A Linux Mint bemutatása
tvamos
Automatan csatolja fel, nem piszkaltam, fstab-ban nincs benne.
A Windows szerint nincs baja a meghajtonak."A VGA (DisplayPort)vezérlése" Ezzel mondjuk nem szokott gond lenni.
"A gép BIOS-ának ACPI-vel kapcsolatos problémájára utal." Oke... nagyjabol mukodik. Egy ideje nincs hibernalas, de az nem olyan nagy gond. -
tvamos
Azt hiszem, ez vonatkozik az USB SSD-re:
[30699.270663] usb 1-5.7.4.1: new high-speed USB device number 22 using xhci_hcd
[30699.407599] usb 1-5.7.4.1: New USB device found, idVendor=152d, idProduct=0580, bcdDevice=31.03
[30699.407621] usb 1-5.7.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[30699.407631] usb 1-5.7.4.1: Product: USB 3.1 Storage Device
[30699.407639] usb 1-5.7.4.1: Manufacturer: JMicron
[30699.407645] usb 1-5.7.4.1: SerialNumber: DD5641988395D
[30699.485893] usbcore: registered new interface driver usb-storage
[30699.493233] scsi host2: uas
[30699.493397] usbcore: registered new interface driver uas
[30699.493754] scsi 2:0:0:0: Direct-Access SAMSUNG MZVLB256HAHQ 3103 PQ: 0 ANSI: 6
[30699.495006] sd 2:0:0:0: Attached scsi generic sg1 type 0
[30701.467881] sd 2:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[30701.467896] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[30701.468192] sd 2:0:0:0: [sdb] Write Protect is off
[30701.468206] sd 2:0:0:0: [sdb] Mode Sense: 6b 00 00 08
[30701.468655] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[30701.468969] sd 2:0:0:0: [sdb] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[30701.476393] sdb: sdb1 sdb2 sdb3 sdb4
[30701.477885] sd 2:0:0:0: [sdb] Attached SCSI disk
[30701.873734] ntfs3: Enabled Linux POSIX ACLs support
[30701.873736] ntfs3: Read-only LZX/Xpress compression included
[30701.874118] ntfs3: Unknown parameter 'windows_names'Ez mi lehet amugy?
[30361.501193] i915 0000:00:02.0: [drm] *ERROR* mstb 0000000025f73321 port 1: DPCD read on addr 0x4b0 for 1 bytes NAKed
[30361.512088] i915 0000:00:02.0: [drm] *ERROR* mstb 0000000025f73321 port 2: DPCD read on addr 0x4b0 for 1 bytes NAKed
[30361.523198] i915 0000:00:02.0: [drm] *ERROR* mstb 0000000025f73321 port 3: DPCD read on addr 0x4b0 for 1 bytes NAKedEz lehet a baja a halozati meghajtoknak?
[ 19.184336] FS-Cache: Duplicate cookie detected
[ 19.184339] FS-Cache: O-cookie c=00000003 [p=00000002 fl=222 nc=0 na=1]
[ 19.184342] FS-Cache: O-cookie d=0000000032fdb1f7{CIFS.server} n=000000000dd1ce51
[ 19.184344] FS-Cache: O-key=[8] '020001bdc0a80064'
[ 19.184351] FS-Cache: N-cookie c=00000004 [p=00000002 fl=2 nc=0 na=1]
[ 19.184353] FS-Cache: N-cookie d=0000000032fdb1f7{CIFS.server} n=00000000e28db338
[ 19.184355] FS-Cache: N-key=[8] '020001bdc0a80064'
[ 20.754629] CIFS: VFS: parse_server_interfaces: malformed interface info
[ 20.758461] CIFS: VFS: parse_server_interfaces: malformed interface infoEz a BIOS error mi lehet?
[ 5.071534] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20210730/exoparg2-393)
[ 5.071591] ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
[ 5.071606] ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
[ 5.072795] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20210730/exoparg2-393)
[ 5.072851] ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
[ 5.072866] ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529) -
tvamos
Nem volt ezzel gond regebben, meg a ceges geppel (W10) megy minden frankon.
