VladimirR
VladimirR
#3388
a harmadik emerge --sync utan eszheztert
valszonuleg kozrejatszott, hogy volt egy kisebb hdd problema (virtualis gep es emerge -ave world kozben a host-on elfogyott a lemezterulet, igy beleszaladtam egy kisebb adatvesztesbe), de nem ertem, hogy miert nem pofozta helyre az elso sync
VladimirR
van arra otlete valakinek, hogy az emerge -ave world miert akarja nekem downgrade-elni a portage-t 2.1.6.11-rol 2.1.6.7-re?
[ebuild UD] sys-apps/portage-2.1.6.7 [2.1.6.11] USE="-build -doc -epydoc (-selinux)" LINGUAS="-pl" 49 kB
*** Portage will stop merging at this point and reload itself,
then resume the merge.eszerint egyik sincs x86-ra maszkolva
VladimirR
akit erint, ez nemreg jott hardened levlist-en:
As of today =sys-libs/glibc-2.8_p20080602-r1 is available for installation on 'stable' hardened systems. As =sys-libs/glibc-2.8_p20080602-r1 will be compiled against also stable =sys-kernel/linux-headers-2.6.27-r2, it is recommended one first upgrade to a >=sys-kernel/hardened-sources-2.6.27
kernel. Running a <=sys-kernel/*-2.6.27 kernel on a system with
=sys-libs/glibc-2.8_p20080602-r1 compiled against
=sys-kernel/linux-headers-2.6.27-r2 has not be tested by the Gentoo Hardened team and is not supported.Now on to the fun...
To attain sha512 shadow password hash capability one must:
1. Upgrade to >=sys-libs/glibc-2.8
2. Compile (+install) >=sys-libs/pam-1 against >=sys-libs/glibc-2.8 3. Compile (+install) >=sys-auth/pambase-20081028 with USE="sha512" (enabled by default)Any newly created or changed user passwords will now be stored via sha512 hash rather than md5. Be aware, sha512 password hashes are not backward compatible with older glibc/pam.
Let's find all md5 password hashes:
# fgrep '$1$' /etc/shadow
Simply change the password for any listed account to have the password stored via sha512 hash.
Many thanks go to Diego "Flameeyes" Pettenò for maintaining PAM and making
sha512 shadow password hash capability a reality in Gentoo.That is all.
Gordon Malm (gengor)
VladimirR
http://torrents.gentoo.org/ masnak sem megy?
en napok ota nem erem el -
VladimirR
VladimirR
ez ma jott hardened levlist-re, hatha erdekel valakit: tin-hat
egy harded gentoo alapu distro, ami tisztan ram-bol futkivancsi vagyok, elegendo lesz-e neki 2 GB memoria (bar ketlem, ha jol ertem, egy 2.3 GB-os image-et csinal boot kozben), tobb sajnos nincs
VladimirR
hogyan tudok gentoo ala a windoze-ban levohoz* hasonlo nslookup-ot varazsolni?
*: jobb referenciam nincs, ami szamit, hogy en adhassam meg parancssorbol a hasznalni kivant dns-t is - ha ezt elmulasztom, hasznalja azt, amit amugy is szokott (itt resolv.conf-bol)
VladimirR
dr_strange
#3347
koszonom
ez vegulis nem tragedia, hogy kimaradt, ugyanezt kinyomta stdout-ra is az emerge, azt meg beirtam a bugzillaba -
VladimirR
VladimirR
#3323
na, szuletett reakcio, egybol ketto is
a masodikkal viszont epp vitaban allok, mert szerintem a ket bug egy es ugyanaz, viszont o nem akarja megerteni, hogy ha emerge-vel, vagy make-kel forgditom, akkor nekem is felzabal minden ram-ot, majd elszall, s csak akkor segfault-ozik, ha kulon a dht_manager.cc sorat kimasolom a make kimenetebol, s azt akarom futtatni a megfelelo konyvtarbanno de nem is ezert irok, hanem mert keri, hogy adjak neki build.log-ot, viszont nekem egy arva build.log nincs a gepemen
mifele allat ez, s mi kell hozza, hogy teremjen?valaszaitokat elore is koszonom
VladimirR
Hi!
ezt mi okozhatja?
