Keresés
  • toza
    KOSSZ!
    viszont kozben meg ezt fedeztem fel...meglevo beos adatja
    BIOS Type: American Megatrends
    BIOS ID: 61-0208-001169-00111111-071595-440LX-1440L000
    OEM Sign-On: A6160O1 V1.2B1 042999
    ez meg az uj lenne...
    This is the initial Award® BIOS release.
    3. This BIOS employs the new naming convention of Micro-Star
    BIOS: W6160 MS V1.0 011599
    szal gyanus..ez nem is ujabb,meg nem is american megatrends...pedig alaplapon ott figyel ms6160 v1.0 as felirat... i m confused...
  • toza
    gaz van!
    1. Turn on your computer.
    2. Boot up clean, bypassing your AUTOEXEC.BAT and CONFIG.SYS files.
    3. Then, run the AWDFLASH.EXE file.
    EX: C:\>AWDFL52B
    The programming screen will be shown. You will prompt to enter the file
    name:
    File name to program:
    EX: WF73.BIN
    At the bottom of the screen, the following message will appear:
    Do you want to save BIOS (Y/N)?
    Press ''N'' if you do not want to save the old BIOS.
    Press ''Y'' if you want to save the old BIOS. Enter file name to save.
    File name to save: __________
    After saving the old BIOS, the following message will appear at the
    bottom of the screen:
    Are you sure to program (Y/N)?
    Press ''N'' if you do not want to program the new BIOS.
    Press ''Y'' if you want to continue programming the new BIOS. The new BIOS
    will then be programmed. When it has finished programming, the following
    Flash EPROM Program Successful.
    igy kene csinalni,de igazabol 2. pontnal elakattam,korabban mar kb 5 cor fleseltem bioszt,de akkor mindig lemezre dobtam file okat,es onnan butolt kb,vagy alaplap miatt konnyebbvolt meg stb...e most nem ok vmi...
    elmondana vki hogy kell bypassingni?merthogy en win98 indito floppal ertem el vmit,aztan indult a cucc,de ha nem mentem regi beost akkor aztirja hogy nem egyezik a fajlrencerremmel vmi,biztos akarom vagy vmi ijesmit,ha meg menteni akarom beost akkor meg owerflood akarmi van es megkene vmit valtoztatni config.sys ben..hogy is van ez??
    (bocs a hoszzu hsz k miatt...)
  • toza
    hihetetlen h mijen lusta emberek vannak...igazabol 2 mp volt az a 2 ora vizualis keresgeles...ugynezki...
    elbujt a rohadek a video kartya ala...ms6160 az alaplap ..
    leszedem legujabb biost,de gyanus h az van mar fennt...nem baj..
    azert koszi szepen mindenkinek segitseget!!
  • toza
    mindenkinek nagyon koszi szepen..probalkozok live updat izevel egyenlore ..aztan nezek megint..majd mentek,es pakolok..es koszi..
  • toza
    válasz kraftxld #613 üzenetére
    en is rakerestem nyilvan azert irtam h gyanus ,de nem ez a,3 pci slot,2 ram slot, es allul is csak egy ojan nagy ize van...de kereso megis ezt dobja ki bios id alapjan...erdekes mi?!?! :D :(
    egyebkent mi ez a pci s atalakitos vmi???ez erdekelne!!!
