MultiDoodad
MultiDoodad
MultiDoodad
#75539
Remelem ezzel segítek valakinek a döntésben.
Samsung S95B
Pros:
· pristine uniformity
· high sustained peak brightness (78% of full PQ)
· high color volume
· high color gamut coverage
· no white subpixel
· slightly more saturation in high APL scenes
Cons:
· countless Tizen Bugs
· game mode is still overtracking PQ-EOTF which leads to a compression of dynamic range, color banding and elevated shadow and midtones. Worst thing is you cannot get out of game mode for playing games!
· no Dolby Vision support
· bad calibration controls compared to LG
· cheap build quality
· questionable quality control
· only available in 55" and 65".
LG G2
Pros:
· pretty accurate OOTB with the right settings
· high sustained peak brightness (75% of PQ)
· heat sink
· exceptional calibration capabilities
· good OS
· longtime support
· Dolby Vision
· low input Lag
· superior build quality and very slim
· available in 77" and bigger
Cons:
· most WBE panels suffer from very bad tinting
· HGiG bug currently (will be fixed though)
· lower color volume than the S95B
· unintuitive interface
· slight color washout in high APL scenes
Generelly both TVs represent the flaqship of their respective brand on paper the S95B is superior in terms of it's technical capabilities, but LG is pushing WRGB to it's limits making both TVs look very similar when both are calibrated side-by-side. The S95B has the slight edge in high APL HDR scenes and can present highlights more saturated than the G2, but to be honest most that seen both calibrated in the same room agreed that the biggest differences are in the tone mapping. I would personally go with the G2 because I can calibrate it to reference and like WebOS. The gaming features are superb and movie consumption is a dream, but you can decide for any TV you want you have to be happy with it at the end of the day!
MultiDoodad
Vhiktor
#75536
Nagyon szépen köszönöm. Hogy én ezt mennyire utálom mikor ott az a termék ami jelen esetben a s95b, ami mellesleg egy kiváló készülék és erre ami nálam fontosabb lenne abban meg pont “hibás”…. És a tudat hogy amikor filmet nézek a G2-n lehetne meg szebb a S95B-n… vicces. Akkor várok meg egy kicsit és ha javítják a problémákat akkor beruházok egy S95B-re ha meg nem akkor lesz más. Számomra azért fontos a téve mert az egyik legtöbb mindenre használt kijelzőm…
MultiDoodad
Sziasztok, egy kis segítségre lenne szükségem mert a YouTube összehasonlító videókban már mindenki mond mindent. Szóval a jelenlegi LG CX 55 Oled tévémet lenyúlta a drága öcsém ezért néztem magamnak egy újat. A helyzet az, hogy a Samsung S95B 55 és a LG G2 55 itt egy árban van ami jelenleg kuponnal 1600 euró.. mivel egy árban van így meg nehezebb a döntés. Elsősorban játékra lenne használva és hébe-hóba film is megjelenne rajta. Pc és Ps5 lenne ami használná… a szobám általában sötét a nap minden percében
így ezek alapján kellene választanom. Most nézem hogy az lg 79 euróval olcsóbb …. -
MultiDoodad
Sziasztok, egy kis információra lenne szükségem. Elég sokat játszom az LG CX-n már hónapok óta és eddig hibátlan a tévé viszont egy két játékban van egy apró zavaró elem, a játékban lévő HUD mint az életerő csík a célzás segítő irányzék halvány de olyan zavaróan halvány és csak az segít ha SDR-ben játszom. Ilyen például a The division 2.. a kérdésem az ha inkább csak SDR-ben játszom mennyivel jobban kockáztatnom a beégés veszélyét? Jelenleg a beállítás SDR-ben oled fényerő 80 kontraszt 85
MultiDoodad
Sziasztok egy LG CX-t szeretnek monitorként használni és az lenne a kérdésem, hogy HDR-Ben vagy SDR-ben van kevesebb esély a beégésre? Csak mert akkor úgy használnám. A válaszokat előre is köszönöm.
MultiDoodad
Valaki meg tudná erősíteni hogy igazak e a pletykák, miszerint az LG CX-re érkező 3.23.06-os frissítéssel csökkentették a maximális fényerőt? Mert ha ez igaz, akkor kicsit csalódtam az LG-ben hogy 1 éves modellnél már lejjebb húzzák a fényerőt....
