--- Még az új vizsgarendszer előtti információk, majd frissítjük! ---
Gyakran ismételt kérdések
Olvasd el a cikkeket itt.
Akiii
Hedgehanter
#8400
ugyanez itt, aws, azure blabla..
Akiii
Hedgehanter
#8393
Moving to the cloud?
Akiii
HP to acquire @ArubaNetworks to create an industry leader in enterprise mobility. http://stks.co/g1sYb
hopp
Akiii
pankers
#8256
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
Itt körbe tudsz nezni melyik SFP jöhet szóba
VSLnek minimum rakjatok 2 darab 10G kapcsolatot osszeboundolva mivel ezen atvan extendalva a data plane
Dual activenak (ami a keepalive kb) annak elég a Giga
Plusz ne lepodj meg ha az elejen felorat bootol a switch mikor felall a VSS teljesen normalis
Akiii
Aki holnap jön Techtorialra azzal majd morzézva megtalaljuk egymast?
Akiii
Az uj V5 OCG egyik reviewja
"Very horrible. I just spent months reading this book front to back, memorizing all the content that I hadn't previously known. I spent more time going through the practice tests that come with this book. I felt ready more than ever and took the 400-101 test ($400 by the way). I failed pretty bad. I got 644 with a passing score of 804. From the first question to the last, there was barely any question that was covered in this book, and if it was, not at all in the depth that the exam required. NetFlow is barely covered in this book (which was covered heavily on the exam) as well as other protocols that were on the exam. Very, very, very disappointed. Even if you knew this book word for word, you wouldn't be able to pass the exam with this book alone. I would not buy it. I wasted money on this book, $400, time I could have spent with family, and pride. I will not be studying this book to re-take the exam...waste of time."
Akiii
HTTP2 ^o^
Akiii
Nemtudom hanyan ismerték az Emeritus statuszt de ezen a héten mondta egy kollegam, hogy ő ebbe van aztan utananeztem:
Akiii
FecoGee
#8100
jó olvasni ezeket, h milyen dolgokon mentél át
Van egy updatelt listad, h milyen forrasokat hasznaltal az IEhez vegul? Regebben lattam egyet a blogodon nemtudom viszont, hogy up to date -e.
Egy ideje mar jatszom a gondolattal, hogy elkezdjem en is valahol de sajnos munka, munkabol adodo utazas illetve pozicio valtas miatt valahogy mindig hatterbe szorult. De szerintem most valamikor tavasszal végre raveszem magam es elkezdem addigra megprobalok beszerezni mindent.
Azon gondolkoztam meg, hogy erdemes-e ujra atolvasni a CCNP, CCIP anyagokat vagyis legalabb azokat a reszeket amik a v5 blueprintbe benne vannak, hogy felelevenuljenek de ahogy mondtad szerintem IE tanulassal ugyis atismetlodnek.
Akiii
hétvégi party
Akiii
Azt tudom, hogy az elso generacios ASAknal az 5505ben lehetett csak SVIt csinalni de az uj X generaciosban lehet valamelyikben? 5515-Xet forgatok es ugy nez ki, hogy nem viszont az 5512-Xrol sem talalok semmi infot vlan interfaceel kapcs.
valaki tudja esetleg?
Akiii
valaki probalkozott python tanulással? valami jo material?
Akiii
Akiii
Cyber_Bird
#6932
hopp azt kihagytam
Akiii
felmilliomodik ipv4 prefix
http://www.cidr-report.org/as2.0/
Akiii
Feco, mi lett a blogoddal? Valami privatra atkapcsolt.
Akiii
Letezik, h megse kell reboot ahogy régen v license fuggo? 3945E
%LICENSE-6-INSTALL: Feature hseck9 1.0 was installed in this device
Feature name Enforcement Evaluation Subscription Enabled
hseck9 yes no no yesmintha valami olyan remlene regebbrol hogy kerte a CLI hogy rebootold.
Akiii
http://www.collabcert.com/blog/uncategorized/ccie-lab-exam-resit-policy-changes/
policy change...
Akiii
valami ötlet, hogy miért szakad meg az adsl mindig amikor kimaxolom a 10megas vonalat torrental? Van egy ismerosomnek egy 10/1-e asszem T és akarhanyszor eljut max 1,2Mig a letoltes torrent eseteben random idokozonkent megszakad a pppoe.
Probaltam utorrenten belul levinni a maximum kapcsolatok szamat de no joy. Viszont ha a torrent kliensen belul lekorlatozom 500kb/sre es nem engedem, h kimaxolja a vonalat akkor nem szakad meg...
mit lehet ezzel kezdeni? ios upgrade?
Akiii
Ha ASA 8.2ről 8.4re ugrok iosben akkor automatikusan convertalja az uj nat sytaxokat vagy manualisan hozza kell adnom egyenkent ujra?
Akiii
sziasztok, melyik konyvet ajanlanatok CCIEhez ami egyszeru nyelvezeten es erthetoen segit QoSben?
köszi
Akiii
Cyber_Bird
#5272
Ezt a webinart lelehet valahonnan szedni?
