ASUSTO NAS összefoglaló
Arc27
Sziasztok az As3302T v.2 milyen appal tudom elérni egy Samsung tv-n Ue40Nu7192
köszönöm
Arc27
Stealth
#4612
Hello
Már mindent megtaláltam a logba de jelszó sehol nincs
Pontosan hol találom ?Üdv Roland
(N) 2025-02-03T20:42:16 - qBittorrent v5.0.3 started. Process ID: 146
(N) 2025-02-03T20:42:16 - Using config directory: /config/qBittorrent
(N) 2025-02-03T20:42:16 - Trying to listen on the following list of IP addresses: "0.0.0.0:6881,[::]:6881"
(I) 2025-02-03T20:42:16 - Peer ID: "-qB5030-"
(I) 2025-02-03T20:42:16 - HTTP User-Agent: "qBittorrent/5.0.3"
(I) 2025-02-03T20:42:16 - Distributed Hash Table (DHT) support: ON
(I) 2025-02-03T20:42:16 - Local Peer Discovery support: ON
(I) 2025-02-03T20:42:16 - Peer Exchange (PeX) support: ON
(I) 2025-02-03T20:42:16 - Anonymous mode: OFF
(I) 2025-02-03T20:42:16 - Encryption support: ON
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "127.0.0.1". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "127.0.0.1". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "172.17.0.2". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "172.17.0.2". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "::1". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "::1". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - UPnP/NAT-PMP support: ON
(W) 2025-02-03T20:42:17 - Couldn't load IP geolocation database. Reason: No such file or directory
(N) 2025-02-03T20:42:17 - Using built-in WebUI.
(N) 2025-02-03T20:42:17 - WebUI translation for selected locale (en) has been successfully loaded.
(N) 2025-02-03T20:42:17 - WebUI: HTTPS setup successful
(N) 2025-02-03T20:42:17 - WebUI: Now listening on IP: *, port: 18181
(I) 2025-02-03T20:42:17 - Detected external IP. IP: "176.63.144.150"
(I) 2025-02-03T20:42:17 - IP geolocation database loaded. Type: DBIP-Country-Lite. Build time: Sat Feb 1 03:16:56 2025.
(I) 2025-02-03T20:42:17 - Successfully updated IP geolocation database.
(W) 2025-02-03T20:44:53 - UPnP/NAT-PMP port mapping failed. Message: "could not map port using UPnP[172.17.0.2]: no router found"
(W) 2025-02-03T20:45:50 - WebAPI login failure. Reason: invalid credentials, attempt count: 1, IP: ::ffff:192.168.0.34, username: admin
(W) 2025-02-03T20:46:31 - WebAPI login failure. Reason: invalid credentials, attempt count: 2, IP: ::ffff:192.168.0.34, username: admin
(W) 2025-02-03T20:46:38 - WebAPI login failure. Reason: invalid credentials, attempt count: 3, IP: ::ffff:192.168.0.34, username: admin -
Arc27
Most vettem egy AS3302T v2 Nas-t. Tökéletesen müködik minden megosztás, elérés .
Már csak qBittorrent beállitása nem sikerül
Már a belépés se megy a qBittorrent WebUI-ba az alapértelmezett user/password (admin/adminadmin)páros nem megy. A config fájlba pedig nem találom hol tudom változtatni . A transmission muködik de a sebbesége nem a legmegfelelöbb. A Net az One 1 Gigás net .
Elöre is köszönöm a segiséget
- AKCIÓ! LENOVO ThinkPad P15 Gen1 munkaállomás - i7 10875H 16GB DDR4 512GB SSD Quadro T1000 4GB W
- BESZÁMÍTÁS! Asrock 970 Pro3 970 chipset alaplap garanciával hibátlan működéssel
- LG 27G850A - 27" Nano IPS - UHD 4K - 240~480Hz 1ms - NVIDIA G-Sync - FreeSync Premium PRO - HDR 600
- HP EliteOne 800 G6 All-in-One i5-10500 32GB 1000GB 24" Érintőkijelző!! 1 év garancia
Gawamatsu