MultiDoodad
Sziasztok, egy kis segítségre lenne szükségem. Ma az LG CX-n (egy hónapja vásárolt), YouTube app nézése közben egyszer csak sötétebb lett a kép, olyan mint ha az Oled fenyerőt letolta volna magától 60-rol 15-re… Megnéztem és most játék konzolon is sötétebb az SDR és a HDR tartalom is, mint a játék mint a filmek tekintetében is… mi történhetett? Újraindítottam a tevét az sem segített. A valaszokat előre is köszönöm.
MultiDoodad
MultiDoodad
#59816
Bár én meg mindig hadilábon állok a DV-vel mert bár fényesebb eltűnnek a részletek a nagyon ragyogó részeknél, mint nap vagy amikor egy barlangból vagy esetleg házból kifelé jövet a kinti fény teljesen elnyomja a kinti részleteket…
MultiDoodad
Ha a Lg CX-re optikai kábellel kötöm rá a Logitech z906 5.1-t akkor konzol hoz és filmezéshez is a autora vagy PCM-re érdemesebb állítani? Ezek mellet konzolon ugyan így a kimenet PCM vagy Bitstream-re legyen állítva? A válaszokat előre is köszi.
MultiDoodad
GalaHU
#58905
Igazából mind a kettő “jelentős” ugrás a a7 gen2 procihoz képest.
Megnéztem több tesztet CX C1 versenyben és tényleg minimális az eltérés, sőt volt ahol kontrasztban jobban teljesített sötétebb helyeken a CX. Szóval mostani akcióval 1170€ ért tudom elhozni a CX 55” 2021-es gyártásút, szóval a CX marad. Nagyon szépen köszönöm. (Azért sajnálom szegény B9-m
MultiDoodad
Sziasztok, Lg B9 55Oledem el ajándékozom lassan az Öcsémnek és szeretnék helyette egy másikat a jövő hónapban. Ezt a B9-t sokat nyúztam és imádtam… A következő kiszemelt egy cx vagy c1 lenne. A CX most 1280 € a C1 1700€ És mind a kettő 55”. A kérdés az lenne, hogy meg éri e a C1 azt a plusz eurót vagy sem?! Elsősorban én csak játszanék rajta (ps5,sxs) és néha napján meg meg néznék pár sorozatot. A válaszokat előre is köszönöm.
MultiDoodad
Nekem jelenleg az a Black level a probléma. Ps5-n auton van az rgb és ha a tévén autora rakom a black levelt, akkor a fekete nem fekete, ellenben ha low-ra rakom akkor már a fekete az teljesen fekete de így a sótétebb részeknél elvesznek a részletek. :F Elvileg az hogy a ps5 "csak" 32 gbps-t hdmi kábelen keresztül az nem lehet opcionális probléma. Cseréljem ki a gyári hdmi kábelt?
MultiDoodad
Sziaaztok. A Ps5-n próbálom már a harmadik videó alapján beállítani a tévét. Ez egy Lg B9 és a baj nekem most ugyan az a gond mint anno pc-nél. Ha auto a black level akkor fakó kicsit a szín és fátyolos, ha magas akkor meg eléggé sötét az egész... Nem értem miért. DTM On mert minden más sötét, ps5 minden auto. A tévé jelenleg pc hdmi kimenetre van állítva mert mindenhol azt ajánlották. Mi lehet a legjobb beállítási lehetőség?
MultiDoodad
Talán itt kapok választ, lehet a tévé van el állítva.
Egy fura dologra lettem figyelmes ma. Elkezdtem a gears 5 nevezetű játékot, de olyat tapasztaltam amit más játékokban nem, mégpedig hogy a tévé jobb felső sarkában lévő pixel csík olyan 7-11 centiméteres hosszúságban furán villan néha és mint ha nem egyszerre működne a többi pixelel. Másnak is volt hasonló? (Xbox series x és LG B9) Csak ennél a játéknál van jelen ez a furcsaság, 60 és 120hz-n is... kicsit zavaró. -
MultiDoodad
Sokan ajánlották (többek közt youtube mesterek is) a Pc-re való beállítást játék konzol helyett xbox series x esetén Lg oled tévéken. Ez így rendben is van de mi igaz abból, hogy pc módban megnő a “késés” (latency). Bár konkrétumokat nem tláltam eddig, de szerencsére van pár hozzáértő szaki itt
Háta be esik egy jó válasz. A válaszokat előre is köszönöm.
