TP-Link WR1043ND - N450 router
vargalex
sto1911
#25900
Hi!
Ja, hogy leszedted a dropbear-t. Akkor a remove törölte, ugyanis az scp a dropbear csomag része:
root@OpenWrt:~# opkg files dropbear
Package dropbear (2011.54-2) is installed on root and has the following files:
/usr/bin/dbclient
/usr/bin/scp
/etc/dropbear/dropbear_rsa_host_key
/etc/init.d/dropbear
/usr/bin/dropbearkey
/etc/config/dropbear
/etc/dropbear/dropbear_dss_host_key
/usr/sbin/dropbear
/usr/bin/sshiptables-save nincs. A /etc/config/firewall-ban tudod config-olni a tűzfalat, illetve a /etc/firewall.user-ben tudsz saját iptables parancsokat írni. Az 1.1-es build-emben így néz ki:
/etc/config/firewall:
config defaults
option syn_flood 1
option input ACCEPT
option output ACCEPT
option forward REJECT
# Uncomment this line to disable ipv6 rules
# option disable_ipv6 1
config zone
option name lan
option network 'lan'
option input ACCEPT
config zone
option name wan
option network 'wan'
option input DROP
option masq 1
option mtu_fix 1
config forwarding
option src lan
option dest wan
# We need to accept udp packets on port 68,
# see https://dev.openwrt.org/ticket/4108
config rule
option src wan
option proto udp
option dest_port 68
option target ACCEPT
option family ipv4
# Allow IPv4 ping
config rule
option src wan
option proto icmp
option icmp_type echo-request
option family ipv4
# Allow DHCPv6 replies
# see https://dev.openwrt.org/ticket/10381
config rule
option src wan
option proto udp
option src_ip fe80::/10
option src_port 547
option dest_ip fe80::/10
option dest_port 546
option family ipv6
# Allow essential incoming IPv6 ICMP traffic
config rule
option src wan
option proto icmp
list icmp_type echo-request
list icmp_type destination-unreachable
list icmp_type packet-too-big
list icmp_type time-exceeded
list icmp_type bad-header
list icmp_type unknown-header-type
list icmp_type router-solicitation
list icmp_type neighbour-solicitation
option limit 1000/sec
option family ipv6
# Allow essential forwarded IPv6 ICMP traffic
config rule
option src wan
option dest *
option proto icmp
option family ipv6
# include a file with users custom iptables rules
config include
option path /etc/firewall.user
config 'rule' 'transmission_web'
option 'target' 'ACCEPT'
option '_name' 'transmission_web'
option 'src' 'wan'
option 'proto' 'tcp'
option 'dest_port' '9091'
config 'rule'
option '_name' 'ssh_WAN'
option 'src' 'wan'
option 'dest_ip' '192.168.1.1'
option 'dest_port' '22'
config 'rule'
option '_name' 'ftp_WAN'
option 'src' 'wan'
option 'dest_port' '21'
config 'rule'
option '_name' 'Transmission'
option 'src' 'wan'
option 'proto' 'tcpudp'
option 'dest_port' '21234'
config 'rule'
option '_name' 'Luci_HTTPS'
option 'src' 'wan'
option 'dest_port' '443'
config rule
option src 'lan'
option name 'block_internet_access_IP'
option src_ip '192.168.1.181'
option target 'DROP'
option dest 'wan'
option extra '-m time --weekdays Mon,Tue,Wed,Thu,Fri --timestart 10:00 --timestop 22:00'
option enabled '0'Ebből az utolsó rule-t ne tedd be, mert 10.03.1 alatt enabled opció biztos nincs, és az extra opcióban sem vagyok biztos, hogy lenne.
/etc/firewall.user:
