Kraptor
Én nyomo, mondjuk elég nagy szünetet tartottam és most csak 60 vagyok. Igen Rise of Kunark tartalmazza az alap játékot és az összes kieget, az adv packokat nem.
Mondjuk elég jót tett az idő EQ2nek, szerintem sokkal élvezetesebb lett mint volt, mondjuk csak PvE téren PvP nem neki való.Hoppá, tévedtem tényleg jön az összes adv pack is vele. Ha nem nyomta még valaki EQ2 vel akkor most érdemes beszállni.
Kraptor
Satan_Claus
#1939
Platinumodat nincs kedved ingyé oda adni?
Én mindig is csóró voltam Eq2ben...valahogy sose gyütt a lé... -
Kraptor
Drachoo
#1763
EQ II Firewall Information
Sony Online Entertainment does not support the use of firewalls and proxies, including cable/DSL NAT routers, campus and office networks, or any type of Internet connection sharing services. However, in an effort to assist you in configuring your systems on your own, we would like to provide the following information which may help you in setting up your firewall to work with EverQuest II.
EverQuest II LaunchPad and Patch Servers
A TCP connection is initiated from the LaunchPad client port > 1023 to patch.station.sony.com at port 7000.
A UDP connection is initiated from the LaunchPad client port > 1023 to sdlaunchpad1.station.sony.com and sdlaunchpad2.station.sony.com port range 3016-3021 and 9700-9703.
EverQuest II Patch:
A TCP connection is initiated from the EverQuest II client port > 1023 to patch.everquest2.com, ablpatch.everquest2.com, abepatch.everquest2.com, or rrpatch.everquest2.com at port 7010
Everquest II Game Client
UDP connections are initiated from the EverQuest II client port >1023 to servers on UDP ports 9100, and UDP ports in the range 32800-33000
Additionally, ICMP messages type 0 (echo reply), 3 (unreachable), 8 (echo request) and 11 (expired) should be permitted bi-directionally between the client PC and the EverQuest II servers.
EverQuest II Servers Subnets
There are multiple IP addresses for the Patch and LaunchPad clusters, and they may change as the network demands, so check often using a DNS lookup tool if you provide a specific firewall rule for these services. The EverQuest II server IP addresses are currently in these subnets: 64.37.158.*, 199.108.13.*, 199.108.12.*, 199.108.202.*, 199.108.203.*, 195.33.135.* -
Kraptor
wolverine375
#1718
Ez a játék is beletartozik majdnem abba a katba, de ennyi pénzt megér szerintem
Kraptor
ImpersonatoR
#1633
Hát igen ez halott ügy
Próbálj meg rákeresni, hogy EQ2 client és hátha letudod valahonnan tölteni -
Kraptor
ImpersonatoR
#1549
Nekem is hasonló a konfigom, ugyanaz a proc én 3Gn hajtom és GTx a kártya. Én high qualitiben futtatom a játékot úgy, hogy shadow mind kivan nyomva ez elég sokat segít meg pár effektek amik nem nagyon tetszettek, pl ruha animációja, extra lightning mikor esik és hasonlók víz felszinnel nincs interaction a leggyorsabb víz rajzolás van, stb. AMi még sokat tud segíteni az a fények visszábbvétlel, mennyi fény legyen egyszerre megrajzolva, milyen legyen a minősége, stb.
Azt se felejtsd, hogy mikor sokan vagytok egy helyen akkor lag miatt szokott néha akadni és nem csak a géped miatt.
[Szerkesztve] -
Kraptor
Valahogy meglehet kerülni és nem kell rögtön megadni GCr vagy hitelkártya számot. Több emberkének is sikerült itt azért kérdeztem énis rá az elöző oldalon lévőtől.
Dark Elf az nem az igazi harcosnak, ez nem azt jelenti, hogy nem lehet harcos csak, hogy nem olyan jól fogja byrni a gyűrődést és hamarabb kipurcan mint egy Ogre mondjuk.
eq2.budo.hu ra gyertek ott a forum valamivel élénkebb is mit itt. -
Kraptor
Eq2t már 2.5Kért lehet kapni
Ez tartalmazza az 1 hónapot is
Lol lassan érdemesebb megvenni minden hónapban a szoftvert mint a gamecardot, mondjuk kíváncsi vagyok, hogy hozzá lehet e adni mint csak havi fizetést.
[Szerkesztve] -
Kraptor
Elég drágán vetted hallod e
. Tényleg itt jegyezném meg, ha most kezdene valaki EQ2zni akkor csak elég a Desert Of Flamet megvenni mert az tartalmazza az eredeeti EQ2t is és 30nap ingyen játékot.
