Sztojcsi
A probléma az volna hogy mikor próbálok nero7-tel írni egy dvd-t ami daemon toolsból van bemountolva akkor rögtön az elején azt írja hogy hiba van. Ha elmentem akkor ezt írja:
18:16:07 #15 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 4x (5 540 KB/s)
18:16:07 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
18:16:07 #17 Text 0 File Cdrdrv.cpp, Line 8411
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: SONY....
Media type ID: D21
Product revision number: 0
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 53 4F 4E 59 00 - 00 00 00 44 32 31 00 38 ...SONY....D21.8
23 54 37 14 00 28 6E 00 - 80 69 17 19 0C 0C 0A 0B #T7..(n..i......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
18:16:07 #18 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: Yes
18:16:09 #19 CDR -1 File Writer.cpp, Line 302
Unspecified Recorder Error
E: ASUS DRW-1604P
18:16:09 #20 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:16:09 #21 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
18:16:26 #22 Phase 127 File dlgbrnst.cpp, Line 1725
Generating DVD high compatibility borders
18:16:26 #23 CDR -1 File WriterStatus.cpp, Line 167
E: ASUS DRW-1604P
18:16:26 #24 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
18:16:26 #25 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 4x (5 540 KB/s)
Már újrainstalláltam a windows-t, frissítettem az író firmware-jét, újratelepítettem a daemon tools-t és a Nero-t is, más verziójukat is vissza raktam és hardware-es hiba sem lehet mert a másik gépen is ugyanezt csinálja.
Már több dvd-t is elrontottamm így. Könyörgöm valaki segítsen.
- The Elder Scrolls Online Imperial Collector s Edition
- Apple Watch Series 10 46mm Jet Black használt karcmentes 100% akku garancia 2026.10.26.-ig
- 134 - Lenovo Legion Pro 7 (16IRX8H) - Intel Core i9-13900HX, RTX 4090
- szinteÚJ Lenovo ThinkPad L14 Gen5 i7 155U 32GB 1TB FHD+
- iPhone 17 Pro 256 GB Silver - Bontatlan !! www.stylebolt.hu - Apple eszközök - Számlás
- Lenovo LEGION 5 PRO Ultra 7 255HX 24GB RAM 512GB SSD RTX 5070 8GB 16" QHD+ 3év Prémium GAR
