Témaösszefoglaló
rtitusz
rtitusz
rtitusz
rtitusz
Ingyenes fekete paintjob az összes hajóra minden előrendelőnek!
Black Ships for Black Friday: 29 free black paint jobs for all those that pre-order Horizons.
As part of our Black Friday sale we’re adding an Elite Dangerous: Horizons pre-order incentive. Every Commander who pre-orders Elite Dangerous: Horizons before Tuesday December 1 at 6PM GMT will get an in-game black paint job pack called Midnight. Don’t worry, all Commanders who have already pre-ordered Horizons, including those with the lifetime expansion pass, and those with Horizons beta access, will also be given the Midnight paint job pack.
With this pre-order offer you’ll get 29 black paint jobs in the pack – that’s one for each ship in the game! (excluding those in CQC).
This pre-order incentive will be withdrawn after 6PM GMT on Tuesday December 1 - so make sure you pre-order Elite Dangerous: Horizons now to get your free Midnight paint job pack. Those who take advantage of this deal will have the pack waiting for them in-game when Elite Dangerous: Horizons is released.
We’ve got some brand new merchandise and paint jobs available in store, so make sure you don’t miss out.
Our Black Friday Sale starts today and will end on Tuesday December 1 at 6PM GMT.
rtitusz
warcat
#18016
Ezt csak a magyar virtus mondatja velem, de tegyük fel megveszem leárazva Steam-en, majd megveszem a Horizonst a frontier oldalán amire megkapom a 10 euró loyalty kedvezményt és akkor kb ugyan ott vagyok, mintha csak a Horizonst vettem volna meg, de megkapom a CobraMK4-et és már most játszhatok vele.
rtitusz
rtitusz
Diopapa
#17965
Nincs holnap béta, tegnap írta Braben a fórumra, hogy váratlan problémába futottak és amíg azt nem oldják meg addig nem lesz béta.
"The team are still hard at work on the Horizons beta, including yesterday and today (Sunday). A huge thanks to the team for this, and for those that sent us pizza. Unfortunately the issues last week have compressed the timescales, but the game is looking ever better. This has put the Tuesday beta release at risk, and though Tuesday is still theoretically possible, in all likelihood it will be in the following few days before we can release it.
While playing today I took this video (unedited) – an extra ‘sneak peek’ – landing a Vulture outside Kaleri Oasis in the Teppani system and deploying an SRV– with me messing around in solo. Again some issues, which I won’t list here."
rtitusz
rtitusz
Ide lessetek. GIF
rtitusz
rtitusz
Cooper911
#17933
Robigo Mines outpost mellett van egy állig felfegyverzett konda és az oda érkezőket lövi ki nagy szeretettel, pont le tudtam szállni 24% hull-al. Szegény felfedező Asp-omon a pajzsot nem player konda ellen terveztem. Vigyázzatok arrafelé. Eddig még nem találkoztam vele. Biztos nincs jobb dolga.
rtitusz
rtitusz
rtitusz
rtitusz
Új válalkozásom:
Milliárdos birodalmi arab Elite sejkeknek árulok speciálisan átalakított iCuttert kalózkodáshoz.
Ajánlott fogyasztói ára: 1 674 299 550,- Cr (csak a készlet erejéig), melyre most a biztosítás akciósan csupán 83 714 978,- Cr.Szerintem ezek venni fogják mint a cukrot.
Itt a brossúra, ha valakit érdekelne:
Burzsuj Kalóz - coriolis.io -
rtitusz
undercover
#17800
MC-ből nincs C3, nem jó ötlet kisebb fegyvert felrakni mint amit fel lehet.
rtitusz
Pár új infó a Horizonsról:
https://forums.frontier.co.uk/showthread.php?t=201524&p=3117483#post3117483
Módosul a gépigény, 64 bites oprendszer kell majd hozzá.
rtitusz
undercover
#17731
Hiszem ha látom, egyelőre csak egy gigantikus pénzmosásnak és lehúzásnak tűnik az egész. Mutassanak ingame videókat, ne csak rendelet csodákat. Addig játszom az Elite-el, az legalább kész van. Ha kijön és jó lesz a SC akkor megveszem azt is, de látalanba nem fektetek bizalmat a cégbe.
rtitusz
rtitusz
#25-ös hírlevélben volt anno egy ilyen HUD concept. Most hogy lassan akkora egy hajó mint a levélbedobó, lehet nem ártana.
rtitusz
Új Beta update, SCB-k kicsit finomítva, heat sink erősebb, stb. ÉS FDL BUFF!!! Lehet veszek újra!
