tzabo
4Grider
#101602
Ez lehet az: Disconnect after time of inactivity (in seconds)
Ennek 0 az értéke -
tzabo
Optikai net van nálunk saját Asus ax55-ös routerrel. Az "Internet detection" beállítást már Disabled-re tettem mégis a system logban az alábbiakat látom. Itthonról dolgoztunk ketten is és nem vettünk észre kiesést VPN-ben sem, ennek ellenére nekem ez kissé fura. Mi miatt lehet ez? Gyanúsan óránként történik valami.
Ötlet?Jan 28 14:44:27 WAN Connection: Fail to connect with some issues.
Jan 28 14:44:27 pppd[2069]: Connection terminated.
Jan 28 14:44:28 pppd[2069]: Modem hangup
Jan 28 14:44:38 pppd[2069]: Connected to 00:25:90:e5:63:7b via interface eth0
Jan 28 14:44:38 pppd[2069]: Connect: ppp0 <--> eth0
Jan 28 14:44:41 pppd[2069]: PAP authentication succeeded
Jan 28 14:44:41 pppd[2069]: peer from calling number 00:25:90:E5:63:7B authorized
Jan 28 14:44:42 pppd[2069]: local IP address 62.165.215.231
Jan 28 14:44:42 pppd[2069]: remote IP address 10.0.0.1
Jan 28 14:44:42 wan: finish adding multi routes
Jan 28 14:44:42 kernel: Archer TCP Pure ACK Enabled
Jan 28 14:44:47 WAN Connection: WAN was restored.
Jan 28 15:44:45 WAN Connection: Fail to connect with some issues.
Jan 28 15:44:47 pppd[2069]: Connection terminated.
Jan 28 15:44:47 pppd[2069]: Modem hangup
Jan 28 15:44:57 pppd[2069]: Connected to 00:25:90:e2:13:f3 via interface eth0
Jan 28 15:44:57 pppd[2069]: Connect: ppp0 <--> eth0
Jan 28 15:45:00 pppd[2069]: PAP authentication succeeded
Jan 28 15:45:00 pppd[2069]: peer from calling number 00:25:90:E2:13:F3 authorized
Jan 28 15:45:00 pppd[2069]: local IP address 91.82.61.172
Jan 28 15:45:00 pppd[2069]: remote IP address 10.0.0.1
Jan 28 15:45:00 wan: finish adding multi routes
Jan 28 15:45:00 kernel: Archer TCP Pure ACK Enabled
Jan 28 15:45:05 WAN Connection: WAN was restored.
Jan 28 16:44:42 pppd[2069]: Connection terminated.
Jan 28 16:44:42 pppd[2069]: Modem hangup
Jan 28 16:44:43 WAN Connection: Fail to connect with some issues.
Jan 28 16:44:52 pppd[2069]: Connected to 00:25:90:e5:63:7b via interface eth0
Jan 28 16:44:52 pppd[2069]: Connect: ppp0 <--> eth0
Jan 28 16:44:56 pppd[2069]: PAP authentication succeeded
Jan 28 16:44:56 pppd[2069]: peer from calling number 00:25:90:E5:63:7B authorized
Jan 28 16:44:56 pppd[2069]: local IP address 91.82.61.154
Jan 28 16:44:56 pppd[2069]: remote IP address 10.0.0.1
Jan 28 16:44:56 wan: finish adding multi routes
Jan 28 16:44:56 kernel: Archer TCP Pure ACK Enabled
Jan 28 16:45:01 WAN Connection: WAN was restored.
Jan 28 16:46:26 WAN Connection: Fail to connect with some issues.
Jan 28 16:46:29 pppd[2069]: Connection terminated.
Jan 28 16:46:29 pppd[2069]: Modem hangup
Jan 28 16:46:39 pppd[2069]: Connected to 00:25:90:e5:63:7b via interface eth0
Jan 28 16:46:39 pppd[2069]: Connect: ppp0 <--> eth0
Jan 28 16:46:44 pppd[2069]: PAP authentication succeeded
Jan 28 16:46:44 pppd[2069]: peer from calling number 00:25:90:E5:63:7B authorized
Jan 28 16:46:44 pppd[2069]: local IP address 212.40.76.116
Jan 28 16:46:44 pppd[2069]: remote IP address 10.0.0.1
Jan 28 16:46:44 wan: finish adding multi routes
Jan 28 16:46:44 kernel: Archer TCP Pure ACK Enabled
Jan 28 16:46:46 WAN Connection: WAN was restored.
