nubreed
bobalazs
#1668
Mondjuk ez igaz, RR-nél én is sokat mászkáltam egyedül, sokszor senki más nem mozgatta meg magát, hogy gyűjtsük az ore-t, aztán meguntam a gyűjtögetést, és aztán már csak a Treasury Note -ért mentem/megyek oda is, mint egy csomó más eventre, na meg persze az XP sem jön rosszul.
nubreed
Kijöttek a leírások az Event balance -okhoz, meg van említve többek közt a Campfire Tales, Radiation Rumble, Tea Time.
Campfire Tales: The campfire was previously dying down too quickly, which could cause the event to fail too easily. The campfire will now last a little longer, giving you and your event mates some more time to feed its flames.
**Free Range: The Brahmin during this event were too fragile, so we’ve beefed up their resistances to help them survive more easily (though they will still need you to defend them).
Line in the Sand: This event was taking a bit too long to come to an end. We’ve shortened the event’s overall time limit to 10 minutes, and reduced some enemy wave timers and the preparation phase timer accordingly.
Project Paradise: To help reduce the difficulty of Project Paradise, we’re lowering the amount of food required to 15 per rank. We’re also adding some more resistances to the friendly creatures that spawn during the event.
Radiation Rumble: To encourage more players to participate in the ore collection objective, we’re lowering the requirements to 5, 15, 30, and 50 ore for reward tiers one through four, respectively. The event no longer ends immediately when you reach the final collection tier, so you can continue to defend against enemy waves until the now 8-minute event timer expires. Finally, we’ve doubled the Scavengers’ resistances to make them more survivable.
Swarm of Suitors: We’ve addressed a number of bugs that could prevent players from receiving the highest tier of rewards and from successfully completing the event. We’ve also made some design adjustments to help smooth out the experience while playing through Swarm of Suitors. Mirelurk attack waves now each have two timers: an initial timer and a “last chance” timer. Players must kill all enemies in a wave before the last chance timer expires, or the Mirelurk Queen will spawn, resulting in event failure.
Tea Time: While we did not feel that Tea Time was overly difficult, it could end in failure too quickly at times. As a result, we’ve increased the health for two of the three pipes so that they match the sturdiest one. Additionally, Rad Ants and Ticks can no longer spawn during the event, and we’ve slightly increased the enemy spawn rate to keep up the action.Én eddig sem tartottam különösen nehéznek egyiket sem, sosem futottam failed -re (lehet, hogy csak mindig jó csapattal voltam és szerencsém volt, nem tudom) de most elég sokat könnyítettek ezeken így elnézve a leírást. Szerintem így túl könnyűek lesznek már, nem tudom miért kell a habzó szájú vérpistikékre hallgatni, akik biztos döngették a mellüket, hogy túl nehéz a játék vagy az eventek. A Tea Time könnyítést különösen nem értem, a Path to Enlightment event után szerintem ez a másik legkönnyebb.
Aztán a 4 star legendaryk közül eddig egyik sem hozott lázba, ennél jobban is megerőltethette volna magát a Bethesda.
nubreed
Volna egy kérdésem a Gunsmith perk carddal kapcsolatban. Ugye van az a tulajdonsága ennek a kártyának, hogy x százalékkal később mennek tönkre a fegyverek. Ahhoz, hogy ez a hatás érvényesüljön, mindig fel kell, hogy legyen szerelve a kártya? Vagy ez a hatás akkor érvényesül, amikor pont legyártasz egy fegyvert és onnantól kezdve végig "él" ez a hatás?
nubreed
A jet packek hogy működnek? Ha jól látom nem csak power armorhoz érhető el jet pack, hanem külön is. De ezeket hogy lehet megszerezni? Vagy a power armorhoz használható külön is, akkor amikor egyébként nincs rajtam a power armor?