# This file is interpreted as shell script.
# Put your custom iptables rules here, they will
# be executed with each firewall (re-)start.
BRUTEFORCE_PROTECTION_START=3
BRUTEFORCE_DROPPORT=55555
PROTO=tcp
ROUTERIP=$(uci get network.lan.ipaddr)
#SSH Brute Force protection on port 2222
PROTECTEDPORT=2222
SERVICEPORT=22
SERVICE=SSH
echo Enabling Brute Force protection for $SERVICE on port $SERVICEPORT
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --set --name $SERVICE -j DNAT --to-destination $ROUTERIP:$SERVICEPORT
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --update --seconds 60 --hitcount $BRUTEFORCE_PROTECTION_START --name $SERVICE -j DNAT --to-destination $ROUTERIP:$BRUTEFORCE_DROPPORT
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --rcheck --seconds 60 --hitcount $BRUTEFORCE_PROTECTION_START --name $SERVICE -j LOG --log-prefix "BruteForce-${SERVICE} "
#FTP Brute Force protection on port 2221
PROTECTEDPORT=2221
SERVICEPORT=21
SERVICE=FTP
#Block URL on certain time for specified IP
#URL_STRING=facebook.com
#LOCAL_IP=192.168.1.188
#TIME_START=10:00
#TIME_END=16:00
#echo Blocking $URL_STRING from $LOCAL_IP at time interval $TIME_START - $TIME_END
#iptables -I FORWARD -s $LOCAL_IP -m string --string $URL_STRING --algo bm -m time --weekdays Mon,Tue,Wed,Thu,Fri --timestart $TIME_START --timestop $TIME_END -j DROP
########################################Az idő alapú szűréshez viszont kell az iptables-mod-ipopt csomag.
(#25901): Igen, ez a régi megoldás.
vargalex
sto1911
#25898
Hi!
Valószínűleg törölted (automatikus törlés nem szokott lenni, ezért nem mondom, hogy valami telepítésekor törlődött).
Nézd meg a /overlay/usr/bin könyvtár tartalmát. Ha a 10.03.1-ben az új megoldás van már alkalmazva, akkor találsz ott egy scp symlinket, ami az (overlay-whiteout)-ra Ha még a régi megoldás van, akkor lesz ott egy META_* file, amiben lesz egyD scp
sor.
vargalex
sto1911
#25889
A dyndns az OpenWrt alatt egy shell script. ps- el így látod:
/bin/sh /usr/lib/ddns/dynamic_dns_updater.sh myddns
Alapban nem logol, ha szeretnéd bekapcsolni, az is megoldható.
Johnsones
sto1911
#25831
köszi a segítséget
kijavítottam:iptables -I FORWARD -m iprange --src-range $LOCAL_IP -m string --string $URL_STRING --algo bm -m time --weekdays Mon,Tue,Wed,Thu,Fri --timestart $TIME_START --timestop $TIME_END -j DROP
de sajna még mindig hibát dob...
Enabling Brute Force protection for SSH on port 22
Enabling Brute Force protection for FTP on port 21
Blocking sample.com from 192.168.1.100-192.168.1.200 at time interval 10:00 - 16:00
iptables v1.4.10: Couldn't load match `iprange'
ile not foundTry `iptables -h' or 'iptables --help' for more information.
Optimizing conntrack
Loading interfaceskérhetnék arra segítséget, hogy a wireless kliensek ne lássák a lan hálózatot és csak a netet
köszönöm... -
sto1911
#25496
Ne akard te azt! Még véletlenül se'!
Intruder2k5-nek volt valami visszaállítós képe, hogy soroson mit kell vissatolni, csak azt nem tudom, hogy hol. O.o--------------------
YEY! Mit találtam!
Üdv. core2
gerokrisz
sto1911
#25419
Azért, mert NEM TUDOM mit rontottam el.
Visszatettem a gyári szoftvert, utána minden jól ment.
De pár napja azt csinálj amit leírtam...
Tegnap este a SYS villogás helyett égve maradt, és mindenhol elment a net.
Utána kikapcsoltam, a modemet is. 10perc múlva be, és minden jól ment.
Reggel már az én gépemen nem volt net, DNS nem elérhető hibára hivatkozva.
Bedugtam a másik hálókártyát tökéletesen ment.
Ma úgy dél körül pedig az se ment.Nemrég újraindítottam, így lett net. Viszont a SYS nem villog, és nem jön be a menüje. Így semmit nem tudok rajta állítani, resetet viszont nem akarok mert portok vannak beállítva.
Restartolni este fogom tudni, mert a többi gépen a net most használatban van. Csak nem tudok rájönni, hogy mi lehet a hiba.
deminos
sto1911
#25400
Itt tudod leszedni a legújabb DD-wrt buildeket : ftp://ftp.dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/.
Személy szerint a legutolsó 2011-es buildet használom és tökéletesen működik. Több, mint 60 napja megállás nélkül, ami nagy szó ennél a tourternál, mert valamiért a többi verziót nem komálta. Ált. a wifi része nem ment, de voltak egyéb bugok is, viszont ez a build nekem nagyon bevált : ftp://ftp.dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/2011/12-20-11-r18024/tplink_tl-wr1043nd/
bpmcwap
sto1911
#25214
???? Lehet nálam van a hiba????