MultiDoodad
Most akkor még is a DTM On a jobb? [link]
MultiDoodad
GuruZone
#51576
Sziasztok, olvastam hogy volt akinek akadtak problémái C9/CX-n az xbox series x-el. Nos úgy tűnik, hogy az B9-n nincs jelen, legalább is nekem eddig minden remekül megy. Egyedül a Cod warzon-ban van sötét helyeken valamiért némi villódzás amit nem tudok hova tenni...
MultiDoodad
janos666
#51276
Köszönöm a választ. Őszintén bevallom én még egyik játékban sem állítgattam a csúszkát HDR üzemmódban, valahogyan sosem volt vele problémám. Nekem még mindig fura kicsit ez a HGIG, mind ha túl tolná a fényes részek fényerejét és ezzel részletek vesznének el (például felhő szélei).
MultiDoodad
Értem, de tudtommal játékmódban nem tudom tévével hdresíteni a játékot. Csak van egy hdr hatás képi üzem mód, azzal az a baj hogy elvesztem az azonnali játék funkciót. Szóval még mindig él a kérdés, játéknál mi lesz a jobb hdr beállítás dinamikus tónus-nál... be,ki,hgig?
MultiDoodad
Látom túl sok teszt még nincs a hdmi 2.1-el kapcsolatban. Viszont a xbox series x-nél jön mellé az auto HDR mód is amivel így minden egyes játékban hdr-ben tudunk játszani. Na a kérdésem az lenne, hogy itt jó lesz e hgig-en marad a beállítás?
MultiDoodad
Sziasztok, jelenleg egy B9 55 gyönyörűséggel rendelkezem amit imádom, viszont Öcsém ki sírta magának a tévémet így újat akarok most vásárolni. Mivel én csak játszom és nagyon ritkán nézek rajta filmet, így van e érdemi különbség BX és CX között? Jövőhónapban jön mellé a xbox series x amivel már kihasználható lesz a hdmi 2.1 “ereje”. Szóval igazából nekem csak a játékélménybeli különbség ami számít, ha egyáltalán van olyan. Mivel a BX 350 euróval olcsóbb így inkább azt választanám, de csak abban az esetben ha nem veszítek vele semmit játék élmény terén. A válaszokat előre is köszönöm.
MultiDoodad
Szia, nekem 11 hónapja van 55 B9... kegyetlen amit kap tőlem jelenleg... átlagban napi 5-8 órát megy hétvégén napi 12 órát is egyhuzamban. Körülbelül 4 hónapig csak warframe ment 80-as Oled fényerőnél SDR-ben (ugye hdr-ben nem nyúlunk a fényerőhöz ha nem muszály marad 100-on), nekem eddig semmi nyoma a beégésnek, ráadásul én pc-hez is használom igaz fekete hátérrel. Szóval nálam már nincs annyira ott az a be égés para, ha még 2 évet kibír nekem megérte. Van 144 hz ips monitorom is és egy 55-ös régebbi samsung tévé de ezt a Oledet semmire nem cserélném le max másik oledre.
MultiDoodad
Nagy Oled tévén való játékosoktól kérdem, van már pontosabb infó arról, hogy érdemesebb HDR-ben játszani? HGIG,Off vagy On? Most az új Cod-ban is próbálkoztam, sima On beállításnál egyenletesen fényes mindenhol HGIG-nél csak az erősebb fények él világosabb... melyik lehet a jobb döntés?
MultiDoodad
Akit érdekel már vannak fent youtube-n HDMI 2.1-es RTX 3080-as kártyákkal, B9,BX,C9,CX 4K 120hz-es tesztek.
MultiDoodad
rothfb
#49535
Számomra ez is fura, mert hogy jó pár youtube emberkénél láttam monitorként használva... ha megtalálom belinkelem, az egyik illető valami 11 vagy 12 hónapja használ munkára C9 Oled tv-t windows futtató géphez. Na az az illető mutatott egy beégés tesztet 11 hónap használat után, neki sem volt semmi (ha igazat mond).
MultiDoodad
Igazából égett már be valakinek 2019-es model? E9,C9,B9,...? Már mint ahol videókban megmutatják vagy éppen képen?! Mert itt sem panaszkodott még senki, bár 1 éves még csak a tv. Mert olyat láttam, hogy valakinek a B7 beéget 13 hónap után... Van konkrét eset? Jó rediten van 1-2 de ami konkrétan bizonyított hogy 2019-es model olyan akad esetleg itt a csoportban?
