Keresés
  • footy
    válasz Pötty #15 üzenetére
    Köszi,de már sikerült elindítani 1 pár drivercsere után.DX + a catalyst3.1 + 3dmark reinsatall és voila...
  • footy
    válasz The_Tom #3 üzenetére
    128sd-vel ment.256ddr-rel nem megy.A gamekkel eddig nem volt problem.
  • footy
    Eddig 128sd-vel(Hynx) simán lefutott a 3d mark ma vettem 256DDR-t(Elixir) és nem fut le.
    Itt az error.log:
    Application info
    Name 3DMark2001 SE Pro
    Build 300
    Error log
    Failed to decode DDS image: ''Not a valid DDS file''
    System info available: yes
    Project available: yes
    Result file
    3DMARK2001 PROJECT FILE
    PROJECT
    Name My Benchmark
    Description
    Registration Name Twice
    Registration Key
    3DMark Version 300
    DISPLAY
    Platform RADEON 8500 SERIES
    CPU Optimization D3D Pure Hardware T&L
    Width 1024
    Height 768
    Depth 32 bit
    Z-Buffering 24 bit
    Texture Format Compressed
    Buffering Double
    Refresh Rate Default
    FSAA Mode None
    OPTIONS
    Show Title Screens Yes
    Continuous Benchmark No
    Benchmark Run Count 1
    Demo Sounds Enabled Yes
    Continuous Demo No
    Game Sound Effects Enabled Yes
    Game Music Enabled Yes
    Game Detail Level Low
    RESULTS
    3DMark Score N/A
    Game 1 - Car Chase - Low Detail N/A
    Game 1 - Car Chase - High Detail N/A
    Game 2 - Dragothic - Low Detail N/A
    Game 2 - Dragothic - High Detail N/A
    Game 3 - Lobby - Low Detail N/A
    Game 3 - Lobby - High Detail N/A
    Game 4 - Nature N/A
    Fill Rate (Single-Texturing) N/A
    Fill Rate (Multi-Texturing) N/A
    High Polygon Count (1 Light) N/A
    High Polygon Count (8 Lights) N/A
    Environment Bump Mapping N/A
    DOT3 Bump Mapping N/A
    Vertex Shader N/A
    Pixel Shader N/A
    Advanced Pixel Shader N/A
    Point Sprites N/A
    SYSTEM INFO
    System Info Version 2.2
    Installation ID 0x00000000
    OEM ID
    CPU INFO
    CENTRAL PROCESSING UNITS
    Manufacturer AMD
    Family Duron
    Internal Clock 1.27 GHz
    Internal Clock Maximum 1.46 GHz
    External Clock 100 MHz
    Socket Designation Socket A
    Type <unknown>
    Upgrade ZIF Socket
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
    Version AMD Duron(tm)
    CPUID 0x00000671
    CACHES
    Level 1
    Capacity 128 KB
    Type Internal
    Type Details Synchronous
    Error Correction Type <unknown>
    Associativity <unknown>
    Level 2
    Capacity 64 KB
    Type External
    DIRECTX INFO
    DirectX Version 8.1
    DIRECTDRAW INFO
    DirectDraw Version 4.08.01.0881
    DISPLAY DEVICES
    Description Primary Display Driver
    Manufacturer ATI Tech. - Enhanced
    Name RADEON 8500 SERIES
    Total Local Video Memory 64 MB
    Total Local Texture Memory 64 MB
    Total AGP Memory 119 MB
    Display Driver ATI2DRAG.DRV
    Display Driver Version 4.14.01.9082
    Driver WHQL Certified Yes
    Max Texture Width 2048
    Max Texture Height 2048
    Max User Clipping Planes 6
    Max Active Hardware Lights 8
    Max Texture Blending Stages 8
    Textures In Single Pass 6
    Vertex Shader Version 1.1
    Pixel Shader Version 1.4
    Max Vertex Blend Matrices 57
    Max Texture Coordinates 6
    Vendor ID 0x1002
    Device ID 0x514c
    Sub-System ID 0x7149174b
    Revision 0x00
    DISPLAY MODES
    Resolution 320x200x16-bit RGB [565]
    Resolution 320x200x32-bit RGB [888]
    Resolution 320x240x16-bit RGB [565]
    Resolution 320x240x32-bit RGB [888]
    Resolution 400x300x16-bit RGB [565]
    Resolution 400x300x32-bit RGB [888]
    Resolution 512x384x16-bit RGB [565]
    Resolution 512x384x32-bit RGB [888]
    Resolution 640x400x16-bit RGB [565]
    Resolution 640x400x32-bit RGB [888]
    Resolution 640x480x16-bit RGB [565]
    Resolution 640x480x32-bit RGB [888]
    Resolution 800x600x16-bit RGB [565]
    Resolution 800x600x32-bit RGB [888]
