TP-Link WDR3600 - N600 router
Zirowe
Intruder2k5 #1148 üzenetére
Modem a másik szobában van, így a ledeket nem láttam, de általában azzal nem szokott probléma lenni (előzőn kb 20 net leállásból csak 1x volt a modem a ludas), webes felületről is el tudom érni.
Zirowe
Igen, upc net, torrent gépen, routerre nincs vinyó rákötve.
Mar 4 13:34:05 Zirowe syslog.info syslogd started: BusyBox v1.19.4
Mar 4 13:34:05 Zirowe kern.notice kernel: klogd started: BusyBox v1.19.4 (2013-01-28 14:24:51 CET)
Mar 4 13:34:05 Zirowe kern.notice kernel: [ 0.000000] Linux version 3.7.4 (gavarga@gavarga-Inspiron-N5110) (gcc version 4.6.4 20121210 (prerelease) (Linaro GCC 4.6-2012.12) ) #2 Tue Jan 29 10:01:41 CET 2013
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] SoC: Atheros AR9344 rev 2
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Determined physical RAM map:
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Zone ranges:
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Normal [mem 0x00000000-0x07ffffff]
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Movable zone start for each node
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Early memory node ranges
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Mar 4 13:34:05 Zirowe kern.notice kernel: [ 0.000000] Kernel command line: board=TL-WDR4300 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Mar 4 13:34:05 Zirowe kern.notice kernel: [ 0.000000] __ex_table already sorted, skipping sort
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] Memory: 126512k/131072k available (2172k kernel code, 4560k reserved, 411k data, 228k init, 0k highmem)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.000000] NR_IRQS:51
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.060000] Calibrating delay loop... 278.93 BogoMIPS (lpj=1394688)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.070000] pid_max: default: 32768 minimum: 301
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.070000] Mount-cache hash table entries: 512
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.080000] NET: Registered protocol family 16
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.080000] MIPS: machine is TP-LINK TL-WDR3600/4300/4310
Mar 4 13:34:05 Zirowe kern.warn kernel: [ 0.090000] registering PCI controller with io_map_base unset
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.310000] bio: create slab <bio-0> at 0
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.310000] PCI host bridge to bus 0000:00
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.320000] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.320000] pci_bus 0000:00: root bus resource [io 0x0000]
Mar 4 13:34:05 Zirowe kern.info kernel: [ 0.330000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Mar 4 13:34:05 Zirowe kern.err kernel: [ 0.330000] pci 0000:00:00.0: invalid calibration data
Mar 4 13:34:05 Zirowe kern.info kernel: [ 8.980000] usbcore: registered new interface driver ums-freecom
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.000000] usbcore: registered new interface driver ums-isd200
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.010000] usbcore: registered new interface driver ums-jumpshot
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.020000] usbcore: registered new interface driver ums-karma
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.040000] usbcore: registered new interface driver ums-sddr09
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.050000] usbcore: registered new interface driver ums-sddr55
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.060000] usbcore: registered new interface driver ums-usbat
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.230000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.380000] hub 1-1:1.0: USB hub found
Mar 4 13:34:05 Zirowe kern.info kernel: [ 9.380000] hub 1-1:1.0: 4 ports detected
Mar 4 13:34:05 Zirowe kern.info kernel: [ 29.430000] eth0: link down
Mar 4 13:34:05 Zirowe kern.info kernel: [ 30.960000] Compat-drivers backport release: compat-drivers-2013-01-08-3
Mar 4 13:34:05 Zirowe kern.info kernel: [ 30.970000] Backport based on wireless-testing.git master-2013-01-07
Mar 4 13:34:05 Zirowe kern.info kernel: [ 30.980000] compat.git: wireless-testing.git
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.010000] cfg80211: Calling CRDA to update world regulatory domain
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.010000] cfg80211: World regulatory domain updated:
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.020000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.030000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.040000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.040000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.050000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Mar 4 13:34:05 Zirowe kern.info kernel: [ 31.060000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Mar 4 13:34:07 Zirowe kern.info kernel: [ 37.730000] device eth0.1 entered promiscuous mode
Mar 4 13:34:07 Zirowe kern.info kernel: [ 37.740000] device eth0 entered promiscuous mode
Mar 4 13:34:07 Zirowe daemon.notice netifd: Interface 'lan' is now up
Mar 4 13:34:07 Zirowe daemon.notice netifd: Interface 'loopback' is now up
Mar 4 13:34:07 Zirowe kern.info kernel: [ 37.970000] eth0: link up (1000Mbps/Full duplex)
Mar 4 13:34:07 Zirowe kern.info kernel: [ 38.010000] br-lan: port 1(eth0.1) entered forwarding state
Mar 4 13:34:07 Zirowe daemon.notice netifd: wan (817): udhcpc (v1.19.4) started
Mar 4 13:34:08 Zirowe daemon.notice netifd: wan (817): Sending discover...