A kapcsolat alaphelyzetbe állt
A kiszolgálóhoz való kapcsolat alaphelyzetbe állt az oldal letöltése közben.
A webhely ideiglenesen nem érhető el vagy túlterhelt. Próbálja újra pár
perc múlva.
Ha semmilyen oldalt nem tud letölteni, ellenőrizze a számítógépe hálózati
kapcsolatát.
Ha a számítógépet vagy a hálózatot tűzfal vagy proxy védi, ellenőrizze, hogy a
Firefox számára engedélyezett-e a webhozzáférés. -
vargalex
sto1911
#25164
Hi!
Igen, a dropbear (SSH daemon) valóban úgy van config-olva, hogy a 22-es porton hallgasson. Az, hogy kívülről a 2222-es porton legyen elérhető, tűzfal szabályokkal szabályokkal oldottam meg, azért, hogy ne kelljen külön dropbear példányt futtatni. Illetve ezen a porton Brute Force támadás elleni védelem is megvalósításra került.
Az ezt végző tűzfal szabályok:
/etc/config/firewall-ban (LuCI-ban Network->Firewall->Traffic Rules):
config 'rule'
option 'src' 'wan'
option 'dest_port' '22'Ez ugye annyit csinál, hogy a WAN oldalról a 192.168.1.1-es IP 22-es portjára irányuló forgalmat engedélyezi (ez átirányítás nélkül nem lehetséges, mert kívülről nem megcímezhető a 192.168.1.1).
Illetve hozzá tartozóan a /etc/firewall.user-ben (Luci-ban Network->Firewall->CustomRules
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --set --name $SERVICE -j DNAT --to-destination 192.168.1.1:$SERVICEPORT
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --update --seconds 60 --hitcount $BRUTEFORCE_PROTECTION_START --name $SERVICE -j DNAT --to-destination 192.168.1.1:$BRUTEFORCE_DROPPORT
iptables --table nat -I zone_wan_prerouting -p $PROTO --dport $PROTECTEDPORT -m state --state NEW -m recent --rcheck --seconds 60 --hitcount $BRUTEFORCE_PROTECTION_START --name $SERVICE -j LOG --log-prefix "BruteForce-${SERVICE} "Ez forwardolja a WAN oldalra 2222-es portra érkező kérést a 192.168.1.1 22-es portjára, miközben figyeli a próbálkozások számát. A megadott küszöbérték elérésekor egy nem használt (DROP-olt) portra irányítja és logol.
sto1911
vargalex
sto1911
#25157
Hi!
Ha nem változtattál a tűzfal config-on, nem másik router mögött vagy és publikus IP-t ad a szolgáltatód (nem privátot, mint pl. Mobilnet esetén), akkor kívülről az ssh (és az scp) a 2222-es, az ftp a 2221-es, a LuCI a HTTPS (443), a transmission GUI pedig a 9091-es porton érhető el. Feltétel még természetesen, hogy ahonnan próbálkozol ezek a portok ne legyenek tiltva.
sto1911
sto1911
#25141
Jelentem a storage-ot megcsinaltam, akkora user error volt, hogy inkabb le se irom.
A http tiltasat viszont nem talaltam azota se, tuzfalon tiltsam? Esetleg egy altalanos tuzfalszabalyzatot tud ajanlani valaki? Ha jol latom most accept minden iranyba.
Mi a leggyorsabb masolasi mod egyebkent, amit barhonnan elerhetek? Winscp-re gondoltam, abbol van portable is, most tesztelem, 600-800k a sebesseg, gondolom ennyit bir a cpu (bar ha belegondolok, akkor nem is kell tobb...
vargalex
sto1911
#25126
Hi!
A factory gyári firmware-ra készült, a sysupgrade pedig már telepített OpenWrt frissítésre.
Természetesen a flash-ba elfér, marad is 960 KB szabad hely, amiből kb. 720 KB használható is.
SSH-n frissítve automatikusan reboot-ol, ha az mtd parancsot -r kapcsolóval hívod (a leírások egyébként így írják).
Viszont néhány embernek gondja akadt az 1.1-es verzióval, így elérhetővé tettem a korábbi, 1.02.1-es verziót is. Erről még megvárhatod mások véleményét is. (Nálam sem a samba sebességével, sem a transmission sebességével nem volt gond 1.1 alatt.)
sto1911
#10625
Lehet, hogy a DNS szerverekkel van probléma, amit a szolgáltatód biztosít. Én ezért használok google publikus DNS szervert is, az alapértelmezettek mellett. A címük...
