kenwood
Jah,teljesen vilagtalanok egyesek.
A csucs a "kivetted a routeredet egy mukodo halozatbol" volt.
Ha nem lennek szakmabeli, ez akkor is fajna, de igy rendesen kihullik a hajam.Emlekszem regen ugyanez volt,amikor a szolgaltato tiltotta a sajat router hasznalatat,mert ha ket geped van, fizess elo ketszer.
Paran talan meg emlekeznek a mac klonozasra meg a tobbi baromsagra.
Ott is volt par okos,aki megmagyarazta,hogy az ugy jo am,mert le van irva,ezt irtad ala
Inkabb torlom is ezt a topicot a listarol,mielott jobban felbasszak az agyamat
kenwood
nrg_52
#100578
Mindegy, amit akartam,en megtudtam, meg amit nem kerdeztem,azt is tizen megvalaszoltak.
Zarszonak egy idezet, hogy milyen mentalitassal kellene kezelni ezeket a cegeket. Igaz,ez a warranty void matricarol szol, de a logika ugyanaz mogotte. Ha bebizonyitjak,hogy az en layer 2 switchingem okoz gondot naluk,akkor elismerem,hogy jogosan vettek el azt a menupontot tolem
They cannot void your warranty for using tech-menus, breaking warranty stickers, or any other sort of self repair unless they can prove, specifically, that it was your actions that caused the issue. Warranties, especially those included from a manufacturer by default with no willing agreement on the customers part, are not legally binding in a restrictive sense, only in a liability sense. They have the burden of proof if they want to violate the service contract. The mere act of servicing your device does not alone allow them to invalidate the warranty, regardless of whatever warnings or stickers they place on the device. These companies rely almost exclusively on the ignorance of the consumer in order to employ shady practices that would not be upheld in a court if someone was actually willing to take it that far. I realize the practical reality is somewhat askew of this technicality, but I always feel it is important that people be informed on these issues, because we should NEVER give these corporations an ounce of lenience on these matters because to do so only grants them the justification to take more and more without end. The fact of the matter is that yes, you CAN void your warranty by opening your device but NOT BECAUSE you opened your device. A small but insurmountable distinction.
kenwood
CirrMee
#100568
Nem is kell ide belinkelni.
Az ugye megvan, hogy nem modositani akarom az eszkozt, hanem az hozzaertes hianyabol fakado modositast torolnem,hogy ugyanolyan legyen az ONT, mint az osszes tobbi szolgaltatonal a vilagon.
Ertek hozza,ez a szakmam, be tudnam normalisan allitani,ha nem lenne teljesen kiherelve. -
kenwood
Raiden_
#100561
Azert erdekelne, hogy mi volt az indok, amikor az a dontes megszuletett, hogy a tobbi szolgaltatoval ellentetben, ok nem adnak hozzaferest az eszkozhoz.
En arra gyanakszom, hogy a funkciok tesztelese kozben belefutottak nehany hibaba, amiknek a kijavitasa ido,szakertelem,penz lett volna, ezert egesz egyszeruen kizartak a usereket a
"sajat" eszkozukbol, igy nem tudnak olyan beallitast eszkozolni, ami nem mukodik rendesen.Nyilvan a sajat idezojeles,mert berled ugyan ,de a tobbi szolgaltato csak nagyon indokolt estben tilt le funkciokat,es akkor sem az osszeset.
#100562
Hogyne lenne mar a sajat LAN-om ?
A diginek is van sajat LAN-ja, de az csak a dolgozok szamara erheto el,nincs elroutolva az ugyfelek fele, vagy a tobbi AS-be.
Vagy szerinted ez is az o Local Area Netoworkjuk,es barmikor bejohetnek nezelodni ? -
kenwood
Anyueknal eddig az aktiv szolgaltatoi eszkozok a lakason kivul voltak, csak egy utp kabel jott be a folyosrol, sajat routert hasznaltak.
Nemreg kapott egy modemet,aminek van wireless access point funkcioja is, igy a regi router nyugdijba vonult.Alapvetoen minden fasza lenne, de van 1 nagy problema :
A Samsung mobiljahoz tartozik egy szoftver,ami a belso halon keresztultudja osszekapcsolni a desktop pct es a telefont.
Ez az uj eszkoz beszerelese ota nem mukodik.Mi az oka ennek, illetve hogyan lehetne a problemat megoldani anelkul,hogy a modem melle meg egy plusz fogyasztot (a regi router) is aram alatt kelljen tartani?
kenwood
kulfoldre is megvan amugy a gigabit?
kenwood
belabacsi698
#17413
viszont nagyon csinos lanyok dolgoznak a marketing osztalyon
kenwood
TeeJay
#17578
igazabol nem elore fizetsz.
bar a ho elejen ki kell fizetni a szolgaltatas dijat,de ha felmondod,a hatralevo idore visszakapod a penzedet.
amit irtal,valami felreertes lesz.
ha dragabb szolgaltatasra valtasz,csak arra az idoszakra kell tobbet fizetned,amikortol valoban igenybe vetted.
ha valahogy megis hozzajutottal egy olyan csekkhez,amin mar a magasabb osszeg szerepel az atmeneti idoszakra,akkor tulfizetesed lesz a rendszerben,aminek kerheted a jovairasat.az egyetlen hatranya ennek a modszernek,hogy egy tizedikeig befizetett targyhavi csek eseten nagyjabol 20 napig hasznaljak a penzed egy reszet,amit 2-3%os kamatra be is fektethetnel
persze ez forditva is igaz,ha juli 10.-en fizeted be a juliusi szamlat,akkor 10 napig hasznaltad az o penzuket,hitelben neteztel
egyebkent a 25-os netemet feltoltak 60-ra a napokban.
Olvasd el az összefoglalót!
Társtopikok:
● DIGI kábel TV
● DIGI Mobil
● DIGI műholdas TV
● DIGI vezetékes telefon
● Milyen routert?
● Router gondok
- sziku69: Szólánc.
- Három év után újra előkerült a SiN Reloaded
- Bambu Lab 3D nyomtatók
- Haditechnika, harcászat
- Eredeti játékok OFF topik
- Elektromos autók - motorok
- Mit tehetsz jogilag, ha átvertek, megkárosítottak a Hardveraprón?
- PlayStation 5 FAT Lemezes + kontroller 6 hó garancia, számlával!
- Apple iPhone 13 Pro Max 128GB,Átlagos,Dobozaval,12 hónap garanciával
- Lenovo ThinkPad X240,12.5",HD,i5-4300U,4GB RAM,128GB SSD,WIN10
- REFURBISHED és ÚJ - Lenovo ThinkPad 40AY Universal USB-C Dock
- Logitech Mx mechanical master series magyar keyboardlabor gmail.com
