klambi
sztanozs
#4025
na a másik progit sikerült elindítani...:
C:\WINDOWS\system32>python --version
Python 3.10.10
C:\WINDOWS\system32>d:
D:\>cd d:\Egyebek\KMORA\MatrixConfigurator-master\
d:\Egyebek\KMORA\MatrixConfigurator-master>logger.py
d:\Egyebek\KMORA\MatrixConfigurator-master>main.py
Traceback (most recent call last):
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 7, in <module>
from PySide2 import QtWidgets, QtCore
ModuleNotFoundError: No module named 'PySide2'
d:\Egyebek\KMORA\MatrixConfigurator-master>pip install PySide2
Collecting PySide2
Downloading PySide2-5.15.2.1-5.15.2-cp35.cp36.cp37.cp38.cp39.cp310-none-win_amd64.whl (137.4 MB)
---------------------------------------- 137.4/137.4 MB 13.3 MB/s eta 0:00:00
Collecting shiboken2==5.15.2.1
Downloading shiboken2-5.15.2.1-5.15.2-cp35.cp36.cp37.cp38.cp39.cp310-none-win_amd64.whl (2.3 MB)
---------------------------------------- 2.3/2.3 MB 49.2 MB/s eta 0:00:00
Installing collected packages: shiboken2, PySide2
Successfully installed PySide2-5.15.2.1 shiboken2-5.15.2.1
[notice] A new release of pip available: 22.3.1 -> 23.1
[notice] To update, run: python.exe -m pip install --upgrade pip
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 8, in <module>
from asyncqt import QEventLoop, asyncSlot
File "C:\Program Files\Python310\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'asyncqt'
d:\Egyebek\KMORA\MatrixConfigurator-master>pip install asyncqt
Collecting asyncqt
Downloading asyncqt-0.8.0.tar.gz (12 kB)
Preparing metadata (setup.py) ... done
Installing collected packages: asyncqt
DEPRECATION: asyncqt is being installed using the legacy 'setup.py install' method, because it does not have a 'pyproject.toml' and the 'wheel' package is not installed. pip 23.1 will enforce this behaviour change. A possible replacement is to enable the '--use-pep517' option. Discussion can be found at https://github.com/pypa/pip/issues/8559
Running setup.py install for asyncqt ... done
Successfully installed asyncqt-0.8.0
d:\Egyebek\KMORA\MatrixConfigurator-master>setup.py
'setup.py' is not recognized as an internal or external command,
operable program or batch file.
d:\Egyebek\KMORA\MatrixConfigurator-master>python.exe -m pip install --upgrade pip
Requirement already satisfied: pip in c:\program files\python310\lib\site-packages (22.3.1)
Collecting pip
Downloading pip-23.1-py3-none-any.whl (2.1 MB)
---------------------------------------- 2.1/2.1 MB 10.1 MB/s eta 0:00:00
Installing collected packages: pip
Attempting uninstall: pip
Found existing installation: pip 22.3.1
Uninstalling pip-22.3.1:
Successfully uninstalled pip-22.3.1
Successfully installed pip-23.1
Requirement already satisfied: asyncqt in c:\program files\python310\lib\site-packages (0.8.0)
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 10, in <module>
import can
File "D:\Egyebek\KMORA\MatrixConfigurator-master\can\__init__.py", line 41, in <module>
from .bus import BusABC, BusState
File "D:\Egyebek\KMORA\MatrixConfigurator-master\can\bus.py", line 14, in <module>
from aenum import Enum, auto
ModuleNotFoundError: No module named 'aenum'
d:\Egyebek\KMORA\MatrixConfigurator-master>pip install aenum
Collecting aenum
Downloading aenum-3.1.12-py3-none-any.whl (131 kB)
---------------------------------------- 131.8/131.8 kB 2.6 MB/s eta 0:00:00
Installing collected packages: aenum
Successfully installed aenum-3.1.12