MultiDoodad
adamssss
#49522
Szerintem a 9-es szériától ezt is felül kéne vizsgálni, nekem B9-m van 11hónapja csak játszom rajta folyamatosan ugyan azzal a 3 játékkal (néha egy kis netflix) és még mindig nincs be égés. Nekem ráadásul SDR-ben 80-as oled fényerőn van.... Még egy évet ki bír nekem elég, utána majd csere cx-re vagy valami másra. De nekem mivel csak játszom az Lg volt a legjobb választás. Most fog Öcsém beújítani egy Cx 55”-t kíváncsi leszek lesz e nagy különbség.
MultiDoodad
janos666
#49040
Én az 55” tévéhez is elég közel ülök
. Tudom elég rossz felhasználó vagyok de én így szeretem. Néha ps-n kifolyik a szemem a pixelek miatt de pc-n 1440p-ben 120hz-n minden szipi szupi szuper
. Nem tudom mennyire lesz jó a B9 az új konzolokhoz de nem vagyok most meg ijedve a váltástól, elraktam rá egy kis összeget mert tervezem egy ideje a vásárlást. De mostanába ez a “sok” panasz cx-re kezd elbizanytalonítani (40gbs hdmi 2.1, hibásan megérkező készülékek, foltok stb stb) csak hát mivel én csupán játszom, nem nagyon van más alternatíva... -
MultiDoodad
Már is kifejtem neked. Elsősorban játszom és ott SDR-ben néha nekem kevés a 144hz-es 1440p-s Acer ips monitor után, másrészről viszont a HDR én a dinamic t.m. -t csak simán Be kapcsolom mert imádom, hogy kifolyik a szemem a gyönyörű sötét feketétől és a szem kiégető napsütéstől. SDR-ben filmeknél nincs különösebb problémám egyedül csak játékoknál zavar (bár már az sem mert jó ideje 80-as Oled fényerőn használom.)
MultiDoodad
Mivel készülődöm a pa5 és xbox sx jövetelére, gondoltam kiépítem magamnak a játék kuckóm véglegesre.... A jelenlegi Lg B9 tévém megkapja öcsém aki szintén várja már a ps5-t és erre alapozva gondoltam lassan vásárlok egy Lg CX 48” mert ebben a méretben kényelmesebben elférnék mint most a 55” tévémmel. Keresgélek neten (németországban, mivel itt tartózkodom többet) erre mi jön velem szembe?
Bár csak 1-2 hónap múlva tervezem a vásárlást (addigra lefutnak az első 30xx kártyák hdmi 2.1 tesztek), de ezt azért nem tudom hova tenni. Hihetetlen, hogy a nagyobb képátló olcsóbb most mint a kisebbik... -
MultiDoodad
Sziasztok, abban tudnátok segíteni, hogy miért fakóbak a színek HDR-ben mint SDR-ben? Már mint értem én hogy nem full Rgb, de akkor ezen nem is lehet segíteni? Egy B9-ről van szó és ps4, pc-s játékokról.
MultiDoodad
Kicsimix
#47878
Szia, le írhatnánk megint de ajánlom neked, hogy olvass vissza körülbelül 2 oldalt. Az elmúlt héten 3x is kitárgyaltuk a tapasztalatot ezzel kapcsolatban. Személy szerint én egy 55B9-el rendelkezem lassan 9 hónapja nyúzom, napi 6 órát is játszom hétvégenként meg napi 11-et is és néha egy kis sorozat. Nincs eddig be égés és semmilyen más meghibásodás sem, de kérlek csak egy kicsit, olvass vissza....
MultiDoodad
torma1981
#47750
Persze én ezt értem, nem hiába vettem meg a B9-et plusz garival itt kint németbe. Senkit nem akarok elijeszteni, Isten ments... sőt ajánlom. De számolni kell azzal, hogy talán lehetnek gondok ha olyan játékos vagy mint én. Még egyszer írom, 9. hónapban járok a tévével és eddig nincs be égés.
MultiDoodad
rothfb
#47744
Úgy gondolom, hogy ez nem az a csoport ahol meg kéne vitatni nem? Android Ios harcot lehet tolni a többi “úgy is az enyém a jobb teló” topikban.. Mellesleg részben igazad van, sok hülye “státusz” szimbólumként próbálja használni, de énnpéldául egy Samsung s20 ultra mellett egy Ipad pro-t használok úgy, hogy előtte iphone 11 pro-m volt. Imádom mind a két rendszert, mind a kettőnek meg van az előnye és a hátránya, kár ezen erősködni. Olyan meg nincs , hogy te 150-ért veszel jobbat akár a 350 ezres samsungtól akár az iphontól. Mellesleg már a Huawei is dobott piacra nem csak fél de 1 milliós “telót” is. Nincs miről beszélni. Mindig lesz jobb olcsóbb stb... de mindenkinek másra van szüksége.
