Keresés
F-ECT$
A volatile object is one that may be modified outside of program control. Memory-mapped I/O ports are a typical example. Declaring an object as volatile indicates that the compiler should always generate code to fetch the object's value from its actual memory location — it may have changed since the last access by the program. (This disallows optimizations which could load the value into a register and possibly return erroneous results.)
volatile char *port1 = 0x00f3; /* ptr to I/O port */
while( *port1 & DATA_FLAG ) /* needs to be volatile */
clear_io();
Bővebben: link
- Elemlámpa, zseblámpa
- Okos Otthon / Smart Home
- E-roller topik
- Tőzsde és gazdaság
- 215 - Lenovo LOQ (15IRX9) - Intel Core i7-13650HX, RTX 4060
- Apple iPhone 17 Pro Max 256GB,Újszerű,Dobozaval,24 hónap garanciával
- Dell Latitude 7280,12.5",FHD,i7-6600U,8GB DDR4, 128GB SSD,WIN11, 2 KAMERA
- Thermal Grizzly Aeronaut paszta 3,9g /BONTATLAN/Több darab/Számlával/
- 244 - Lenovo LOQ (15IRX9) - Intel Core i7-13650HX, RTX 4060
