ux1
B-L-A-C-K
#49902
Soha. A WiFi-nek majdnem akkora a teljesítményfelvétele mintha telefonálnál. Nem értem... Mégis mit várnak egyesek
Csodát? Perpetum-mobile-t?(#49907) DnBHun
Persze hogy normális, a ROM kifőzése után jöhet az akksi kisütése is. Így lesz teljes a menü.
Nyugodtan megkérdezhetsz más Séfeket is.
ux1
Speeedfire
#49551
Mindíg becsúszik egy két ilyen. Nem veszi a lapot, aztán meg csinálja a fesztivált.
Knyihár úr miért nem mész a 3.14csába, és oldod meg a problémáidat magad. Ez így elég rossz belépő.
ux1
News
For Plus users only:
* Facebook login (for the Facebook widget) is now handled through the official Facebook app where available. This should help people with low DPI devices who were having throuble logging in before.
* Updated the Twitter API backend to fix some issues that some people were having with status updates.
* New Gmail widget! (Side note: Oh boy, this widget has been giving me lots of trouble to code. Since there’s no officially supported Gmail API in Android, there’s pretty much no documentation whatsoever on it). You can choose the source Gmail account, so you if you have multiple Gmail accounts, you can have a widget for each one of them. My intention was to have the widget simply open conversations in the official Gmail app when you click on them, but unfortunately 3rd party apps are not allowed to open that part of the Gmail app directly, so I had to create my own internal viewer to view them. It’s not as full-featured as the official app but it should be enough for most users. Replying to emails is handled by the official Gmail app (we can launch that part of it from 3rd party apps).For all users:
* Gingerbread fixes and improvements. The 3D app drawer has been fixed to work properly on Gingerbread. Other tweaks should provide much improved graphics performance (smoothness) on Gingerbread as well.
* New homescreen transition effects: “Flip” and “Rotate 2″. The old “Flip” effect is now named “Flip 2″. If anybody can come up with better names for these transitions, I’m open to suggestions :-) -
ux1
atillaahun
#49263
Persze hogy létezik... keresel nyílt wifit, beülsz egy mekibe, bemész egy bevásárlóközpontba...
ux1
Skullen
#49243
Igen ez így még viszonylag normális lenne... Még egy kérdés, az AHB kernelt használod? Nekem csak a WiFi volt bekapcsolva, és néhány (5-6) óra alatt. lenullázódott.
(#49248) szeryo
Szerintem jobb ha vársz... Szvsz sokkal jobban eszi az akksit az SS. Annyival meg nem nyújt többet, nem gyorsabb. -
ux1
kagzer
#49200
Igen. Most nekem is a 3.0.0.6 van fent. De csináltam update zipet is
Néznéd majd az akksifogyást? Mert tegnap nekem 6 óra alatt leszítta
ux1
Trailblazer
#49112
T-Mob-os teló eddig 1 embernek nem ment. Mindenki másnak igen.
ux1
anglergab
#49098
szerinted???
1. Csak ránézel a dátumokra és látod, hogy az utolsó módosítás dátum márc 14. Na vajon a az r8 és r9 és r10 volt-e már akkor. Hát volt.
Ilyenkor felteheted a kérdést magadnak, belerepülhettek a változások, vissza az időben az r8-ba? Lehetséges, mert se Einstein, se a húrelmélet nem zárja ki ennek a lehetőségét.2. Vajon a linux kernel hogy épül fel? Hadd ne részletezzem, de tele van természetesen feltételekkel, ha a proci ilyen, akkor ezt a kódot fordítjuk, ha intel ezt, ha 64bit akkor ezt... stb stb. Azt is elmondanám hogy a fordítás menete se az lesz, hogy uccu gcc fordítsd arm-ra és működni fog.
Igen és a Tex/LaTex még csak egy leírónyelv
(#49109) xakta
Igen szerintem maradjon annál
ux1
sunahunter
#49080
vegyél egy nokiát telefonálni...
Erre meg fejleszteni kel....
(#49081) Skullen
Ez most lelombozott ( mármint a lemerülése )
Hozzá voltam szokva a 1,5-2-5 napos megbízható működéshez.
