OpenWrt topic
oatis
Teljesen ki reseteltem a routert és a wan portokat töröltem.
Minden esetben a konfig fájlok végére másoltam az általad írtakat. a dhcp nem megy + az interfészeknél a guest zónára az írja: unsupported protocol type
dhcp:config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.auto'
option localservice '1'
config dhcp 'lan'
option interface 'lan'
option dhcpv6 'server'
option ra 'server'
option ignore '1'
option ra_management '1'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
config dhcp 'GUEST'
option interface 'GUEST'
option start '100'
option leasetime '1h'
option limit '15'firewall:
config defaults
option syn_flood 1
option input ACCEPT
option output ACCEPT
option forward REJECT
# Uncomment this line to disable ipv6 rules
# option disable_ipv6 1
config zone
option name lan
list network 'lan'
option input ACCEPT
option forward ACCEPT
config zone
option name wan
list network 'wan'
list network 'wan6'
option input REJECT
option masq 1
option mtu_fix 1
config forwarding
option src lan
option dest wan
# We need to accept udp packets on port 68,
# see https://dev.openwrt.org/ticket/4108
config rule
option name Allow-DHCP-Renew
option src wan
option proto udp
option dest_port 68
option target ACCEPT
option family ipv4
# Allow IPv4 ping
config rule
option name Allow-Ping
option src wan
option proto icmp
option icmp_type echo-request
option family ipv4
config rule
option name Allow-IGMP
option src wan
option proto igmp
option family ipv4
# Allow DHCPv6 replies
# see https://dev.openwrt.org/ticket/10381
config rule
option name Allow-DHCPv6
option src wan
option proto udp
option src_ip fe80::/10
option src_port 547
option dest_ip fe80::/10
option dest_port 546
option family ipv6
config rule
option name Allow-MLD
option src wan
option proto icmp
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
option family ipv6
# Allow essential incoming IPv6 ICMP traffic
config rule
option name Allow-ICMPv6-Input
option src wan
option proto icmp
list icmp_type echo-request
list icmp_type echo-reply
list icmp_type destination-unreachable
list icmp_type packet-too-big
list icmp_type time-exceeded
list icmp_type bad-header
list icmp_type unknown-header-type
list icmp_type router-solicitation
list icmp_type neighbour-solicitation
list icmp_type router-advertisement
list icmp_type neighbour-advertisement
option limit 1000/sec
option family ipv6
# Allow essential forwarded IPv6 ICMP traffic
config rule
option name Allow-ICMPv6-Forward
option src wan
option dest *
option proto icmp
option family ipv6
# include a file with users custom iptables rules
config include
option path /etc/firewall.user
### EXAMPLE CONFIG SECTIONS
# do not allow a specific ip to access wan
#config rule
# option src lan
# option src_ip 192.168.45.2
# option dest wan
# option proto tcp
# option target REJECT
# block a specific mac on wan
#config rule
# option dest wan
# option src_mac 00:11:22:33:44:66
# block incoming ICMP traffic on a zone
#config rule
# option src lan
# option proto ICMP
# option target DROP
# port redirect port coming in on wan to lan
#config redirect
# option src wan
# option src_dport 80
# option dest lan
# option dest_ip 192.168.16.235
# option dest_port 80
# option proto tcp
# port redirect of remapped ssh port (22001) on wan
#config redirect
# option src wan
# option src_dport 22001
# option dest lan
# option dest_port 22
# option proto tcp
# allow IPsec/ESP and ISAKMP passthrough
config rule
option src wan
option dest lan
option proto esp
config rule
option src wan
option dest lan
option dest_port 500
option proto udp
### FULL CONFIG SECTIONS
#config rule
# option src lan
# option src_mac 00:11:22:33:44:55
# option src_port 80
# option dest wan
# option dest_ip 194.25.2.129
# option dest_port 120
# option proto tcp
#config redirect
# option src lan
# option src_port 1024
# option proto tcp
config zone
option name 'lan'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'ACCEPT'
option network 'lan'
option masq '1'
option mtu_fix '1'
config zone
option name 'GUEST'
option forward 'REJECT'
option network 'GUEST'
option input 'REJECT'
config forwarding
option dest 'lan'
option src 'GUEST'
config rule
option target 'ACCEPT'
option proto 'tcp udp'
option dest_port '53'
option name 'GUEST-DNS'
option family 'ipv4'
option src 'GUEST'
config rule
option dest_port '67-68'
option name 'GUEST-DHCP'
option proto 'udp'
option src 'GUEST'
option src_port '67-68'network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd9a:af65:6f91::/48'
config interface 'lan'
option ifname 'eth1'
option force_link '1'
option type 'bridge'
option netmask '255.255.255.0'
option ip6assign '60'
option ipaddr '192.168.64.2'
option dns '8.8.8.8 8.8.4.4'
option gateway '192.168.64.254'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 1 2 3 4'
config interface 'GUEST'
option ipaddr '192.168.101.1'
option dns '8.8.8.8 8.8.4.4'wireless
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option hwmode '11g'
option path 'platform/ar934x_wmac'
option htmode 'HT20'
option txpower '18'
option country 'HU'
config wifi-iface
option device 'radio0'
option mode 'ap'
option ssid 'XXXXXXX'
option encryption 'psk2'
option key 'xxxxxx'
config wifi-iface
option mode 'ap'
option ssid 'guest'
option encryption 'none' -
oatis
Töröltem, de sajnos nem működik a vendégen a net így sem. A lanhoz bridgelt wifin pedig minden ok.
