OpenWrt topic
xabolcs
#20076
Ebből a leírásból hiányzik a LAN bridge beállítása szerintem
A robot havertől (chatgpt) kérdeztem kiemelve, h így volt beállítva: "Wireless Repeater/Extender with Relayd" , többször említette
Itt még a lan beállításnál (semmi konkrétat):
Bridge Configuration:
Ensure the LAN interface is bridged correctly.
Disable any relay-specific configurations.Majd a wifi AP beállításánál:
Bridge Interfaces:
Ensure the new Wi-Fi interface is bridged with the LAN interface.
Go to Network -> Interfaces, and edit the LAN interface to include the new Wi-Fi interface in the bridge.És amikor értetlenkedtem részletezi kicsit:
To bridge the interfaces correctly on your OpenWrt router, follow these steps:
Go to Network -> Interfaces.
Edit the LAN Interface:
Ensure the protocol is set to 'Static Address'.
Include the Wi-Fi network in the bridge.Wireless Network Settings:
Client: This mode connects to another Wi-Fi network (like your Padavan router). Use this if you need the OpenWrt router to connect wirelessly to the Padavan router.
Master: This mode creates a Wi-Fi network. Use this to broadcast the same SSID as your Padavan router.For your scenario, if you are connecting the two routers with a cable and want to extend the Wi-Fi coverage, set the Wi-Fi network to Master.
Steps:
Network -> Wireless:
Ensure the wireless interface is set to Master.
Set the SSID, security, and password to match your Padavan router.
Network -> Interfaces -> LAN:
Make sure the LAN interface includes both the Ethernet and the Wi-Fi interfaces in the bridge.Example Bridge Configuration:
Network -> Interfaces -> LAN -> Physical Settings:
Check the box for Bridge interfaces.
Select both the Ethernet (eth0) and Wireless Network (Master) interfaces.Testing:Connect a device to the OpenWrt Wi-Fi.Check for internet connectivity and IP address assignment from the Padavan router.This configuration will extend your Padavan router’s Wi-Fi network using the OpenWrt router.
Végre sikerült összekábelezni a két routerem, most megszüntetném a wifi-s kapcsolatot közöttük. Így voltak összekötve: "Wireless Repeater/Extender with Relayd"
A cél az lenne, h a main router (padavan) össze van kötve kábellel a másikkal (openwrt): ezen legyen hálózat, internet és, h a padavan wifi hálózatát kibővítse.
Miket kell állítsak be (elméleti szinten)? Már beállítottam a dolgokat (működik is) csak ellenőrzésképpen kíváncsiskodok, h nem-e hagytam ki valamit
E.Kaufmann
#19975
Tényleg írja, ezen átsiklottam
#19976attila.86:
Így marad. Ez csak kényszermegoldás míg nincsenek "összevezetékelve"
Egyébként a két router nem mai darab, nem hiszem, h ismernék a mesh-t
- RT-AC1200GU - padavan 3.4.3.9L-101_da8a271
- Archer C6 v2 (EU/RU/JP) - OpenWrt SNAPSHOT r25366-7f13b9f8be, Qualcomm Atheros QCA956X
Most, h állítgattam a kamerákat (mert áramszünet után új ip-t kaptak) feltűnt egy furcsaság. Két router van összekötve nálam "Wireless Repeater/Extender with Relayd" ebben a formában. Az az érdekes, h minden eszköz ami a második (openwrt) routerre csatlakozik egyforma mac címet mutat. Fel akartam venni a kamerákat az első routeren a dhcp listába (ö a dhcp szerver, de minden ott a fenti leírásban) de azt mondja nekem (jogosan), h ugyanazzal a mac címmel nem vehetek fel másik ip címet:
Itt látszik, h 4 eszköznek ugyanaz a mac címe (+ az nvr-nek amit már felvettem a listára). Szóval, ez most így hogy?
Kicsit elvesztem az openwrt beállításaiban
Az lenne a cél, h a fenti router egy másik wifi hálózatról (bodynetwork) kapja a net-et (hálózatot) és adja tovább vezetéken és wifi-n. Jól így van beállítva, h client és master is ez a router?
Kicsit elkapkodtam az új (használt) router-em frissítését, mert megáll a luci telepítésénél "helyhiány" miatt:
root@OpenWrt:~# opkg install luci-ssl-nginx
Installing luci-ssl-nginx (git-22.299.78093-3260371) to root...
Downloading https://downloads.openwrt.org/snapshots/packages/mips_24kc/luci/luci-ssl-nginx_git-22.299.78093-3260371_all.ipk
Installing libstdcpp6 (12.3.0-4) to root...
Collected errors:
* verify_pkg_installable: Only have 1312kb available on filesystem /overlay, pkg libstdcpp6 needs 1880
* opkg_install_cmd: Cannot install package luci-ssl-nginx.Most kicsit utánaolvasva van több fajta ilyen router (archer c6 v2), több fajta tárhellyel, az enyém ilyen:
root@OpenWrt:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 3.8M 3.8M 0 100% /rom
tmpfs 59.3M 1.2M 58.1M 2% /tmp
tmpfs 59.3M 36.0K 59.3M 0% /tmp/root
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock5 1.5M 224.0K 1.3M 15% /overlay
overlayfs:/overlay 1.5M 224.0K 1.3M 15% /Látom mi a baj, 1,5M az egész tárhely ahova telepítené az 1,8M dolgot
Szóval tudnátok egy link-et a megfelelő fw-hez?