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 15, in <module>
from port import serial_ports
File "D:\Egyebek\KMORA\MatrixConfigurator-master\port.py", line 3, in <module>
import serial
ModuleNotFoundError: No module named 'serial'
d:\Egyebek\KMORA\MatrixConfigurator-master>pip install serial
Collecting serial
Downloading serial-0.0.97-py2.py3-none-any.whl (40 kB)
---------------------------------------- 40.9/40.9 kB 1.9 MB/s eta 0:00:00
Collecting future>=0.17.1 (from serial)
Downloading future-0.18.3.tar.gz (840 kB)
---------------------------------------- 840.9/840.9 kB 7.6 MB/s eta 0:00:00
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Collecting pyyaml>=3.13 (from serial)
Downloading PyYAML-6.0-cp310-cp310-win_amd64.whl (151 kB)
---------------------------------------- 151.7/151.7 kB ? eta 0:00:00
Collecting iso8601>=0.1.12 (from serial)
Downloading iso8601-1.1.0-py3-none-any.whl (9.9 kB)
Building wheels for collected packages: future
Building wheel for future (pyproject.toml) ... done
Created wheel for future: filename=future-0.18.3-py3-none-any.whl size=492053 sha256=3ed5a781b8a7ee7b2f8dcb363e9ee51fa1e090167e18029a50cc6e8a0953f35b
Stored in directory: c:\users\klambi\appdata\local\pip\cache\wheels\5e\a9\47\f118e66afd12240e4662752cc22cefae5d97275623aa8ef57d
Successfully built future
Installing collected packages: pyyaml, iso8601, future, serial
Successfully installed future-0.18.3 iso8601-1.1.0 pyyaml-6.0 serial-0.0.97
File "D:\Egyebek\KMORA\MatrixConfigurator-master\port.py", line 27, in serial_ports
s = serial.Serial(port)
AttributeError: module 'serial' has no attribute 'Serial'
During handling of the above exception, another exception occurred:
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 1464, in <module>
window = MainApp()
File "D:\Egyebek\KMORA\MatrixConfigurator-master\main.py", line 352, in __init__
self.Port.addItems(serial_ports())
File "D:\Egyebek\KMORA\MatrixConfigurator-master\port.py", line 30, in serial_ports
except (OSError, serial.SerialException):
AttributeError: module 'serial' has no attribute 'SerialException'
window = MainApp()
window = MainApp()
d:\Egyebek\KMORA\MatrixConfigurator-master>pip install pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
---------------------------------------- 90.6/90.6 kB 1.7 MB/s eta 0:00:00
Installing collected packages: pyserial
Successfully installed pyserial-3.5 -
klambi
klambi
MasterMark
#4021
klambi
Szevasztok!
Egy kis futtatási gondba üzkötztem:
Hiba:Traceback (most recent call last):
File "main.py", line 10, in <module>
File "logger.py", line 33, in logger
File "C:\Users\PC\AppData\Local\Programs\Python\Python38-32\lib\encodings\cp1252.py", line 19, in encode
UnicodeEncodeError: 'charmap' codec can't encode characters in position 11-23: character maps to <undefined>
[27092] Failed to execute script mainEzt nem tudtam kiküszöböolni, valakinek ötlet?
- Beszámítás! Apple Mac Mini M4 16GB 256GB számítógép garanciával, hibátlan működéssel
- G.Skill Aegis 16GB DDR4 3200MHz VADIÚJ, GARANCIÁS!
- Apple iPhone 16 Plus 128GB Ultramarine használt, karcmentes 96% akku (266 ciklus) 6 hónap gar
- LG 27G850A - 27" Nano IPS - UHD 4K - 240~480Hz 1ms - NVIDIA G-Sync - FreeSync Premium PRO - HDR 600
- HP EliteBook 840 G9 i7-1265U 16GB 512GB 14" FHD+ 1 év teljeskörű garancia
igaz angol volt és utána állítottam oroszra... fene tudja, hogy ez is baj-e vagy sem de ott sem ment