Akiii
jerry311
#5079
nterface Serial0/0
bandwidth 34010
no ip address
rate-limit input 10000000 13000000 20000000 conform-action transmit exceed-action drop
rate-limit output 10000000 13000000 20000000 conform-action transmit exceed-action drop
encapsulation frame-relay IETF
dsu bandwidth 34010
serial restart-delay 0
frame-relay lmi-type cisco
end5 minute input rate 31931000 bits/sec, 5022 packets/sec
5 minute output rate 19078000 bits/sec, 4532 packets/sec -
Akiii
Cyber_Bird
#5077
input output ratere gondolok miert ir tobbet mint 10 mega ha egyszer rajta van a rate limit
Akiii
Ha egy 34megas E3on interfacen levan rate-limitelve a bw input|output 10megara viszont ha megnezem az interface statisztikákat akkor azt irja hogy 30megan fut akkor az valami ios bug?
Akiii
kristofkax
#4937
ha az UPDATE kodot hasznalod a ciscopress.comon akkor 35%al olcsobban tudsz vasarolni ev vegeig
Akiii
Cyber_Bird
#4200
köszi!
Akiii
valaki tudja a domain name OIDját? Mert idáig csak a sysName OIDon keresztul tudom lehuzni a domain nevet. Probalkoztam már ezzel 1.3.6.1.4.1.9.2.1.4 de nem nyert.
Akiii
PumpkinSeed
#3404
Kabel modem lesz. Van rajta DB9, Ethernet illetve Coaxkabel bemenetet. Nehez megmondani mennyit ér ird be googleba barmely rajta talalhato szamot.
Akiii
közbe megtalaltam
https://supportforums.cisco.com/docs/DOC-18983
+ The list does not include modules/blades for the Catalyst 4000/4500, 5000/5500, 6000/6500 although it is mentioned here that TDR was introduced with IOS Release 12.2 ZY for the Catalyst 6000/6500. It’s not included in the list above because I don’t have the resources to test and verify.
Legacy Cisco Catalyst models 1900, 2900XL/3500XL, 2940/2950/2955, 2948G and 2970 are not supported. Routers are also not supported. I do not have any resources to test router Ethernet Switch Modules (NME, HWIC, EHWIC). Wireless Access Points do not support TDR.
Akiii
A routerek nem forwardolnak broadcast by default, viszont ip-helperrel ahogy mondtad azt a bizonyos 8 servicet forwardoljak. Ha csak ip forward protocol 53ad van global modeban az meg egymagaban nem fog semmit sem csinalni. Az egyetlen módja a helper address.
Ha csak DNSt szeretnel forwardolni es a tobbi 7et nem akkor
ip-helper address x az interfacen
no ip forward-protocol udp 37
no ip forward-protocol udp 49
no ip forward-protocol udp 69
no ip forward-protocol udp 67
no ip forward-protocol udp 68
no ip forward-protocol udp 137
no ip forward-protocol udp 138 -
Akiii
Hedgehanter
#3299
Én mar csinaltam nem nagy ordongoseg csak az OIDokat kell pontosan beirni illetve a ReadWrite stringet hasznalni. Az utolso 3 szám jelent esetben 123 egy random szam viszont minden stringhez egyeznie kell!
snmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.2.123 i 1
The ConfigCopyProtocol is set to TFTPsnmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.3.123 i 4
Set the SourceFileType to running-configsnmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.4.123 i 1
DestinationFileType to networkfilesnmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.5.123 a <TFTP IP>
ServerAddress to the IP address of the TFTP serversnmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.6.123 s <Filename>
Sets the CopyFilename to your desired file name.snmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.14.123 i 1
Sets the CopyStatus to active which starts the copy process.snmpset -c <community> -v <version number> <device> 1.3.6.1.4.1.9.9.96.1.1.1.1.14.123 i 6
Sets the CopyStatus to delete which cleans all saved informations out of the MIB -
Akiii
Hedgehanter
#3295
Running configot lementeni szeretned snmp queryvel vagy atmasolni?
Akiii
zsolti.22
#3288
set ip next-hop
Van 2 next hop address ha az első kikerul a routing tablabol akkor probalkozik a masodikkal ha az is akkor figyelmen kivul hagyja a PBRt es a sima route tabla alapjan routeol
set ip next-hop verify-availability
Ez kb az ellentéte az a sima 'set ip next-hop'nak. Csinalsz sla-t, trackinget, schedulet majd amilyen modon szeretned hogy mukodjon a pbr olyan sorrendben egymas utan irod beirod a next hoppokat. Annyi a kulonbseg hogy itt a tenyleges elerhetőseget megtudja nezni a destinationnek es ha nem elerhető akkor atmegy a kovetkezőre és igy tovább . Ha az elsőt valasztod es nincs trackinged attol meg az interface up up lehet de viszont nem elerhető = black hole routing
PBRnél mindig megkell nezni az aktualis memoriát hogy mennyi TCAM van hozzarendelve a pbr folyamatokhoz sokszor elofordult mar, hogy core\dist switcheknel az alap templatet hagytam bent es reboot kellett hozza hogy desktop routingot kitudjam valasztani + mindig connectednek kell lennie az interfacenek. Remelem segitettem
Akiii
attila199207
#2964
Kurzus felesleges CCNAhoz, packet tracerezz vagy vegyel ebayrol egy lowcost routert switchet hogy mikent is nez ki a cisco cli. Egyedul CCIE bootcampben latok fantaziat meg nehany specifikus tréningben. CCNAtol ne vard a megvaltast mert csak egy alap felkeszultseget ad, hogy mi is a kulonbseg a switch es a router között kb de kezdesnek jo, viszont kurzus szinten ne adj ki rá pénzt ha csak nemtudod elszamolni valahogy.
