Debian GNU/Linux
Drótszamár
bambano
#7123
Igen, ezeket magamtól is berakhattam volna
Időközben annyi történt, hogy töröltem a konfigot, és visszatettem a régit, hogy legalább a wifi működjön.
ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:1e:06:cd:68:aa
inet6 addr: fe80::21e:6ff:fecd:68aa/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:300 (300.0 B) TX bytes:4663 (4.6 KB)
Interrupt:40
ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1452 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:43 errors:0 dropped:0 overruns:0 frame:0
TX packets:43 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3788 (3.7 KB) TX bytes:3788 (3.7 KB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
wlan0 Link encap:Ethernet HWaddr 00:e0:4c:81:7d:b3
inet addr:192.168.1.220 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::2e0:4cff:fe81:7db3/64 Scope:Link
RX packets:2028 errors:0 dropped:485 overruns:0 frame:0
TX packets:400 errors:0 dropped:2 overruns:0 carrier:0
RX bytes:717232 (717.2 KB) TX bytes:152217 (152.2 KB)
wlan1 Link encap:Ethernet HWaddr 02:e0:4c:81:7d:b3
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:5537 overruns:0 frame:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0interfaces:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
dns-nameservers 8.8.8.8 8.8.4.4
wpa-ssid halo_neve
wpa-psk xxxxEzen felül van egy ip kamera, aminek 192.168.0.9 az IP címe.
Ezt dugnám az eth0 portra. Erről kéne képeket lementeni, és továbbítani wifin.Ha a lentit beteszem a konfigba, akkor wifin ugyan kap ip-t, de többet nem lehet rajta kívülről elérni. Még pingre sem reagál.
auto eth0
iface eth0 inet static
address 192.168.0.8
netmask 255.255.255.0Mit csinálok rosszul? Mit hagyok ki?
Drótszamár
Egy kis segítség kéne wifi + kábel témakörben.
Odroid C1 ARM procis "kártya" pc + Debian. (asszem 8.0)Egy USB-s wifi adapterrel kapja a netet. Boot után automatikusan felcsatlakozik a hálózatra.
Egy IP kamerát szeretnék rádugni a LAN portjára, és onnan percenként képeket szeretnék továbbítani wifin a netre.A kamera kapott egy fix ip címet (192.168.1.9).
A wifin az eszköz 192.168.0.x-es címet kap.
Beállítottam, hogy a LAN port címe fix legyen (192.168.1.8)
Amint ezt beállítom a wifi megszűnik működni. IP-t még kap, de olyan mintha a LAN beállítása után minden forgalom a LAN felé indulna el. Próbáltam default gatewayt állítani, próbáltam statikus útvonalakat felvenni, de a végére már kb semmi sem működött
Mit és hogyan kell ehez beállítani?
Én úgy gondolom, hogy a wifi-nek kéne lennie a default gateway-nek, és kéne egy statikus útvonal, hogy a 192.168.1.9 felé az eth0-án induljon el. Vagy esetleg már ez az elgondolás is hibás? Kell az eth0-nak a kamerával egyező címtartomány?Ha más nem veszek egy routert, és azon keresztül összedugom őket, de jó lenne kihagyni.
Hú kicsit kusza lett, remélem érthető mit szeretnék.
- Google Pixel topik
- Szerkesztett és makrofotók mobillal
- Eredeti játékok OFF topik
- Samsung kuponkunyeráló
- Horgász topik
- The Elder Scrolls Online Imperial Collector s Edition
- Apple iPhone 15 Pro Max 256GB,Újszerű,Dobozaval,12 hónap garanciával
- Azonnali készpénzes AMD Radeon RX 7000 sorozat videokártya felvásárlás személyesen/csomagküldéssel
- GYÖNYÖRŰ iPhone 14 Pro 128GB Deep Purple -1 ÉV GARANCIA - Kártyafüggetlen, MS4677
- Értékcsökkentett gamer alaplapok /ASUS/MSI/AM5/Számlával/
- Telefon felváráslás!! iPhone 15/iPhone 15 Plus/iPhone 15 Pro/iPhone 15 Pro Max
