A Kodiban csak bcm...headphone eszközök látszanak hangkimentként, azonban nem csak a Kodi alatt, hanem az egész Pi alatt nincsen hang, ha be van kapcsolva a dtoverlay=vc4-kms-v3d, ha viszont az nincs, akkor a Kodi nem indul el, sehogy sem.
Köszi az eddigi segítséget
, legalább a probléma már tisztábban látszik! -
Megtaláltam a logját, így kezdődik:
2023-08-15 14:23:57.675 T:5691 INFO <general>: -----------------------------------------------------------------------
2023-08-15 14:23:57.675 T:5691 INFO <general>: Starting Kodi (19.4 (19.4.0) Git:20221007-166303c4f0). Platform: Linux ARM 32-bit
2023-08-15 14:23:57.675 T:5691 INFO <general>: Using Release Kodi x32
2023-08-15 14:23:57.675 T:5691 INFO <general>: Kodi compiled 2022-10-07 by GCC 10.2.1 for Linux ARM 32-bit version 5.15.61 (331581)
2023-08-15 14:23:57.675 T:5691 INFO <general>: Running on BCM2835 with Raspbian GNU/Linux 11 (bullseye), kernel: Linux ARM 64-bit version 6.1.21-v8+
2023-08-15 14:23:57.675 T:5691 INFO <general>: FFmpeg version/source: 4.3.6-0+deb11u1+rpt3
2023-08-15 14:23:57.675 T:5691 INFO <general>: 4 CPU cores available
2023-08-15 14:23:57.675 T:5691 INFO <general>: ARM Features: Neon enabled
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://xbmc/ is mapped to: /usr/share/kodi
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://masterprofile/ is mapped to: /home/pi4/.kodi/userdata
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://envhome/ is mapped to: /home/pi4
2023-08-15 14:23:57.675 T:5691 INFO <general>: special://home/ is mapped to: /home/pi4/.kodi
2023-08-15 14:23:57.676 T:5691 INFO <general>: special://temp/ is mapped to: /home/pi4/.kodi/temp
2023-08-15 14:23:57.676 T:5691 INFO <general>: special://logpath/ is mapped to: /home/pi4/.kodi/temp
2023-08-15 14:23:57.676 T:5691 INFO <general>: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
2023-08-15 14:23:57.676 T:5691 INFO <general>: Local hostname: raspberrypi
2023-08-15 14:23:57.676 T:5691 INFO <general>: Log File is located: /home/pi4/.kodi/temp/kodi.log
2023-08-15 14:23:57.676 T:5691 INFO <general>: -----------------------------------------------------------------------
2023-08-15 14:23:57.676 T:5691 INFO <general>: loading settings
2023-08-15 14:23:57.677 T:5691 INFO <general>: special://profile/ is mapped to: special://masterprofile/
2023-08-15 14:23:57.694 T:5691 INFO <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2023-08-15 14:23:57.694 T:5691 INFO <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2023-08-15 14:23:57.694 T:5691 INFO <general>: Default Video Player: VideoPlayer
2023-08-15 14:23:57.694 T:5691 INFO <general>: Default Audio Player: paplayer
2023-08-15 14:23:57.694 T:5691 INFO <general>: Disabled debug logging due to GUI setting. Level 0.
2023-08-15 14:23:57.694 T:5691 INFO <general>: Log level changed to "INFO"
2023-08-15 14:23:57.694 T:5691 INFO <general>: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2023-08-15 14:23:57.696 T:5691 INFO <general>: creating subdirectories
2023-08-15 14:23:57.696 T:5691 INFO <general>: userdata folder: special://masterprofile/
2023-08-15 14:23:57.696 T:5691 INFO <general>: recording folder:
2023-08-15 14:23:57.696 T:5691 INFO <general>: screenshots folder:
2023-08-15 14:23:57.700 T:5691 INFO <general>: Running database version Addons33
2023-08-15 14:23:57.737 T:5691 ERROR <general>: CAddonInfoBuilder::Generate: Unable to load '/home/pi4/.kodi/addons/script.module.slyguy/addon.xml', Line 0
Failed to open file
Raspberry4 Pi 32 bit alatt nem indul el a Kodi, fekete képernyő után az alábbi hibaüzenettel kilép:
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ERROR: Unable to create GUI. ExitingHang van a TV-n a Pi-ről, amire rá van kötve. Mi lehet a gond?
Előre is köszönöm!
Tudtok egy jó leírást arra, hogyan lehet elérni az RPI-re kötött SSD-t távolról? A helyi hálón samba-n és dlna-n megosztva, no-ip regisztrálva, routeren beállítva.
Előre is köszönöm!
UberMutant
#45304
És tényleg, köszi, így mérve meg van a sebesség! Ez a PI lebutított böngészői miatt mutat más sebességet? PC-n böngészőben is megvan.
A Pi4 Cat5E kábellel a routerre dugva csak 130 Mbps-t tud a speedtest.net szerint, miközben a netem 250-es, és más eszközökön meg is van ez a sebesség. Mi lehet a gond? Előre is köszönöm!
