Elnézést, az ottani linkek döglöttek. Szóval:
''The maximum length for an IDE cable allowed by the ATA/IDE Standard is 18 inches; and that is the length of the cable that is supplied with the OnStream drive. In some cases, this 18-inch length may not be long enough to span the distance from the motherboard or IDE controller to the drive bay in which the OnStream drive is being installed. Although it’s possible to obtain or make a custom IDE cable with a length exceeding 18 inches, be aware that the devices attached to such a cable might not operate properly due to noise and/or signal attenuation. Possible problems can include anything from intermittent data errors to the drive not being recognized by the system. OnStream cannot guarantee proper operation for drives that are connected to cables that exceed the 18-inch maximum length.''
18'', azaz kb. 45 cm a maximális hossz. Elvileg kapni 24''-os (60 cm) kábeleket is, de ha nem olyan a vezérlőd és a vinyód, akkor azzal nagyon be tud lassulni a rossz illesztettség miatt. -
- Milyen okostelefont vegyek?
- Peugeot, Citroën topik
- Windows 11
- Eredeti játékok OFF topik
- Napelem
- Dell Precision 5750 17" UHD+ touch, i7 10850H, 16-64GB RAM, 6GB VGA, 512GB SSD, jó akku, számla, gar
- Lenovo ThinkPad T14 Gen1 Ryzen5 4650U Refurbished - Garancia
- Apple iPhone 13 / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 88%
- Samsung Galaxy A16 / 4/128GB / Kártyafüggetlen / 12HÓ Garancia
- Alphajack MSH V1 mágneses autós telefontartó szellőzőre (Magsafe kompatibilis)