Hello Commanders!
In the next beta update, we'll be making some adjustments. I'll briefly explain each one, and the reason behind it.
1. We are doubling the length of time a shield cell provides shield regeneration benefit. This effectively makes shield cells stronger, mitigating *slightly* the need for cell stacking.
2. We're retaining the heat penalty for cell use, but improving heat sink effectiveness. So you can still stack cells, as long as you are able to spend the heat sinks.
3. We're adding a small amount of damage reduction to hull reinforcement packages. These are additive and increase the effectiveness of the packages (including module protection, as the damage reduction gets applied before modules are hit).
The end result of this is to make both shield cells and hull reinforcement packages viable, but not without cost. Fundamentally, using a shield cell should fry your systems a little, but can be managed with heat sinks to avoid massive hull damage (module damage from heat, is in general. quite light, even though the feedback is a little startling).
In addition:
4. We've increased the amount of SYS power a collapsed shield can "suck" to reform quite a bit, especially at higher classes. The effect of this is that large shields should reform significantly quicker, around a third of the time it would take before, in the best cases.
5. Zorgon Peterson has offered all of its FDL customers a free upgrade kit: slight improvements pitch and roll rates, a larger power plant housing (size 6) and more efficient cooling systems.
As with always, I look forward to your feedback.
To help manage this thread, please provide a heading comprising of SHIELD CELL, HULL PACKAGE, SHIELD GENERATOR or FDL as appropriate with your response (you can talk about multiple points, just use multiple headings).
rtitusz
A föderáció és a birodalom közreműködésével, bemutatom a CorvetteCutter-t!
rtitusz
Pajzs nélküli Corvette vs 2 iCutter:
https://www.youtube.com/watch?v=YMKOWI4IGJQ -
rtitusz
CactuS
#17498
A Corvette kifér kikérem az egész FED nevében, a föderációs mérnökök tudják hogyan kell használni a mérő szalagot, nem úgy mint a birodalmiak.
Nem kell ide semmi nerf, azoknak a hajóknak a biztosítása is 30-50 millió között lesz. Ha nem tudnál velük pénzt keresni, senki nem használná.
rtitusz
gigafun
#17496
Még szép, hogy tudnék írni! Mozgékonysága a Cuttert a földbe döngöli, kis virgonc mint egy Eagle, gyors mint egy Cobra, tűzereje mint 10 Anacondának. Aki nemhiszi, annak utána megyek a Corvetteemmel. De majd csak ha kijött az 1.5. NINCS BÉTÁM. (Ezt nem kellett volna elárolnom, most hogy lódítok tovább?)
Komolyra fordítva a szót, én csak annyit tudok, amennyi információt a különböző helyeken felcsíptem. Fordulékonysága az Anacondánál picit jobb (a Cutter olyan mint a T9), sebessége kb. Konda, ugrótáv siralmas, pajzs elég jó, Hull brutál (FED, mit vártunk?). Kicsit meleg szegény, a két C4 plazmával csak óvatosan, SCB-t meg kerülni.
Még egyszer mondom, nincs bétám!
rtitusz
Arra az esetre, ha a SCB nem lenne opció a végleges 1.5-ben, itt egy alternatív Federal Corvette outfit, 1492MJ Bi-Weave Shield, 3035 Armour.
rtitusz
Meleg van.
Cutter + SCB -
rtitusz
És van pár új textúra, nézzétek a hajó sebződését.
https://www.youtube.com/watch?v=g0ucRdk_omIValamint van új típusú Shield Generator!
Bent vannak az új hajók és modulok az ED shipyardban. A Cutterre elég brutál pajzsot lehet csinálni, 2900MJ!!!
rtitusz
1.5 Beta HRP értékek:
5D: 390
5E: 360
4D: 330
4E: 300
3D: 260
3E: 230
2D: 190
2E: 150
1D: 110
1E: 80 -
rtitusz
Valami eltűnt a lábunk közül.
Valamint az új HRP-k kicsit OP-k lettek, lesz még ebből nerf.
