ocso
Hát ez az, amit én sem tudok.... :)
De találtam végre jobb megoldást is :
[L]http://support.microsoft.com/default.aspx?scid=http://support.microsoft.com:80/support/kb/articles/q271/9/65.asp&NoWebContent=1[/L]
[L]http://support.microsoft.com/default.aspx?scid=kb;EN-US;314082[/L]
Ez talán bejön....:DD
[Szerkesztve] -
ocso
Találtam egy ilyet :
Szerintetek melyik (az elsőt próbálta már valaki)?
-If you are unable to boot into Windows 2000 or Windows XP:
Restart Windows 2000 or Windows XP in Recovery Console mode.
Note: Recovery Console mode requires the use of the Windows 2000 or Windows XP setup disks.
In Recovery Console, type disable imgatapi to disable the Imgatapi service.
Type enable atapi SERVICE_BOOT_START to enable the ATAPI service.
Restart your computer.
Note: If you disable the Imgatapi service but do not enable the ATAPI service, you will receive a ''Stop 0x0000007B INACCESSIBLE_BOOT_DEVICE'' error message.
-If you are still experiencing problems booting into your system, please use the following steps.
Note: You will need a Windows 2000 or Windows XP setup disks to perform the following steps. You must do the steps in the order that they are listed.
Boot the computer from the setup disks with the installation CD in your CD-ROM drive.
From the three options listed, press the Enter key to set up Windows 2000/XP.
Press the F8 key to agree to the license agreement.
Once the system detects a previous installation of Windows 2000, you will need to press the R key to repair Windows. This will recopy all Windows files and leave the system in exactly the same state it was in prior to the boot problem.
Reinstall any Windows 2000 or Windows XP service packs that you previously had installed. -
ocso
Hi!
Elég macerás a dolog, mivel, eddig mindig kék képernyő fogadott ilyen esetekben: INACCESSABLE_BOOT_DEVICE.....
Újratelepíteni nem akarok semmiképpen, mivel rengeteg program és telepített dolog van rajtuk.
Ötlet, ha mégsem indul?Olvastam valami olyat, hogy elindul ismét, ha Recovery Consol-lal az atapi service-t megbuheráljuk, erről nem tud valaki közelebbit? -
ocso
Helló!
Van egy olyan problémám, hogy alaplap csere előtt vagyok és van egy W2K és egy XP a gépemen. Szóval ezek nem fognak bebootolni a csere után. Tudna valaki olyan módszert, hogy reinstall nélkül meg lehessen oldani a dolgot, mert újragányolni elég nehéz lenne? Esetleg a Recovery Consol-lal? (atapi service)
Előre is köszi a segítséget!
Üdv.: ocso
- OpenMediaVault
- Fűnyíró topik
- Death Stranding (PC)
- BestBuy topik
- TCL LCD és LED TV-k
- Házimozi haladó szinten
- Home server / házi szerver építése
- BESZÁMÍTÁS! 1TB Kingston Fury Renegade NVMe SSD meghajtó garanciával hibátlan működéssel
- BESZÁMÍTÁS! 4TB Corsair MP600 Pro XT NVMe SSD meghajtó garanciával hibátlan működéssel
- BESZÁMÍTÁS! 1TB Kingston KC3000 NVMe SSD meghajtó garanciával hibátlan működéssel
- BESZÁMÍTÁS! 4TB Kingston NV2 NVMe SSD meghajtó garanciával hibátlan működéssel
- BESZÁMÍTÁS! 2TB Kingston Fury Renegade NVMe SSD meghajtó garanciával hibátlan működéssel
- Bialetti kézi kávéőrlő
- GYÁRI TÖLTŐK: USB-C / DELL / LENOVO / HP / FUJITSU / TOSHIBA / Asus / Macbook /// Bp,/MPL/Foxpost
- Részletre. Kingston FURY Impact 32GB DDR5 4800MHz KF548S38IB-32
- BESZÁMÍTÁS! Gigabyte B760 i5 12600KF 16GB DDR4 512GB SSD RTX 3080 10GB Asus A31 PLUS TG ARGB 750W
- ASUS TUF A14 Gaming Notebook! Ryzen AI HX 370 / RTX 4050 / 16GB DDR5 / 1TB NVMe! BeszámítOK!