Ez a gep lett ergya valamelyik Linux frissites utan. Vagy en buheraltam valamit... nem tudom, nem figyeltem elegge.
A NAS szerint minden drive 100%-os, mindig kuldozgeti e-mail-ben, hogy juhu, de jok. -
tvamos
Volt mar ez az SSD 3 elozo konfigban. Most azt tervezem, hogy berakom egy 5. konfigba. Regebben is voltak mar vele anomaliak. Szoval ideje ujratelepiteni.
A laptopba, ahol most van, meg vissza megy a regi, 250-es SSD, es arra is kerul egy uj Linux.
Ez a terv. De elotte jol le kene menteni rola az adatokat, mert bar 90% meg van a NAS-on, de a maradekot szeretnem megmenteni. -
tvamos
Windowsos geppel mukodik az SSD.
A NAS SAMBA, es van rajta eleg hely. Ugy kb 4TB. Nincs felhasznaloi limit beallitva.Most az jutott az eszembe, hogy kiveszem a gepbol a SSD-t, beteszem kulso hazba, es radugom ugy a NAS-ra, USB-n. Lehet, hogy ez a legegszerubb, es leggyorsabb modja az adatmentesnek? Mi a velemenyed?
A dmesg kimenetet akkor tudom megnezni, ha hazamentem.
tvamos
Ket dolog jott most elo nalam:
1, van egy M.2 SSD-m, (Valami Samsung 250GB,) NTFS file rendszerrel, egy kulso hazikoban, es nem tudom ugy felcsatolni, hogy irasra, csak olvasasra. Ez kb. 1 eve, amikor beleraktam, talan mukodott. (Probaltam a hazon a lock kapcsolot babralni, de nem segitett.)
2, Halozati meghajtora (NAS) iraskor teljesen lelassul a gep, es a file-kezelot sem tudom bezarni. Raadasul ugy tunik, egy ido utan nem is ir oda semmit sem.
Szeretnem ujra telepiteni a gepet, de nem tudom az adataimat menteni.
tvamos
Ceges gepen jo... (Amugy ESP32)
Amugy nagyon fura, mert nem is tudok ramenni a port kivalasztas menure.
Ami nagyon szar, hogy ugye su-kent meg megy. Idegesito.
Neten neztem, hogy megvaltoztatjak a port jogosultsagokta, de nekem az sem mukodik. (sudo chmod 777 /dev/ttyUSB0) Vagy valami ilyesmi. (Nincs most elottem a gep.) -
tvamos
Szeretnem a segitsegeteket kerni, mert frissiteskor lett valami a rendszeremmel.
(Linux Mint 21.3 / 5.15.0-122-generic)
Az a hibajelenseg, hogy amikor elinditom az arduinot, a programozo nem latja a portot. De eddig jo volt, es az arduinot nem frissitettem. Raadasul kiszedtem, es ujra beraktam magam a dialout csoportba. Mondjuk putty latja a portot, es jon is az adat az panelrol. Vegul super userkent elindul a program, de igy meg nem tudom, hogy hova menti a c library-ket, de tuti nem oda, ahova eddig, mert szarakszik velem. -
tvamos
tvamos
#14323
Ha esetleg ez meg segit...
$ inxi -Fxpmrz
Audio:
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GA102 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: Microsoft LifeCam HD-3000 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2
Device-4: Intel ELEGIANT SR030 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.1.4:13
Sound Server-1: ALSA v: k5.15.0-69-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:12
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.2A bluetoothnal meg ezt latom:
tvamos
tvamos
#14322
Rosszabb a helyzet, mert a Sound Output-nal nincs meg az alaplapi hang sem, csak egy HDMI / DisplayPort, meg az USB hangszorom, mondjuk annak az analog, meg az S/PDIF kimenete is.
$ lsb_release -a
No LSB modules are available.
Distributor ID: Linuxmint
Description: Linux Mint 21
Release: 21
Codename: vanessa$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC897 Analog [ALC897 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 3: SR030 [ELEGIANT SR030], device 0: USB Audio [USB Audio]
Subdevices: 0/1
Subdevice #0: subdevice #0A "..." helyen az NVidia kartya kimenetei vannak.