És ha valaki lemaradt volna róluk, vannak BOBBLEHEAD-ek!
https://www.youtube.com/watch?v=qezfJg9eE84&feature=youtu.be
rtitusz
Ebből a szempontból pont mindegy, mert az Elite küldiket csak Elite-ként veheted fel, és ha Elite vagy, akkor van permited. Csak azt nem értem, hogy miért baj, ha más állomás is ad Elite küldiket? Ennek így semmi értelme, vagy én értek valamit nagyon félre.
Más: Nézzétek az Anaconda ugrótávját a Level 3 FSD Boost-al!!!
rtitusz
Olvasom a changelogot, ezt a sort nem értem. Mármint azt nem értem hogy miért. Mi értelme változtatni?
"Elite/Founder missions are now only available at the Founders World"
rtitusz
Nem hinném, hogy I/O probléma, mikor a Windows SSD-n van. Hálózati lehet, mert p2p az hagy némi kívánnivalót maga után, hába a 240/20-as net. A lag mindig bolygóközelben van, és kb ugyan ott minden alkalommal (már amikor van, mostanában nem tapasztaltam), tuti a játék a ludas.
rtitusz
undercover
#17389
Openben gyakrabb, és GTX980Ti alatt is akad néha pillanatra. Tudják a fejlesztők, és már sokkal jobb mint korábban volt, de még van mit csiszolni.
rtitusz
Csak akkor boostol a VGA (nVidia) ha szükség van az extra teljesítményre. Az elite nem egy nagy gépigényű játék, hacsak nem 4K-ban 2x DSR-el (16K) játszol.
Nekem az nVidia kártyám egyszer crashelt csak, de akkor véletlenül az egekbe volt tolva az OC mert előtte tesztelgettem.
rtitusz
rtitusz
Új videjó!
Sneak Peak: Imperial Cutter and Fortified Starport
"Here’s another unedited sneak peek dev video. There are some streaming issues and the starport lighting is not final, plus some other things. The team is hard at work getting 1.5 out (likely tomorrow), so this is just me this time. I thought people hadn’t had a good look at the Imperial Cutter, so here is some more of it, and a little something else too – the first look at a fortified starport."
rtitusz
Folytatódik a bázisépítés!
Trade CG-hez ajánlott a Wilcutt Station a Dietri rendszerben. Van bőven készlet raktáron.
rtitusz
Azok a régi szép idők... Anaconda 7 Railgunnal.
rtitusz
gigafun
#17279
Ingyen volt, és buta fed agyam csak az AKCIÓS táblát látta. Pont az az eset, hogy csak azért vetted mert akciós.
Azóta is a Founders World-ön porosodik az alaphajó, mert költeni már nem költöttem rá egy dekát se, de még csak ki se vittem a szalonból, nulla fényéves még a jószág. Próbakört se mentem. -
rtitusz
Vigyázzatok, nehogy kipukkanjon!
rtitusz
undercover
#17268
Ha Openban játszol, lehet hogy egy másik játékos ellopja tőled a killt mert ő lő bele utoljára.
rtitusz
Csinálja most valaki a mostani Combat Zone-os CG-t? Azt se tudom mikor lesz vége. Két napja nem tudtam belépni, anno a 17 milliómmal benne voltam a top 5%-ban.
Cooper911, lehet rosszul tudom, de tudtommal a limited time csak a £10 kedvezményre vonatkozik, a Cobra utána is jár.
rtitusz
Cooper911
#17212
Mindegy mikor veszed, ha megvan az alapjáték és a Horizons is külön akkor megkapod. Valamelyik streamben mondták, hogy ha valaki most megveszi a Horizonst hogy belekezdjen az Elitebe és mondjuk egy év múlva rájön, hogy kell neki az MK4, megveheti az alapjátékot és megkapja. Nem mintha ennek bármi realitása lenne.
rtitusz
undercover
#17210
1.5-el jönnek az új hajók, megkapják az alap játékosok is. Egy kivétel van, a Cobra MK4, azt csak azok vehetik, akiknek az alapjáték és a horizons is a tulajdonukban van.
rtitusz
rtitusz
Federal Corvette - https://www.youtube.com/watch?v=choK7Z4FXSQ
Imperial Cutter - https://www.youtube.com/watch?v=INLcyPZgY68
Asp Scout - https://www.youtube.com/watch?v=n9rkd1j1IzI
Keelback - https://www.youtube.com/watch?v=ysYDnyr13sA
Viper MK4- https://www.youtube.com/watch?v=h52lCL9r964
Cobra MK4 - https://www.youtube.com/watch?v=D_hw1RCTOd4Bónusz:
Landed Federal Corvette viewed from an SRV - https://www.youtube.com/watch?v=E8iNq2LI0g0Szerk: Ez nem sokon múlt.
rtitusz
Imperial Cutter. Pfffffffffffff.