SSD-n, amelyről nem a rendszer fut, hanem adattárolásra szolgál, érdemes vagy lehet beállítani valamilyen energiatakarékossági funkciót? Cigam összefoglalója szerinti első módszert nem támogatja az SSD.
Más:
Ha valakinek crashelni a Firefox ESR 32 bites Raspberry op. rendszer alatt, kapcsolja ki a fiókszinkronizációt, azzal elkerülhető a folytonos összeomlás.
VNC alól használtam mostanában a PI-t, de most a rákötött monitoron akartam ránézni, de a korábban működő egér nem működik rajta, ahogy a bluetooth billentyűzet sem. Az utóbbin a kurzorbillentyűkre és a backspace, enter gombokra csipog, de semmi mást nem csinál. Próbáltam más wired és wireless egérrel, semmi változás. Az lsubs parancsra mutatja az eszközt. Lehet ezt valahogy orvosolni, vagy marad az újratelepítés?
wassermann
#45069
Hasonló, spec. kábellel próbáltam, ami közvetlenül a merevlemezbe megy bele, de nem működött.
Viszont sikerült kiderítenem a qBittorrent logjának átnézésével, hogy a porttal lehetett valami gondja, ezért azt átraktam 8085-re, és így most sikerült belépni másik gépről is webes felületről.
Úgy néz ki, hogy a rádugott merevlemez szállt el.
A PI nem tud egyszerre meghajtani egy SSD-t és egy USB-s merevlemezt (az utóbbi egy eagate USB 3 backup)?
Adódott egy problémám a qBittorrenttel is: Feltelepítem, beállítom a PI-n a webes felhasználót és jelszavát, majd be is tudok lépni másik gépről, tudok letöltést is indítani, de újraindítás után már "Érvénytelen felhasználónév vagy Jelszó." hibát kapok.
Illetve a PI újraindítása után nem csatolja fel a futó torrenteket, megszakad a visszaseedelés, ez valahogy kiküszöbölhető?
Előre is köszönöm a tanácsokat!
A vacakolás az volt, hogy állandóan lecsatlakozott a megosztott meghajtó, crashelt a Firefox. Az SSD a Raspberry Imager-ével tettem fel. A telepítésével is szívtam, mert USB3-ban nem tudott felállni a rendszer, csak USB2-vel (vagy a beletett régi SSD nem kezeli vagy a doboz).
Az az érdekes, mikor felcsatolom a merevlemezt a leírásod szerint, akkor a media könyvtárban a csatolási név alatt nem a korábbi könyvtárak látszanak azonnal, hanem mindenféle bin, root, stb., és csak a velük egyszinten lévő media könyvtárban jelenik meg a felcsatolt nevű könyvtár, azon belül ismét az (a pi mellett), és azon belül vannak csak a szokásos könyvtárak. Lehet, hogy a sok próbálkozásban valamiféle rendszermeghajtó lett belőle, amikor SD-ről próbáltam bootolni kínomban és az elsődleges USB boot volt beállítva?
adika4444
#45057
Már kétszer jutottam ebbe az állapotba, mindig újrahúztam, harmadszorra el szeretném kerülni, de hogyan? Cigam logoutos leírása szerint felcsatolja a külső meghajtót a megadott könyvtárba, de nem látszik ott a tartalma, és amikor a leírtak szerint be akarom állítani a jogosultságot, akkor futok bele. Utána már nem tudok belépni a root-ba, akkor dobja a hibát.
Elkezdett vacakolni a PI4-m, ezért gondoltam újrahúzom, és ha már újra, akkor a 64 bites rendszerrel, SSD-vel.
Amikor Cigam leírása szerint próbálom ismét beállítani a Samba-t egy USB-s merevlemezre, a "sudo chown -R pi:users /media/WDMyBook" parancs után már nem fut le a "sudo chmod -R 775 /media/WDMyBook" parancs, hibát kapok, sőt, már az su-ba sem tudok belépni utána, "sudo: /etc/sudo.conf is owned by uid 1000, should be 0" hibára futok.
Van esetleg ötletetek, miért van ez?
Miért lehet az, hogy újraindítás után minden rendben működik, aztán egyszer csak írásvédetté válik a rádugott USB3-as hordozható lemez? Ilyenkor nem lehet megnyitni pl. a képfájlokat róla sem a PI-n, sem a hálózaton keresztül sem. Újraindítás után megint egy ideig megjavul.
GAgyiXyXy
#39202
Köszi, ez segített! Viszont előjött megint az azt megelőző probléma: a Kodi telepítése után állandóan "ugrál" a képernyő, hol elfekedetik, hol visszaáll, a Kodi sem indul el, csak egy fehér kurzor a bal felső sarokban a fekete képernyőn, így használhatatlan a Pi, le kellett szednem a Kodi-t.