Szerintem az alaplapi hang a "device 0: ALC897 Analog [ALC897 Analog]" lehet, de azt nem tudom kivalasztani az audio eszkozoknel.Mi lehet itt a gond? Megoldas?
tvamos
Az a prolemam, hogy ossze van paositva a BT fejhallgato a geppel, de megsem lehet kivalasztani az audio eszkozoknel, csak, ha ujrainditom a gepet. Mi lehet a herotja? Van valami ilyen ismert hiba, vagy ez nalam egyedi jeleseg lehet?
Linux Mint Vanessa. -
tvamos
tvamos
#14151
Az open-source driverrel indulas utan lefagy a grafikus felulet, parancssorbol (vagy hogy hivjak mar! <ctrl><alt><F1>) tudok visszarakni masik drivert. Persze, az "nvidia-driver-520-open - distro non-free recommended" driverrel sem jo, maert akkor meg csak 1 display megy, VGA modban, alacsony felbontassal, es azonnal indul a Driver Manager, mert szerinte nincs mukodo driver. Szoval most az "nvidia-driver-520 - distro non-free" megy, jatek alatt megy is a kartya, az "nvidia-smi"-re ezt mondja magarol: Driver Version: 520.56.06.
tvamos
Nem akar indulni a gepen se a Cheese, se az OBS Studio. Az OBS ezt a hibauzenetet adja:Failed to initialize video. Your GPU may not be supported, or your graphics drivers may need to be updated.
De ugy tunik, hogy van video driver:$ ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00002216sv00003842sd00004897bc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-520-open - distro non-free recommended
driver : nvidia-driver-520 - distro non-free
driver : nvidia-driver-515-server - distro non-free
driver : nvidia-driver-515 - distro non-free
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-470 - distro non-free
driver : nvidia-driver-510 - distro non-free
driver : nvidia-driver-515-open - distro non-free
driver : nvidia-driver-510-server - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
Ha lehet, meg sok is....
(RTX3080 van a gepben)
Az OS:$ lsb_release -a
Description: Linux Mint 20.3
Release: 20.3
Codename: una
Mi lehet itt a problema? -
tvamos
ubyegon2
#14108
Bocs, ezt nem ertem:
"Ha mondjuk van egy joco felhasználóm, akkor berakom azt felhasználónak ubyegon helyett és fel is csatolja a particiót."
Ha 3 felhasznalo van, akkor 3x rakjam be az fstabba?UUID=6kcc0d47-fa5e-3441-94b6-0c87e15db075 /media/admin/Data ext4 nosuid,nodev,nofail 0 0
UUID=6kcc0d47-fa5e-3441-94b6-0c87e15db075 /media/kukac/Data ext4 nosuid,nodev,nofail,noexec 0 0
UUID=6kcc0d47-fa5e-3441-94b6-0c87e15db075 /media/zorro/Data ext4 nosuid,nodev,nofail,noexec 0 0
Igy kell erteni? -
tvamos
Ezt a sort probaltam beilleszteni az fstabba:UUID=7efac92c-6425-4c51-80f4-09f7b2f939fd /mnt/Data ext4 defaults 0 0
Nomost oda is kerul, csak igy nem latszik az eszkozok kozott a nemoban, es igy azert nem olyan franko.
Mi erre a megoldas? Marmint, hogy fel legyen mountolva amikor elindul a gep, es meghajtokent is latszodjek a nemoban? Termeszetesen azt szeretnem, ha minden felhasznalonak ott lenne. -
tvamos
cappa72
#14018
Beirtam amit javasoltal a
/etc/samba/smb.conf-ba.Aztan ezt tapasztaltam:
$ sudo systemctl restart smbd.service
Failed to restart smbd.service: Unit smbd.service not found.Gondolom nem igy kellett volna legyen!
(#14022) zizidor
Szerintem a NAS-sal nem lehet gond, mert Windowsos geprol, meg Androidos telefonrol jo. -
tvamos
zizidor
#14014
IP-vel tudom pingelni, arra valaszol, es ezert azt adtam meg neki.