Pedig még tetszene is...(#49084) Keeperv85
Te is eléred a githubon
Akár kallt-ét akár flibblesan- ét.
ux1
Skullen
#49077
Ez olyan, mint amikor törölsz a fontkészletetből, merthogy úgyse kell thai, meg héber, akkor fasza kis kockák jelennek meg a különféle szövegekben, meg a marketen
Egyre erősödik bennem a gyanú, hogy ezt az egész androidot úgy ahogy van az elejétől újra kellene írni. Ráférne már a kódtisztítás. Az 1.5-től kezdve csak fércelik...
Te az akksi zabálással hogy állsz?
(#49079) dipeti
rootexplorer
/system/app/stk.apk
ux1
Skullen
#49064
Hát erre a setupwizzardra nem jöttem volna rá egyhamar
De hogy mi köze hozzá???
Egyébként így kész is a SetupWiz-update az RLS3-hoz
Nekem a nagyobb gondom az hogy kb 5-6 óra alatt kikapcsolásig zabálta az akksit fullról. Másnál is? Előbb keresem az nem válaszol
Kimerült...Én meg mérgemben töröltem az F1 appot mert nem tudtam kilépni belőle
ux1
atillaahun
#48973
Igen, mert nem alszik el. és esetleg aktív a mobilnetjük is. Aztán meg ők panaszkodnak hogy rossz az akksi idő.
Csak gondolj bele hogy kb. 40mW a WiFi sugárzási energiája
Ja és persze tartani kell a kapcsolatot az adott routerrel, mert az se hülye észreveszi ha rá vagy lekapcsolódnak róla. A DHCP is ez alapján osztja az IP címet. Csak egy kicsit gondolkodjunk...
(#48974) qltsar
Csakhogy a telenoros blade nem= G2!
ux1
Bdanyy
#48968
Ámberek! Válaszuk mán el az alvást a WiFi-től! Ha az eszköz alszik akkor egy-két bill figyelésén kívül, és esetleg a WOL-on kívül nincs élet. Ha van WiFi, nincs alvás. Ez a PC-nél is így van! Max egy MagicPackettel felélesztheted és ez a funkció a WakeOnLan. Ezt az android altt is megteheted, de a gmail, és egyéb szolgáltatások ezt soha nem fogják megtenni neked. Jól is néznénk ki.
ux1
Ha pedig valaki kísérletezni akar az ebből készített főzettel. Akkor innen letöltheti.
Csak saját felelősségre!
(#48903) joni20
Volt ilyen irányú próbálkozás, de asszem megrekedt
Tehát nem... -
ux1
sunahunter
#48892
Tessék: itt a kódtisztítás nyoma 02.19-óta Ha valaki úgy érzi cserélni, kell cserélje... Engem nem izgat, de én egy csepp különbséget se fedeztem fel 1dBm-et se, hogy jobb lenne. Lehet hogy a 2 blédemben van a hiba
Volt itt már néhány ilyen vicc, buditeszt és társai, hirtelen mindenkinek gradienshibás lett a készülék stb.
ux1
sunahunter
#48879
Szerintem egyáltalán nem kellett, figyeljétek legaláb 10 percig az analyzert és rájöttök.
De én a véleményem írtam. A .ko csak azért kisebb mert debugg info nélküli a fordítás
A placebót meg azért írtam mert aki nem hisz benne, nem is érzékel különbséget.
Ha én ilyen alacsony jelnél 1.5 m-el arrébb megyek akkor teljesen mindegy hogy melyik driver van fent, mert olyan -85 dBm alatt baxik csatlakozni. Akkor hol itt a javulás?
ux1
Lenne még néhány észrevétel:
sd-ext:
Jó ha van (nálam ext3), így a 2.2 app2sd-t használó rendszerek ezt használatba is veszik, ezáltal egy elkülönített particióra kerülnek az appok, kisebb a sérülékenység, és a véletlen törlés veszélye. Ellenkező esetben ha az app támogatja áthelyezheted az sd-re ugyan, de elég ha leválasztás nélkül lehúzni a telót az usb-ről, a fat32 máris sérül.
Jönnek hogy miért FC-zik ez+az.
Elég utána megnézni az SD Lost+Found könyvtárát, lesz ám meglepi.
Miért használok /datát a romjaimban?:Mert az a qva data part azért van a telóban hogy használjuk! Nem hogy üresen álljon, amúgy meg elég sok átszabott partíciórendszerű gép van (128M system, 286M data). Amit csak lehet én átteszek a /datára, előnye szabadon frissíthető és uninstallálható. Nem a systemet kell tömni, pláne nem az átszabott rendszereknél, ugyanis vannak olyan appok amik oda is raknak libeket, egyebeket ha kell installálásuk során.