Mar 4 13:34:09 Zirowe kern.info kernel: [ 40.010000] br-lan: port 1(eth0.1) entered forwarding state
Mar 4 13:34:11 Zirowe daemon.notice netifd: wan (817): Sending discover...
Mar 4 13:34:11 Zirowe daemon.notice netifd: wan (817): Sending select for 89.132.74.111...
Mar 4 13:34:11 Zirowe daemon.notice netifd: wan (817): Lease of 89.132.74.111 obtained, lease time 259200
Mar 4 13:34:11 Zirowe daemon.notice netifd: Interface 'wan' is now up
Mar 4 13:34:12 Zirowe user.info sysinit: 'radio1' is disabled
Mar 4 13:34:13 Zirowe user.info sysinit: 'radio1' is disabled
Mar 4 13:34:13 Zirowe kern.info kernel: [ 44.050000] cfg80211: Calling CRDA for country: HU
Mar 4 13:34:13 Zirowe kern.info kernel: [ 44.060000] cfg80211: Regulatory domain changed to country: HU
Mar 4 13:34:13 Zirowe kern.info kernel: [ 44.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Mar 4 13:34:13 Zirowe kern.info kernel: [ 44.070000] cfg80211: (2402000 KHz - 2494000 KHz @ 40000 KHz), (N/A, 2700 mBm)
Mar 4 13:34:13 Zirowe kern.info kernel: [ 44.080000] cfg80211: (5170000 KHz - 5835000 KHz @ 40000 KHz), (N/A, 2700 mBm)
Mar 4 13:34:15 Zirowe kern.info kernel: [ 46.040000] device wlan0 entered promiscuous mode
Mar 4 13:34:16 Zirowe kern.info kernel: [ 47.380000] br-lan: port 2(wlan0) entered forwarding state
Mar 4 13:34:16 Zirowe kern.info kernel: [ 47.390000] br-lan: port 2(wlan0) entered forwarding state
Mar 4 13:34:18 Zirowe user.info sysinit: 'radio1' is disabled
Mar 4 13:34:19 Zirowe kern.info kernel: [ 49.390000] br-lan: port 2(wlan0) entered forwarding state
Mar 4 13:34:19 Zirowe user.info sysinit: Loading defaults
Mar 4 13:34:19 Zirowe user.info sysinit: Loading synflood protection
Mar 4 13:34:19 Zirowe user.info sysinit: Adding custom chains
Mar 4 13:34:20 Zirowe user.info sysinit: Loading zones
Mar 4 13:34:20 Zirowe user.info sysinit: Loading forwardings
Mar 4 13:34:20 Zirowe user.info sysinit: Loading rules
Mar 4 13:34:21 Zirowe user.info sysinit: Loading redirects
Mar 4 13:34:21 Zirowe user.info sysinit: Loading includes
Mar 4 13:34:21 Zirowe user.info sysinit: Enabling Brute Force protection for SSH on port 2222
Mar 4 13:34:21 Zirowe user.info sysinit: Enabling Brute Force protection for FTP on port 2221
Mar 4 13:34:21 Zirowe user.info sysinit: Optimizing conntrack
Mar 4 13:34:21 Zirowe user.info sysinit: Loading interfaces
Mar 4 13:34:21 Zirowe user.info firewall: adding lan (br-lan) to zone lan
Mar 4 13:34:22 Zirowe user.info firewall: adding wan (eth0.2) to zone wan
Mar 4 13:34:23 Zirowe authpriv.info dropbear[1870]: Not backgrounding
Mar 4 13:34:26 Zirowe user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mar 4 13:34:26 Zirowe user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: started, version 2.62 cachesize 150
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack
Mar 4 13:34:29 Zirowe daemon.info dnsmasq-dhcp[2023]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: using local addresses only for domain lan
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: reading /tmp/resolv.conf.auto
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: using nameserver 213.46.246.53#53
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: using nameserver 213.46.246.54#53
Mar 4 13:34:29 Zirowe daemon.info dnsmasq[2023]: read /etc/hosts - 1 addresses
Mar 4 13:34:29 Zirowe daemon.info dnsmasq-dhcp[2023]: read /etc/ethers - 0 addresses
Mar 4 13:34:31 Zirowe user.info sysinit: setting up led USB1
Mar 4 13:34:31 Zirowe user.info sysinit: setting up led USB2
Mar 4 13:34:31 Zirowe user.info sysinit: setting up led WLAN2G -
Zirowe
Sajnos itt is előjött az a problémám, ami korábban a 1043-ason volt, és amitől nagyon reméltem, hogy végleg megszabadultam a router cserével, és pedig a netszakadás.
Már tegnap is volt egy hasonló, éppen másoltam két gép között lanon+ment maxon a torrent (3MB/sec-et írt), és egyszer csak elment a net, megjelent a jól ismert kis sárga háromszög.
Router elérhető volt (ugyanúgy, mint a 1043 esetében), de mire az újraindítás ponthoz értem visszajött magától a net, szóval hagytam az egészet.Erre ma bekapcsolom a gépet, torrent be, nem ment maxon, kb 2,4MB-vel, lejött 1,5gb és közben ment egy net rádió, majd kb 10perc múlva megint sárga háromszög.
Vártam, de nem jött vissza magától, szóval újraindítottam a routert és megint minden rendben.Mi lehet a problémája?
Igazából csak ezért cseréltem le a 1043at, mert az utóbbi időben egyre gyakrabban csinálta már ezt, de most csalódott vagyok, hogy már ez is csinálja.Vargalex fw-je van fent, kb minden alap beállításon van.
Zirowe
Sziasztok, ma kaptam végre meg az új routerem, 1043ról cseréltem 3600ra.
Tp-link gyári fw-jében ismét nem csalódtam, repült is róla 5perc után.
Vargalex féle már fent is van, kérdésem az lenne, hogy a 1043hoz hasonlóan itt is kell 30/30/30-as művelet a telepítés után, vagy használható nyugodtan?
Zirowe
Sziasztok, fontolgatom a cserét 1043-ról.
Kérdenék párat.
Fogyasztás?
Másolás usb eszközre?
Másolás lan-wifi között?Előre is köszi.
- Klipsch R-120SW aktív Mélynyomó / Subwoofer - 1,5 év garanciával
- Lenovo X13 Thinkpad Gen2 WUXGA IPS i5-1145G7 16GB RAM 256GB SSD Intel Iris XE Win11 Pro Garancia
- Bomba ár! HP Probook 440 G10 - i3-1315U I 16GB I 256SSD I 14" FHD I W11 I Cam I Garancia!
- Bomba ár! HP Probook 450 G10 - i3-1315U I 16GB I 256SSD I 15,6" FHD I W11 I Cam I Garancia!
- Bomba ár! HP ProBook 450 G8 - i5-1135G7 I 8GB I 256SSD I HDMI I 15,6" FHD I Cam I W11 I Gar
- Konzol felvásárlás!! Nintendo Switch
- Bomba ár! Lenovo ThinkPad T470 - i5-G6 I 8GB I 256GB SSD I 14" FHD I HDMI I Cam I W10 I Garancia!
- Microsoft Surface Pro 6 fekete
- Samsung Galaxy Tab A8 32GB, Újszerű, 1 Év Garanciával
- Lenovo ThinkPad P14s Gen 1 i7-10510U 32GB 1000GB Nvidia Quadro P520 14" FHD Gar.: 1 év