MultiDoodad
Bazsi81
#47742
Igazából már nem érdekel, csak használom. Ha be fog égni a következő egy évben, tudni fogom azt hogy ez nem nekem való és akkor átcuppanok a Qledre vagy ha lesz valami a másik technológiából a samsungnál akkor arra... Annyit görcsöltem már ezen az Istenverte Oleden, hogy meguntam. Eszméletlen gyönyörű a kép amit kilök magából, de ha játékosként ennyi probléma jár vele akkor inkább legyen a rosszabb képminőségű qled és akkor nem kell semmivel sem foglalkozni csak hogy ki essen a szemem a magas fényerőtől
MultiDoodad
alaves
#47734
Tudod mi a fura számomra? Hogy igazából van amikor a 60-as fényerő is sok de van amikor a 80 is kevés.... másik érdekesség, hogy ha pc-ről játszom akkor előjön ez a “fekete villódzás” viszont Ps4 pro-nál ez nincsen még ugyan annál a játéknál sem. Bár én csak játszom elsősorban és SDR-ben 80-as Oled fénnyel tolom, nem nagyon van vele problémám. Engem csak egy dolog zavar igazából, HDR-ben a logó védelem
ahh az a szürkés folt körülötte kiábrándító, viszont a játékfejlesztők csak figyelnek már erre, van rá példa hogy hud egyáltalán nincs vagy full dinamikus. -
MultiDoodad
Bazsi81
#47649
Nekem kb 8 hónapja van egy Lg B9 és eddig nincs be égés, de ha tetszik a Qled akkor inkább azt vásárold meg. Így nem kell tartani a be égéstől és nincs (számomra zavaró) a logo védelem sem ami HDR-ben bizonyos hudoknál enyhe sötét foltot eredményez ezzel védve a be égéstől az Oledet. Bár én imádom a tévét és sokkal szebbnek tartom mint az ips acer monitorom még is parázom a be égéstől, pedig 8 hónap alatt semmi baja. Azt is tudnod kell, hogy tévéknél jelenleg az Lg Oledeknek az egyik legjobb a válaszideje. Hátrány még számomra a kevés fényerő… bár HDR-ben semmi bajom vele, SDR-ben néha még a 60-70 -es fényerőt is keveslem egy kicsit. Összességében egy kiváló tévé játékra ami még sem a legideálisabb ha állandóan éjjel nappal játszol rajta. Nagyon kettős bennem az Oled iránti “érzelmem” mert tényleg szebb “mindennél” de ott vannak azok a hátrányok is. Én is gondolkodom, hogy ez marad filmezésre vagy megkapja Öcsém és beújítok egy Qled-re... másra nem igazán tudnák cserélni főleg Oled után. Nálam a probléma az, hogy én szinte csak játszom, és a napi 4-7 óra mellé a hétvégi 8-10 óra is be esik...
MultiDoodad
Sziasztok, egy kérdésem lenne. Ha csak játékra használom a jelenlegi 55B9-em akkor érdemes lecserélnem egy 55CX-re? Van bármi érdemi különbség amiért megérné lecserélnem? Mert, hogy Öcsém átvenné a mostani, de ha nincs értelme akkor meg minek? Nyújt nekem annyival többet majd Ps5 és Pc-vel a Cx, hogy esetleg megérje lecserélni? Elsősorban csak játék számít.
MultiDoodad
sakal83
#46611
Ne vedd el a kedvem, kérlek...
banding az van itt is ott is, de nem nagyon veszem észre. Viszont szomorú, hogy ennyire “sok” pénzért még mindig nincs “kiváló” termék a piacon. Na jó nem is nagyon lesz szerintem. Ó én már meg írtam, ha egyszer is be ég, akkor ez nem nekem való és keresek mást. Addig viszont elmókázom vele mert szeretem.
MultiDoodad
MultiDoodad
wallace 234
#46550
Hát igen, a fényerő lehetne több de na.