Természetesen ezek a megállapítások, csak az én véleményemet, és tapasztalataimat tükrözi. Van akinek ez jön be, van akinek amaz.
@turho:
Nem lehet hogy az történt ?
ux1
sunahunter
#48869
Szvsz az erősebb WiFi csak placebo hatás
flb-r11-ben meg nem is kell cserélni, mivel az új van beleforgatva. Kb. 30. percet töltöttem a méricskéléssel.
Persze a hit ereje...
api29:
Nekem is felejtős lett úgy 1 óra használat után.
ux1
anglergab
#48852
1.2.3. majdnem, dd ebben a barátod...
persze a "radio" nem oldható fel...
(#48854) anglergab: 3. - Ja és minden híreszteléssel ellentétben, aludni is szoktam.
(#48850) tlac
Így már számomra is egyértelműbb, látom már a többiek leírtak mindent.
(#48858) Aggregátor
A készülékek 98%-a nem tartalmaz manapság valós rtc-t. A GSM jelből veszik az időt. Egy újraindítás, vagy cellaváltás segít. Illetve amikor bejelenkezik a "torony"-nak a készülék. r11b is átállt.
Igaz én nem voltam ébren, hogy azt figyelgessem mikor.
F1 appokat izzítani!
ux1
Zsolaf
#48841
Csak úgy érdekességképpen megemlíteném, hogy csináltam egy rövidke tesztet WiFi jelerősség témában.
Mivel az flb-r11b ROM-ban már az új driver van a CM7-n31-el összehasonlítva az r11b jött ki győztesnek. Sokkal stabilabban tartja a jelet. A jelszintet egy árnyalatnyival szintén az flb-r11b érzékelte jobban kb. 3 dBm-el. Mindezt egy nálam szabadon fogható, igaz -80 - 70 dBm-es jelerősséget produkáló eszközt nézve mértem. Tehát nem kell cserélni semmit, pláne az r11-ben!
tomgabor:
Akkor küldi el a lehallgatott beszélgetéseket műhódon az NSA-nak.
2. De majd fox.
ux1
SteveBeard
#48822
Az 5.0.0-ás Navitel már működni fog. De ez még nem az a ROM amit napi-szinten használatba vennék
Megy vissza az equinox
(#48827) DeatHLesS:
Nem, az attól van, hogy sokat erőlteted a szemed a hibák keresésével. Meg egy kis önszuggeszció is közrejátszik
ux1
Keeperv85
#48785
Óha. Itt már megváltozott az USB-szabvány is
Az USB adatvonalakra(USB_DMINUS, USB_DPLUS) rá van kötve egy ÉS kapu(U1501). Ennek a kimenete(USB_ACC_DET) visszamegy a processzor egyik megszakítás(INT) bemenetére. Ez addig 0 szinten marad míg az adatvonalakon normális adatáramlás van. Amikor csatlakoztatod a töltőt, akkor a két adatvonalat a töltő felhúzza magas szintre(5V vagy kb. 3.8V). Ekkor az U1501 kimenete is magas lesz és a processzor észleli a megszakítást. Ezután a proci I2C-n keresztül utasítja a táp IC(PMIC), hogy kezdje meg a töltést.
Ha számítógéphez csatlakoztatod, akkor a driver vagy felhasználói program utasítja a processzort az USB-n keresztül, hogy töltsön.
A +- okoskodást helyezzétek már be. Nem földfüggetlen az elektronika. az usb data-n is azért van plusz meg minusz mert a 0 potenciál ha úgy tetszik, neki +2.5V a GND-hez képest.
ux1
ux1
Astaroth
#48682
1. amit használsz, arra csak ráfogják hogy router. (TP-LINK TL-WR741ND ugye ez ?)