    Resolution 848x480x16-bit RGB [565]
    Resolution 848x480x32-bit RGB [888]
    Resolution 1024x768x16-bit RGB [565]
    Resolution 1024x768x32-bit RGB [888]
    Resolution 1152x864x16-bit RGB [565]
    Resolution 1152x864x32-bit RGB [888]
    Resolution 1280x768x16-bit RGB [565]
    Resolution 1280x768x32-bit RGB [888]
    Resolution 1280x1024x16-bit RGB [565]
    Resolution 1280x1024x32-bit RGB [888]
    TEXTURE FORMATS
    Pixel Format 32-bit ARGB [8888]
    Pixel Format 32-bit RGB [888]
    Pixel Format 16-bit RGB [565]
    Pixel Format 16-bit RGB [555]
    Pixel Format 16-bit ARGB [1555]
    Pixel Format 16-bit ARGB [4444]
    Pixel Format 8-bit RGB [332]
    Pixel Format 8-bit YUV [800]
    Pixel Format 16-bit AYUV [8800]
    Pixel Format FourCC [DXT1]
    Pixel Format FourCC [DXT2]
    Pixel Format FourCC [DXT3]
    Pixel Format FourCC [DXT4]
    Pixel Format FourCC [DXT5]
    3D Capabilities AGP Texturing, Edge Antialiasing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Rendering to a Window, N Patches, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
    DIRECTSHOW INFO
    DirectShow Version 6.03.01.0400
    REGISTERED DIRECTSHOW FILTERS
    Filter .RAM file Parser
    Filter AAC Decoder
    Filter AC3 Parser Filter
    Filter AC3 from AVI XForm
    Filter ACELP.net Sipro Lab Audio Decoder
    Filter ACM Wrapper
    Filter ASF ACM Handler
    Filter ASF DIB Handler
    Filter ASF DJPEG Handler
    Filter ASF ICM Handler
    Filter ASF JPEG Handler
    Filter ASF URL Handler
    Filter ASF embedded stuff Handler
    Filter ASX file Parser
    Filter ASX v.2 file Parser
    Filter AVI Decompressor
    Filter AVI Draw
    Filter AVI Splitter
    Filter AVI/WAV File Source
    Filter BDA MPEG2 Transport Information Filter
    Filter ClearVideo® Decompression Filter
    Filter Color Space Converter
    Filter CyberLink Audio Decoder
    Filter CyberLink DVD Navigator
    Filter CyberLink Video/SP Decoder
    Filter DV Muxer
    Filter DV Splitter
    Filter DV Video Decoder
    Filter Default DirectSound Device
    Filter Default MidiOut Device
    Filter DivX Decoder Filter
    Filter DivX MPEG-4 DVD Video Decompressor
    Filter DivXAntiFreeze
    Filter Elecard MPEG2 Demultiplexer
    Filter Elecard PIM2 Null
    Filter Elecard PVA Demultiplexer
    Filter File Source (Async.)
    Filter File Source (Netshow URL)
    Filter File Source (URL)
    Filter File stream renderer
    Filter IVF source filter
    Filter Indeo(R) audio software
    Filter Indeo® audio software
    Filter Indeo® video 4.4 Decompression Filter
    Filter Indeo® video 5.04 kitömörítő szűrő
    Filter InterVideo Audio Decoder
    Filter Internal LMRT Renderer
    Filter Internal Script Command Renderer
    Filter Ligos MPEG Audio Decoder
    Filter Ligos MPEG Splitter
    Filter Ligos MPEG Video Decoder
    Filter Line 21 Decoder
    Filter Lyric Parser
    Filter MIDI Parser
    Filter MJPEG Decompressor
    Filter MPEG Audio Decoder
    Filter MPEG Layer-3 Decoder
    Filter MPEG Video Decoder
    Filter MPEG-2 Demultiplexer
    Filter MPEG-2 Splitter
    Filter MPEG-I Stream Splitter
    Filter Microsoft MPEG-4 Video Decompressor
    Filter Microsoft Screen Video Decompressor
    Filter Moonlight Sync2Async
    Filter Morgan MJPEG Decompressor
    Filter Morgan MJPEG2000 VFW Decompressor
    Filter Morgan Stream Switcher
    Filter Multi-file Parser
    Filter NSC file Parser
    Filter Overlay Mixer2
    Filter QT Decompressor
    Filter QuickTime Movie Parser
    Filter Rududu Decoder
    Filter SAMI (CC) Parser
    Filter SONY DV Video Decoder
    Filter TrueMotion 2.0 Decompressor
    Filter URL StreamRenderer
    Filter VBI Surface Allocator
    Filter VGA 16 Color Ditherer
    Filter VIVO Audio Decoder Filter
    Filter VIVO Video Decoder Filter
    Filter Video Renderer
    Filter Voxware MetaSound Audio Decoder
    Filter Voxware MetaVoice Audio Decoder