MultiDoodad
daneel_hu
#46546
Ahogy írtam is, ez a négy nap semmiség. Viszont 8 hónapja kapja a kicsike, főleg játékra és főleg HDR-ben. Bár napi 5-7 óra plusz hétvégente napi 11 is de még így sincs eddig gond, persze SDR-ben 60-as oled fény mellett játszom és több multi játékot, de ettől függetlenül ez már több mint fél év. Szóval eddig nem lehet panaszra, de az tény, hogy ha csak például fifa menne az meglátszódna. Viszont nagyon sok új játéknál, automatikusan el van rejtve a hud ha nem használsz bizonyos dolgokat. Mindezek mellett már rengeteg játékban fehér és átlátszó a hud, mér némelyik 2013-as játékban is (lásd Kill Zone) automatikusan rejtve van a hud és ezek mellett még fehér is. Néztem youtub-n teszteket, (amit persze nem hiszek el 100%-ban) ahol sokan sima mezei monitornak használják akár még videó vágásra is, volt olyan emberke aki c9-t használ már hónapok óta és nem történt még beégés se más probléma..
MultiDoodad
MultiDoodad
#46425
Na, közel 4 napi stressztesztemnek vége. Napi 18-20 órát ment a tévé (be kellet vonni a két Öcsémet hozzá
) és csak két féle játék ment, Cod warzone HDR-ben és Warframe SDR-ben. Minden esetben maxon az Oled fényerő. Ma csináltunk egy kis ellenőrzést, hogy van e esetleges beégés, de semmi nem változott (bár ahogy halottam megtörtént a “nagy” pixel frissítés.). Bár rövid idő volt ezt értem, de azért ennyire durván nem fogom használni. Szóval úgy döntöttem, hogy adok egy esélyt a CX 55” vagy 65”-nek csak is kizárólag játékra... ha tudok természetesen kötök rá plusz garanciát, megmondom őszintén ha kb 2,5 évet ki bír minden hiba nélkül akkor nekem megérte. Utána talán már élet képes lesz ez a QD-oled isten nyavajája is. Szóval a B9 nem adja olyan könnyen magát, remélem év végéig nem is fogja, utána jöhet egy CX és persze mellé majd az új konzol. -
MultiDoodad
Hugoméknak B8 van és ők szinte csak a HBO Go-t nézik. Mér több mint egy éve SDR-ben olyan 60-70 oled fényerőn és még nem égett be nekik, múltkor néztem át. Napi szinten megy nekik a tévé és ők hát, hogy is mondjam... egyszerű felhasználók
laikusok
szóval csak használják. -
MultiDoodad
MultiDoodad
#46426
Ja és a másik, hogy bár én is furcsállom az oledet játékra azért azt meg kell hagyni, hogy amikor korom sötétben botorkálva fel csillan egy halvány fény és azt követve a korom sötét szobában (köszönhetően az olednek) lassan kivilágosodik az egész kép majd velea szoba... az marha jól néz ki
MultiDoodad
rothfb
#46424
Egyet értek veled, viszont én szeretem a hatalmas képátlót melyben eltudok merülni egy kontrollerel a kezemben belesüppedve a kanapéba... Ott az 5.1 ami körül vesz és a tv ... ahhh fantasztikus érzés tud lenni és órákon ét magával ragad a szép kép és hangi világ. Nem kell itt pártolni sehova, lásd multi platform RDR 2, akár lovaglom vagy horgászom... leköt és szeretem. Monitor előtt ülve a székemben nem ugyan ezt kapom. Kell legalább egy 55” tévé mellé egy kis hangtechnika egy ps4 vagy xbox és már is kész nekem a varázs.... a filmek meg nem nagyon érdekelnek, én akarok a főszereplő lenni
MultiDoodad
blakey
#46423
Elnézést, igen kétértelmű lett. Véget ért abban, hogy újat nem fogok már vásárolni és mivel csak játszom így a “játék” részéről ez is történik. Eszméletlen gyönyörű az Oled ez tagadhatatlan de számomra így nem túl használható (mint írtam már, szinte csak játszom filmezni ha havonta talán egyszer szoktam). Maximum megpróbálhatok egy erős tesztett ami tanulságos lehet, esetleg mindent beállítok úgy ahogyan nekem tetszik (bele értve a fény erőt is) kikapcsolom a logo védelmet és meglátjuk mi lesz. Ha be ég, akkor maximum tényleg csak porosodni fog, viszont ha 3-4 hónap múlva is hibátlan lesz akkor abban az esetben elgondolkodtató a Cx 65” megvásárlásának lehetősége. Mint írtam, imádom az oled képi világát, de rengeteget játszom és így mindig bennem a tüske.