2. nem árt ellenőrizni wifi analyzerrel hogy használják e még azt a csatornát amire a routert belőtted. Ha igen tedd el onnan.Sok sikert...
ux1
sunahunter
#48604
Várja mindenki a forma1 kezdetét
Ha már új CM7 sincs...
ux1
Keeperv85
#48552
Kár ezen vitatkozni. Minden ami a windowsban ( ugye itt már az NT alapú dolgokról beszélünk ) az nem M$ találmány. Unix-ból lett átemelve. Egy unix rendszernek, legyen az bsd sysv linux, fényévekkel jobb a multiuser, multitask kezelése mint a windows-nak. Elvileg android alatt se kell a telefont újraindítanod, csak kernel szintű csere esetén. Én pl linux-al az 1996-óta foglalkozom. Mellette persze mindig is volt windows. Eléggé ismerem a különbségeket.
ux1
ux1
Keeperv85
#48348
persze nem ilyen egyszerű tudtommal a helyzet, mert az apk-t a DalvikVM futtatja mint közbülső réteg, a kernel libeket pedig ő hívja meg és nem az apk. Ezért nehézkes a natív programírás az Androidon mivel nincs közvetlen hw hozzáférés már csak a linux kernel miatt sem. ( operációs rendszerek )
ux1
Pumika1975
#48284
nem sokban.
usb és wifi tethering update +stock caller & contact
bár nekem mindegy mert úgyse a beépített callert használom, hanem az aTakePhone-t
+az extrákban néhány kimaradt app pótolva
+ OC + smartass rendesen a helyükön
(/etc/init.d/80overclock)(#48282) Glatius
Na ez-az, a jogászok... Ideje lenne ezeket a törvényeket és jogokat is harmonizálni a magyar jogrendnek.
ux1
Glatius
#48273
De azért érzed a sántaságot... Pl veszek egy laptopot pl XP-vel, és nem vehetnék utána hozzá win7-et, mert akkor ugrana a gari.
De nem rakhatnám fel a linuxot sem. Én mondjuk a készülékemet, az adott szolgáltatónál, az ő kártyájával használom. A készüléket megvettem, nem részletre, nem hűséggel és elkötelezettséggel. Tehát az enyém.
Még valami: az M$ eulát se kérdőjelezheti meg ugye egy szolgáltató se? Akkor hogy is van ez?
ux1
Glatius
#48264
Mint egyszer már írtam, a telefonban benne van a "legal info" amit elfogadsz amikor használatba veszed. Ez pedig megengedi a módosítást míg ezzel kárt nem okozol másnak. Nyílt oprendszerről van szó. A függetlenítés viszont más tészta. Az egy más kérdés, hogy mikor e szép magyar törvények születtek, még nem volt nyílt rendszerű teló. Ilyen esetben viszont a nemzetközi ill. a gyártó által meghatározott feltételeknek kell érvényesülni. A google megengedi, a rootolást, a rom cserét. Ezt még a marketen elő is segíti. Támogatja a CyanogenModot is.
ux1
kopuler
#47912
1. felteszed mégegyszer a patchet
2. egy minfreq és egy maxfreqecho "ondemand" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
#echo "smartass" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 90 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/up_threshold
echo 30 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/down_differential
echo 500000 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/sampling_rate
echo 122880 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
#echo 245760 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
# CPU overclock
#echo 480000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
#echo 600000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
#echo 652800 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo 672000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
#echo 691200 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
#echo 710400 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freqA 600 az a ROM alapértelmezése.
Így nézett ki az eredeti
ux1
B-L-A-C-K
#47840
Természetesen, hiszen ez a ROM "sajátnak" születik, azokkal az appokkal, amit napi szinten használunk, de minden eltávolítható
Az Android SYS infoban a taskokat nézted? Hajlamos az elején az acore és a media beragadni és zabálni a cpu-t ( míg be nem indexeli az egész SD-t )
(#47842) api29
Dehogy, csak a 800Mhz-hez kellene a kernelt időzíteni
Azt a hibát, meg biztos nem a rom okozta
Csak tanúja lehetett, hogy megy tönkre egy gyári hibás tft
ux1
ux1
barnam_
#47778
Itt megtalálsz mindent a smartass, BFS/BFQ -ról.
ux1
N.E.W.S.