Lehet ez nem is megoldható ilyen formában.
"If you want the OpenWRT to just be a simple Access Point, the upstream router will have to create the VLAN, and route to it in order to have internet access." -
oatis
dhcp:
config dnsmasq
option domain 'lan'
config dhcp 'lan'
option ra 'server'
option ignore '1'
config dhcp 'wan'
option ignore '1'
option maindhcp '0'
config dhcp 'guest'
option interface 'guest'
option start '50'
option limit '200'
option leasetime '1h'firewall:
config defaults
option syn_flood 1
option input ACCEPT
config zone
option name lan
list network 'lan'
option input ACCEPT
config zone
option name wan
list network 'wan'
list network 'wan6'
option input REJECT
option masq 1
option mtu_fix 1
config forwarding
option src lan
option dest wan
config rule
option src wan
option proto udp
option dest_port 68
option family ipv4
# Allow IPv4 ping
config rule
option src wan
option proto icmp
option family ipv4
config rule
option src wan
option proto igmp
option family ipv4
config rule
option src wan
option proto udp
option src_port 547
option family ipv6
config rule
option src wan
option proto icmp
option family ipv6
config rule
option src wan
option proto icmp
option family ipv6
config rule
option src wan
option dest *
option proto icmp
option family ipv6
config include
#config rule
# option src lan
# option dest wan
# option proto tcp
#config rule
# option dest wan
#config rule
# option src lan
# option proto ICMP
#config redirect
# option src wan
# option dest lan
# option proto tcp
#config redirect
# option src wan
# option dest lan
# option proto tcp
config rule
option src wan
option dest lan
option proto esp
config rule
option src wan
option dest lan
option proto udp
#config rule
# option src lan
# option dest wan
# option proto tcp
#config redirect
# option src lan
# option proto tcp
config zone
option name 'guest'
option network 'guest'
# Allow Guest -> Internet
config forwarding
option src 'guest'
option dest 'wan'
# Allow DNS Guest -> Router
# Client DNS queries ordinate from dynamic UDP ports (>1023)
config rule
option name 'Allow DNS Queries'
option src 'guest'
# Allow DHCP Guest -> Router
# DHCP communication uses UDP ports 67-68
config rule
option name 'Allow DHCP request'
option src 'guest'
option proto 'udp'
option target 'ACCEPT'network:
option ifname 'lo'
option ula_prefix 'fd0c:9583:f25f::/48'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option reset '1'
config switch_vlan
option vlan '1'
config interface 'guest'
option ipaddr '10.0.0.1'
option dns '8.8.8.8 8.8.4.4 84.206.109.1'
option gateway '192.168.64.254'wireless
option channel '11'
option hwmode '11g'
option txpower '18'
option country 'HU'
option distance '30'
config wifi-iface
option mode 'ap'
option key '123456'
config wifi-iface
option mode 'ap'
option ssid 'guest'
option encryption 'none'Időközben megpróbáltam újra. Ezzel a beállítással dhcp működik, de a net továbbra sem. Még a fő routereme tse tudom pingelni a vendég hálózatról.
oatis
Nekem egy tp-link 940n v5-tel van problémám. Az OpenWrt Chaos Calmer 15.05.1 / LuCi- verziója van fenn. Amit szeretnék elérni, hogy legyen egy guest vlanom, ami el van szeparálva az alap wifi-től.
Ezen leírás alapján hoztam létre az új vlant, de a net nem megy rajta. Ip címet kapok a beállított tartományból.
A router switchként van konfigurálva, tehát ip-t nem oszt sem a wifi, sem a lan portokra. Amit még kipróbáltam, hogy routerként konfigoltam be, akkor minden ok, csak az meg nekem nem jó. :/
Valaki esetleg tudna ebben segíteni nekem?
A konfig file:
option _orig_ifname 'wlan0-1'
option _orig_bridge 'true'
option broadcast '192.168.101.255'
option gateway '192.168.101.1'
Amint látható, én dns-ként a google névszervereit adtam meg, ehelyett mindig a 192.168.101.1-et küldi el... Lehet ez a hiba?
- Lenovo ThinkPad X13 Gen 2 i5-1145G7 16GB 512GB FHD+ HunVillBill- 1 év garancia
- iKing.Hu - Google Pixel 10 Pro 5G Porcelain AI-fotó varázs, Super Actua 120 Hz 128 GB
- ÁRGARANCIA!Épített KomPhone Ryzen 7 9800X3D 64GB RAM RTX 5080 16GB GAMER PC termékbeszámítással
- Beszámítás! Lenovo LOQ 17IRX10 FHD Gamer notebook - i7 13650HX 24GB DDR5 1TB SSD RTX 5050 8GB
- Nvidia Quadro M2000/ P2000/ P4000/ RTX 4000/ RTX 5000/ RTX A2000
vargalex
