OpenWrt topic
footy
vargalex
#17606
Azt nem ertem miert az eth1-et keresi, az nincs konfiguralva sehol:
root@WAN2-Yess:/etc/config# cat ddns
config ddns 'global'
option ddns_dateformat '%F %R'
option ddns_loglines '250'
option ddns_rundir '/var/run/ddns'
option ddns_logdir '/var/log/ddns'
config service 'myddns_ipv4'
option lookup_host 'XXX
option use_ipv6 '0'
option service_name 'duckdns.org'
option domain 'XXXX'
option username 'XXXX'
option password 'XXXXXXX'
option ip_source 'interface'
option use_syslog '2'
option check_unit 'minutes'
option force_unit 'minutes'
option retry_unit 'seconds'
option ip_network 'wwan0'
option interface 'wwan0'
option enabled '1'Ami pedig az error file-t illet az ures
:root@WAN2-Yess:/etc/config# cat /var/run/ddns/myddns_ipv4.err
root@WAN2-Yess:/etc/config# ls -ltra /var/run/ddns/myddns_ipv4.err
-rw-r--r-- 1 root root 0 Aug 5 13:38 /var/run/ddns/myddns_ipv4.err
root@WAN2-Yess:/etc/config# -
footy
vargalex
#17604
A masik routeren most talaltam logokat:
110814 note : PID '20844' started at 2022-08-05 11:08
110814 : ddns version : 2.8.2-12
110814 : uci configuration:
ddns.myddns_ipv4.check_unit='minutes'
ddns.myddns_ipv4.domain='XXXX'
ddns.myddns_ipv4.enabled='1'
ddns.myddns_ipv4.force_unit='minutes'
ddns.myddns_ipv4.interface='wwan0'
ddns.myddns_ipv4.ip_network='wwan0'
ddns.myddns_ipv4.ip_source='interface'
ddns.myddns_ipv4.lookup_host='XXXX'
ddns.myddns_ipv4.password='***PW***'
ddns.myddns_ipv4.retry_unit='seconds'
ddns.myddns_ipv4.service_name='duckdns.org'
ddns.myddns_ipv4.use_ipv6='0'
ddns.myddns_ipv4.use_syslog='2'
ddns.myddns_ipv4.username='wan2a1'
ddns.myddns_ipv4=service
110814 : verbose mode : 0 - run normal, NO console output
110814 : check interval: 600 seconds
110815 : force interval: 4320 seconds
110815 : retry interval: 60 seconds
110815 : retry counter : 0 times
110815 : No old process
110815 : last update: never
110815 : Detect registered/public IP
110815 : #> /usr/bin/nslookup XXXXX.duckdns.org >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
110815 : Registered IP '89.x.x.x' detected
110815 info : Starting main loop at 2022-08-05 11:08
110816 : Detect local IP on 'interface'
110816 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
110814 : ************ ************** ************** **************
111420 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111420 : Data detected:
111420 :
111420 WARN : Get local IP via 'interface' failed - retry 7/0 in 60 seconds
111520 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111520 : Data detected:
111520 :
111520 WARN : Get local IP via 'interface' failed - retry 8/0 in 60 seconds
111621 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111621 : Data detected:
111621 :
111621 WARN : Get local IP via 'interface' failed - retry 9/0 in 60 seconds
111721 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111721 : Data detected:
111721 :
111721 WARN : Get local IP via 'interface' failed - retry 10/0 in 60 seconds
111822 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111822 : Data detected:
111822 :
111822 WARN : Get local IP via 'interface' failed - retry 11/0 in 60 seconds
111922 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
111922 : Data detected:
111922 :
111922 WARN : Get local IP via 'interface' failed - retry 12/0 in 60 seconds
112022 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
112023 : Data detected:
112023 :
112023 WARN : Get local IP via 'interface' failed - retry 13/0 in 60 seconds
112123 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
112123 : Data detected:
112123 :
112123 WARN : Get local IP via 'interface' failed - retry 14/0 in 60 seconds
112223 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
112224 : Data detected:
112224 :
112224 WARN : Get local IP via 'interface' failed - retry 15/0 in 60 seconds