"a NAS milyen SMB verziót támogat"
Ez nagyon jo kerdes... QNAP TS-251+ NAS-rol van szo, firmware frissitve van. Szerintem van SMB2/SMB3 support, de nem tudom, hogy ezt nekem kulon be kell kapcsolni, vagy hogy mi hogy van. -
tvamos
Tegnap frissitettem a linux mintemet, es azota nem tudom a NAS-on a share foldereket bongeszni. (Termeszetesen ezelott jol mukodott.)
Eloszor ezt a hibauzenetet kaptam frissites utan:
Nemo cannot handle network locationsEzt megoldottam ugy, hogy ujratelepitettem a gvfs backends-et, barmit is jelentsen ez:
sudo apt reinstall gvfs-backendsMostmar latja a NAS-t a Nemo, de most meg ezt a hibauzenetet kapom:
Unable to Mount Location
Failed to retrieve share list from server: Invalid argumentNomost, ha igy probalom, akkor mukodik:
smb://<server>/<share>Node az nem lenne baj, ha nem kene ezt mindig beirogatni, hanem tudnam listazni a kulonbozo megosztasokat, mint regen!
tvamos
lev258
#13910
De mi mehetett felre? Mindent ugyan ugy csinaltam, (vagyis nem csinaltam semmit,) mint legutobb, (ugyan az a telepito pendrive volt bedugva, ugyan abba az USB portba,) es megsem tette fel.
(#13909) Sonja
De legalabb mostmar jo lett. Nagyon szepen koszonom!inxi -Gxxx
Graphics:
Device-1: Intel vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:4c8b
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1200~60Hz
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.0.3
direct render: Yes
lshw -c display
*-display
description: VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:145 memory:50000000-50ffffff memory:40000000-4fffffff ioport:3000(size=64) memory:c0000-dffff -
tvamos
NeoPampalini
#13904
Ezek a kimenetek:
inxi -Gxxx
Graphics:
Device-1: Intel vendor: Gigabyte driver: N/A bus ID: 00:02.0
chip ID: 8086:4c8b
Display: x11 server: X.Org 1.20.13 driver: fbdev
unloaded: modesetting,vesa resolution: 1024x768~76Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.0.3
compat-v: 3.1 direct render: Yeslshw -c display
WARNING: you should run this program as super-user.
*-display UNCLAIMED
physical id: 2
version: 04
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list
configuration: latency=0
resources: memory:50000000-50ffffff memory:40000000-4fffffff ioport:3000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.Annyi meg, hogy minden bekapcsolasnal felugrik a Driver kereso, hogy video drivert keres, de aztan azt irja, hogy minden redben.
tvamos
Sziasztok! Itt vagyok megint... Bocs!
Tegnap elott ujra installaltam a gepem, mindent frissitett is, de valamiert nem ismeri fel a monitorom, es csak 1024x768-ban hajlando kuldeni ra a kepet. Elvileg a systemnel felismeri az i5-11400 CPU-t, de nem tudom, hogy miert nem latja, hogy a monitor 1600x1200-at is tud kezelni. (Regebben ezzel nem volt gond.) Hogyan kene elindulnom a problema kivizsgalasaval? -
tvamos
lev258
#13897
Nem nagyon latok kulonbseget, a "cp -p" atmasolja a jogosultsagokat is, de ugy tunik, hogy megis van valami.
"-p(preserve): With -p option cp preserves the following characteristics of each source file in the corresponding destination file: the time of the last data modification and the time of the last access, the ownership (only if it has permissions to do this), and the file permission-bits."
Mondjuk akkor tanul az ember, ha elrontja...
tvamos
gregory91
#13895
De, azt is megprobaltam mar, csak nem lett jo. (Live rendszer alol.) De mar nagyon keson volt, es csak fejbol csinaltam, ahogy emlekeztem. De nem lett jo, es igy, hogy a "sudo"-ra hibauzenetet dob, mar nincs idegem tovabb kuzdeni vele.
