steveetm
make -C app
make[1]: Entering directory `/usr/src/martina/app'
ld app.o mouse.o ../lib/applib -o app.bin -oformat binary -T app.ls
../startup/cstart.o: file not recognized: File format not recognized
make[1]: *** [app.bin] Error 1
make[1]: Leaving directory `/usr/src/martina/app'
make: *** [app/app.bin] Error 2
Press any key to continue...
debian:/usr/src/martina# make
make -C startup
make[1]: Entering directory `/usr/src/martina/startup'
nasm -f coff cstart.asm
gcc -c -O2 tinymain.c
make[1]: Leaving directory `/usr/src/martina/startup'
make -C lib
make[1]: Entering directory `/usr/src/martina/lib'
gcc -c process.c; ar cr applib process.o; rm process.o
In file included from ../global/syscall.h:28,
from process.c:25:
../global/synch.h:45:7: warning: no newline at end of file
nasm -f coff bitmanip.asm; ar cr applib bitmanip.o; rm bitmanip.o
gcc -c memory.c; ar cr applib memory.o; rm memory.o
memory.c:24:29: ..global ypes.h: No such file or directory
memory.c:25:29: ..globalsynch.h: No such file or directory
memory.c:26:30: ..globalmemory.h: No such file or directory
memory.c:49: error: syntax error before ''char''
memory.c:50: error: syntax error before ''struct''
memory.c:51: error: syntax error before ''struct''
memory.c:51: error: `NULL' undeclared here (not in a function)
memory.c:59: error: syntax error before ''struct''
memory.c:60: error: syntax error before ''void''
memory.c:68: error: syntax error before ''void''
memory.c:68: error: syntax error before ''nbytes''
memory.c: In function `malloc':
memory.c:74: error: `nbytes' undeclared (first use in this function)
memory.c:74: error: (Each undeclared identifier is reported only once
memory.c:74: error: for each function it appears in.)
memory.c:78: error: `NULL' undeclared (first use in this function)
memory.c: At top level:
memory.c:128: error: syntax error before ''void''
memory.c:169: error: syntax error before ''struct''
memory.c: In function `morecore':
memory.c:181: error: `NULL' undeclared (first use in this function)
memory.c:198: error: syntax error before ''void''
memory.c:215: error: syntax error before ''void''
memory.c:215: error: syntax error before ''ulong''
memory.c: In function `clearmem':
memory.c:220: error: `ptr' undeclared (first use in this function)
memory.c:222: error: `s' undeclared (first use in this function)
ar: memory.o: No such file or directory
rm: cannot remove `memory.o': No such file or directory
make[1]: *** [applib(memory.o)] Error 1
make[1]: Leaving directory `/usr/src/martina/lib'
make: *** [lib/applib] Error 2
Nekem ezt csinálja.
Üdv.: steveetm
- aquark: Zsebszámológépek
- Xbox tulajok OFF topicja
- Pécs és környéke adok-veszek-beszélgetek
- Azonnali játékos kérdések órája
- iking.hu Apple MacBook Pro 16 (2021) 16GB / 512GB használt, szép állapot 82% akku 353 ciklus
- PlayStation 5 Slim (lemezes) + kontroller 2027.12.17-ig garancia, számlával!
- Újszerű iPhone 14 Plus 128GB Lila független, 100% aksi, 1 Év garancia
- Eladó Samsung A53 5G 6/128GB / 12 hó jótállás
- Telefon felvásárlás!! Xiaomi Redmi Note 12, Xiaomi Redmi Note 12 Pro, Xiaomi Redmi Note 12 Pro+
