Barton
In response to claims from a forum member of a certain hardware review site, ECS Elitegroup wishes to make the following statement:
ECS has conducted extensive re-testing of the K7S5A and has held discussions with AMD to investigate the claim that there is a problem with the ZP setting on the K7S5A. ECS tested the K7S5A, as it tests all motherboard models, with a wide range of industry-accepted benchmark tests, including Memtest (not Memtest86) and Winstone 2001, that are used by all tier one motherboard manufacturers. As none of these reputable tests identified any such problem, ECS and AMD are therefore of the view that the alleged problem does not exist. However, we do believe there could possibly be a utility problem with the Memtest86 program.
It should be noted that AMD issued a Technical Note on 30th August, stating that the ZP setting for its XP series of processors should be 56.0 ohms. Since this bulletin was issued, ECS has complied with the guideline to ensure that the ZP setting on the K7S5A is fixed at around 56 ohms, otherwise the XP processors do not work. There is no problem with Athlon processors.
The K7S5A has passed AMD’s stringent testing and appears on AMD’s list of recommended motherboards that are compatible with the full series of AMD XP processors.
In circumstances where ECS believes an unreasonable accusation has been made publicly against the company, ECS reserves the right to take legal action if deemed appropriate.
Nemcsak az utolsó mondat sikerült egy kicsit M$sra és Int$sre.
Szóval tök jó minden és mi mindannyian hülyék vagyunk !
I should use 1 of those 4 lettered words !
EEEEEEEEEEEEEERRRRRRRRRRRRR.............
- Milyen légkondit a lakásba?
- Nintendo Switch
- Google Pixel topik
- OLED monitor topic
- World of Tanks - MMO
- Bomba Ár! HP ProBook 650 G1 - i5-4GEN I 8GB I 128-256SSD I 15,6" HD I Cam I W10 I Garancia!
- Samsung Galaxy A54 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- Xiaomi 14T Pro 512GB, Kártyafüggetlen, 1 Év Garanciával
- Honor 90 /12/512GB / Kártyafüggetlen / 12Hó Garancia
- Nagyakkus, mobilnetes - Dell Latitude 5330 i3-1215U 6mag! 16GB 512GB 13.3" FHD 1 év gar