112324 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
112324 : Data detected:
112324 :
112324 WARN : Get local IP via 'interface' failed - retry 16/0 in 60 seconds
112424 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err
112424 : Data detected:
112425 :
112425 WARN : Get local IP via 'interface' failed - retry 17/0 in 60 seconds
112525 : #> ip -o addr show dev eth1 scope global >/var/run/ddns/myddns_ipv4.dat 2>/var/run/ddns/myddns_ipv4.err -
footy
vargalex
#17599
Szia,
iigy neznek ki a configok:
root@WAN1-Magenta:~# cat /etc/config/ddns
config service 'DDNS'
option use_ipv6 '0'
option enabled '1'
option lookup_host 'XXX'
option domain 'XXX'
option username 'XXX'
option ip_interface 'wwan0'
config service 'wan1magenta'
option use_ipv6 '0'
option enabled '1'
option lookup_host 'XXXXX'
option domain 'XXXXXX'
option password 'XXXXXX'
root@WAN1-Magenta:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd06:6bd9:9ab3::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth0.1'
config interface 'lan'
option device 'br-lan'
option netmask '255.255.255.0'
option ip6assign '60'
option ipaddr '192.168.100.1'
config device
option name 'eth0.2'
option macaddr '20:28:18:a2:39:57'
config interface 'wan'
option proto 'dhcp'
option device 'eth0.2'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '4 6t'
config switch_vlan
option vlan '2'
option ports '0 6t'
config interface 'wwan'
option proto 'ncm'
option pdptype 'IP'
option apn 'business.gprsinternet'
option ipv6 'auto'
option service 'preferlte'
option device '/dev/ttyUSB0'
config route
option interface 'lan'
option target '192.168.1.0'
option gateway '192.168.100.250'
config route
option target '192.168.5.0'
config route
option target '192.168.10.0'
config route
option target '192.168.99.0'
option gateway '192.168.100.250'Ugye WWAN0 csak csatlakozas utan van. Erdekes modon most nem talalom a logokat hozza.
footy
van 2db LTE routerem(Huawei 3372 USB modemek lognak NEX es Glinet eszkozokon) amik a tuzfalon lognak.
Sajnos mindkettonel jelen van az hogy a DDNS script nem mokodik rendesen.
Amennyire meg tudom allapitani a problem az hogy az LTE virtualis interface(WWAN0) nem elerheto meg akkor amikor a DDNS script a bootnal indulna.
Hogyan tudom kesleltetve automatikusan ujrainditani a DDNS-t?koszi
footy
stopperos
#14517
Van benne valami amit mondassz. Úgyhogy most úgy csináltam meg, hogy a routeren megcsinálom a backupot és utána a nasról SCP-vel áthúzom. Bemásolom ide, hátha valakinek kell majd:
Router: (törlöm a régi backupot hogy ne teljen meg a tmp és generálom az adott napit):
#!/bin/sh
#/sbin/backup.sh
rm /tmp/backup-*.tar.gz
sysupgrade -b /tmp/backup-${HOSTNAME}-$(date +%F).tar.gzNAS: (áthúzom a backup nevű fájlokat (mindig csak egy van a fenti scriptnél))
#!/bin/sh
#/sbin/router_backup.sh
scp root@192.168.1.1:/tmp/backup-*.tar.gz /export/backup -
footy
Ha el tudnád küldeni a scriptet szuper lenne, nem kell különösebben szofisztikált megoldás, ami benne van a Luciban backup funkció az jó is lenne, csak nem tudom milyen programot hív meg a háttérben.
Az eredeti terv az volt hogy becsomagolom az etc/configban lévő fájlokat egy tar-ba és scp-vel másolom a NASra az egészet pedig berakom cronjobba.(#14505) vargalex
Erről van valami leírás?(#14506) suste
Nekem az ofmodemsandmens féle rooter firmware van fennt, mást nem akarok felrakni, mert ez minden trükközés nélkül működteti az LTE modemet. (van benne trigger az IP váltáshoz is stb.)
Megvan a scipt külön is? -
footy
periodikus(heti) backupot szeretnek csinalni a routerrol(openwrt18.06) egy NASra.
Nem csak a config fileokat hanem szeretnem a tuzfal szabalyait is menteni.
Van erre valami out-of-the-box megoldas?koszi
footy
Na megválaszolom a saját kérdésemet.
Szóval a statikus út csak akkor megy ha nem a default GW-t használja az ember, így ez nekem kiesett.
