BullZeye
Semmi, de a renice pgreppel hibátlan, szóval nem aggódom, majd egyszer remélhetőleg belebotlom hova rakja magát Flexget daemon.
NEXT LEFT LAST PASSED UNIT ACTIVATES
Sun 2018-09-02 22:16:07 CEST 2h 19min left Sun 2018-09-02 11:40:34 CEST 8h ago apt-daily.timer apt-daily.service
Mon 2018-09-03 06:46:24 CEST 10h left Sun 2018-09-02 06:23:00 CEST 13h ago apt-daily-upgrade.timer apt-daily-upgrade.service
Mon 2018-09-03 12:53:12 CEST 16h left Sun 2018-09-02 12:53:12 CEST 7h ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
3 timers listed.
Pass --all to see loaded but inactive timers, too. -
BullZeye
Rimuru
#61931
Köszi, tökéletes így, most már csak reménykedni kell, hogy megoldja a problémát.
@Cigam
Crontab tök üres, a parancs pedig ezt adja kiinit.scope loaded active running System and Service Manager
session-c1.scope loaded active running Session c1 of user pi
session-c2.scope loaded active running Session c2 of user pi
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
bluealsa.service loaded active running BluezALSA proxy
bluetooth.service loaded active running Bluetooth service
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
dhcpcd.service loaded active running dhcpcd on all interfaces
getty@tty1.service loaded active running Getty on tty1
grafana-server.service loaded active running Grafana instance
hciuart.service loaded active running Configure Bluetooth Modems connected by UART
home-assistant@homeassistant.service loaded active running Home Assistant
influxdb.service loaded active running InfluxDB is an open-source, distributed, time series database
lightdm.service loaded active running Light Display Manager
ModemManager.service loaded active running Modem Manager
NetworkManager.service loaded active running Network Manager
nmbd.service loaded active running Samba NMB Daemon
polkit.service loaded active running Authorization Manager
rsyslog.service loaded active running System Logging Service
smbd.service loaded active running Samba SMB Daemon
ssh.service loaded active running OpenBSD Secure Shell server
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-udevd.service loaded active running udev Kernel Device Manager
triggerhappy.service loaded active running triggerhappy global hotkey daemon
udisks2.service loaded active running Disk Manager
user@1000.service loaded active running User Manager for UID 1000
wpa_supplicant.service loaded active running WPA supplicant
avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket
dbus.socket loaded active running D-Bus System Message Bus Socket
syslog.socket loaded active running Syslog Socket
systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log)
systemd-journald.socket loaded active running Journal Socket
systemd-udevd-control.socket loaded active running udev Control Socket
systemd-udevd-kernel.socket loaded active running udev Kernel Socket
triggerhappy.socket loaded active running triggerhappy.socket -
BullZeye
BullZeye
#61929
Hol lehet még autostart, ha ezekben nincs, és mégis elindul a Flexget rebootkor?
Ilyen mappa/fájl nincs
/etc/init.d/flexgetEbből kiszedtem már
/etc/rc.localItt pedig nincs flexget
crontab -eMi indíthatja még el Raspbianon a Flexget daemont? Nem találok már más opciót, és elindul, és így a többi indítás (nice) nem működik. Renice pedig ID nélkül nem megy utólag, az pedig minden induláskor változik.
BullZeye
CPT.Pirk
#61927
Akkor viszont mégsem jó így
770 influxdb 20 0 1650928 70608 3748 S 36,6 9,4 37:43.47 influxd
869 homeass+ 20 0 364132 104236 7724 S 12,2 13,9 101:31.29 hass
15269 pi 20 0 8292 3408 2816 R 1,7 0,5 0:00.28 top
1802 root 20 0 349824 86848 5644 S 0,7 11,6 16:11.07 flexgetAkkor valamit elrontottam, mert minden 20as prio. Megnézem a Renice-t is.
Raspbiaonon a renice-al ezt kapom hibának:
pi@hassio:~ $ renice 19 flexget
renice: bad process ID value: flexgetNice parancs úgy néz ki működik, már csak az auto startot kell megtalálnom.
nice -n19 /usr/local/bin/flexget -c /home/flexget/config.yml daemon start -d
15484 root 39 19 255340 74884 6128 S 0,7 10,0 0:00.49 flexget -
BullZeye
Linux alatt lehet megadni, hogy egy process maximum hány % procit használjon?
Flexgetet használok Raspbianon és alapból jó ha 5% kihasználtsága van az eszköznek, viszont 20 percenként mikor a flexget lefut és keresi az RSSeket, akkor 100%on pörgeti a procit percekig, és így a Home Assistant időnként elérhetetlen, vagy nem futtatja az automatizálásokat, ami nem túl jó.
Flexgetnek ha meg tudnám adni, hogy a daemonja valahogy csak max 80%ot használjon, akkor máris hibátlan lenne a rendszer.
BullZeye
Edit.: Most nézem, nem biztos, hogy ez a megfelelő topic.
Dijnet törli számlákat, nekem viszont szükségem lenne rá, de vagy 1 év lenne letölteni egyenként mindet, és emailben konkrétan mossák kezeiket, hogy ilyen helyzetbe hozzák az embereket.
Találtam HUP-on egy megoldást, és más linux rendszerem nincs, csak Synology ds215j
Itt a Shell Script hozzá, viszont login után azt írja ki, hogy:
login... OK
query service providers... ERROR: not able to detect service providers
TerminatedVan valami tippetek, hogy miért? Linkek elméletileg jók, legalábbis amit értettem belőle.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Vírusirtó, Antivirus, VPN kulcsok
- Witcher 1 Collector's Edition
- iKing.Hu - Apple iPhone 14 Stílusos megjelenés, megbízható teljesítmény
- AKCIÓ!!! RITKASÁG! Microsoft Surface Pro 11 Qualcomm Snapdragon X Elite 16GB 1000GB OLED 120Hz Gar!
- Azonnali készpénzes Sony Playstation 5 lemezes és digitális felvásárlás személyesen/csomagküldéssel
- Apple Watch Ultra, Újszerű,Dobozával, 12 hónap garanciával
- BESZÁMÍTÁS! Asrock B450M R5 5500 16GB DDR4 512GB SSD RTX 2060 Super 8GB THERMALTAKE VERSA H17 600W
