▼▼▼ ANDROIDOS TABLETEK ▼▼▼
Utolsó frissítés: 2025. szeptember
Sargarigo765
Richee11 #53159 üzenetére
Elég nyomorult oldalt sikerült linkelned, talán a gyártói többet mond
A gépet amúgy nem ismerem, de a felbontása elég megnyerő.Itt a spec amúgy:
Hardware
Processor (CPU) Cortex A7 quad core, 1 GHz
RAM 1 GB (DDR3)
Memory 8 GB*
Graphic Unit (GPU) PowerVR™ SGX 544 MP2 (2 cores, 8 threads)
Display type Capacitive HD screen,IPS, 5-Point-Multitouch
Display size 17.7 cm (7")
Screen resolution 1280 x 800 Pixel
Camera Rear: 2.0 MP, Front: 0.3 MP
Interface 1 x Micro-USB 2.0 connector (female), Bluetooth® , Camera, Card reader, Micro HDMI connector (female), Microphone, Stereo Audio out, WiFi
Card reader (supported card formats) microSD , microSDHC (max. 64 GB)
G-Sensor Yes
Dimensions (W x H x D) 190 mm x 116 mm x 8,9 mm
Weight approx. 290 g (only the device without accessories)
Type of housing Aluminum , Plastic
Color White
Record and playback
Gaming 3D games, Classic games, G-Sensor games, Touch games
Playable video formats MPEG-4.10 H.264/AVC (MP@L4.1, HP@L4.0) , MPEG-4.2 SP/ASP (e.g. Xvid up to 1080p) , WMV HD/VC-1 , Additional format support through plugins or applications
Video container formats AVI , MKV , MOV , Additional format support through plugins or applications
Supported picture formats BMP , GIF , JPEG , PNG , Additional format support through plugins or applications
Playable audio formats AAC, FLAC , MP3 , OGG , WAV , Additional format support through plugins or applications
Max. video-resolution 2160 p
Aspect ratio 16:10
Internet connection
WiFi IEEE 802.11b/g/n
Other characteristics
Operating system Android™ 4.2 (Jelly Bean)
Software Access to thousands of applications
Power supply Lithium-polymer battery
Maximum operating time Approx. 5.5 h (WiFi off), Approx. 5 h (WiFi on), Standby (approx. 4 days)
Charging time Approx. 4 hours
Charge by Micro-USB port
Languages Multilanguage support by Android™ OS 4.2
Package contents SurfTab® xiron 7.0 HD, Hi-Speed USB 2.0 cable (USB-A / Micro-USB), Hi-Speed USB 2.0 Host-Adaptercable (Micro-USB / USB-A (female)), Power supply (100 V - 240 V), Cleaning cloth, Operating instructions
Memory card not included in the delivery.
We reserve the right to make changes and corrections. -
Sargarigo765
A véleményetekre lennék kíváncsi! Kinéztem két gépet, az egyik egy "Concorde Rokee c" típus, a másik pedig egy "DPS iq7".
Árban ugyanott vannak. Megnyomkodtam őket, döccenés nélkül mentek (nyilván mélyebben nem tudtam belemenni a boltban) azok a dolgok, amik alapból rajtuk volt.A rokee-ról találtam tesztet, ahol nagyon tetszett a tesztelőnek, ez mindenképpen mellette szól. Az akkuja is elég erősnek tűnik, és ahogy olvastam nem is nagyon melegszik.
A dps a nyers adatokat tekintve jobbnak tűnik (core4 vs core2), ámde tesztet nem találtam, és az akkut sem tudom hogy mekkora. Cserébe állítólag melegszik, ami nem tudom mit jelent a másikhoz képest.
Szóval ha valakinek volt már a kezében ilyen kütyü, akkor szeretném ha szólna hozzá
Elsősorban olvasásra használnám (ehhez bármelyik jó),
utána filmnézésre, de wifiről (itt már nem tudom melyik erősebb),
nyilván játék is, de az csak a harmadik helyen.Természetesen az optimumot keresem ezért az árért, de ha van más trónkövetelő, azt is szívesen meghallgatom!
Köszönöm segítségeteket!
- Kuponkunyeráló
- Milyen széket vegyek?
- Windows 11
- Hiánypótló funkciót vezet be a Nothing
- (nem csak) AMD FX / Ryzen tulajok OFF topikja
- újszerű iPad Pro 11" (2018) Wi-Fi 64GB asztroszürke ajándék tok fólia
- iPad pro 11 M2 Celluar 128 GB + Apple Smart Folio
- Eladó iPad Pro 13 256GB WIFI + CELLULAR ~1.000.000 Ft újkori ár
- Tolino Vision 4 HD Ebook olvasó Háttérvilágítás, wifi,8 GB, 6"
- iPad Pro smart case tokok gyári!! iPad Pro és mini modellekhez
- Honor X6 64GB, Kártyafüggetlen, 1 Év Garanciával
- LG 45GS95QE - 45" Ívelt OLED / 2K WQHD / 240Hz 0.03ms / NVIDIA G-Sync / FreeSync Premium / HDMI 2.1
- Gamer PC-Számítógép! Csere-Beszámítás! R5 5600 / RX 6700XT 12GB / 16GB DDR4 / 500GB SSD
- Telefon felvásárlás!! Samsung Galaxy S25, Samsung Galaxy S25 Plus, Samsung Galaxy S25 Ultra
- Bomba ár! Lenovo ThinkPad X390: i5-G8 I 8GB I 256SSD I 13,3" FHD I HDMI I Cam I W11 I Gari!