Akiii
Hedgehanter
#2829
Itthon összesen 3-4 cég van ahol routing switching certekkel kulfoldi szinvonalu fizetest lehet kapni. Azok a szamok amiket irsz mind brutto szamok mellesleg.
Akiii
Akit érdekelne Franciaországban (Párizs mellett) level 2 network engineeres pozicio egy Cisco goldpartner cégnél, kiköltőzéssel illetve sok juttatással - írjon nekem PÜt.
CCNA alapkövetelmény
Akiii
Spa4aPaSWebr
#179
CCNPvel már lehet otthon talalni jopofa allasokat, CCIEt keves helyen kérik és nagyon rkevés helyen szukséges az a technologiai tudás.
Akiii
Mercutio_
#175
Semmit nem ad az Academy csak felkeszit a vizsgara aztan kalap kabat. A munkaltato nem az academys okleveled fogja nezni hanem a vizsgaidat es a tapasztalatot. Felre ne erts indulasnak tokeletes, hogy van hands on lab gyakorlatod es erdemes is beulni egy ilyenre de 2év szerintem sok. Jomagam a self studyt preferalom, videokkal, eszkozokkel egybekotve
Üdv
Akiii
JuiceCrew
#62
Configure, verify and troubleshoot a switch with VLANs and interswitch communications
Describe enhanced switching technologies (including: VTP, RSTP, VLAN, PVSTP, 802.1q)
Describe how VLANs create logically separate networks and the need for routing between them
Configure, verify, and troubleshoot VLANs
Configure, verify, and troubleshoot trunking on Cisco switches
Configure, verify, and troubleshoot interVLAN routing
Configure, verify, and troubleshoot VTP
Configure, verify, and troubleshoot RSTP operationInterpret the output of various show and debug commands to verify the operational status of a Cisco switched network
Implement basic switch security (including: port security, unassigned ports, trunk access, etc.)
Implement an IP addressing scheme and IP Services to meet network requirements in a medium-size Enterprise branch office network
Calculate and apply a VLSM IP addressing design to a networkDetermine the appropriate classless addressing scheme using VLSM and summarization to satisfy addressing requirements in a LAN/WAN environment
Describe the technological requirements for running IPv6 (including: protocols, dual stack, tunneling, etc)
Describe IPv6 addressesIdentify and correct common problems associated with IP addressing and host configurations
Configure and troubleshoot basic operation and routing on Cisco devices
Compare and contrast methods of routing and routing protocolsConfigure, verify and troubleshoot OSPF
Configure, verify and troubleshoot EIGRP
Verify configuration and connectivity using ping, traceroute, and telnet or SSH
Troubleshoot routing implementation issues
Verify router hardware and software operation using SHOW & DEBUG commands
Implement basic router securityImplement, verify, and troubleshoot NAT and ACLs in a medium-size Enterprise branch office network
Describe the purpose and types of access control lists
Configure and apply access control lists based on network filtering requirements
Configure and apply an access control list to limit telnet and SSH access to the router
Verify and monitor ACL's in a network environment
Troubleshoot ACL implementation issuesExplain the basic operation of NAT
Configure Network Address Translation for given network requirements using CLI
Troubleshoot NAT implementation issuesImplement and verify WAN links
Configure and verify Frame Relay on Cisco routers
Troubleshoot WAN implementation issues
Describe VPN technology (including: importance, benefits, role, impact, components)
Configure and vary PPP connection between Cisco routersEzek közul varhato
Akiii
Esetleg a Ph-n kivul ismertek valami magyar nagyobb cisco forumot?
Üdv,
- Kérlek használd a keresőt, mielőtt kérdezel!
- Olvasd el a téma összefoglalót mielőtt kérdezel!
- A dumpok és a warez tiltott témának számítanak!
- Dell Latitude 5530 i7-1255U 16GB 512GB 15.6" FHD TouchScreen Nagyakksis! 1 év teljeskörű garancia!
- Honor 200 256GB,Újszerű,Dobozával, 12 hónap garanciával
- BESZÁMÍTÁS! ASRock B450 R5 5600X 16GB DDR4 512GB SSD RTX 3060 12GB Zalman Z1 Plus Cooler Master 750W
- Lenovo L14 Thinkpad Gen2 FHD IPS i5-1135G7 16GB RAM 256GB SSD Intel Iris XE Win11 Pro WiFi6 Garancia
- Honor 200 Lite / 8/256GB / Kártyafüggetlen / 12HÓ Garancia