MultiDoodad
Nálam úgy néz ki, véget ér az oled korszak. Van ugye bár a B9 aminek a képével teljesen meg vagyok elégedve, viszont ez az sdr-ben gyengébb fényerőn játszom és HDR-ben ott az a logo védelem ami miatt az a istenverte sötét folt is ott van (tudom kikapcsolható de akkor nagyobb a be égés veszélye)... Ma a kisebbik öcsém vásárolt egy Q90T-t és bár messze nem olyan szép mint bármelyik oled, azért az, hogy nem kell a beégés miatt aggódni mellete maxon tolhatom a fényerőt SDR-ben, az nagyot dob az élményen számomra. Mivel én csak is kizárólag játszom és sajnos nem nagyon kapható 55/65” monitor így gondoltam beújítok egy Q95T-re, a B9 meg megmarad filmezésre. Sajnálom mert némelyik játéknál HDR-ben valami eszméletlen a képminőség még az új Samu Q szériához képest is... De mist mit tegyek, imádom ha kiégeti a retinám a fényerő
és vele eyógyütt az effektek
MultiDoodad
MultiDoodad
#46067
Ja és ugyan itt, még akkor gondolom mindig nem érdemes Pc-re állítani a HDMI kimenetet avagy bemenetet..
MultiDoodad
Keresgéltem youtubon de nem találtam, lehet tudni? Van már valami jó beállítás pc-ről tévére? B9 és C9. Gondolok itt HDR SDR beállításokra és a HDR problémákra win 10-be. 4.2.2 beállításnál. Ha bárkinek bármilyen információja van ne tartsa magában, vágjon hozzám egy linket.
MultiDoodad
Bocsássátok meg tudatlanságomat, de mit takar az hogy comp ciklus?
MultiDoodad
daneel_hu
#46015
Hmm, végül is. Lehet én is oda küldöm a B9-nek a kakaót... 8 hónapja megy és elég sokat játszogatom vele, ideje betolni a HDR-t
. Ja srácok, ha ne pc-re hanem simán HDMI-re állítom akkor ha win 10-ben be kapcsolom a HDR-t akkor minden játék amit megnyitok még az alap sdr játékok is HDR-ben mennek... ez okozhat problémát? (Ugyebár ilyenkor 100 oled fény) -
MultiDoodad
MultiDoodad
Egy kis segítség kéne, öcsém beleszerelmesedett az oledbe (látva nálam a B9-et és kipróbálva) és most szeretne vásárolni egy CX 48”-as méretben. A gond szerintem az ó, hogy ő ezt pc-hez akarja monitor helyett és csak játékra. Kicsit naív mert a reklámban is 48”-as Oledet hiper szuper minitor ként reklámozzák és úgy gondolja nem lehet baj a be égéssel, sajnos a probléma az hogy elsősorban max 2 játékkal játszana és SDR-ben.. Én úgy gondolom ez problémát jelenthet be égés terén. Átlagban napi 3-5 órát menne hétvégén meg 9-et is. Szerintetek? Érdemes lehet bevállalni csak erre a célra? Nekem nincs bajom a B9-el és tökéletesen üzemel de én ps4-ről pc-ről játszom és filmezem is rajta.. (bár tény, hogy pc-n csak sdr-ben játszom én is mert í HDR néha borzasztó) -
MultiDoodad
FollowTheORI
#45726
Na hogy az a... akkor meglesem majd melyik a jobb
de ezek szerint a HGIG se a legjobb megoldás.. Köszi az infót. -
MultiDoodad
Játéknál melyiket érdemesebb használni a dinamikus tónusáthelyezésnél? HGiG vagy simán csak Be? Esetleg off? LG B9 és ps4-en használom.
MultiDoodad
MultiDoodad
#45060
Ja és még ehhez kapcsolódóan, mekkora a maximum oled fény amivel használhatnám nyugodtan SDR-ben játékra a tévét? Ugyan így pc-n.
MultiDoodad
Sziasztok, egy gyors kérdés.
Ha a pc-t csak sima SDR módban használnám a lg b9-en attól nem kehet különösebb baja igaz? Csak mert HDR windowson nem a legjobb mint sokan tudják... Mert nekem még SDR-ben is szebb (bár sötétebb) mint a mosta “fullos” monutorom.. -
MultiDoodad
Egy gyors kérdésem lenne, az LG B97LA/BLA/SLA tudja a 4k 120 hz-t? Ha igen, csak HDMI 2.1-el tudja majd? Azért kérdem mert pc-n ugyebár megy a 1440p 120hz de úgy hallottam, hogy a B9 nem tudja a 4k-ban a 120hz-t. Valaki tud erről valamit?
