Zoli_2010
KTTech
#47384
Lehet a videokártyáknál is hasonló, ami nekem rémlett, az a SandyBridge integrált videomoduljában van:
This isn’t intentional, but rather a propagation of an oversight that started back with Clarkdale. Despite having great power consumption and feature characteristics, Clarkdale had one glaring issue that home theater enthusiasts discovered: despite having a 23Hz setting in the driver, Intel’s GPU would never output anything other than 24Hz to a display.
The limitation is entirely in hardware, particularly in what’s supported by the 5-series PCH (remember that display output is routed from the processor’s GPU to the video outputs via the PCH). One side effect of trying to maintain Intel’s aggressive tick-tock release cadence is there’s a lot of design reuse. While Sandy Bridge was a significant architectural redesign, the risk was mitigated by reusing much of the 5-series PCH design. As a result, the hardware limitation that prevented a 23.976Hz refresh rate made its way into the 6-series PCH before Intel discovered the root cause.
...What happens when you try to play 23.976 fps content on a display that refreshes itself 24.000 times per second? You get a repeated frame approximately every 40 seconds to synchronize the source frame rate with the display frame rate. That repeated frame appears to your eyes as judder in motion, particularly evident in scenes involving a panning camera.
És nem eldob framet, hanem 1-et megismétel.
Bocs, ez így hosszú lett, + az első google találatot raktam be ide, nem keresgéltem magyarul.Ja, és ennyit a (HT)PC-kről, a legjobb a médialejátszó!
Zoli_2010
creatorium
#47356
Ha csak kb. 40mp-enként akad, akkor az egy CPU-bug (?? nem tapasztalatból írom, csak olvastam valahol). Azért akad, mert a gép tényleg csak 24Hz-et ad ki a 23.976 helyett, és végül eldob egy framet. 1/(24 - 23,976) = 41,6666 mp.
(azt hiszem, még a core-i3 / i5 / i7 sem tudja rendesen...)
Zoli_2010
Gabor970
#44290
Helló, régebben írtad, hogy gond volt a PS50C430 egyik firmware-vel (a beépített médiaplayer körül). Nekem most a 1023-as van, a legújabb a 1024-es, talán 2011. áprilisi. Érdemes-e frissíteni? Neked melyik van fenn, és rendben működik-e?
Naponta használom a belső lejátszóját, nagyon elégedett vagyok vele. (Az .mkv releaserek is lassan rájöttek, hogy Level@4.1-ben kell kódolni, mert az L5.1 felesleges is, és alig van lejátszó, ami viszi... + mostanában az igényesebbek mellé teszik már az .SRT feliratokat is!)
A legnagyobb hibája, hogy ha sokat nyomkodom (ugrálok vissza a filmben, ...), akkor néha lefagy. Ilyenkor a watchdogra kell várni 1-2 percet, hogy rebootolja a TV-t, mert semmire sem reagál(!) Van, hogy egy héten kétszer is megesik, van hogy 2-3 hétig semmi baja.Bónusz info: néha a "Nem támogatott audio codec" üzenet ellenére egy oda-vissza nyelvváltás után mégis lejátsza az adott film hangját. (Mondjuk, ha épp nincs lehetőség nyelvváltásra, mert nincs 2. nyelv, akkor pech.)
Zoli_2010
M_AND_Ms
#38774
Ha a villámhárító a házadon van, "odacsalja" a villámot, és az általa létrehozott elektromágneses tér jó eséllyel olyan feszültséglökéseket indukál, ami sokmindent hazavág a háztartásban. A villámhárító akkor jó, ha 1-2 km-re van, de legalább 500m-re. Különben csak a biztosítás segít...
A kihúzott kábeleket pedig illik minél távolabb tenni a csatlakozóktól, meg egyéb fém részektől. Bár ha becsap a villám, akkor szinte mindegy. Ha többszáz méter magasról becsapott, azt a pár cenit már simán átugorja...
A távoli villámlások ellen persze érdemes kihúzni a madzagokat.
Zoli_2010
zippofcy
#37789
én az alatt az 1 perc alatt ilyen rossznak láttam... megnéztem volna valami filmmel is, -- de ha már az erre kidolgozott 3D-s demo ilyen gyengén muzsikál, akkor mit várjak tőle?
