Keresés
  • holloo
    Nekem ez működött Canon MP140-nél:
    http://resetprinters.com/how-to-reset-canon-mp-series-printers-and-fix-common-errors/
    How to Reset Canon MP Series Printers and Fix Common Errors
    List of Canon Mp Series Printers:
    canon mp830
    canon mp780
    canon mp640
    canon mp620
    canon mp610
    canon mp600
    canon mp560
    canon mp530
    canon mp520
    canon mp510
    canon mp500
    canon mp490
    canon mp470
    canon mp460
    canon mp280
    canon mp270
    canon mp258
    canon mp250
    canon mp240
    canon mp210
    canon mp198
    canon mp190
    canon mp160
    canon mp150
    canon mp145
    canon mp140
    Common Canon MP Error Messages:
    P02 (Carriage error)
    P03 (Line feed error)
    P05 (ASF sensor error)
    P06 (Internal temperature error)
    P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full.
    P08 (Print head temperature rise error)
    P09 (EEPROM error): – The logic board need to be replaced for this one.
    P15 (USB VBUS over current)
    P20 (Other hardware error
    P22 (Scanner error)
    E13 or E16: Ink has run out. Press the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
    E04, E05, E14 or E15: Cartridge may not be installed properly. Reinstall the ink cartridge.
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
    E16-E19 = Failed to scan head alignment sheet
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error –
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error – USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    Reset Procedure:
    Turn ON the printer.
    Press and Hold the “Reset button” on the printer.
    While pressing the “Reset button“, press and hold the “Color Start” button.
    Wait for 5 seconds.
    Release the “Color Start” button, and then release the “Reset Button“.
    Wait until the printer starts to configure itself. This should take approximately around 20 seconds.
    The no. “1” should be on the display, press and hold the “Tool” button and the letter “A” should now be on the display.
    While pressing on the “Tool” button, press and hold the “Reset button“.
    Wait util there are no more blinking lights on the printer.
    Release the “Tool” button, and then release the “Reset Button“.