Ezután beállítottam a WAN interface alatt a keret méretet 1472-re, viszont még ez sem hozta a megfelelő eredményt. Be kellett állítanom a LAN interface alatt is 1472-re a keretméretet így már nincs csomagvesztés és stabil a kapcsolat. -
footy
Bizonyos cel IP-t(ceges VPN Gateway) csomagvesztessel tudok elerni. Ahogy tesztelgettem 1432-es MTU-nal meg nincs csomagvesztesem. Lattam hogy az Openwrt-nel lehet route illetve interface alapon az MTU-t valtoztatni.
Melyik ajanlott inkabb? Ha beallitok egy statikus utat a VPN GW-hez es ott veszem le az MTU-t az eleg?koszi
footy
wiggen123
#11753
Elvileg az APN(internet.telekom)-n kivul mast nem kell beallitani.
footy
sikerult mar valakinek a csibvpnhez csatlakozni openwrt routerrel? (klienskent)
en az alabb hibauzeneteket kapom:
Mon Jul 3 08:49:58 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 1
Mon Jul 3 08:49:58 2017 daemon.notice openvpn(csibvpn)[11471]: UDP WRITE [14] to [AF_INET]185.112.157.197:443: P_C ONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=41d8fb10 dc41ef91 [ ] pid=0 DATA
Mon Jul 3 08:49:58 2017 daemon.notice openvpn(csibvpn)[11471]: UDP write returned 14
Mon Jul 3 08:49:59 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:00 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:00 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 1
Mon Jul 3 08:50:00 2017 daemon.notice openvpn(csibvpn)[11471]: UDP WRITE [14] to [AF_INET]185.112.157.197:443: P_C ONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=41d8fb10 dc41ef91 [ ] pid=0 DATA
Mon Jul 3 08:50:00 2017 daemon.notice openvpn(csibvpn)[11471]: UDP write returned 14
Mon Jul 3 08:50:01 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:03 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:04 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:04 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 1
Mon Jul 3 08:50:04 2017 daemon.notice openvpn(csibvpn)[11471]: UDP WRITE [14] to [AF_INET]185.112.157.197:443: P_C ONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=41d8fb10 dc41ef91 [ ] pid=0 DATA
Mon Jul 3 08:50:04 2017 daemon.notice openvpn(csibvpn)[11471]: UDP write returned 14
Mon Jul 3 08:50:05 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:06 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:07 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:09 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:10 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:11 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:12 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:12 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 1
Mon Jul 3 08:50:12 2017 daemon.notice openvpn(csibvpn)[11471]: UDP WRITE [14] to [AF_INET]185.112.157.197:443: P_C ONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=41d8fb10 dc41ef91 [ ] pid=0 DATA
Mon Jul 3 08:50:12 2017 daemon.notice openvpn(csibvpn)[11471]: UDP write returned 14
Mon Jul 3 08:50:14 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:15 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:16 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:17 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:18 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:20 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:21 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:22 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:23 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0
Mon Jul 3 08:50:24 2017 daemon.notice openvpn(csibvpn)[11471]: event_wait returned 0 -
footy
van ra mod, hogy az Openwrt routeremet Bridge Mode-ban hasznaljam?
Azt szeretnem hogy a mogotte levo tuzfal kapja meg a nyilvanos IPt. (Illetve o kezdemenyezne a PPPoE-t)koszi
ui.:
Jelenleg az openwrt routermen van az LTE usb modem, a tuzfal pedig nem tamogatja a modemet teljeskoruen ezert kellene ez a megoldas. -
footy
vargalex
Erre tudsz valamit mondani?Generaltam a routeren uj kulcsokat:
dropbearkey -f id_rsa -t rsa -b 2048
A routeren lett egy ujid_rsafile.
Aztan adropbearkey -y -f id_rsaparancs kimenetet(fingerprint nelkul) beillesztettem az authorized_keys-be a NAS-on.
Viszont igy sem mukodik:root@ROOter:/etc/dropbear# ssh NAS
ssh: Exited: String too long -
footy
vargalex
#10600
dropbearkey -f id_rsa -t rsa -b 2048A routeren lett egy uj
id_rsafile.Aztan a
dropbearkey -y -f id_rsaparancs kimenetet(fingerprint nelkul) beillesztettem az authorized_keys-be a NAS-on.Viszont igy sem mukodik:
footy
vargalex
#10559
A routerrol root-kent probalok bejelentkezni. A NASon igy neznek ki a jogosultsagok:
root@NAS:~/.ssh# ls -ltra
total 20
drwxr-xr-x 3 root root 0 Jan 3 07:05 ..
