madmike
Valamikor csaphatnánk egy mx-5-ös versenyt egymés ellen. Mondjuk azt nem tudom, hogy van e valahogy lehetőség arra, hogy kiválaszd ki ellen szeretnél menni..
madmike
Köszi, megnéztem, az SR-emet kell feljebb tornázni, amit a 13. heti ereszd el a hajamban sikeresen elcsesztem (illetve cseszték mások...)
Nem csak a váltó a különbség a két MX-5 között.
A Cup bal kormányos, a Roadster jobb, ezért máshol van a sulypont. A roadsternek kisebbek a kerekei és más lengáscsillapitoi vannak.De egy forumon megtaláltam minden különbséget:
The cars are more than just mirror images of each other. The Cup car is left hand drive, and uses the 6-speed transmission available in the production car. The Roadster is based more closely on the Japanese-spec NR-A version, with it’s 5-speed transmission and slightly smaller tires.
This may seem like a mis-match, but it’s closer than you may think. With the different gearing, the Roadster loses a little bit in straight line acceleration, due to the bigger RPM drops between shifts, but partly makes up for it with a better top (5th) gear ratio compared to 6th in the Cup car. That’s not even mentioning the right hand weight bias that can prove beneficial on the predominantly clockwise-run road racing tracks. However, the Cup car does have a potentially higher top speed (in the draft) on the longer tracks.
- Gearing and setups are the big difference between the two. Gearsets are below:
Cup Roadster
1st: 3.82 3.136
2nd: 2.26 1.888
3rd: 1.64 1.330
4th: 1.18 1.000
5th: 1.00 0.814
6th: 0.79
Final Drive: 4.10- Both cars are going to be fixed setup for Novice level races, so that takes a lot of the “tinkering” out of the equation. Advanced level events in both cars will allow standard adjustment of alignments (Caster, Camber and Toe) along with tire pressures. The Cup car will allow shock damping adjustments as well as limited ride height variation.
- Roadster has Bilstein (non-adjustable) dampers and stiffer springs than standard production, but not too stiff for daily use. (A good number of the racers that run the car at Tsukuba Raceway drive the cars to and from the track, and even commute in them.)
- Cup car has Sachs 2-way adjustable dampers (Bump and Rebound) and are quite similar to the Mustang shocks in their damping adjustment method. Bump is adjusted in “clicks” while rebound is modified by 45° “sweeps.”
- Tires are BFGoodrich G-Force R-1s on the Cup car. The Roadster is going to run the same tires on it, for consistency of performance between the two cars. The mandated tires for the NR-A car are a Bridgestone RE-11 tire, but they aren’t a DOT-R compound, so to minimize any competitive disadvantage it was decided to be consistent, even if not 100% correct in this particular case.
madmike
Nemrég elkezdtem én is játszani a játékkal.
Ha nem gurul el a gyógyszerem akkor általában a mezőny első felében tudok végezni, de sajnos még elég sokszor becsúszik egy-egy baki, főleg nyomás alatt.
Mi kell ahhoz, hogy feljebb kerüljek a rookie-ból?
Amugy nagyon bejön az iRacing. Régebben sokat LFS-eztem, eddig azt gondoltam etalonnak, de most már ezt jobbnak gondolom. Ami nem tetszik, hogy nem elég, hogy fizetsz azért, hogy játszhass még fizetned kell külön a pályákért és az autókért.Nem az én pénztárcámnak lett kitalálva.
Mazdából Ti a Cup-ot vagy a Roadstert ajánljátok?
- Pánik a memóriapiacon
- Gumi és felni topik
- Házimozi belépő szinten
- A robotaxik bizony karamboloznak, nincs itt semmi látnivaló!
- Asztalos klub
- kraftxld: Diáklaptop - Dell Latitude 3140 - Királyunk ajándéka
- Xbox Series X|S
