xb
nem láttam linkelve eddig, itt az új M1-es FW
http://www.geniatech.com/news/m1-android-4.0-20120730-upgrading-instruction.asp -
xb
Hello
A lifeview-hez ma kaptam új FW-t
http://www.notonlytv.net/download/other/LV2GBOX/update2022012/update20120111.zip
ill az email szövege :Then unzip, change the file name/format to update.img, all are small characters. Please note you did not hide filename extension on your pc.
Plug SD card into the box, go to setting->privacy->update system to update new firmware directly.
You also can use USB disk to update, here is steps:
A: Download and copy the file into USB disk, don’t unzip, change the file name /format to update.img, please note you did not hide filename extension on your pc.
B: Connect USB disk to the box, then, press the update/reset button on the bottom, and plug in power adapter at the same time, hold some seconds, it will update automatically, release the button and the box will restart after finished.
Improvements:
1. Fixed jerky boot screen
2. Improved the Youtube video playback, 1080P videos work more smoothly.
3. Improved the local videos playback with video player.
4. Adding CVBS resolution output in setting as default(For the model with CVBS port)
5. Modified online update function. Update later firmware from internet directly is possible.Regards
- Hardcore café
- Monster Hunter (gyűjtő topik) - PC/PS/XBOX/SWITCH
- Motorola Signature - mielőtt aláírnád...
- Jövedelem
- Szerinted mennyi az ára...? (Közösségi beárazás)
- A cégvezetők látják az AI költségeit, csak azt nem hogyan lesz ebből haszon
- iPhone 13 Pro 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4383, 100% Akkumulátor
- ÚJ/BONTATLAN Microsoft Surface Laptop 7 X Elite 16GB 512GB
- Dobozos! Xbox Series S 512 GB + kontroller 6 hó garancia, számlával!
- AKCIÓ! LENOVO ThinkPad P15 Gen2 munkaállomás - i7 11800H 16GB DDR4 1TB SSD RTX A2000 4GB W
- GYÁRI TÖLTŐK Macbook Magsafe 1 és 2 Budapest,/MPL/Foxpost