''Kaptam két telepítési kódot a játékhoz de nem kellett regisztrálnom őket A játék nem kérte!
Ez lehet a baj? Ha ez akkor hol kell regisztrálnom ?''
2 telepítési kódot? Azt, hogy csináltad? Igen az a baj. Mikor bejön a launchpad után a kis EQ2 ablakocska ott aszem edit accountba kell menni és lesz egy olyan opció, hogy add collectors item vagy valami hasonló és ott kell megadnod az egyik kulcsot. Most nincs ezen a gépen EQ2 telepítve, majd ha olyan géphez jutok ahol van pontosan leírom, hogy mit kell csinálnod. -
Kraptor
ImpersonatoR
#1479
Néha jobb bekerülni alacsonyabb szinten mert egy csomó jó cuccot tudnak neked majd kraftolni
Én tegnap gyúrtam kraftolásra lvl 12 scholarról 17re és nagyon bejött. Aszem alchemist leszek,nem is tudtam, hogy ilyen jó kis kotyvalékokat lehet csinálni, nagyon frankók. -
Kraptor
eq2.budo.hu-n van egy Eq2 magyar forum ami régebben jobban pörgött. Manapság eléggé lelassult, gondolom ez annak is betudható, hogy eléggé szétszorva találhatóak meg a magyarok.
Kraptor
Kraptor
NE az Automexnél vegyétek meg, hanem UBISoftnál. A sima EQ2 9 font, ha reggelsz az oldalukon akkor kapsz 3 font discountot, tehát 6 fontért megtudod venni
Dobozost is tudsz, ha DOFt veszel az már alapban tartalmazz mindent. -
Kraptor
Trial az már csak 7 napig érvényes és csak a kezdő szigeten mászkálhatsz. Azért nem látod a Runnyeye és SPlitpaw servert, mert mikor elfogadod az EULAt akkor kikell választani melyik régióba akarsz tartozni, USA, EU angol, EU francia, EU német, stb és csak azokat a szervereket fogod látni. Ha runnyeyeon akarsz menni akkor csak simán válaszd EU GBt az EULAnál
[Szerkesztve] -
Kraptor
Lesz majd dobozos ferzió DOfnak, ha azt veszed akkor kapsz egy kis majom-háziállatot vagy hasonló. eq2.budo.hu vagy mmorpg.hun nagyobb a forum aktivitás a témában mint itt.
[Szerkesztve] -
Kraptor
Nem hinném, hogy sokan most kezdenének el EQ2ni, de a szegedi Mben rosszul van felárazva a Limited Ed. 10e lenne, de 8e ért árulják
[Szerkesztve] -
Kraptor
AlyArkhon
#1320
Semmi, akarid 90 napig biztos még ben marad a ''rendszerben'' utána nem garantálják, hogy bennt marad, de nem is törlik. Magyarán, ha valami hiba folytán tölődik a 90 napon túl, akkor nem fogják vissza állítani. Az accountod nem tölrődik soha, ha csak nem baneltek.
[Szerkesztve] -
Kraptor
Lord Speedyu
#1305
Nállad van a gond, nekem megy.
Kraptor
Desert of Flames az új kiegészítő:
Bővebben: link
Key Features
Arena champions: Take the form of new exotic creatures, or fight as yourself, in battles for glory against other creatures or players.
New movement: Search for treasure and find adventure in new areas by climbing up and down walls for the first time in an MMO.
Voice-over emotes: Express yourself in a battle or expand your social circle with new voice emotes.
Guild vaults: Share the loot of a hard won battle with the rest of your guild members.
Level range increase: Now play up to level 60!
New land: Discover over a dozen new zones and epic encounters.
New creatures: Test your combat skills in battles with over 40 new fearsome creatures.
Bővebben: link
[Szerkesztve] -
Kraptor
Kraptor
AlyArkhon
#1120
Nekem is olyan a szerencsém, hogy mikor beteg vagyok akkor vannak a legnagyobb kimaradások
Nemindegy, nem ez a fontos igazán, Az dventure pack ot a launchpadon az optional downloadsban tudod letölteni, után Nektulosban tudsz belépni a vízesésnél. Elötte kell egy questet kérned a nem messze lévő emberkéktől, ami lehetővé teszi, hogy belépj. Instanced zóna, tehát csak te és a csapat társaid lesznek benne. Az összes mob heroics 31+ és magasabb. A főcsóka nagyon brutál. A legdurvább területi támadása van, egy speckó ütéssel mindenkinek 1200hpt sebzett
Aszem az első szinthez nem kell letöltened az Adventura packot, csak akkor kell he megveszed.