Nagyon köszi
Archttila
#17138
Nekem egy ac1200gu-m van picit több dolog megy mint nálad (rpi-n HA, x86-on plex, torrent, syncthing, adguardhome, etc a routeren vpn szerever, 13 eszköz) és tökéletesen teszi a dolgát
Ami még mellette szól, h kapsz egy ingyenes ddns-t is az asus-tól
Jah, és digis gigás net mint nálad -
Érdeklődnék, h mikor kerül bele az openwrt-be a FragAttacks nevű sebezhetőség "halom" javítása?
Szeretnék kipróbálni egy másik openwrt típust (most vargalex v1.1.7 r35342 van fent és megnézném a gargoyle_1.6.2-ot). Kérdésem az lenne, h rá lehet húzni a Firmware frissítés menüpont alatt vagy vissza kell tenni a gyárit?
A másik, h TP-Link TL-WDR3600 v1 típusú routerhez ez a megfelelő állomány?
gargoyle_1.6.2-ar71xx-generic-tl-wdr3600-v1-squashfs-factory.bin -
amstro555
#2491
Hátööö... nem. De ha jól rémlik eddig se nyúltam (ezért) a tűzfalához és ment eddig...
Mit állítsak ott? Az SSH dolgot megint nem értem... én nem SSH-n akarok belépni hanem dyndns-en keresztül a luci-ba
Vagy ahhoz kell SSH és azért nem megy
Mert az nincs persze beállítva... -
Valamit elpiszkáltam a routeren, nem tudok távolról belépni dyndns-en...
https://body007hun.dyndns-ip.com lenne a cím de nem lép be. Mindent (a dyndns-nél) úgy állítottam mint eddig (mert már le is reseteltem a routert) de nem akaródzik nek... Mit nézzek meg?
Szeretnék belépni a routerbe ssh-n de ez fogad (nem vágom az ssh témát...):
body@fedorka .ssh$ ssh 192.168.1.1
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
5b:ff:e5:51:19:5f:47:e0:16:29:32:c2:aa:e6:5b:42.
Please contact your system administrator.
Add correct host key in /home/body/.ssh/known_hosts to get rid of this message.
Offending RSA key in /home/body/.ssh/known_hosts:1
RSA host key for 192.168.1.1 has changed and you have requested strict checking.
Host key verification failed.Ftp-t szeretném meghegeszteni, gondoltam konzolon egyszerűbb lesz de nem enged belépnem...
body007
#1951
Dobálja a wifi kapcsolatot a router-em
Csak reboot segít rajta. Csak a 2,5-es antennát használom jelenleg. 4 napig gond nélkül ment. Mit csináljak én ezzel?mod.: vagyis az eszközön a wifi on / off is helyre teszi a kapcsolatot. Míg írtam a hsz-t eldobta megint...
dyndns beállításhoz kellene kis segítség.
Ez így nem érhető el, miért vajon?
Helyi hálóról be tudok lépni, de egy ismerőst megkértem, h próbáljon belépni de nem elérhető az oldal azt mondja a böngészője... -
Egy ilyen multifunkciós, mindent olvasó, vinyó dokkot fel tudna mount-olni a router-em? Vagy ez próba cseresznye?
vargalex
#1925
Közben az már meglett (olvasom a wiki-t). Telnet-en pass csere megvolt, ssh-n bejelnetkezve és most itt állok (ülök) és nézek... Szóval a régi router bent a hálózatba (onnan jön még a net wifi-n), ez kábelen rákötve a notira. De egyszerre nem tudok wifi-n is és eth0-n lógni...
Így most, h a bánatba töltöm le a csomagokat? -
Noob vagyok még a témába... A TL-WDR3600os router-emre melyik fw-t töltsem?
openwrt-ar71xx-generic-tl-wdr3600-v1-jffs2-fact..> 03-Apr-2013 08:15 8126464
openwrt-ar71xx-generic-tl-wdr3600-v1-jffs2-sysu..> 03-Apr-2013 08:15 3932164
openwrt-ar71xx-generic-tl-wdr3600-v1-squashfs-f..> 03-Apr-2013 08:15 8126464
openwrt-ar71xx-generic-tl-wdr3600-v1-squashfs-s..> 03-Apr-2013 08:15 2883588
köszi
- PC Game Pass előfizetés
- AKCIÓ! Asus TUF A16 2024 FA607NUG Gamer notebook - R7 7445HS 16GB DDR5 1TB SSD RTX 4050 6GB
- GYÁRI TÖLTŐK: USB-C / DELL / LENOVO / HP / FUJITSU / TOSHIBA / Asus / Macbook /// Bp,/MPL/Foxpost
- BESZÁMÍTÁS! Intel Core i7 6700K 4 mag 8 szál processzor garanciával hibátlan működéssel
- Hp 830 G8 Core i7 1185U 16Gb Ram Intel Iris FullHD IPS Boltból számlával Garanciával
- Honor 200 pro