8.8.8.8
8.8.4.4Windows alatt nem mindegyik kezel flash meghajtókat... Használj valami LiveCD-t, mondjuk Parted Magic-et, esetleg Hiren's BootCD-t, illetve Win alá fizetős programot tudok, ami egész biztosan kezel PenDrive-ot, a "Paragon Drive Copy 9 Pro". Esetleg nézz utána, hol lehet beszerezni... ;
sto1911
#10622
Most is bejött, onnan másolom be...
Optware od Tplink - My solution - Tutorial
1. Mount usb-disc as /jffs (formated as ext2)
2. Run in console
Quote:
cd /jffs
wget http://openwrt.groov.pl/projekty/ddwrt/opkg-ddwrt.tar.gz
tar -zxvf opkg-ddwrt.tar.gz
rm opkg-ddwrt.tar.gz
3. Add to startup scrips
Quote:
echo "export PATH=/jffs/bin:/jffs/sbin:$PATH" >> /tmp/root/.profile
echo "export LD_LIBRARY_PATH=/jffs/lib:/jffs/usr/lib:/jffs/usr/local/lib" >> /tmp/root/.profile
4. Save and reboot router.
5. opkg update
6. Now you can install openwrt`s packages
Quote:
opkg install <package>
WARNING
Openwrt`s packages aren`t compile with prefix /jffs and ARE compile with UCI support. Well same of package may not work correct.
Transmission
I recompiled transmission 2.03 for tplink&ddwrt
Quote:
cd /tmp
wget http://openwrt.groov.pl/projekty/ddwrt/transmission-daemon_2.03-3-ddwrt_ar71xx.ipk
wget http://openwrt.groov.pl/projekty/ddwrt/transmission-web_2.03-3-ddwrt_ar71xx.ipk
opkg install transmission-daemon_2.03-3-ddwrt_ar71xx.ipk
opkg install transmission-web_2.03-3-ddwrt_ar71xx.ipk
Edit /jffs/etc/transmission/settings.json file and set login, password, whitelist etc. Save and run transmission
Quote:
/jffs/etc/init.d/transmission start
done
Nano
If you have a problem with nano (xterm error) you have to do:
Quote:
cp /usr/lib/libncurses* /jffs/usr/lib/
The End Smile -
vargalex
sto1911
#10338
Hi!
Szerintem erre a lemezre az fdisk kapásból azt mondaná, hogy nincs rajta partíciós tábla. Normál esetben úgy kellene lennie, ahogy Intruder2k5 is írta.
DD-Wrt alatt szerintem a postinst scriptek hibára futnak, mert semmi nem az OpenWrt alatt megszokott helyén található. De attól elképzelhető, hogy működik a telepített alkalmazás. -
sto1911
#10333
Először is, elméletileg jó lehet az NTFS, vagy FAT32 PenDrive is, bár azt hiszem, hogy alapból csak NTFS-t tud mountolni a DD-WRT, FAT-ot nem! Na, de ez mindegy is, szóval kell egy partíció, amit felcsatolsz a /jffs mappa alá. Lehet, hogy tévedek, de szerintem ez itt nem partíció...
/dev/discs/disc0/disc on /jffs type ext2 (rw)
Ennek valahogy így kellene kinéznie...
/dev/discs/disc0/part1 on /jffs type ext2 (rw)
sto1911
sto1911
#10333
Jo, megoldotam, user error volt: nem startup scriptkent mentettem el, hanem csak siman lefuttattam.
root@sto_home:~# opkg update
Downloading http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/Packages.gz.
Inflating http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/Packages.gz.
Updated list of available packages in /jffs/var/opkg-lists/packages.
root@sto_home:~# opkg install wget
Installing wget (1.12-2) to root...
Downloading http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/wget_1.12-2_ar71xx.ipk.
Installing libopenssl (0.9.8m-3) to root...
Downloading http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/libopenssl_0.9.8m-3_ar71xx.ipk.
Installing zlib (1.2.3-5) to root...
Downloading http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/zlib_1.2.3-5_ar71xx.ipk.
Configuring zlib.
Configuring libopenssl.
Configuring wget.
Collected errors:
* pkg_run_script: postinst script returned status 1.
* opkg_configure: wget.postinst returned 1.Igy viszont kaptam par hibat, a /var/log/messages hallgat ezekrol, mashol meg nem talaltam logot.