Bár olyan sokat nem számít, mivel év végén tervezem majd megvásárolni az LG Cx-t, mivel csupán egyedül csak is a játék érdekel, film nagyon ritkán lesz nézve rajta.
MultiDoodad
BusinessGuy
#44654
Én ezt teljes mértékben megértem, de látod, belanígytlani kell egy tévé adásba... na ne vicceljünk már. Jó, én gondolom túl, de azért ami itt lemegy néha... tényleg gyönyörű egy képe van, “utánozhatatlan” de ha tudom, hogy nekem ez ennyire problémás lesz akkor választom a rosszabb képminőségű qledet, nincs nagyítgatás, nincs beégéstől való félelem, nincs ki be kapcsolgatás csak megy és kész, csak hát nekem szükségem volt a jó válaszidőre..
Amúgy mellesleg, pc-re kötve a tévé miért állítgatja magától a fényerőt? (Minden ki van kapcsolva, de pl facebook olvasgatás közben kicsit sötéteb lesz majd világosabb majd sötétebb...)
MultiDoodad
Számomra hihetetlen néha mennyit kell “bajlódni” az Oledek állítgatásával, ne használd max fényerőn, vigyáz a statikus elemekre, a felirat így a felirat úgy, nekem valamiért és már láttam 1-2 embernek furán kezeli a színeket.... Esküszöm ha olyan jó válaszidővel rendelkezne a Qled mint az oled, hanyat homlok szaladnék át oda... (De mivel csak játszom és imádom a hatalmas képernyőt, még mindig az Oled a nyerő) Bocsánat, csak az elmúlt egy hónapban annyit kellet állítgatni, hogy az már vicc, ellenben öcsémnek lent a samsung tévével semmit sem kell tökölni, jó elismerem rosszabb a képminőség, de reggeltől estik megy és semmit nem kell vele csesződni és mindezek mellet nem kell aggódni bármilyen statikus elem miatt.
MultiDoodad
janos666
#44623
Köszönöm a segítséget, azért szerettem volna “állítgatni” mert például ps4 pro-n világosabb HDR-ben a kép mint pc-n, ha viszont 4:2:2-re állítottam ugyan olyan volt mint ps4-en, csak ezért gondoltam. Még egy kérdés, akkor ne pc módban használjam? Ha nem akkor melyikben érdemes?
MultiDoodad
Esetleg nem tudja valaki aki sokat használja pc-vel az Oled tévéjét, hogy nem lehet valahogy automatikusra állítani az Rgb/yuv megjelenítést? Az a problémám, hogy az nvidia panelben mindig át kell állítanom yuv 4:2:2-re ha HDR-ben szeretnék játszani, vissza ha rgb-re ha csak SDR-ben szeretnék játszani... próbáltam automatikusra állítani de úgy nem működik szépen... elég bosszantó, hogy állandóan manuálisan kell állítgatni. Köszi előre is az infókat.
MultiDoodad
Igen, be van kapcsolva Hgig, igen lehet látni most simán 50%.
MultiDoodad
De tudod mi az érdekes, hogy a meglévő passzív tűz ami már alapból a pályán van semmi baja, szép sárgás amilyennek lennie kell, ellenben az “élő” ( amikor felrobban egy lépegető, felgyullad valami) tűz vagy fény ilyen túlszaturáltas pirosas valami. Szóval érdekes számomra ez a dolog, mert amúgy gyönyörű a kép és szín hű (ugyebár nem olyan színes mint sdr-rgb-ben de gyönyörű.) De jó a meglátásod.
MultiDoodad
Rendben, valahogy megoldom a fotót, hogy jól látható legyen. Nagyon szépen köszönöm nektek a segítséget és hogy ennyire igyekeztek, le a kalappal előtetek.
Délután esete fele igyekszem vissza a fotókkal. -
MultiDoodad
Sajnos a helyzet változatlan
, tényleg nem tudom, hogy ezt mi okozhatja. De tényleg fura, hogy SDR-ben tökéletes a kép, pedig ott picivel több a szín. -
MultiDoodad
Jaj, elnézést, kipróbálom mindjárt.
- MSI Prestige A16 AI+ Ryzen AI 9, 32GB DDR5 7500, QHD+ 165Hz csúcskategóriás ultralaptop!
- HP Probook 6530b,14",Intel Core P8700,4GB RAM,250GB HDD,WIN10
- Vállalom Xianomi Okos kamerák, szoftveres javíttását
- Apple iPhone 15 Plus 128GB, Kártyafüggetlen, 1 Év Garanciával
