moonman
ne tessék rámszállni, csak kopizok
meg különben is up
Changes/Improvements made from MCU SW v3.26.0 to v04.01.0 for NOKIA 7710:
- SMS:
- User can add SMS-sender’s name and number to contacts
- An SMS can be replied to with an MMS – and vice versa
- An SMS can be sent to a name or number selected from the Log
- MMS:
- Picture can be sent directly from Camera Application
- An MMS can be replied to with an SMS – and vice versa
- An MMS can be sent to a name or number selected from the Log
- Email
- Email attachments can be viewed while editing a message-to-be-sent
- XHTML
- When downloading a large document that takes time, the backlight will
time out and shut off, but comes back on when the download is
completed.
- Phonebook
- User can add an SMS-sender’s name and number to contacts
- SIM contact can be added to device contacts list while editing
- A call can be made to a SIM contact
- SIM
- SIM contact can be added to contacts while editing
- A call can be made to SIM contact
- Camera/imaging
- Camera upgraded from 1.0 Megapixels to 1.23 Megapixels.
- A picture can be sent directly from the Camera Application
- In the Images application, the user can toggle between ‘List’ view and
‘Thumbnails’ view using the ‘B’ key
- Profiles/ringtones
- Profile icon is displayed in the Desk Tool-bar (when tool-bar is
selected).
- Voice recorder clip can be set as a ringing-tone from Voice-recorder
- A sound clip can be set as a ringing-tone from the Music Player
- A Music Player track can be set as a ringing-tone from the Music
Player
- An alternate line (i.e.: Line 2) can have a separate ring-tone setting
- ‘To-do’ list
- Method of making a ‘To Do’ list entry private has changed.
- Bluetooth:
- SU-8W (Bluetooth) Wireless Keyboard is supported
- Real Player (REAL ONE VIDEO PLAYER)
- Real Player Settings have been moved from the Control Panel to the
Real Player menu
- Visual Radio:
- Visual Radio shuts off when incoming call is received, and re-starts
when call is ended
- Screensaver:
- User can temporarily backlight the screensaver by pressing the On/Off
key
- Alarms:
- When user taps on the Alarm icon on the Desktop, the Alarms
application view is shown
- ‘SKETCH’ application:
- The ‘Full Screen’ command button has been replaced by an ‘Undo’
button
- Wallpapers:
- When the user selects ‘Set Background Image’ (Wallpaper) in the
Desk view, the device simply displays thumbnails of the images in the
‘Images’ folder, instead of displaying a list of every image in the device
and in the MMC.
- Control panels:
Real Player menu
- Languages:
- A number of linguistic/localisation corrections have been incorporated
- Mobile TV support
- Mobile TV enablers are now integrated into the standard 7710
software
- Enhancements:
- Memory Card Content:
- Photobase application dropped from Memory Card content. -
moonman
na most azt az infót kapom, hogy fut azon a többi is, csak scrollozni kell vagymi.
most akkor mivan?
próbáljon már valaki elindítani 5 programot, mondjuk elsőnek egy mp3-lejátszót, hogy egyértelmű legyen ha kilövi. -
moonman
moonman
Az a baj ezzel a 7710-zel, hogy egy csomó hiányossága van.
1,3Mpixel kamera - nem túl meggyőző
videó - realplayer - ratyi minőség, kevés fps
nincs wifi
egyszerre csak 4 alkalmazás futhat
Lehet, hogy most már kivárok az utódáig a 6600-val, még mindig fain kis teló
moonman
GodHeart
#106
na ez az amit én sem értek, hogy nem lehet kilépni?
mert videókon meg leírásban is használ valamit, aztán megnyomja a menüt és visszalép. de a program akkor fut tovább? mert S60-nál ugye fut. hosszan nyomni kell a menüt és akkor lehet választani a futó alkalmazások közül. (alt+tab módjára)
most akkor hogy lehet egyáltalán kilépni programokból? -
moonman
1GB-os MMC hozzája 18200-ért jól Bővebben: link
moonman
én most komolyan gondolkodóba estem Bővebben: link
moonman
az egyik fő különbség, hogy S90-es, aki látott már S90 alkalmazást, tudja ez mennyit számít.
melléfogás? hát gondolom a 7700 hibáiból tanulva adták ki, így eleve nem lehet melléfogás. volt már a kezedben?
anno örülök, hogy nem vettem meg a 6630-at, ritka ronda élőben, vastagabb(!) mint a 7710. jelenleg 6600-m van, nem is lett volna értelme váltani. -
moonman
hivatalosan ''bézs göngyház'' és ''szürke gyöngyház'' színű
Bővebben: link
sárgát még mindig nem látok. persze nem ez a legnagyobb gond, de ha már az ember ennyi pénzt kiad, teccen is.
[Szerkesztve] -
moonman
nekem valahogy PH! fórum-homokszürkében (így jó?
) jobban bejön. -
moonman
GSM Portálon végre a teszt is megjelent Bővebben: link
moonman
ekkora képernyőnél nem zavaró, hogy ''csak'' 65ezer színű és nem 256k?
ja még egy kérdés:
''Mivel a készülék értékesítési csomagja is tartalmaz egy Try&Buy alkalmazáskulcsot, így az összes következő alkalmazást ingyen megkapja hozzá:
Photobase, TimeOut city guides, WorldMate, Mobile Music Maker, SlovoEd Dictionary, Slurp, Lemonade Tycoon.''
ezeket adják hozzá CD-n vagy fel van telepítve, aztán ha letörlöd így jártál?
[Szerkesztve] -
moonman
7710sector Bővebben: link
moonman
poénos kis teszt Bővebben: link
[Szerkesztve] -
moonman
Bővebben: link majd beindul.
hol vetted mennyiért? infókat sokatgyorsan!
én is szemezek vele. -
moonman
Caesarion
#10
ByB írta #4-ben. namost ehhez képest már vásárláskor adnak hozzá valami 6 programot try&buy kulccsal.
mondjuk manualjában így külön nincs is, hogy wab browser, ''web'' rész van csak.
de tökmindegy, mert akkor rendel az ember gprs netet. kb ugyanannyiba kerül és legalább pop3azni is tud.
[Szerkesztve]
- Vállalom FRP Lock os telefonok javítását ingyen kiszálással és akár helyszíni javittással
- Lenovo LEGION 5 PRO Ultra 7 255HX 24GB RAM 512GB SSD RTX 5070 8GB 16" QHD+ 3év Prémium GAR
- AZONNALI SZÁLLÍTÁSSAL Eladó Windows 8 / 8.1 Pro
- szinteÚJ Lenovo ThinkPad L14 Gen5 i7 155U 32GB 1TB FHD+
- Dell Optiplex 390 MT,i3-2130,4GB RAM,500GB HDD,WIN10
![[kép] [kép]](http://www.mobile-review.com/review/image/nokia/7710/screen58.jpg)
) jobban bejön.![[kép] [kép]](http://www.gizmodo.com/archives/images/nokia_7710_l4.jpg)
![[kép] [kép]](http://www.gizmodo.com/archives/images/nokia_7710_l3.jpg)