[c]mir ~ # /etc/init.d/acpid start
* Caching service dependencies ... [ ok ]
* ACPI support has not been compiled into the kernel[c]
illetve:mir ~ # acpi
No ACPI support in kernel, or incorrect acpi_path ("/proc/acpi").es valoban nincs /proc/acpi
dmesg ilyeneket mond:
ASUS P2B-DS detected: force use of acpi=ht
ACPI: RSDP 000F8190, 0014 (r0 ASUS )
ACPI: RSDT 0DFFD000, 0030 (r1 ASUS P2B-DS 58582E32 ASUS 31303030)
ACPI: FACP 0DFFD100, 0074 (r1 ASUS P2B-DS 58582E32 ASUS 31303030)
ACPI: DSDT 0DFFD180, 1DEE (r1 ASUS P2B-DS 1000 MSFT 1000001)
ACPI: FACS 0DFFF000, 0040
ACPI: BOOT 0DFFD040, 0028 (r1 ASUS P2B-DS 58582E32 ASUS 31303030)
ACPI: APIC 0DFFD080, 005C (r1 ASUS P2B-DS 0 0)
ACPI: DMI BIOS year==0, assuming ACPI-capable machine
ACPI: PM-Timer IO Port: 0xe408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x01] enabled)a kernel konfig idezonatkozo resze pedig:
# Power management options (ACPI, APM)
CONFIG_PM=y
CONFIG_PM_LEGACY=y
# CONFIG_PM_DEBUG is not set
CONFIG_PM_SLEEP_SMP=y
CONFIG_PM_SLEEP=y
CONFIG_SUSPEND_SMP_POSSIBLE=y
CONFIG_SUSPEND=y
CONFIG_HIBERNATION_SMP_POSSIBLE=y
# CONFIG_HIBERNATION is not set
CONFIG_ACPI=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_PROCFS=y
CONFIG_ACPI_PROC_EVENT=y
CONFIG_ACPI_AC=y
CONFIG_ACPI_BATTERY=y
CONFIG_ACPI_BUTTON=m
CONFIG_ACPI_FAN=m
# CONFIG_ACPI_DOCK is not set
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_HOTPLUG_CPU=y
CONFIG_ACPI_THERMAL=m
# CONFIG_ACPI_ASUS is not set
# CONFIG_ACPI_TOSHIBA is not set
CONFIG_ACPI_BLACKLIST_YEAR=2001
CONFIG_ACPI_DEBUG=y
# CONFIG_ACPI_DEBUG_FUNC_TRACE is not set
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_SYSTEM=y
CONFIG_X86_PM_TIMER=y
CONFIG_ACPI_CONTAINER=y
# CONFIG_ACPI_SBS is not set
# CONFIG_APM is not set
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_TABLE=y
CONFIG_CPU_FREQ_DEBUG=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_STAT_DETAILS is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
# CPUFreq processor drivers
CONFIG_X86_ACPI_CPUFREQ=y
# CONFIG_X86_POWERNOW_K6 is not set
# CONFIG_X86_POWERNOW_K7 is not set
# CONFIG_X86_POWERNOW_K8 is not set
# CONFIG_X86_GX_SUSPMOD is not set
# CONFIG_X86_SPEEDSTEP_CENTRINO is not set
# CONFIG_X86_SPEEDSTEP_ICH is not set
# CONFIG_X86_SPEEDSTEP_SMI is not set
# CONFIG_X86_P4_CLOCKMOD is not set
# CONFIG_X86_CPUFREQ_NFORCE2 is not set
# CONFIG_X86_LONGRUN is not set
# CONFIG_X86_LONGHAUL is not set
# CONFIG_X86_E_POWERSAVER is not setaz alaplap egy asus p2b-ds, aminek illenek tudnia az acpi-t, meg boot-kor is azt irja, hogy asus p2b-ds acpi bios rev 1013
kerdes, hogy mit ahgyok ki?
