmenting the registry. The result of this work is to increase the stability and performance of your computer.
    AVG PC Tuneup 2014 allows you to recover accidentally deleted data and documents deleted by viruses and malware. This improves the safety of the system.
    • Setting up
    AVG PC Tuneup 2014 includes a tweaker in its composition (a utility for fine tuning of the operating system or software) that allows changing over 280 system settings. Most often, these settings change the appearance of the user interface. The tool is interesting because most of these settings are difficult or even impossible to change the means of the system.
    • Optimize your Internet connection
    Internet Optimizer utility can increase the speed of downloading files and websites, optimizing Internet connection settings. Optimization can take place either automatically or manually.
    AVG PC TUNEUP 2014:
    Product: AVG PC TuneUp
    Version: 2014 (build 38) beta 1
    NEW FEATURES IN VERSION 2014
    * Improved cleaning definitions:
    - cleaning unnecessary files from iTunes and Windows Metro applications
    * Duplicate Finder:
    - scanning the hard drive for duplicate files
    - results sorted by categories: Pictures, Music, Videos, Documents, Archives, Others
    - further sorting of the results according to various parameters (e.g. file size, name, count of duplicates)
    - deleting the selected duplicate files
    * Flight Mode:
    - disabling WiFi and Bluetooth connections via simple switch to save the battery time
    * User Interface:
    - simplified layout
    - modern design
    KNOWN ISSUES
    * User Interface: Minor flaws in user interface design.
    * Flight Mode: Does not work (does not turn off/on WiFi and Bluetooth) on Windows XP.
    * Duplicate Finder: Missing result dialog after successful deletion of duplicates.
    * Duplicate Finder: Duplicates are removed (withou moving into Recycle Bin) when Recycle Bin is disabled in Windows.
  • ƵøŁĭ
    válasz #41133696 #19 üzenetére
    Már nem lehet ,mert letöltéskor a 2013 telepítőt tölti .
  • ƵøŁĭ
    válasz #41133696 #17 üzenetére
    Nem is lepődtem meg ezen . Esetleg PM-be tudnál nekem küldeni az TU-hoz egy 2012-es telepítőt ?