Jan 28 17:14:49 WAN Connection: Fail to connect with some issues.
Jan 28 17:14:52 pppd[2069]: Connection terminated.
Jan 28 17:14:52 pppd[2069]: Modem hangup
Jan 28 17:15:02 pppd[2069]: Connected to 3c:ec:ef:38:86:db via interface eth0
Jan 28 17:15:02 pppd[2069]: Connect: ppp0 <--> eth0
Jan 28 17:15:05 pppd[2069]: PAP authentication succeeded
Jan 28 17:15:05 pppd[2069]: peer from calling number 3C:EC:EF:38:86:DB authorized
Jan 28 17:15:06 pppd[2069]: local IP address 94.21.224.254
Jan 28 17:15:06 pppd[2069]: remote IP address 10.0.0.1
Jan 28 17:15:06 wan: finish adding multi routes
Jan 28 17:15:06 kernel: Archer TCP Pure ACK Enabled
Jan 28 17:15:08 WAN Connection: WAN was restored. -
tzabo
Jelenleg 100/100 FTTB csomagunk van és telefon. Ez a szokásos 1 darab UTP kábelen jön be a lakásba és splitterrel megy a wifi routerbe meg a telefonba.
Az új csomagoknál lesz 100-as meg 500-as és az 500-as csak picivel drágább.
500-asra váltáshoz mindenképp kellene új kábelt behúzni vagy a jelenlegi 1 darabon meg lehet oldani az 500-as net és telefont együtt? -
tzabo
Routert cserélnék. A régi tárolta a pppoe név/jelszót. Az újba nem tudom beírni ugyanezt, mert sajnos nem írtam le. Ezért bement DIGI üzletbe és ott azt mondta az ügyintéző, hogy nem tudja megnézni a jelenlegit, de ad újat. Kérdeztem, hogy ez esetben a régi már nem fog működni, mire nemmel válaszolt.
Estére kikapcsolva a routert, reggeli bekapcsoláskor még ment a régi név/jelszóval. Kábelek ki, új router be, új név/jelszó megadva, de nem csatlakozik. Régi vissza, az egyből csatlakozik a régivel.
Ilyenkor mi van? Mennyi idő után él az új név/jelszó és mennyi idő után érvénytelenedik a régi? Maradt volna mégis a régi? Újat gondolom lehet telefonon is kérni.
Kösz! -
tzabo
Szintén Újbuda - Albertfalva.
Itt is volt valami probléma, most már talán úgy néz ki megoldódott.
Érdekes volt, hogy speedtest-en befelé jött adat de kifelé semmi.
Olvasd el az összefoglalót!
Társtopikok:
● DIGI kábel TV
● DIGI Mobil
● DIGI műholdas TV
● DIGI vezetékes telefon
● Milyen routert?
● Router gondok
- Linux Mint
- Hivatalos: készül az Assassin’s Creed IV: Black Flag remake
- Vezetékes FEJhallgatók
- Elden Ring
- Bambu Lab 3D nyomtatók
- Eladó Spirit Of Gamer Headquarter 300 gamer asztal
- Eladó Razer Goliathus Extended Chroma egérpad
- Mika 6EU Konvektor helyére szerelhető gázkazán (Sosem használt,Digitális,ventillátoros,zárt égéstér)
- Samsung Galaxy S26 Ultra 512GB, Kártyafüggetlen, 1 Év Garanciàval
- Eladó dobozos, fóliás THERMALTAKE The Tower 600 fehér ház
- Bomba ár! HP EliteBook 8440P - i5-540M I 4GB I 250GB I DVDRW I 14" HD I Cam I Garancia!
- Apple iPhone 13 Pro Max /128GB / Kártyafüggetlen / 12Hó Garancia / Akku:83%
- Új ASUS Zenbook 14 OLED Ultra 7 155H 32 gb ram 1tb ssd oled pillekönnyű akksibajnok Gari 2027.05
- GYÖNYÖRŰ iPhone 15 Pro Max 256GB Blue Titanium-1 ÉV GARANCIA -Kártyafüggetlen, MS4480
- Telefon felvásárlás!! Samsung Galaxy Note 10+/Samsung Galaxy Note 20/Samsung Galaxy Note 20 Ultra