[Szerkesztve] -
Kraptor
AlyArkhon
#1118
LOL! Volt valami amcsi csóka aki cyberelt valakivel, de elfelejtette ''bezárni'' az ajtót és visitor tagot rajta hagyta és valaki besétált álcázva és csinált pár szaftos képeket majd az internetre felnyomta. Utána szegény srác próbált amenteni ami még menthető.
MA meglátogattam az Adventura Pack első szintjét, ami ingyen van. Elég baró, mondjuk naon durva mobok vannak, de jó kis cuccokat is kapsz. Kaptam egy 20 aransy értékű fegyvert, amit gyorsan el is adtam.
Kraptor
Tegnap megcsináltam a szobám....7 aranyat költöttem rá
Még egy cicát is vettem -
Kraptor
High performance az gyengébb beállítást jelent, de gyorsabb. High quality meg jobb de lassabb. Balanced szerintem azért jó, mert még mindig elég gyors és szépek a közeli emberkék, tárgyak , stb. Szerintem árnyékot kilehet kapcsolni, mrt nem ad annyit a játékhoz. Valaki florát is ki szokta de nekem az kell, mert sokkal szebb tölle szerintem.
Kraptor
Kraptor
AlyArkhon
#1094
Gyüjtögetni kell, aszem Forest Ruins meg mi a másikba találsz ilyen kis állatka odukat. Úgy néznek ki mintha ágakból lenne üsszerakva egy kis építmény. Na azokat kell harvestálnod és akkor kapsz állatbőrt amiböl nem gyártanod kell sima bőrt majd azt felhasználva a táskát is megkapod.Nem tudom a pontos lépéseket így fejből.
Kraptor
Az járvány és köhögéssel terjed. NPCk is átudják adni neked, más játékosok is és te is át tudod adni nekik
Tegnap elértem a 30as szintet
Ja és lesz PvP EQ''ben, elvileg E3 alatt lesz bejelentve.
[Szerkesztve] -
Kraptor
Most nézem, hogy olcsobb lett a Limited verzió, 10e lett 12ről.
Kraptor
Lord Speedyu
#1052
Nekem mükszik.
Kraptor
Igen kevesebben vanak az emberek Freeportban, mint Qeynosba ez azért is lehet, mert 10-20 szint között nehezebb a szint emelés. Több az aggro mint Qeynosba.
Az 500 teremtményt (gnolls vagy Orc attol függ melyiket csinálod, a te esetedben gnollsok lennének) elég könyen és gyorsan megy, mert bámilyen gnolls jó.
Csak qestekre kapsz expt? Az sokáig el fog tartani
Kraptor
Hát a Betrayalt 15 szint elött enm érdmes elkezdeni. Ha van csapatod aki segít akkor hamar meglehet oldani, de ha nincs akkor elég gázos, mert 17es szinten cap-elva leszel és anevezett mobok azok 17-19 ^^ szinten fordulnak elő
Mondjuk é n mikor csináltam az még jócskán az elején volt, de kevesebb mint 3 nap alatt meg lehet csinálni.
[Szerkesztve] -
Kraptor
Adept 4et? Nem Apprentice 4et akartál mondani? Én még nem láttam adept 4eset, csak adept 3, meg master 1
. Szerintem Apprentice 4 az felejtős, többen veszik adepteket, mert sokkal jobbak. Néha nem éri meg app4 venni app2 helyett, de bőven megéri adep1et venni app2 hellyett.
[Szerkesztve] -
Kraptor
P4 1.6, 512Mb Ram és 9600 Sen kafán fut a game
Kraptor
Advanced Scholar Refining Volume 11-be van Suzuri Ink. Szerintem te valamit nagyon nem jól csináltál eddig
Egy csomó adept 3 as spell jön ezzel a receptkönyvel:
Agitation (Adept III)
Blackened Iron Strut
Blaze
Burning Radiance (Adept III)
Chill (Adept III)
Contagion (Adept III)
Coral Gem
Ego Shock
Essence of Blessed Weapon (Adept III)
Essence of Mangle (Adept III)
Essence of Power Strike (Adept III)
Essence of Righteous Blow (Adept III)
Essence of Taunting Blow (Adept III)
Essence of Thrust Kick (Adept III)
Faceted Coral
Fascinate (Adept III)
Lined Poison Vial
Muffled Glass
Nettleshield (Adept III)
Radiant Strike
Rebuke (Adept III)
Rune of Backstab (Adept III)
Rune of Reconnoiter
Rune of Rousing Tune (Adept III)
Rune of Shadow Blade (Adept III)
Rune of Smuggle (Adept III)
Rune of Sparkling Blade (Adept III)
Silver Bar
Silver Sheet
Suzuri Dye
Suzuri Ink
Tellurian Recruit (Adept III)
Tetranoid Reagent
Wailing Haze (Adept III) -
Kraptor
Olyan receptet nem is fogsz kapni amivel suzuki inket tudsz előállítani. Azokat szerezned kell. Azok a receptek az advanced components kiegészítők, nem tuom most pontosan fejből a nevét, de aszem elég alap recept 10 es szint alatt van vagy körüli. Ezeket csak mobok dobják aszem, te nem fosgz olyan receptet kapni amivel suzuri inket tudsz majd csinálni, azt keresni kell.