    viszont van benne egy
    Field Value
    ATA Device Properties
    Model ID Maxtor 91024U4
    Serial Number W40ZY5JA
    Revision VA5105F0
    Parameters 19386 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
    LBA Sectors 19541088
    Buffer 2 MB (Dual Ported, Read Ahead)
    Multiple Sectors 16
    ECC Bytes 57
    Max. PIO Transfer Mode PIO 4
    Max. UDMA Transfer Mode UDMA 4 (ATA-66)
    Active UDMA Transfer Mode UDMA 2 (ATA-33)
    Unformatted Capacity 9542 MB
    ATA Device Features
    SMART Supported
    Security Mode Not Supported
    Power Management Supported
    Advanced Power Management Supported
    Write Cache Supported
    Host Protected Area Supported
    Power-Up In Standby Not Supported
    Automatic Acoustic Management Not Supported
    48-bit LBA Not Supported
    Device Configuration Overlay Not Supported
    ATA Device Physical Info
    Manufacturer Maxtor
    Hard Disk Family DiamondMax Plus 5120U
    Form Factor 3.5''
    Formatted Capacity 10240 million bytes
    Disks 2
    Recording Surfaces 4
    Physical Dimensions 146.6 x 102.1 x 25.9 mm
    Max. Weight 590 g
    Average Rotational Latency 4.18 ms
    Rotational Speed 7200 RPM
    Max. Internal Data Rate 249.6 Mbit/s
    Average Seek 9 ms
    Track-To-Track Seek 1 ms
    Full Seek 20 ms
    Interface Ultra-ATA/66
    Buffer-to-Host Data Rate 66.6 MB/s
    Buffer Size 2 MB
    Spin-Up Time 8.8 sec
    de latom ez is csak ata 66.... bar ez nem tom jo hir e vagy rossz..de ezek szerint 40 gb s nyilvan mar 100 ..es ez majd poblema lesz..
    szoval mi van a pci atalakito izeval??
  • toza
    vagy vki mongya meg pls alaplapon hova irjak a szamomra szukseges adatokat?nev ijesmi?mer en semmit talalok,pedig neztem vagy 2 orat... :(
  • toza
    nem tom ide kell e irni,nyilvan nem kivanok ujabb topikot nyitni ez miatt,de fontos lenne valaszt kapnom,ha rossz hejen van a kerdes vki dobja mar at a megfelelo hejre kosz..
    adott egy p2 es alaplap,everest szerint unknow a neve,es ez nem konnyiti meg a dolgomat bios update teren...de van egy
    Program: eSupport.com BIOS Agent Version 3.60
    BIOS Date: 01/01/98
    Chipset: Intel 440EX/LX rev 3
    Superio: Winbond 977EF rev 1 found at port 3F0h
    OS: Win98
    CPU: Pentium® II With On-Die L2 Cache 400 MHz
    BIOS ROM In Socket: Unknown
    BIOS ROM Size: Unknown
    Memory Installed: 63 MB
    Memory Maximum: Unknown
    ACPI Revision: 1.0
    eSupport.com, Inc.
    1-800-800-BIOS (2467)
    www.esupport.com
    ijen infom.... remelem ez segit... lecci vki megtudna mondani honnan mit toltsek le ujabb bios neven,mert elakkattam..!!pls heelp!!
    (igazabol gyanus h MSI 6117 koruli lap,de aztan megsem,viszont meg azt is tudjuk hogy
    Motherboard ID 61-0208-001169-00111111-071595-440LX$1440L000_A6160O1 V1.2B1 042999
    meg azt is h
    North Bridge Properties
    North Bridge Intel 82443LX/EX PAC
    Revision / Stepping 03 / A3
    Package Type 492 Pin BGA
    Package Size 3.5 cm x 3.5 cm
    Core Voltage 3.3 V
    In-Order Queue Depth 4
    Memory Timings
    CAS Latency (CL) 2T
    RAS To CAS Delay (tRCD) 2T
    RAS Precharge (tRP) 3T
    Memory Slots
    DRAM Slot #1 128 MB (SDRAM)
    DRAM Slot #2 128 MB (SDRAM)
    es hogy 3 pci slot van,meg 1 agp ugye,meg allul egy megvalami agp nal nagyobb hosszabb,nemertek hozza bocs...)
    bocs hogy ide meg igy,de lecci aki tugya hol a heje rakja mar at!! KOSZI SZEPEN!!
    ja egyebkent 40 gb s vvincst akarok beledobni azert kene vmi !!
