Emsisoft Anti-Malware
ƵøŁĭ
New in 2020.11: Key performance indicators, push notifications and more
This month’s release adds significant workplace efficiency improvements for security admins who manage the malware protection of multiple devices.
Unresolved issues
The first tile is displayed in red if there are any unresolved issues with any of the devices in your managed workspace, such as missing updates or disabled protection components.
Detected threats
The second tile provides a quick overview of recent findings from the past 30 days. Click on the tile to filter the device list to show only affected devices.
Quarantined objects
The third tile shows how many malware/unwanted program findings are currently in quarantine on all of your devices. Click the tile to see the affected devices only.
New push notifications
We’ve added a new setting to your user profile that allows you to enable push notifications. When enabled, your operating system will alert you about critical security events in your workspaces.
New System Security settings & policies
You can now use protection policies to turn the Windows Firewall, the RDP Service and the RDP monitoring on and off for groups of devices. Find the new settings near the bottom of the policies list. Firewall and RDP can either be turned on, off, or left as is it.
All 2020.11 improvements in a nutshell
Device protection (desktop)
- Several minor tweaks and fixes.
Management console (web app)
- New key performance indicators in Workspace dashboard.
- New push notifications for important alerts.
- New System Security settings & policies.
- Improved overall usability.
- Several minor tweaks and fixes. -
ƵøŁĭ
ƵøŁĭ
Emsisoft Anti-Malware 20.6
- New support and verification of Emsisoft Browser Security for Chromium-based Edge browser.
- Improved ‘remote-only’ management mode.
- mproved remote deployment support.
- Improved connectivity with Emsisoft Cloud Console.
- Improved integration with Windows Security Center (new ELAM support).
- Removed redundant frequent notifications for detection pattern updates.
- Several minor tweaks and fixes.MyEmsisoft/Cloud Console
- Improved remote deployment support, showing more progress details and fine-tuning usability.
- New ‘What’s new’ side panel that informs about feature updates.
- New auto-detection for bright/dark system modes.
- New ‘All devices’ list in ‘Workspaces’ dashboard.
- Improved device-level logging.
- Cleanup of redundant settings.
ƵøŁĭ
All 2020.4 improvements in a nutshell
- New Active Directory synchronization for users and devices.
- New support for installation on Windows Servers in Emsisoft Business Security plan.
- Improved protection from unauthorized uninstall.
- New remote deployment through relay devices in Active Directory.
- New support for user permission policies on single user level.
- New notifications for protection uninstalls.
- New Dark Mode for the entire console.
- Improved user signup process.
-Improved usability of workspace dashboard.
-Several minor tweaks and fixes. -
ƵøŁĭ
New in 2020.2: Bye Surf Protection, welcome Web Protection!
All 2020.2 improvements in a nutshell
Emsisoft Anti-MalwareChanged ‘Surf Protection’ to ‘Web Protection’.
New feature to specify custom update feeds for testing.
Improved window design.
Restructured and extended events for email and webhook notifications.
Improved user permissions handling.
Improved workspaces dashboard UX.
ƵøŁĭ
Emsisoft 2020
- New color-coded menu badges.
- New authenticator support.
- Improved app restart behavior on scanner findings.
- Improved window design.
ƵøŁĭ
ƵøŁĭ
ƵøŁĭ
ƵøŁĭ
internetezoo
#118
Én az angol kezelőfelületet használom.Biztosan jön még egy hotfix ,mert van beta 2 is.Dark mode is később jön ki hozzá.Nekem mondjuk csalódás lett ez a frissítés.
ƵøŁĭ
Új verzió megjelent.
ƵøŁĭ
Emsisoft Anti-Malware hálózat weboldala megszűnt.
( https://www.isthisfilesafe.com/) -
ƵøŁĭ
Következő frissítéssel egy új kezelőfelület érkezik.
ƵøŁĭ
Megnézem,hogy mutat..
Az Emsisoft gyökerei 1999-ig vezetnek vissza ,amikor Christian Mairoll vezérigazgató életét megkeserítette egy trójai vírus.Nem hátrált meg és úgy döntött utána jár a dolgoknak így megírta az Emsisoft alap kódját.2003-ban a hobbiként indult program írás eredményeket produkált.Mára a világ egyik vezető védelmi megoldása lett amely törekszik az online támadások kivédésre illetve felhasználók igényeinek kielégítésére.
Fontos személyek:
◾Christian Mairoll - alapító
◾Fabian Wosar - kutatási vezető
◾Davlat Aminov - értékesítési vezető
◾David Biggar - ügyfélszolgálati vezető
◾Támogatott operációs rendszerek(32/64bit)
- Windows 7
- Windows 8.1
- Windows 10 -
ƵøŁĭ
Én is megkaptam a kedvezményt.Három gép esetén már csak 1350Ft/db árra jön ki.
ƵøŁĭ
ƵøŁĭ
ƵøŁĭ
Emsisoft Anti-Malware 2018.1.1.8439 released. This release includes fixes, enhancements and stability improvements.
This update will require an application restart.
- Fixed: Issue with scanning of removable device connections. -
ƵøŁĭ
Emsisoft Anti-Malware 2018.1.0.8388 – with BETA updates enabled:
New: Redesigned Behavior Blocker panel that combines application rules with active application processes.
New: Simplified application rules editor that integrates with the ‘Exclude from monitoring’ list.
New: Application rule templates with wildcard- and environment variables support, to be defined via Emsisoft Enterprise Console.
New: Ability to connect Emsisoft Anti-Malware with Emsisoft Enterprise Console via script for automation.
Improved: Forensics log view settings are now automatically saved.
Fixed: Crash when starting a scan from the tray-icon.
ƵøŁĭ
Emsisoft awarded VB100 certification in latest Virus Bulletin test
The good people over at Virus Bulletin, an information security portal and antivirus testing group, recently announced the results of their latest VB100 Comparative Review. We’re happy to report that Emsisoft Anti-Malware was awarded the VB100 certification! -
ƵøŁĭ
Összefoglaló később.
- Dell Precision 7750,17.3" FHD,i7-10875H,32GB DDR4,256GB SSD,RTX 3000 6GB VGA,WIN11
- BESZÁMÍTÁS! Asus ROG Strix B365 i5 9400F 16GB DDR4 512GB SSD RTX 2060 Super 8GB Zalman S2 TG 600W
- 263 - Lenovo ThinkBook 16p (G6 IAX) - Intel Core U9 275HX, RTX 5060
- HP EliteBook 830 G8 13,3" i7 -1185 G7, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
