zzeN
zzeN
Nicsak:
zzeN
zzeN
Mai "patch":
Mid Session Save
Fixed a bug which prevented car setups from being loaded correctly when a mid session save is created while on track in any session.Minor Fixes
Added a DRS Bleep sound to inform the player via audio that the DRS is available. This sound is quite subtle so that players who do not rely on this are not distracted, you may need to lower the engine volume and raise the effects volume to make this clearer during gameplay.The above fixes (where relevant) for the Xbox 360 and PS3 versions of the game are currently being tested and verified. These require additional submission and authorisation from Microsoft and Sony so the release date for these will follow a little later than the PC version.
zzeN
mikrosuttii
#838
Ez milyen felbontás? Eléggé nyúlt.
zzeN
Igen, a változtatások:
PC FPS Issues:
- We’ve made further improvements to the PC FPS issue whereby higher specification PC’s had a considerable lap time advantage over lower ones. The difference now should be negligible and should allow fair competition between all players. Again we are aware this is a hot topic and will continue to monitor the forums for feedback once this fix is live.
- At 30+ FPS the track will now rubber in.Minor Fixes:
- In Online Custom Races AI cars that have retired will now be removed from the track correctly.
- Improved AI replication on high latency / low bandwidth connections in Online Custom Races.
- Corrected Professional and Expert AI difficulty on Sakhir (Bahrain) & Monza.
- Fixed an issue where on certain hardware all menus would be black.
- Force feedback settings have been tweaked to remedy the mid corner ‘dropout’ that some players were reporting.The above fixes (where relevant) for the Xbox 360 and PS3 versions of the game are currently being tested and verified. These require additional submission and authorisation from Microsoft and Sony so the release date for these will follow a little later than the PC version.
zzeN
zzeN
bandika0626
#168
Vedd meg és jó lesz
zzeN
--Lorant--
#162
Ha Európán kívül veszed meg és itt akarod beregisztrálni, akkor nem hinném, de erősítsen vagy cáfoljon meg valaki. Ami biztos, hogy ha magyar boltban veszed meg az működni fog.
zzeN
Ahogy tegnap írtam (úgy látom senki se látta) régió független, tegnap vettem tőlük meg a játékot.
- Bittorrent topik
- Építő/felújító topik
- Melyik tápegységet vegyem?
- OLED monitor topic
- Intel Dual Core 2000 felhasználók barátságos offolós topikja
- Cyberpunk 2077
- Samsung kuponkunyeráló
- Samsung Galaxy Note20 Ultra 12/256GB
- Samsung Galaxy S22 Ultra 12/256GB Újszerű,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Garanciával!
- Thinkpad T14 Gen6 14" FHD+ IPS érintő Ultra 7 265U 16GB 256GB NVMe ujjlolv IR kam gar
- Disney gyerek elefántos falióra
- Dobozos Új HP OmniBook 5 Flip 2-in-1 érintőkijelzős laptop i5-1334U 16gb ram 512ssd Garancia
- BESZÁMÍTÁS! MSI B450M R3 4100 8GB DDR4 240GB SSD GTX 1050Ti 4GB Asus Vento AD DeepCool 400W
- GYÖNYÖRŰ iPhone 13 Mini 256GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS4647, 100% Akkumulátor
- Apple iPhone 15 Plus 128GB, Kártyafüggetlen, 1 Év Garanciával
- Alienware 17r4 olvass