Ezert tetszett jobban az OPEN, az valahogy linux-kozelibbnek tunt.
sto1911
sto1911
#9330
Es elojott egy uj problema is, ha dyndns-en keresztul akarom elerni a webgui-t, akkor nem megy, ip-vel igen, az ssh dyndns-el is hibatlan. Eddig semmi baja nem volt honapokig...
Lehet, hogy megkavarta a kartya? Egyebkent maradjon ext3, vagy formazzam at 2-re, esetleg fat-re?
mgrincs
sto1911
#9190
Szia,
nem tudom DD-WRT-re milyen választék van, de az biztos, még ha tudsz is ilyet telepíteni, a letöltős oldalak AJAX(javascript) alapokon csinálják a visszaszámlálást, várakoztatást, amit ezek a command line browserek nem tudnak.
Lynx-et próbáltam, az optware-es verziót(még WL-500gP-n), de nem sokra jó.Léteznek letöltő scriptek, bizonyos oldalakhoz, de mivel ezeket sem szeretik az oldalak, mindig változtatni kell valamit. Mivel script-ből megy az egész és egyszerű minta-illesztéseken alapul, elég szerver oldalon egy apró dolgot megváltoztatni, és kapálhatsz, hogy újra működjön.
Egy lehetőség ecaddict szkript gyüjteménye(fewgets), a WL-500gp-s fórumban találsz hozzá hivatkozást. Elvileg bővíthető újabb oldalakhoz való pluginekkel is, ha valakinek van hozzá kedve. Nem kell feltétlenül a webes felület hozzá, a letöltő része működik parancssorból is.A samba leírást elnézve nem nagyon lesz ez egyszerűbb.
De csak egyszer kell megcsinálni. -
rionpulya
sto1911
#2047
A VPN kapcsolat felépülése után a route táblád határozza meg hogy merre menjenek a csomagok. Ha jól van beállítva a VPN kliensed, az kellene átkonfigurálja a route tábládat kapcsolódás esetén. Nézz szét a beállításai között, valahol be kellene tudnod állítani, hogy milyen ip tartományok menjenek azon keresztül.
A set as default csak annyit jelent a vpn kapcsolatoknál, ha több profil-t felvennél, melyik legyen az alapértelmezett.
Amit amúgy furcsálok hogy a vpn kapcsolatodnak 0.0.0.0 a gateway-e.
s4tch
sto1911
#1879
Követtem a leírást: megformáztam egy 2 gigás pendrive-ot ext3-ra (ez fontos lehet, ne kérdezd miért, de fatra formázott cuccal nem ment), feltettem a legfrissebb dd-wrt-t, aztán a leírás "manual howto" részét putty-val lépésenként végigcsináltam. A scriptek nem működtek, egyesével kiadva a parancsokat minden szépen lefutott. A nyomtatóval kapcsolatos részt hagytam csak ki. Jelenleg egy hibám van (torrenteknél a kliens "Error: Read-only file system" hibát ad), este dolgozom rajta.
SZERK: szerintetek miért csak 150 mbps sebességgel csatlakozik az asztali gépem a routerhez? Egy elvileg 300-as tp-link kártyám van (tl-wn951n), friss driverrel, win7 alatt. A routeren ahogy írtam, dd-wrt fut, de openwrt-vel is ugyanez volt a helyzet. Jelerősség 90% fölött szokott lenni, routerben dynamic mode (20/40 mhz) sávszélesség van beállítva.
sto1911
#1103
Visszaállítani alapra mindent...
Visszaállítás:
Mi van abban az estben, ha annyira belepiszkáltunk a rendszerbe, hogy nem reagál semmire. Se ssh, se webui, se ftp stb.
Erre találtak ki egy kiskaput a rendszerben.1. Áramtalanítsuk a routert.
2. Húzzunk ki minden ethernet kábelt,csak az legyen rádugva amire a gépünk csatlakozik.
3. Állítsunk be a gépen statikus ip-t (ezt minden rendszernél máshol kell beállítani).
Az ip legyen 192.168.1.2, maszk 255.255.255.0, átjáró 192.168.1.1 .