VladimirR
na, a vege az lett, hogy irtam libtorrent levlistre is, meg bugs.gentoo.org-ra is bugzillaba
es nagyon ugy nez ki, nem egyedi a problema, libtorrent trac-ben van egy ticket, ami nagyon hasonlit az enyemre, szinten 3.4.6-os gcc, csak az freebsd
kozben jatszottam massal is, es lenne egy kerdes
Sipi tanacsolta fentebb, hogy csinaljak sajat ebuild-et
libtorrent-hez, rtorrent-hez ment is, elobbi telepult is szepen, utobbi az emlitett hibaval elszallt, de az ebuild mukodikviszont mivel megtetszett az otlet, bele akartam eroszakolni a pvpgn nevu battle-net szerver svn-bol letoltott forrasat is egy ebuild-be, viszont elakadtam
ezen leirast veve alapul csinaltam meg mind az rtorrent, mind a libtorrent ebuild file-jat, tettem be oket a lokalis portage layout-ba, meg miegymas
aztan nekiestem a /usr/portage/games-server/pvpgn mappaban megbujo pvpgn-1.8.0.ebuild file atszabasanak is
gondoltam minden jol megy, nem sokmindent kell piszkalni, atirom a forrast, svn forrasra, az elejen megmondom, hogy orokolje (legalabbis ugy sejtem, erre valo az inherit kulcsszo) a subversion-t is, par sort meg beleteszek, ahol kell, aztan kiadom, hogyebuild pvpgn-9999.ebuild digest
erre kapok egy ilyet:
!!! /usr/local/portage/games-server/pvpng/pvpgn-9999.ebuild does not seem to have a valid PORTDIR structure.
a gond az, hogy megcsak nem is en rontottam el, mert az eredeti ebuild-re kiadva a fenti parancsot, ugyanez fogad:
!!! /usr/local/portage/games-server/pvpng/pvpgn-1.8.0.ebuild does not seem to have a valid PORTDIR structure.
sajna annyira nem ertek a dologhoz, a par sor beillesztese a megfelelo helyre meg megy, de ezzel mar nem birok el
van valami tippetek, hogy ha az eredeti csomagra sem akar mukodni a parancs (pedig telepul emerge-vel), akkor mitevo legyek?
VladimirR
kozben megprobaltam egy olyat, hogy kezzel leforditom azt az egy file-t
bementem az rtorrent/src/core konyvtarba es ott kiadtam, amit a make is
g++ -DHAVE_CONFIG_H -I. -I../.. -I. -I./.. -I../.. -O2 -Wall -g -DDEBUG -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -MT dht_manager.o -MD -MP -MF .deps/dht_manager.Tpo -c -o dht_manager.o dht_manager.cc
erre kaptam egy ilyet:
g++: Internal error: Segmentation fault (program cc1plus)
Please submit a full bug report.
See <URL:http://bugs.gentoo.org/> for instructions.most akkor menjek gentoo-ekhoz (is) bugreportolni, vagy ez lehet azert, mert nem a make folyamaton belul tortent a forditasi kiserlet?
