LOGOUT témák
- mefistofeles: Az elhízás nem akaratgyengeség! 2 Ahogy én csinálom.......
Keresés
V.ki
<?php
# $Author: chatserv $
# $Date: 2004/12/07 22:09:40 $
# PHP-NUKE: Advanced Content Management System
# Copyright (c) 2002 by Francisco Burzi (fbc@mandrakesoft.com)
# http://phpnuke.org
# This module is to configure the main options for your site
# This program is free software. You can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License.
# Database & System Config
# dbhost: SQL Database Hostname
# dbuname: SQL Username
# dbpass: SQL Password
# dbname: SQL Database Name
# $prefix: Your Database table's prefix
# $user_prefix: Your Users' Database table's prefix (To share it)
# $dbtype: Your Database Server type. Supported servers are:
# MySQL, mysql4, postgres, mssql, oracle, msaccess,
# db2 and mssql-odbc
# Be sure to write it exactly as above, case SeNsItIvE!
# $sitekey: Security Key. CHANGE it to whatever you want, as long
# as you want. Just don't use quotes.
# $gfx_chk: Set the graphic security code on every login screen,
# You need to have GD extension installed:
# 0: No check
# 1: Administrators login only
# 2: Users login only
# 3: New users registration only
# 4: Both, users login and new users registration only
# 5: Administrators and users login only
# 6: Administrators and new users registration only
# 7: Everywhere on all login options (Admins and Users)
# NOTE: If you aren't sure set this value to 0
# $subscription_url : If you manage subscriptions on your site, you
# must write here the url of the subscription
# information/renewal page. This will send by
# email if set.
$dbhost = ''127.0.0.1'';
$dbuname = ''MySQL felhasználóneved'';
$dbpass = ''MySQL jelszavad'';
$dbname = ''MySQL adatbázisod neve'';
//Hagyd változatlanul
$prefix = ''nuke'';
//Ezt is
$user_prefix = ''nuke'';
$dbtype = ''MySQL'';
$sitekey = ''SdFk*fa28367-dm56w69.3a2fDS+e9'';
$gfx_chk = 0;
$subscription_url = '''';
Így kell kinéznie az elejének. -
V.ki
Bővebben: link
Igaz,ez 6.5-ös útmutató,de használható a 7.5-höz.
- BMW topik
- Samsung kuponkunyeráló
- AliExpress tapasztalatok
- Elektromos autók - motorok
- Győr és környéke adok-veszek-beszélgetek
- Melyik tápegységet vegyem?
- Surface 4 - 15" 2496 x 1664 ~2k touch, i7-1185G7, 16GB RAM, SSD, jó akku, számla, 6 hó gar
- Eladó Samsung 860 EVO 2.5 1TB SATA3
- Eladó Samsung SSD 850 EVO SATA III 2.5 inch 500 GB
- E14 Gen7 14" 3K IPS Ultra 7 255H 16GB 512GB NVMe magyar vbill ujjolv IR kam gar
- Eladó HP HyperX Cloud Orbit S gaming headset
- Telefon felvásárlás!! Xiaomi Redmi Note 13, Xiaomi Redmi Note 13 Pro, Xiaomi Redmi Note 13 Pro+
- Telefon Felvásárlás!! iPhone 14/iPhone 14 Plus/iPhone 14 Pro/iPhone 14 Pro Max
- Apple Watch Series 10 46mm GPS+Cellular Titanium, Újszerű, 1 Év Garanciával
- ÚJ/BONTATLAN Microsoft Surface Laptop 7 X Elite 16GB 512GB
- GYÖNYÖRŰ iPhone 13 Pro Max 128GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, MS4160