Persze a passzív szemüveg könnyű, "praktikus", csak minimális fényerőcsökkentést okoz(?) => a "lencse" ugyan nem látszik sötétnek, de mégiscsak a sorok felét kiszűri az egyik, a másik felét a másik szem előtt... bár nekem ez a (felezett?) fényerő nem tűnt fel. (A fényerőcsökkenés az aktív szemüvegeknél nagyon is látható.)
A 3D effekt látható volt, de amikor közel jött a labda (a képernyőnek rugdosta az a zállat belülről
), akkor én két labdát láttam átfedésben (ez a crosstalk?). -
Zoli_2010
Ha már 3D:
kipróbáltam az LG polarizált 3D-jét (Mammut Saturn), de azt sem tudom, pontosan melyik típus volt kitéve...
Biztosan LCD. Persze demóanyaggal ment.
A felbontás feleződése nem is tűnt fel, de a mozgásmegjelenítést azt felejtsük el.
Teniszlabda: homályos, szaggatott sárga csíkok.
Futball labda: homályos maszatok.
Lassú mozgásnál még kivehető, mi is az, de ha valami gyorsan mozog, az katasztrófa. Milyen lehet ezen egy akciófilm??? A látványos, pörgős jeleneteket azolvasónéző fantáziájára bízzák?
Zoli_2010
janos666
#37764
Helló,
az aktív 3D szemüveg vibrál, az biztos. Zavaró is (én még csak bótban, kiállítva próbáltam -- és megvagyok 3D nélkül is...).
A pulzálás viszont attól van, hogy a lámpa fénye (izzó vagy halogén?) másodpercenként ~100-szor villan fel (igazából a 230Vac szinuszos 50Hz szerint változik a fényereje), de persze ez nincs szinkronban a szemüveg vibrálásával, ezért mindig más fényerőszintet lát a szemed, amikor a szemüveg LCD-je éppen nem takarja ki...
Sötétítsd le a plazma képét, és ugyanazt fogod látni. A TV-nek ehhez a jelenséghez semmi köze. (na persze a szemüveget a TV vezérli...) -
Zoli_2010
stifi82
#31604
Az az összeakasztás az nem nagyon lehet jó, és az árnyékolásnak is folytonosnak kellene lennie... különben a 75Ohm impedancia ki tudja mennyi lesz...
De ha az osztrák még így is ilyen jól bejön, akkor az antennával nem lehet gond (esetleg az irányával?). Nem értem, miért nem jön be (legalább) az analóg rtl-tv2-m1 nézhetően.
Egyebet nem tudok mondani... -
Zoli_2010
stifi82
#31599
Milyen TV-d van pontosan? Mert nálam a PS50C430-on 37-57 közötti jelerősség volt jellemzően. 30 alatt bizonyos régebbi firmwarrel már be sem jött, vagy nagyon akadt, kockásodott a kép a DVB-T adóknál. Újabb firmware-rel (kb. szeptember-októbertől) már 20-as jelszinttel is jó volt a vétel.
Firmware verziókat a 1012-től 1023-ig folyamatosan frissítettem, nem tudom, már, melyikkel volt ez a "gond", -- de Samun 10-es jelszint az kb. nulla. -
Zoli_2010
stifi82
#31596
Passz, ha az osztrákok 10/10-es szinten bejönnek, akkor az antenna/kábel/aljzat hibát kizárhatjuk. Az antenna irányát érdemes beállítani, a magyar DVB-T elég gyengén sugároz, -- úgy tudom, majd emelik az adóteljesítményt a többszörösére.
A négy antenna közösítése is bezavarhat...
Remélem koaxon megy le a jel, és nem lapos VHF kábelen? Egy antennát kellene csak rátenni, UHF-et (valsz. a rövidebb az).
A lefedettségi térkép tetőantennára vonatkozik, ha "rossz helyen" laksz, lehet, hogy nem lesz vételed. Hány km Sopron illetve Graz? -
Zoli_2010
sbkoci
#31532
Van olyan is amikor elvileg vinnie kéne egy mkv-t, mégsem megy. Ekkor egyszerűen áttolom TSMuxerrel TS-be, és már le is játsza (ez max. 10-20 perc). Ilyenkor a progi kiírja, hogy '~FPS not set, setting 23,976...', gondolom az mkv-ból kimaradt valami default paraméter, amit a Samu nem helyettesít be magának, de ezt a TSMuxer korrigálja...