"Szita, szita péntek,
Szerelem csütörtök, ROM-szerda..."ROM-szerda révén...
ux1 - Spring Equinox eXTRa G1 rel2
MD5: dac6b7b72b1b83e8bc1531a1db747256
135.17 MBux1 - Spring Equinox lite G1
MD5: fb76ab475cf3a9afc09a35e7cb591548
79.3 MB
Csak a friss gapps - eltávolítható, frissíthető.alapja: FLB-Froyo-r11b
Előfeltételek:
Clockwork Recovery 3.0.0.6
ext2/3/4 partíció az SD kártyánInstall:
wipe data/factory reset
install zip from sdcard
rebootMódosítások:
/data/app mappa, létrehozva, feltöltve
felmegy a 128M-es /system-re
stock dialer és contact
nano bekapcsolva
bash bekapcsolva
ElegantSteel téma
PowerWidget a Notification bar-ban
HW_UI on
VM Heap 32m
/data/apps frissítve, optimalizálva. (ZipAlign)
Az appok, eltávolíthatók, frissíthetők
OC+RDS kernel
Egyedi csengőhangok, bootanim, háttérkép
AdFree host fájlMélyvíz:
Smartass bekapcsolása:
/system/etc/init.qcom.post_boot.sh
"ondemand" elé #
"smartass" elől töröldFix-OC (csak a jól bevált értéket használd!!!)
/system/etc/init.d/80overclock szerkesztéseVagy használd a No-Frills-t esetleg a SetCPU-t
ux1
kopuler
#47653
Nekem ma reggel 69%-on állt. sysinfoban nézve nálam elég sokat futott, 122Mhz-n, sokat volt viszonylag nyugalomban. Így elég pozitív a tapasztalat, Igaz lassabb ez az időzítési forma mint az "ondemand".
Értelemszerűen, az OC kernel alapból tudja ezeket a frekiket, azon fut ahol nincs # (azaz megjegyzésbe téve) annak nincs értelme hogy beállitod pl 600-ra majd rögtön utána 672 re
ux1
Van itt esetleg vki. aki linux servert üzemeltet a világhálón? Egy ssh acc kellene a 3389-es portra, tunnelhez...
(#47620) kelzsoca
Valószínűleg eddig is csak azért működött mert a cache-ből töltötte az eredeti drivert.
ux1
Laacko
#47275
Na ezaz...
Tedd fel a 3.0.0.6-ot azzal próbálkozzál.
Itt megtalálod.
Érdekesség képpen, valahogy a 3.0.1.4 nem mindig úgy megy ahogy kellene. Van amihez az kell, van amihez az eggyel régebbi.
(#47274) kopuler:
Lám már én se emléxem mit írtam
G1-G2 téma: Más a kernel címzése Ezért nem csak a kernelt kell relokálni, hanem a system libek összes pontját is. kallt egyszer már végigzongorázta ezt a JJ-vel, ezért használja azt a kernelt, de szvsz az egész rendszert újra kellene forgatni.... Így viszont a legváratlanabb érdekességek is előfordulhatnak, amúgy elég jól megy...
ux1
Laacko
#47260
Telenoros?
Próbáltad másik rommal is? Milyen recovery-t használnál? Az FLB-knél 3.0.0.6 az ajánlott.
(#47263) kopuler
Persze hogy van hiba, de más romoknál már ezek relatíve eltűntek. Itt viszont egy G1-re eszkábált G2 romról van ismét szó, ami megint ott tart mint anno a JJ-RLS-1-2.
ux1
Thrawn
#47248
Hát igen... Azt a fogyasztás visszafogására találták ki, ezért hagytam a fájlban az ondemandot is, csak egy #csere
Nekem mondjuk nem tűnik lassabbnak... Ismerkedünk vele mint a BFQ/BFS párossal
(#47250) plgr
De arra való, majd ha a stabble ágban lesz, és megveszed a pro-t
- Apple Iphone 16 pro max 256gb desert titanium eladó
- Honor 90 Lite 8/256GB Újszerű,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Garanciával!
- BESZÁMÍTÁS! ASUS B150M i5 7500 8GB DDR4 256GB SSD GTX 1050Ti 4GB Nbase Black Midi DeepCool 400W
- 197 - Lenovo Legion Pro 5 (16IAX10) - Intel Core U7 255HX, RTX 5070 (ELKELT)
- Beszámítás! LG UltraGear 27GL850 144Hz QHD IPS 1ms monitor garanciával hibátlan működéssel
- BESZÁMÍTÁS! MSI B450 R5 5600X 16GB DDR4 512GB SSD RTX 2070 Super 8GB Rampage SHIVA Adata 600W
Igen szerintem maradjon annál ![;]](http://cdn.rios.hu/dl/s/v1.gif)