    Filter WM ASF Reader
    Filter WM ASF Writer
    Filter WMplug
    Filter WST Decoder
    Filter Wave Parser
    Filter Windows Media Audio Decoder
    Filter Windows Media Multiplexer
    Filter Windows Media Video Decoder
    Filter Windows Media source filter
    Filter XML Playlist
    Filter XviD MPEG-4 Video Decoder
    MEMORY INFO
    Total Physical Memory 256 MB
    Free Physical Memory 158.67 MB
    Total Pagefile Memory 565.03 MB
    Free Pagefile Memory 526.58 MB
    MEMORY ARRAYS
    Max Module Capacity 3 GB
    Location System Board
    Use Flash
    Supported Error D&C None
    Supported Speeds <unknown>
    Supported Types <unknown>
    Supported Voltages <unknown>
    MEMORY SLOTS
    Installed & Enabled Size 0 bytes
    Form Factor DIMM
    Frequency 0 Hz
    Slot A0 [Bank0/1]
    Manufacturer
    Type <unknown>
    Type Details <unknown>
    Total Bit Width 0
    Data Bit Width 0
    Installed & Enabled Size 256 MB
    Form Factor DIMM
    Frequency 0 Hz
    Slot A1 [Bank2/3]
    Manufacturer
    Type <unknown>
    Enabled Size 256 MB
    Total Bit Width 0
    Data Bit Width 0
    Form Factor DIMM
    Frequency 0 Hz
    Slot A2 [Bank4/5]
    Manufacturer
    Type <unknown>
    Total Bit Width 0
    Data Bit Width 0
    MOTHERBOARD INFO
    Manufacturer
    Model VT8366-8233
    Version N/A
    BIOS Vendor Award Software International, Inc.
    BIOS Version 6.00 PG
    BIOS Release Date 09/02/2002
    BIOS Properties Plug and Play, Flash, AGP
    CARD SLOTS
    Number 1
    Designation PCI
    Type PCI
    Characteristics 5.0V
    Data Bus Width 32
    Details Available, Long
    Device Class <unknown>
    Device Name
    Device Manufacturer
    Device Driver Date
    Device Vendor ID 0x0000
    Device ID 0x0000
    Device Sub-System ID 0x00000000
    Device Revision 0x00
    IRQ 0
    Number 2
    Designation PCI
    Type PCI
    Data Bus Width 32
    Device Name
    Device Manufacturer
    Device Driver Date
    Device ID 0x0000
    IRQ 0
    Number 3
    Designation PCI
    Type PCI
    Data Bus Width 32
    Device Name
    Device Manufacturer
    Device Driver Date
    Device ID 0x0000
    IRQ 0
    Number 4
    Designation PCI
    Type PCI
    Data Bus Width 32
    Device Name
    Device Manufacturer
    Device Driver Date
    Device ID 0x0000
    IRQ 0
    Number 0
    Designation AGP
    Type AGP
    Data Bus Width 32
    Details In Use, Long
    Device Class Display Adapter
    Device Name RADEON 8500 SERIES
    Device Manufacturer ATI Tech. - Enhanced
    Device Driver Date 1-31-2003
    Device Vendor ID 0x1002
    Device ID 0x514c
    Device Sub-System ID 0x7149174b
    IRQ 11
    SYSTEM DEVICES
    Description VIA Standard CPU to PCI Bridge
    Manufacturer VIA
    Vendor ID 0x1106
    Device ID 0x3099
    Subsystem ID 0x09961019
    Revision 0x00
    Description VIA CPU to AGP controller
    Manufacturer VIA
    Vendor ID 0x1106
    Device ID 0xb099
    Subsystem ID 0x00000000
    Revision 0x00
    Description VIA Standard PCI to ISA Bridge
    Manufacturer VIA
    Vendor ID 0x1106
    Device ID 0x3074
    Subsystem ID 0x09971019
    Revision 0x00
    Revision 2.0
    Rate 1x, 2x, 4x (4x enabled)
    Aperture Size 128 MB
    Sideband Addressing supported (enabled)
    Fast Write not supported
    MONITOR INFO
    MONITORS
    Name Plug and Play képernyő
    Manufacturer (Szabványos képernyő)
    Max Width 1280
    Max Height 1024
    Max Width 0
    Max Height 0
    POWER SUPPLY INFO
    BATTERIES
    OPERATING SYSTEM INFO
    Operating System Microsoft Windows 98
    Version 4.10.2222 A
    Service Pack A
    Locale HU
    Desktop Width 1024
    Desktop Height 768
    Desktop BPP 32
    HARD DISK INFO
    HARD DISKS
    Name GENERIC IDE DISK TYPE47
    Manufacturer (Szabványos lemezmeghajtó)
    Capacity 3.02 GB
    Model <unknown>
    Interface Type <unknown>