Laszlo733
#39137
Raspbian van rajta. Lefuttattam azokat, amiket írtál, de megint ugyanazt a hibát kaptam:
root@raspberrypi:/home/pi# sudo apt-get install kodi
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapotinformációk olvasása... Kész
A következő további csomagok lesznek telepítve:
kodi-bin libao-common libao4 libcec4 libfstrcmp0 libiso9660-11 liblzo2-2
libmariadb3 libmicrohttpd12 libp8-platform2 libpcrecpp0v5
libpulse-mainloop-glib0 libshairplay0 libtinyxml2.6.2v5 mariadb-common
mysql-common python-bluez
Javasolt csomagok:
kodi-pvr-mythtv kodi-pvr-vuplus kodi-pvr-vdr-vnsi kodi-pvr-njoy
kodi-pvr-nextpvr kodi-pvr-mediaportal-tvserver kodi-pvr-tvheadend-hts
kodi-pvr-dvbviewer kodi-pvr-argustv kodi-pvr-iptvsimple
kodi-audioencoder-vorbis kodi-audioencoder-flac kodi-audioencoder-lame
libaudio2 libsndio6.1
Ajánlott csomagok:
libva-intel-vaapi-driver libva1
Az alábbi ÚJ csomagok lesznek telepítve:
kodi kodi-bin libao-common libao4 libcec4 libfstrcmp0 libiso9660-11
liblzo2-2 libmariadb3 libmicrohttpd12 libp8-platform2 libpcrecpp0v5
0 frissített, 18 újonnan telepített, 0 eltávolítandó és 0 nem frissített.
Letöltendő adatmennyiség: 109 kB/41,1 MB.
A művelet után 70,0 MB lemezterület kerül felhasználásra.
Folytatni akarja? [I/n] i
Hiba:1 http://pipplware.pplware.pt/pipplware/dists/unstable/main/binary libshairplay0 0.9.0+git20180824.096b61a-1~stretch
404 Not Found [IP: 176.221.32.193 80]
E: Sikertelen letöltés: http://pipplware.pplware.pt/pipplware/dists/unstable/main/binary/./libshairplay0_0.9.0+git20180824.096b61a-1~stretch_armhf.deb 404 Not Found [IP: 176.221.32.193 80]
E: Nem lehet letölteni néhány archívumot. Próbálja futtatni az „apt-get update” parancsot, vagy használja a --fix-missing kapcsolót. -
Laszlo733
#39128
A 4. sorra ezt dobja:
Az "apt-get update"-t futtattam, a "--fix-missing"-et melyikhez kell hozzáírni? Mi lehet a gond? -
Felraktam a Kodi-t cigam leírása alapján, de a képernyő a bootolás után periódikusan feketére vált, majd vissza. Mivel lehetne ez orvosolni? Köszönöm!
Van arra ötletetek, hogy Pi 4 RaspiOS alatt a qtorrent miért "veszti el" a letöltött torrenteket, és csak jobb katt, erőltetett folytatásra seedeli tovább azokat?
Előre is köszi!
Képernyőként a PI 4-re egy régebbi Samsung TV-t dugtam HDMI-n keresztül. Képet csak úgy sikerült nyernem rajta, ha config.txt-ben a hdmi_safe=1 beállítást bekapcsoltam, valószínűleg a TV alacsony felbontása (1366 x 768) miatt. Viszont így csak 1024x768-ban jelenik meg a kép. Fel lehet ezt valahogy skálázni a TV valós felbontására? A Screen Layout Editor-ban csak az 1024x768 a maximális felbontás.
A Pi4 topikjában nem tudtak segíteni, ezért fordulok ide:
Szeretnék távoli asztal elérést a PI-hez Windows 10 alól.
Telepítve az xrdp, engedélyezve az ssh és a vnc interfész, ssh-val be is tudok lépni a PI-be, de nem tudok Windows 10 alól távoli asztal kapcsolaton keresztül csatlakozni, az alábbi hibaüzenetet kapom:
connecting to sesman 127.0.0.0 port 3350 sesman connect ok
sending login info to session manager, please wait... login failed for display 0.Valakinek esetleg valami ötlete? Esetleg más távoli asztal kapcsolatra?
Előre is köszönöm!
- Professzionális gamer pc...!
- Szerver memóriák - többféle méret - Egyben eladó
- Ryzen 7 7800X3D +hűtött VRM-es B650M lap +32GB DDR5 kit! GAR/SZÁMLA (a Te nevedre kiállítva)!
- Kezdő Gamer PC-Számítógép! Csere-Beszámítás! I7 6700 / 16GB DDR4 / GTX 1650 Super / 500 SSD
- 27% - Intel xeon E5 2630 / RX550 / 16GB / 512GB / 500W Konfiguráció
- iPhone 16 Pro Max 256GB 92% (1év Garancia)- AKCIÓ
- Eladó EDIFIER ES prémium hangszórók ES300 / ES60 / ES20
- PlayStation 5 FAT Lemezes + kontroller 6 hó garancia, számlával!
- Apple iPhone 15 256GB,Átlagos,Adatkabel,12 hónap garanciával
- Samsung Galaxy Book PRO 2 /i7-1260P/16GB/512SSD/AMOLED/13.3/Intel Iris Xe/Gari