VladimirR
ipv6 tiltva van, semmi szuksegem ra es amennyire tudom, a libtorrent/rtorrent sem tamogatja
xmlrpc egyfelol kell*, masfelol neztem nelkule is, ugy sem jobb
es sajnos a kivaras* sem jo nekem
*: fejlesztek rtorrent-hez, szoval szuksegem lenne ra, hogy naprakesz tudjak lenni
p.s.: make.conf nem csak az emerge altal forditott dolgokra hat? csak mert ez nem ebuild-bol jon, svn-rol szedegetem, magam forditom
VladimirR
igen, mint irtam fentebb, felzabal mindne memoriat (akar mas programok karara is, pl mysql le szokott allni miatta), ez nekem inkabb tunik memory leak-nek, mint a szokasosnal kicsit nagyobb memoriaigenynek (elozo rev eseteben az adott file forditasa eseten 50MB korul megall a cc1plus memoriaigenye, itt felzabal 500-at, majd meghal - azert csak 500-at, mert tobb nincs)
majd meg megnezem, mit csinal, ha kap 1G swap-et, de tartok tole, azt is fel fogja elni
es igen, olvasgattam en is 4-es gcc-rol, de ha nem muszaj, inkabb kihagynam
p.s.: debug-ot nem en kapcsoltam be, nem tudom, ki lehetett - kikapcsoljam?
VladimirR
no, kozben addig eljutottam, hogy az 1041-es rev-tol kezdve jon elo a hiba, mindig a rtorrent forrasaban, a dht_manager.c forgitasakor
-Os, -O1 es -O3 kapcsolok eseteben is (volt mar olyan rtorrent bug valamely gcc verzioval, ahol segitett)masik gcc-t azert nem igazan akartam feltenni, mert sokat szivtam mar kulonfele verziokkal, s ez, ami jott a gentoo-hoz, eddig mindenhol jol viselkedett
most is elobb az rtorrent keszitojevel beszelek, hatha tud valamit mondani ra (en ezt a kodot mar nem latom at, attol picit komolyabb)
ha nem jutnek igy semmire, milyen gcc verzio az, amit batran mertek ajanlani es a fenti linkel stabilkent van jelolve?
VladimirR
hasznal valaki ilyesmi forditot?
gcc version 3.4.6 (Gentoo Hardened 3.4.6-r2 p1.5, ssp-3.4.6-1.0, pie-8.7.10)
a problemam a kovetkezo:
a fenti forditoval egy bizonyos program forditasa soran egy adott file-nal (mindig ugyanannal) a cc1plus elkezdi felzabalni a memoriat, amig az el nem fogy, aztan kis ido elteltevel meghal (meg sok minden mas is, gondolom a rendszer lovoldozi ki oket memoriafelszabaditas vegettszoval a fordito a fenti, a progi az rtorrent, pontos verziot most probalom kideriteni, 0.8.0 meg fordul, a legujabb nehany svn rev mar nem
ami meg szukseges info lehet, az az alabbi:cyla@mir ~ $ uname -a
Linux mir 2.6.23-hardened-r7 #3 SMP Sat Mar 29 21:41:55 CET 2008 i686 Pentium III (Katmai) GenuineIntel GNU/Linuxhogyan ha megvan, hogy mely verzional lep fel a hiba, hogyan folytassam?
frissitsek gcc-t? milyen verzio ajanlott hardened gentoo-hoz?
irjak bugreport-ot? kinek? az rtorrent keszitojenek, vagy a gcc-seknek?barminemu utmutatast szivesen fogadok es elore is megkoszonom
p.s.: ugyanaz a forras, debian-on 4.2.3-as gcc-vel szo nelkul fordul
- Lítium-ion/Li-ion akkumulátorok
- Vicces képek
- Lexus, Toyota topik
- E-roller topik
- One mobilszolgáltatások
- iPhone 13 Pro 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4383, 100% Akkumulátor
- Apple iPhone 17 Pro 256GB Deep Blue karcmentes 100% akku (58 ciklus) - 2026.12.03.-ig garancia
- Decathlonos 43-as boxcipő, alig használt, hibátlan állapotban
- Új Dell 14 Precision 5490 WUXGA IPS Ultra 7 165H 32GB 1TB Intel Arc + Nvidia RTX 2000 Win11 Garancia
- GYÖNYÖRŰ iPhone 13 Pro 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4414