Az mkv-be kódolt PGS(?) feliratokat nem kezeli, de a külső (megegyezű nevű) feliratokat igen.
Az mkv / ts stb. fileokban lévő hangsávokat lehet váltani, és az optikai kimenetre kiteszi AC3-ban/DTS-ben is, nem csak PCM-ben.
Ennyiért
, ennél jobb lejátszó nincs.Konkrét kérdésre -- akár privátban is -- szívesen adok tippeket...
Zoli_2010
sbkoci
#31532
Nekem PS50C430 van. (Az elmúlt fél évben 3-4x leírtam, hogy) mindent lejátszik.
.mkv-t .ts-t mp4-et, .wmv-t stb.
Vannak persze kivételek, és néha trükközni kell a lejátszáshoz.
A HD-s divx-eket
(~720p) pl nem szereti, de ez engem nem érdekel. ISO-t sem viszi
A hozzászólásaim fele a belső médiaplayerről szól, most nem ismételném meg, biztos rá lehet keresni...
Röviden: M2TS-t átnevezni TS-re // x264 Level@H5.1-et áttenni 4.1-be (pl. TSMuxer-rel)
DTS-HD-ből (bár azt is lejátsza, de néha nem bírja, ekkor érdemes lehet csak a DTS-core-t kimuxolni...)
Van kb 1TB HD-s filmem (fél év alatt), ebből talán kettőt-hármat nem tudtam megnézni. Persze előtte megnézem, mit is szedek le...
A kezelése nehézkes, de azért ennyi pénzért együtt lehet vele élni.
(aztán majd 1x veszek egy Netgear TV550-et
)Kérdezzetek bátran, szerintem tudok segíteni...
Zoli_2010
pajcsee
#31502
A DVB-T -hez persze a légi (azaz földi
) keresést kell választani. A Samsung TV be tudja hangolni a légi és a kábel TV-s digitális csatornákat is, aztán egymás mellett (mögött?) tárolja őket, és az éppen kiválasztott antenna üzemmódtól függően jelennek meg a csatorna listában. -
Zoli_2010
pajcsee
#31511
Helló,
25km-ről, ha a domborzat vagy panelházak nem árnyékolnak (látod a kabhegyi adótornyot?), akkor egy 75cm, vagy 1,5m körüli csupasz kábellel is be kellene jönnie, amit az adó felé irányítasz. 1 próbát megér.
Én így néztem nyáron a foci-VB-t!
(Igaz, nekem 3m-es volt a drót az udvaron...
Zoli_2010
Digitalis
#31504
Nem csak Neked szól, hanem mindenkinek:
A Samsung TV-knél NEM KELL Finnország -gal, meg hasonlókkal variálni...
A magyar beállításnál is elérhető a légi és a kábeles (DVB-T/C) tuner is.
Ezek között bármikor lehet váltani a Tools menü antenna opciójában, a piros gomb megnyomásával, (a csatornalista alatt jelzi, hogy éppen légi vagy kábel)A Panák hülyesége (bug?), hogy Magyarországon nem engedi a DVB-C tunert használni.
Ezt sokan megírták, sokan olvasták, és még többen összekeverik, felesleges körökre kényszerítve a kezdő Samsungosokat...
Bocs.
Zoli_2010
Gabor970
#27868
Helló Gábor,
nálam ha nem játszik le valamit a PS50C430, akkor ellenőrzöm az MKV profile levelt: a High@4.1-et ugye viszi, az @5.1-et már nem. De ezt biztosan tudod már... (az @5.1-ről simán át lehet "alakítani" @4.1-re)
Ha pedig max 4.1-es, és mégsem megy, akkor a TSMuxer-rel egyszerűen átnyomom TS formátumba (TS muxing). Ez egy régi notebookon is max fél óra, 10-20GB-os MKV-nál is.
Fél év alatt egyszer volt, hogy így sem ment az adott film lejátszása. A többi esetben segített ez a módszer. (általában a "nemigaz, hogy nem megy!" meggondolásból kiindulva próbálom megtalálni a megoldást...
Zoli_2010
hello28
#20364
Nem az időtől vagy az út hosszától függ, hanem a kátyúk mélységétől:-) én nagyon óvatosan, kb. 40fokban megdöntve vittem. nem lett baja, de mindig nézegetem, hogy ettől hullámos-e a teteje, vagy gyárilag ilyen:-) persze csak oldalról látszik, a rajta tükröződö ablak fényében.