4. Dugjuk vissza a táp kábelt a routerre.
5. Amikor boot-ol a router, akkor nyomkodd a QSS gombot, addig, míg nem kezd el gyorsan villogni a sys led., amikor gyorsabban villog a sys, TELNET-en (tehát nem SSH-n) tudunk rá csatlakozni, majd újra kezdhetjünk az egész rendszer konfigurálni.2 parancs van amit ekkor használni kell:
mount_root
firstbootIlletve én még hozzáteszem, a
passwd
parancsot is... Bár nem 100%, hogy szükséges, de ártani nem árt.
sto1911
#1098
Be kell másolni a kívánt firmware-t valahova, ahol eléred SSH alól... Akár a /tmp-be, akár mmc, vagy tök mindegy. Tehát bemásolod a file-t, majd SSH-ban, belépsz abba a mappába, a file van (cd parancs... pl. cd /tmp), és ott kiadod ezt a parancsot:
mtd -r write filename linux
A filename rész értelemszerűen cserélendő a firmware file nevére. A művelet 1-2 percet vesz igénybe, a végén a router újraindul.
szerk.:
Ne tegyél rá sysupgrade-t... Inkább maradj a factory-nál. -
Nézd át pl. ezeket...
http://www.dd-wrt.com/wiki/index.php/Optware
http://www.dd-wrt.com/wiki/index.php/IpkgEz pedig igazából ASUS WL-500 tutorial, viszont ez is DD-WRT, tehát szerintem a router típusa nagyjából mindegy.
http://ocsovszki-dorian.darkhole.hu/?page_id=397 -
toxin2
Bármilyet rá tudsz kötni, ha a p910nd szerverrel használod.
Annyi a lényeg, hogy helyi nyomtatóként kell fölvenned,
és új tcp/ip port hozzáadásával be kell írni a 9100-as portra.
http://toxin.lapunk.hu/?modul=oldal&tartalom=1103144#sec13 -
Speeedfire
nbalus2k: a scripteknek futtatási jogot kell adni, ha eddig mér nem adtál akkor így
chmod a+x scriptnevemount /dev/sda1 /mnt/hdd
igen, felmountolja így is csak így nem tudsz rá írni sehogysem
Pufokaboka: hát ezt szomorúan hallom -
1. Bejelentkezel SSH-n a routerre (PUTTY)
2. Belépsz a /tmp mappába (cd parancs)
3. Ide letöltöd wget-tel a kívánt firmware-t (wget http://www.stb...)Én itt le szoktam egyeztetni a letöltött file méretét, az eredetivel.
ls -l
paranccsal megnézheted a /tmp mappa tartalmát. Ha stimmel, akkor ezután mehet a frissítés.
OpenWrt alatt a parancs:
mtd -r write filename firmware
DD-WRT alatt pedig
filename = a wget-tel letöltött firmware image file neve.
A frissítés 1-2 percet vesz igénybe, és a végeztével a router automatikusan újra fog indulni. Természetesen az SSH (PUTTY) ablakot nem szabad bezárni, míg a folyamat véget nem ér, tehát amíg a router újra nem indul.
Semmi extra... Én SSH-n az mtd paranccsal simán feltoltam rá, nem volt semmi gond. Webes felületen inkább nem próbálkoznék vele, bár elméletileg az is ugyanazt csinálja. Ha esetleg mégsem tetszene a DD-WRT, akkor visszafelé annyi változás van, hogy a parancs végére nem azt írod, hogy firmware, hanem azt, hogy linux.
sorcerer86
Milyen fw-t tettél fel? Én a lengyel buildet használom ott a webif(x-wrt) kintről 443-as portot használ alapból, de ez változtatható, csak firewallban nyisd meg amit kell.
- LED világítás a lakásban
- LEGO klub
- Robotporszívók
- Windows 7
- Pánik a memóriapiacon
- Valami fekete közeleg…
- Samsung Galaxy S20 és S20+ duplateszt
- Számos VGA kihalhat a memóriapánik miatt
- Apple iPhone 11 64GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPad 9th Gen 256GB, Wi-Fi+Cellular, Kártyafüggetlen, 1 Év Garanciával
- Amazon Kindle 10th Generation ébresztős tok
- BESZÁMÍTÁS! Asus H370-A i5 9600K 16GB DDR4 512GB SSD RTX 2060 Super 8GB Zalman T7 Zalman 500W
- Új és régi konzolok Okosítása és Szoftveres szintű javítása - RÉSZLETEK A LEÍRÁSBAN
- HIBÁTLAN iPhone 13 128GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS3760, 100% Akkumulátor
- GYÖNYÖRŰ iPhone SE 2020 64GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3920, 100% Akksi
ile not found
lesznek benne jó dolgok, én is várom...
Ez egy ujabb valtozat, mint ami fenn volt nekem, holnap letesztelem azzal is...
vargalex
