Andrewhouse
INTEL DP35DP
Részletes beszámóló és teljesítmény teszt!
[link]![[kép] [kép]](http://www.intel.com/products/motherboard/pix/dp35dp_lg.jpg)
Form Factor
ATX (12.00 inches by 9.60 inches [304.80 millimeters by 243.84 millimeters])
Processor
Support for an Intel® Core™2 Quad processor in an LGA775 socket with a 1066 MHz system bus
Support for an Intel® Core™2 Duo processor in an LGA775 socket with a 1333/1066/800 MHz system bus
Support for an Intel® Pentium® Dual-Core processor in an LGA775 socket with an 800 MHz system bus
Support for an Intel® Celeron® processor in an LGA775 socket with an 800 MHz system bus
Memory
Four 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
Support for DDR2 800 MHz, or DDR2 667 MHz DIMMs
Support for up to 8 GB of system memory
Chipset
Intel® P35 Express Chipset
Audio
Intel® High Definition Audio (Intel® HD Audio) subsystem in the following configuration:
8-channel (7.1) audio subsystem with five analog audio outputs and one optical S/PDIF digital audio output using the Sigmatel STAC9271D* audio codec
Video
Video support provided via PCI Express* graphics via add-in card
I/O Control
Legacy I/O controller for serial port via header
LAN Support
Gigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82566DC Gigabit Ethernet Controller
Peripheral Interfaces
Twelve USB 2.0 ports
Six Serial ATA 3 ports, including 1 eSATA port with RAID support
Two IEEE-1394a interfaces (1 external port, 1 internal header)
Consumer IR receiver and emitter (via internal headers)
One Parallel ATA IDE interface with UDMA 33, ATA-66/100/133 support (2 devices supported)
One serial port via header
Expansion Capabilities
Two PCI Conventional* bus add-in card connectors
Three PCI Express* x1 bus add-in card connector
One PCI Express x16 bus add-in card connector
Microsoft Vista* Premium Ready
With a PC built with Intel Core 2 Duo or Intel Core 2 Quad processors, and the Intel® Desktop Board, you can experience a more responsive and manageable environment of Microsoft Windows Vista*.
Várom a Tapasztalatokat vagy feljeményeket!
[Szerkesztve]
[Szerkesztve]
[Szerkesztve]
[Szerkesztve]
- Linux Mint
- HTPC (házimozi PC) topik
- Arena Breakout: Infinite
- Apple MacBook
- Linux kezdőknek
- Eredeti játékok OFF topik
- Konzolokról KULTURÁLT módon
- Friss készlet! MacBook Pro 14" M1 16GB RAM 27%-os áfás számla (238)
- Apple Watch Series 11 46mm GPS+Cellular , Újszerű, 1 Év Garanciával
- HP EliteBook 630 G10 - 13,3'FHD IPS - i5-1335U - 16GB - 1TB - Win11 - 1 év garancia - MAGYAR
- Apple iPhone 12 256GB, Kártyafüggetlen, 1 Év Garanciával
- REFURBISHED - DELL Universal Dock D6000 (452-BCYH) (DisplayLink)