Meg is érdemli a birodalom.
Mondjam a legjobbat? A két Huge HP a két szárnyon van, a két fix fegyverrel már olyan kicsi dolgokat is eltaláltok majd mint egy bolygó.
rtitusz
Kész, én beleszerettem a Federal Corvetteba! 2xC1, 2xC2, 1xC3, 2xC4
rtitusz
Jönnek új Large és Huge fegyverek! Kérlek FD, adjál nekem egy Class 4 Multi-Cannont! Lécci!
rtitusz
undercover
#17156
Na akkor elmondom mi miért van úgy abban amit ajánlottam.
- Military Grade páncél a legjobb általános sebzésre, 50%-al redukálja a sebzést minden típusú találat esetén. A reactive 75% védelmet nyújt ugyan a kinetikus behatás ellen, de csak 25%-ot a termikusok esetében. A mirrored ugyan az mint a reactive, csak itt a termikusra ad 75% védelmet, és 25-öt a kinetikusra.
- Thruster, Power Plant, Power Distributorból a legnagyobb "A"-t érdemes venni harci hajó esetén, ezt nem részletezem jobban.
- Life Supportból az aktuális lehetőségeidhez mérten a legjobbat érdemes, de minimum D-s modult. Itt lehet spórolni az energián.
- Sensore-ból minél nagyobb hatótávút érdemes ugyan, de az "A"-s sokkal több áramot eszik mint a "C" és alig látsz vele távolabra, a célnak a C is megfelel, spórolsz vele energiát.
- Shield Generatorból a legnagyobb A-s modult kell venni harci gép esetén, utána pedig a maradék nagy modulok helyére Shield Cell Banket érdemes rakni. A SCB azért B-s, mert untig elég és egyel több töltet van benne, valamint kevesebb energiát eszik.
- Fuel Scoopon nem érdemes se helyet se helyet se pénzt spórolni, ha menni kell valahová megmentheti a hajódat, amúgy meg sok vizet nem zavar.
- Hull Reinforcement Package helyett rakható fel SCB is, Discovery Scanner is, ami tetszik.
- FSD Interdicotor nem kötelező, de egy harci hajóra szokás rakni, sok pénzbe kerül, te döntöd el kell-e, használhatod a helyet másra is.
- Hardpointok: a két medium Multi-cannon nagyon szépen bontja a hullt és a modulokat, a két small Beam Laser pedig tökéletes pajzs ellen.
- Kill Warrant Scannert ki nem szabad hagyni egy harci hajóból, kivéve ha Combat Zone-ra építed. Ott nem kell.
- Shield Booster. Jelenleg hasznosabb mint a Chaff vagy bármi egyébb amit oda felpakolhat az ember, érdemes választani, ha beleférsz az energia limitbe.
A két SCB közül mindig csak egy aktív, így van elég áram. Ha kifogy, a jobb panelen a modulok alatt átkapcsolsz a másikra.
rtitusz
undercover
#17154
RÉSZLETES, FOLYAMATOSAN
FRISSÜLŐ FAQ
AZ ÚJ JÁTÉKOSOKNAK
- Telekom mobilszolgáltatások
- GoodSpeed: Te hány éves vagy?
- Elden Ring
- Projektor topic
- Fotók, videók mobillal
- Építő/felújító topik
- Motorola Edge 50 Neo - az egyensúly gyengesége
- Apple iPhone 17 Pro Max – fennsík
- Apple iPad Smart Keyboard magyar
- MSI CreatorPro Z16P RTX A5500 TOUCH! (vapor chamberrel)
- Xiaomi Redmi Note 12 Pro+ 256GB,Átlagos,Dobozaval,12 hónap garanciával
- AKCIÓ! LG UltraFine 27" 5K IPS 99% DCI-P3 1 év garancia
- GYÖNYÖRŰ iPhone 14 Pro Max 256GB Space Black-1 ÉV GARANCIA - Kártyafüggetlen, MS4143
Az A-B-A kereskedés nekem nem megy.
![[link] [link]](http://scavenger.ch/images/Games/Elite:Dangerous/16K/HighResScreenShot_2015-11-12_20-04-38.jpg)
