- Fórumok
- OS, alkalmazások
- Debian GNU/Linux
- (kiemelt téma)
Fórumok
LOGOUT - lépj ki, lépj be!
Frissítve: 2023-12-13 04:47 Téma összefoglaló
Crvsh3R
Egyébként nem tudom, hogy tudtok-e róla, de Trixie óta a sources.list-nél áttértek deb822 formátumra és szépen lassan vezetik ki a régit.
A meglévő régi source-okat át lehet konvertáltatni az új formátumra a sudo apt modernize-sources paranccsal. A régiekről backupot készít automatikusan. -
Crvsh3R
Ezt értem, csak azt nem, hogy Bookworm esetén miért működött és most miért nem. Annál simán felrakta.
Update:
Közben meg lett a megfejtés, Bookworm-on 13.2 telepítette a default repoból, 14-tól változott a default behavior:"This is going to be quite a long explanation. In order to understand why this is, there are some things about apt that you have to know first.
There are 3 modes to an upgrade with apt.
Only upgrade packages, Do not install or remove any packages. (apt-get upgrade)Upgrade and Install NEW packages if required, but don't remove any (apt upgrade)Upgrade and install NEW packages and Remove packages if necessary (apt/apt-get full-upgrade/dist-upgrade)
Now that we have explained this, we can start talking about Nala. Nala uses python-apt in order to do the apt things. Python-apt has support for upgrade modes 1 and 3, but not 2 which is whatapt upgradeuses.
beforev0.14.0Nala defaulted tofull-upgrade, option 3. There have been many bug reports of upgrades breaking stuff for users of Sid or Ubuntu Devel releases, or sometimes distros who do not manage their repos very well. So with0.14.0we changed the default upgrade mode to option 1. I would have used 2, but it's not available to us, and will be available if I ever finish rewritting it in rust.
This is why you're seeing the discrepancy between nala and apt. If you compare whatnala upgradeis going to do vsapt-get upgrade, You should see that they are the same.
Now, there is a configuration option in/etc/nala/nala.confwhich you can switch the default back to option 3 if you choose too.
Simply go into that file, and change the following option to true, and it will be like Nala was before.# Set to true to make full-upgrade the default full_upgrade = false
If you don't want to change the config you can usenala upgrade --fulland it will be like the old functionality. We also have two aliases for thisnala full-upgradeandnala dist-upgrade, but note there is a bug where the aliases won't automatically update the package lists for you. If you use the config option ornala upgrade --fullthen it still will. This bug will be fixed in the next release.
I think that should be about it, if it's still unclear or you have any further questions, please feel free to ask." -
Crvsh3R
Aki Trixie-t használ és esetleg nala-t is, annál a mai napon lefrissült a legfrissebb kernelre a nala upgrade paranccsal? Bookworm-on simán lefutott az upgrade, most a nala update-re jelzi, hogy van friss kernel, viszont nala upgrade-re azt írja, hogy minden friss. Ezzel ellentétben a sima apt upgrade lefrissítette...
Crvsh3R
Jól olvastam a neten, hogy elméletben lehetséges már Debian 13 Trixie stable-re történő full upgrade?
Itthon van egy docker kiszolgálóm, amin lefuttatnám a frissítést, csak nem tudom mikor lenne érdemes. -
Crvsh3R
Crvsh3R
Hogyan tudnám kideríteni, hogy mibe fagyott bele az itthoni Debian 12 kiszolgálóm? Kora délután még elértem ssh-val, de pár óra múlva ssh-val sem tudtam rálépni, se fizikailag nem tudtam belépni rá (CLI only, logon screen-nél a kurzor nem villogott, mikor rádugtam billentyűzetet nem reagált rá, ki kellett kapcsolnom a power gombbal). Journalctl-ben nem találok semmit, konkrétan arra az időszakra hiányzik. Samba fut rajta, illetve Docker-ben fut pár kiszolgáló, tavaly év vége óta folyamatosan üzemel hibamentesen. Hőfokok rendben vannak. Lenovo ThinkCentre M720q.
Crvsh3R
Crvsh3R
Crvsh3R
Pár perce cseréltem a rendszer meghajtómat egy nagyobb Samsung 970 EVO Plus NMVe SSD-re. A kisebb előző meghajtóról a komplett megajtót a Clonezilla-val klónoztam át, majd Gparted-el újraméreteztem a meghajtókat.
Első indítás után mondom ránézek admesg-re, hogy minden rendben van-e. Hát nem.
Tele van az alábbi sorokkal:[ 37.273979] pcieport 0000:00:1d.0: AER: Corrected error received: 0000:00:1d.0[ 37.274010] pcieport 0000:00:1d.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)[ 37.274017] pcieport 0000:00:1d.0: device [8086:a330] error status/mask=00000001/00002000[ 37.274025] pcieport 0000:00:1d.0: [ 0] RxErr (First)lspciszerint ezzel az eszközzel problémázik:00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
Esetleg valaki tudja, hogy mi lehet a probléma, illetve mi lehet rá a megoldás? -
Crvsh3R
Crvsh3R
Hogyan tudnám kideríteni, hogy egy futó program pontosan hova ír a lemezen?
Plex (Dockerben fut) transzkódolása közben nem találok a megadott temp mappában semmilyen állományt, viszont htop szerint a transzkódolásos folyamatnak I/O-nál van disk activity-je. -
Crvsh3R
Egyelőre amit tervezek ezen a gépen (Dell Optiplex 3070 Micro, i5-9500T, 8GB DDR4 RAM) kiszolgálóként használni azt elbírta a 4GB RAM-al a Raspberry Pi 4 (pár Docker konténer futtatása + Samba). Annyi, hogy pluszban be lesz kapcsolva a transzkódolás is Plex konténer alatt (ez nem tudom mennyit fog dobni rajta, szerintem csak ritkán fog futni, bár ha bírja...). Később felbővítem a max. 32GB-ra, amit bír elméletben a gép.
Crvsh3R
Crvsh3R
Crvsh3R
Headless lesz használva, mint előtte a RPi4, csak itt most ARM64 helyett x64 alapokon, jelentősen erősebb vason fog futni a Docker + Samba kiszolgáló. Menedzselési szempontból érdekelt volna, hogy van-e értelme a GUI telepítésnek, mert konkrétan a WLAN beállítások előhozatala is elég nehézkes volt CLI alatt (alapból nem volt fent a Networkmanager + tiltanom kellett minden hálózati bejegyzést az /etc/network/intrfaces-ben).
Crvsh3R
Friss Debian 12 esetén van valami opció, amit fstab-ban érdemes beállítani az alapértelmezett defaults-on kívül SSD és HDD esetén?
Illetve ha otthoni kiszolgálónak van telepítve, akkor van értelme GUI-t telepíteni? (Eddig Raspberry Pi 4-est használtam erre a célra GUI nélkül)
Fórumok
- Fórumok
- OS, alkalmazások
- Debian GNU/Linux
- (kiemelt téma)
- Dell Precision 7720,17.3",FHD,i7-7820HQ,16GB DDR4,256GB SSD,P3000 6GB VGA,WIN11
- Samsung Galaxy A25 5G 128GB/6GB/Független/Számlával!/
- iPhone 15 128GB Yellow -2 ÉV GARANCIA - Kártyafüggetlen, MS5391
- GAMER PC! i7-10700F / RTX 3070 / B460-Plus / 16GB DDR4 / SSD 512GB / BeszámítOK!
- 27% - ASUS Vivobook S15 OLED Notebook! Ryzen 5 5600H / 24GB 3200MHz / 500GB NVMe