Nagyon bosszanto, amikor tudom, hogy elcseszerintettem, de nem tudok rajonni, hogy mit. Sajnos nem tudok tobb idot raszanni, hogy tovabb kiserletezzek.Igy csinaltam a masolast:
sudo cp -rp /home/* /media/homeAz uj home particio a "/media/home"-ba volt mountolva.
Jah, nincs adatvesztes, csak az "idom" lett oda.
tvamos
A helyzet sulyosabb, mint gondoltam.
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Ez mitol lehet?
tvamos
Ez mi a franc lehet?
error_log
Text (text/plain)
113,5 GB
/var/log/cupsE [31/Jan/2022:19:33:34 +0100] File \"/usr/lib/cups/notifier/dbus\" has insecure permissions (0100777/uid=0/gid=0).
W [31/Jan/2022:19:33:34 +0100] Notifier for subscription 96 (dbus://) went away, retrying!
W [31/Jan/2022:19:33:34 +0100] Notifier for subscription 96 (dbus://) went away, retrying! -
tvamos
lev258
#13884
Ennyit latok:
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: nodmseg
[ 7.601872] iwlwifi 0000:04:00.0: base HW address: 34:c9:3d:02:e7:cf
[ 9.680567] thermal thermal_zone4: failed to read out thermal zone (-61)
[ 9.682281] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0Itt a teljes kimenet, remelem nincs benne kompromittalo info. Majd letorlom kesobb.
Szerencse, hogy kabelen van net...
tvamos
Linux Mint 20.3-am van, es az a baleset tortent, hogy a home a /home konyvtarba lett, de en kulon meghajtora szerettem volna tenni. Nomost azt csinaltam, hogy atmasoltam a sajat home-omat kulon meghajtora, raallitottam a fstab-ot, majd live-ot bootoltam, es letoroltem a regi home konyvtarat. Az tortent, hogy azota nincs wifi a gepen, ami nem jo. (Mert kabelom nincs) Live alatt persze van wifi. Hogy tudnam kivizsgalni, mit rontottam el? -
tvamos
Azt szeretnem kerdezni, hogy miert van nekem ez a hibauzenet:
[FAIL] startpar: service(s) returned failure: plymouth ... failed!
Ezt akkor latom, ha megnyomom a <Ctrl>+<Alt>+<F7> -et... -
tvamos
Ubuntu leirasok kozott volt dd-s megoldas. Gondoltam az a bomba biztos. (Mrmint, ha valami, az tuti mukodik.) Es valoban. Felment a rendszer. (De leallitaskor neha hibauzenetet dob, azzal vissz jovok, ha nem hagyja abba...)
Kar, hogy nem jok ezek a gui-s megoldasok. Kenyelmesebb lenne, mint a dd.
Kosz a segitseget! -
tvamos
Sziasztok linuxmint lmde mate-et szerettem volna ma telepiteni.
Megakad a telepites, amikor ezt irja a telepito:
"Calculating file indexes....."
<Ctrl>+<Alt>+<F7>-re ezt irja:
[Fail] startpar: service(s) returned failure: plymouth ... failed!
<Ctrl>+<Alt>+<F6>-ra ezt irja:
Failed to issue method call: Launcher helper exited unknown return code 1
A topik célja: Segítségnyújtás a Linux Mint-et használó kezdők és haladók valamint a még csak azzal ismerkedők számára.
Kérdés előtt olvasd el a topik összefoglalóját! -> [link]
- Játékra vagy Munkára! Csere-Beszámítás! I7 3930K / Nvida GTX Titan B / 16GB DDR3 / 500GB SSD!
- Ventilátor bazár /NZXT/CORSAIR/LIAN LI/DEEPCOOL/ZALMAN/120MM/140MM/VEZÉRLŐK/LED KIT-ek/
- AKCIÓ! LENOVO ThinkPad P15 Gen 1 munkaállomás - i7 10750H 16GB DDR4 256GB SSD Quadro T1000 W11
- Dell Latitude 5580,15.6",FHD,i5-6300U,8GB DDR4,256GB SSD,WIN11
- ÁRGARANCIA!Épített KomPhone Ryzen 9 5900X 16/32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