Kraptor
Nekem lvl 12es(mivel csak 12 Scholar vagyok) Adept 3 as receptjeim vannak:
Regroth, Vivid Seal, Signet of Intuittion, Spectral Ward, Earthly Brand, Bestowal ov Vitae. Ezekből mind adept 3-as receptjeim vannak. Suzuri Ink kell hozzá mint alapanyag, de mint említetted azt nehéz találni vagy egy kicsit drága.
Vannak olyan receptek amiket nem az NPC árustól veszel, hanem mob dobja, na azok a tutkók. Azok adnak, pl adept 3 as recepteket.
[Szerkesztve] -
Kraptor
Kraftolással nagyon jó lóvét lehet szerezni, ha ügyesen csinálod. Hát, ja a rare dolgok egy kicsit húzósak, de nem mindegyik. Tailor elég jó cuccokta tud csinálni vagy Jeweler amit mindnennki tud majd viselni.
[Szerkesztve] -
Kraptor
Launchpadon van olyan opció, hogy edit account, majd mikor nejön az edit eq2 és ott lennie kell valami opciónak, hogy add ful game vagy valami ilyesmi. Arra klikk és majd kéri a számot.
Kraptor
Fallen Gateel már tököm kivan annyit voltam ott
Csináltam Betrayal questet még anno a másik karimmal, de annyir anem volt az igazi. Freeport az jobban bejött
Ugyis még visszakell menni FGbe ha megöltem a rohadék fairieket. Zek szerintem magas lehet, de nem tuom, hogy tudok Zekbe menni? Ki adja a Zek accesst? -
Kraptor
Dark Elf vagyok. Mostanába Nekben vagyok de sokat voltam/vagyok TSben is. A rohadt AQ6omat csinálnám, de Silian fairieket nagyon nehéz találni, már ideges is vagyok tőle mint állat.
Multkor csináltam EL hozzáférést, de még nem nagyon voltam arra, mert az összes mob tiszta vörös
[Szerkesztve] -
Kraptor
Én is Splitpawn vagyok. LVL 26 Nekro Darquar a név és egyke vagyok. Nem vagyok Guildbe
Kraptor
Ma elkeveredtem Enchanted Landsbe, hát elég zura mobok vannak ott.
[Szerkesztve] -
Kraptor
Ma nagy update volt/van, este 6-ig lennt lesznek a szerverek. Lesz mail rendszer is!
És még servereken keresztül is tudsz üzenni
Ebbe SWG és EQ'1 is beletartozik
[Szerkesztve] -
Kraptor
Lord Speedyu
#903
- Futás, futópályák
- Hardcore café
- Androidos tablet topic
- World of Warships
- Milyen légkondit a lakásba?
- Eladó Gamer számítógépem.
- Honor 90 Lite 8/256GB Újszerű,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Garanciával!
- OnePlus 15 16/256GB Újszerű,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Garanciával!
- Verhetetlen áron!Gamer PC i7-14700K / RTX 5070 / 32GB / 1TB NVMe - Beszámítás
- Logitech PRO X SUPERLIGHT 2
- BESZÁMÍTÁS! Sony PlayStation 4 PRO 1TB fekete játékkonzol extrákkal garanciával hibátlan működéssel
- Astro A50 4th Gen wireless + base station fejhallgató
- BESZÁMÍTÁS! Intel Core i5 8500 6 mag 6 szál processzor garanciával hibátlan működéssel
- Telefon felváráslás!! Xiaomi 13T, Xiaomi 13T Pro, Xiaomi 14T, Xiaomi 14T Pro
- HIBÁTLAN iPhone 12 64GB Purple -1 ÉV GARANCIA - Kártyafüggetlen, MS4655
