sharker
Innen:GeForce 6800 Premium Edition
Product Specfication :
Graphics Controller :
NVIDIA® GeForce™ 6800
Memory Configuration :
128MB 256-bit DDR Memory
Core/Memory Clock :
350/800MHz
Product Overview :
Powered by GeForce 6800 GPU
Superscalar 16-pipe GPU Architecture
0.13 Micron Process Technology
High-Speed 256-bit DDR Memory Interface with Advanced Memory Control
0.13 micron process technology
Full-Speed 32-Bit Color Precision
AGP 8X interface
12 Pixels/Clock Rendering Pipeline
NVIDIA® CineFX™ 3.0 engine
NVIDIA® UltraShadow™ II technology
NVIDIA® Intellisample™ 3.0 technology
NVIDIA® High-Precision Dynamic-Range (HPDR) technology
NVIDIA® ForceWare™ Unified Driver Architecture (UDA)
NVIDIA® nView™ multi-display technology
NVIDIA® Digital Vibrance Control™ 3.0
400MHz RAMDACs supports 2048x1536 resolution at 85Hz
Highest DVI output up to 1600x1200 resolution
128-bit studio-precision computation
Integrated full MPEG encode and decode support
Integrated NTSC/PAL TV encoder up to 1024*768 resolution
DirectX 9.0 and OpenGL 1.5 optimizations and support
Cooler Master® CoolViva Specification :
Heat Sink Dimension 120x82.6x13 mm
Heat Sink Material Aluminum
Fan Dimension 60x60x10 mm
Fan Speed 2500rpm
Fan Airflow 10.8 CFM
Fan Air Pressure 1.1mmH2O
Fan Life Expectance 50,000 hrs continuous
Bearing Type Ball bearing
Voltage Rating 10.8-13.2V
Noise Level 23.8 dBA
Connector 3 Pin
Weight 23 g
Application VGA Card Processor
Installation Guide
Components
Fan Front Side Heat Sink Base Back Side Heat Sink Base
Heat Pipe Heat Sink Thermal Grease
Other Parts
How Heat Pipe works
Note: The gap between the AGP slot and the Northbrigde chipset must be at least 25mm. -
sharker
És a veszek hozzá bordát annak meg nem lenne értelme mert az +2000-3000!
Nem??? -
sharker
23,8 db a heatpipe!!!
A tiéd kb mennyi? -
sharker
Szerintetek jó a heatpipeos???
Van értelem mert ahogy elnéztem az csak a cpu-t hűti a ramokat nem! -
sharker
Hadjuk már látom hogy nálad ilyen gond nincs!:DD
sharker
Egy centivel megtudod nézni???
sharker
Mert ha igen lemérnéd hogy mekkora távolság van az AGP és northbridge között?
Merthogy őszinte legyek nincs nálam az alaplap!/Szervíz:nincs rajta biosz!:DD/
Nagyon fontos lenne!
Köszi! -
sharker
Alvin_ti4200!
Figyu lehet egy kérdésem neked Msi k8n neo fis2r-ed van?? -
sharker
Tudjátok mi a vicc???:DD
Hogy 24mm távolság van nálam!/AGP és northbridge/
Szerintetek megpróbáljam???/Megvenni a heatpipeosat!/
Mer azért az csak jobb nem?? -
sharker
Ja OKÉ!:DD
sharker
És ha nem adnak hozzá ventit akkor hol lehet venni?
Zalman jó rá? -
sharker
Én is ettől félek!
Az aqua-ban legalább tudom mi az és még raktáron is van!:DD -
sharker
Miért gyárilag nem adnak hozzá ventit?:F
sharker
Nemtom hogy van e venti rá!
Amugy ezt!
GEFORCEFX 6800 128MB TV/DVI 59.600/Nettó/ -
sharker
Szerintetek visszamodjam azt a karit amit rendeltem a demotól?
Mert ez olcsóbb és legalább tudom hogy milyen!
NA?? -
sharker
Valami teszt?
sharker
Ő az!:DD -
sharker
De nem chaitech!Hanem natúr nvidia!
sharker
Nem baj hogy csak 128 bites!:DD
Így is jól jön ki a tesztekből!:) -
sharker
Ja az lessz!!!:DD
sharker
Amúgy mi az e-vga?
sharker
Sima Nvidia!
Amúgy én már láttam a fix.tv-n.
Nem olyan szörnyő!Akkor konkrétan az x800Pro nyert mert a hülyék egy tök gagyi gépen tesztelték!
A demostudio meg basszott visszahívni pedig azt mondták hogy öt perc és visszahívnak!
Azóta is várom!:)) -
sharker
Bizony, de azért az nekem sok!:))
sharker
Ja és nem kell valakinek egy 420w thermaltake táp?
sharker
Na gyerekek megrendeltem!:DD:DD:DD:DD:DD:DD!!!!
Reméljük annyi lesz mer ha nem durci leszek!:)) -
sharker
Jó lenne!!!:DD
sharker
Ahogy nézem 12 pipelinea van.Valahogy ezt nem lehet kioldani mint az X800Pro-nál?
sharker
Tényleg!
A ezt a sima 6800-at mennyire lehet húzni? -
sharker
Köszi a hozzászolásokat valószínüleg 6800 lesz!:DD
sharker
Igen amúgy jobb lenne a 6800!/apám ''elbulizza'' az áfát!/:DD
Csak az a kérdés hogy ez a bolt mennyire megbízható? -
sharker
De ahogy én megnéztem 9800Pro újonnan 60k!
Használtan kb.50k!/Nemtom mennyi!/
De huzni nem igazán akarom!
Akkor inkább a 9800XT mint a 9800Pro!Nem? -
sharker
Lehetséges?
sharker
Ezzen az oldalon olvastam![L]http://www.demostudio.hu/[/L]
Lehet ez????
Konkrétan itt![L]http://www.demostudio.hu/index.php?mode=arlista&id=11[/L]
GEFORCEFX 6800 128MB TV/DVI 59.600 <==Nettó! -
sharker
Bocsi rosszul írtam bruttó 75-ért!:DD
sharker
Szerintetek melyik a jobb?
Most tudnák venni használtan 55k-ért 9800XT Heatpipeos Zalman borda plusz hozzá való hűtő!+10hónap gari
Vagy
GEFORCEFX 6800 128MB TV/DVI netttó 75k-ért?
NA???
Válaszokat köszi!
- GYÖNYÖRŰ iPhone XR 128GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS3984, 100% Akkumulátor
- Telefon felvásárlás!! Xiaomi Redmi Note 13, Xiaomi Redmi Note 13 Pro, Xiaomi Redmi Note 13 Pro+
- HP ZBook Firefly G9 - 14" hibás kijelző, i7 1255U, 16GB RAM, Nvidia T550 4GB VGA, hiányos bill.
- ÁRGARANCIA!Épített KomPhone i9 14900KF 32/64GB RAM RTX 5070 Ti 16GB GAMER PC termékbeszámítással
- Dell P2419H / P2719H Full HD LED IPS 24"-27" LCD monitorok