-rw-r--r-- 1 root root 963 Feb 12 14:25 known_hosts
-rw-r--r-- 1 root root 598 Feb 27 07:47 id_dsa.pub
-rw------- 1 root root 672 Feb 27 07:47 id_dsa
-rw-r--r-- 1 root root 390 Feb 27 09:37 id_rsa.pub
-rw------- 1 root root 1679 Feb 27 09:37 id_rsa
drwx------ 2 root root 0 Feb 27 09:37 . -
footy
Van valakinek leiras ahhoz hogy ssh kulccsal be tudjak jelentkezni a a routerrol a NASra?
A NAS-on generaltam egy RSA key-t ezt bemasoltam az Openwrt routeren a /.ssh/authorized_keys-be , de nem mukodik
footy
Privoxy-val van valakinek tapasztalata?
Mennyire stabil es mennyire eroforrasigenyes?
Egy GL AR150-re menne fel. -
footy
bambano
#10400
Az a problema hogy nem tudom kihagyni az openwrt-s routert, mert az a padlason van beepitve az antennaval egyutt. A sophos tuzfal pedig a pinceben lenne. Azt egyebkent sem tennem ki az idojaras viszontagsagainak. (Szerintem egy X86-os rendszer erzekenyebb ra mint egy ARM SOC)
Az LTE kapcsolatot PPP-vel hivom meg, viszont ha a sophos tuzfalrol inicializalnam a kapcsolatot, akkor szerintem PPPoE kellene mert ethernet keresztul akarok PPP-t. Vagy rosszul gondolom? -
footy
Olyat hogy lehet csinalni, hogy az Openwrt routerem WAN bridge-kent mukodjon?
Jelenleg igy nez ki a helyzet----------------- Hivatalos IP -------------------------- -------------
LTE USB modem ============> OPENWRT Router ============> LAN
---------------------- -------------------------- -------------Szeretnek osszerakni egy Sophos tuzfalat es jo lenne hogyha annak a WAN interfeszen lenne a hivatalos/szolgatltatotol kapott IP. (A tizfallal csinalnek PPPoE-t)
------------- -------------------------- Hivatalos IP ------------- -------------
LTE USB modem ===========> OPENWRT Router ===========> Firewall============> LAN
---------------------- -------------------------- ------------- -------------meg lehet ez oldani?
koszi
Na ez jol szecsuszott, de remelem latszik a lenyeg...
footy
dupla
footy
Headless
#9995
En nem SSL VPN-t hanem site-to-site ipsec vpn-t terveztem. Szerintem nekem valamit a strongswan-nal kellene alkotni...
footy
Site-to-site VPN-t szeretnek két openwrt router között. Valaki csinált már ilyesmit?
Esetleg tud valaki jó leírást hozzá? Az Openwrt wikin találtam egyet, de az nem tűnt átláthatónak.köszi
footy
vettem egy NEXX WT3020F 300M-t jo megszokasbol, amint megerkezett elkedzdtem ra feltolni az OPENWRT-t . A kovetkezoket csinaltam:
cd /tmp
# wget http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/openwrt-15.05.1-ramips-mt7620-wt3020-8M-squashfs-sysupgrade.bin# mtd_write -r write openwrt-15.05.1-ramips-mt7620-wt3020-8M-squashfs-sysupgrade.bin mtd3
Azota se kep se hang. Probaltam resetelni. (aram kihuz, reset benyom aram vissza) , de nem segitett.
Valakinek otletl?
koszi
- PC Game Pass előfizetés
- The Elder Scrolls Online Imperial Collector s Edition
- 16gb (2x8gb) Micron DDR5 SODIMM 4800 Mhz RAM
- darkFlash Shadow Pro
- Telefon felvásárlás!! Apple iPhone SE (2016), Apple iPhone SE2 (2020), Apple iPhone SE3 (2022)
- Lenovo Flex 5 - 14.0" Touch WUXGA - Ryzen 3 5300U - 8GB - 256GB - Win11 - Garancia - MAGYAR
- Keresünk iPhone 16/16e/16 Plus/16 Pro/16 Pro Max