nubreed
Na most, hogy elmentem farmolni legendary core -t és modult, rá is raktam a The Fixer -emre egy 3-asz szintű legendary modot, ami elég jó is lett (RNG isten jót adott), pl kaptam exploding bullets -et is. Ami tök jó meg nagy móka, igenám de ha közel harcról van már szó akkor ugye az általam kilőtt felrobbanó golyók engem is sebeznek. Van olyan perk esetleg ami immunissá tesz a saját robbanásaim ellen? Vagy ezt hogyan lehetne kezelni?
nubreed
Hol vagy hogyan érdemes Legendary Core -t farmolni?
nubreed
Szokott olyat csinálni a játék kliens, hogy "elfelejti" a login információt és hiába írom be újra a felhasználónevet, jelszót, azt mondja, hogy nem stimmel? Rányomok a "Forgot Password" linkre beírom a usernevem, azt mondja, hogy "Something went wrong please try again" és ugyanezt írja ki akkor is, ha az email címemet adom meg. Nagyon furcsa ez az egész.
Szerk: megoldódott, aztán egyszer csak beengedett, nem tudom mi volt ez, eddig ilyet sosem csinált.
nubreed
pootzdorjah
#1648
Hú de szép kis dög ez.
nubreed
Az 50. szint elérése után, lehet új perk card -okat felszerelni? És ha igen, hogyan?
nubreed
pootzdorjah
#1642
Köszönöm, így működik! Elnézést, elfelejtettem hamarabb reagálni.
nubreed
Egy láma kérdés:
fotó módban hogyan kell úgy körbe forgatni a kamerát, hogy a karekter arca legyen benne? Egyszerűen nem jövök rá, pedig már mindent végig nyomkodtam.
nubreed
Meddig szokott tartani egy server maintenance? Ugye épp most is az van...
Amúgy tudni azt pontosabban, hogy most milyen update jön? Vagy ez csak egy karbantartás?És egy másik kérdés:
Combat armor plan -t hol/hogyan lehet szerezni? -
nubreed
Pont ez az, hogy nem akarom őket kikapcsolni, csak kissebbre venni. De találtam valamit a nexusmodson: [HUDEditor - Customize your HUD]
Csak az nem világos még, hogy hova kell ennek a fájlait bemásolni.
nubreed
Sziasztok ismét!
Felvettem/aktiválódott jó néhány küldetésem. Mindent ki rakja a képernyő jobb részére. De már olyan sok van, hogy teljesen beteríti a képernyő jobb oldalát, kicsit idegesítő. A HUD -ot nem lehet átméretezni valahogy, hogy sokkal kisebb betűvel írja ki ezeket?
nubreed
Néztem (friss 2021 -es) videokat és olvastam friss cikkeket a játékról és úgy tűnik nagyon sok mindent kijavítottak benne vagy átalakítottak, amiket a megjelenéskor nagyon sokan kritizáltak és utáltak a játékban. Ezért most már lehet, hogy megvenném én is. De nem egyértelmű, hogy mit kell beszerezni ahhoz, hogy ne csak az alapjáték hanem minden eddig megjelent tartalom is meglegyen. Szóval elég ha megveszem a legújabb Steel Dawn -t, az tartalmazza az alapjátékot és az előtte megjelent fizetős tartalmakat is? Vagy nem ilyen egyszerű?
- Amit látnod kell 80’ – 90’ évek, egész estét betöltő mozi filmjei.
- Okos Otthon / Smart Home
- Mikrotik routerek
- Alkoholista nevelde
- Filmvilág
- Tőzsde és gazdaság
- BESZÁMÍTÁS! Gigabyte Z270 i7 6700 16GB DDR4 512GB SSD GTX 1660 Super 6GB Rampage SHIVA DeepCool 400W
- 2 TB-os Samsung 980 PRO M.2 SSD with heatsink - garanciával
- BESZÁMÍTÁS! MSI B650 R7 7700 32GB DDR5 1TB SSD RX 9070XT 16GB LIAN LI LANCOOL 217 Wood 750W
- MacBook felváráslás!! MacBook, MacBook Air, MacBook Pro
- Beszámítás! VALVE Steam Deck OLED 512GB SSD kézikonzol garanciával hibátlan működéssel