Zoli_2010
Helló, a frissítés sima ügy, nem kell hozzá üres pendrive sem, mint itt írta valaki (persze úgy biztosan előbb megtalálja, de) -- nekem az 500GB-os külső HHD-ről is mindig sikerült.
Nem kell az alapbeállításokat sem alkalmazni, és a frissítés sem szokta ezt tenni (bár előtte erre figyelmeztet). Az alapbeállításokra csak a szervizmenübe való belépéskor áll vissza
A letöltött firmware *.exe-t ki kell csomagolni
, ezt egyszer én is elszúrtam, nem árt többször leírni, hátha valaki még nem tudja.A PS50C430-hoz:
A FLAC-et benéztem, csak emlékezetből írtam, -- valamikor június elején próbáltam, és mivel a TV nem ír kiterjesztést, meg fájltípust sem az info-val -- azt hittem, hogy az egyik lementett diszkográfia FLAC-ben van kódolva. Nos nem. Ennek ellenére még mindig rémlik valami, de nam találom, hogy akkor mivel is próbáltam.
Zenehallgatásra nem használom, mivel ekkor NEM lehet kikapcsolni a képet
, és elég érdekesen belesülhetne a lejátszó felülete. Igaz, a képbeállításokat vissza lehet venni alacsonyabb értékekre, sőt kb. a 1019-es firmwaretől saját maga is letekeri a cellafényt pár másodperc után, illetve rémlik, mintha később képernyővédőre is kapcsolna, de nem tudom, ehhez hány percet kellene várni... Ha pedig hozzányúlok, akkor ugye bejön megint a kép, és ezt nem akarom bámulni. (lehetne még a firmware-en jobbítani...)
Szóval marad a bakelit, meg a Pio585-ösről az SACD...
Zoli_2010
hello28
#20306
Bejáratás alatt ajánlatos, utána egyéni ízlés dolga, de én szeretem, ha a kép kitölti a TV felületét, (és jó ha ugyanakkor még a képarány is rendben van). Ehhez néha trükközni kell kicsit... most lecseréltetem a SCART-os xar t-homis STB-t HDMI-s-re, na ott remélem a képarányt már automatikusan váltja a 4:3-as/16:9-es adóknak illetve műsoroknak megfelelően... vagy ott is váltogatok kézzel.
Mondjuk én mindig állítgatom a képarányt, mert nem bírom, a fekete csíkokat, pláne ha az még a képarányt is torzítja. Meg persze úgy sem nézném az 50"-es TV-t, hogy a közepén van egy kb.40"-es téglalapban a kép
XBOX mehet, ha ki lehet kapcsolni a HUD-ot, kilométer órát meg ilyeneket. Ha nem, akkor eleinte csak óvatosan, 1-2 óra xbox után 1-2 óra teljes képernyős TV-zés ajánlott. (Vagy egy másik játék
-- Fő a változatosság...) -
Zoli_2010
hello28
#20299
A C430-is tudja a szürke oldalsávot, én is arra állítottam.
DE! A földi digitális (DVB-T) adásban a 16:9-es képbe a DunaTV, illetve az m1, m2 is sajnos beleteszi fixen a kétoldali fekete(!) oldalsávot, amit ugye oldalra nem is lehet sehogyan kizoomolni.
Ennél valamivel jobb, amikor a 4:3-as adásban adnak alulfelül fekete csíkkal filmetket
Na, erre a megoldás leírva bonyolult, de amúgy egyszerű: a SetTopBox-ot 4:3-as TV-re állítom (ezzel széthúzza a képet vízszintesen a TV-n), aztán a TV-n a 2.nagyítással az alsó-felső fekete csíkokat is kizoomolom, ezzel a logóknak is szevasz, már csak a keret mögött "égetik be" a panelt
Persze, ezzel a nagyítás következtében a felbontás jelentősen 'romlik', de még mindig jobb így, mint jobbról balról szürke, alulfelül meg fekete csíkkal nézni a filmet -- és így a képarány is rendben van.
Ugyanezt a beállítás 4:3-as adásnál is használom, ekkor ugyan alulfelül kilóg 'némi' képtartalom, de ez soxor csak a logókra korlátozódik. Ha már a zemberek homloka is áldozatul esik neki, akkor meg inkább megnézek egy HD-s filmet...
Zoli_2010
Helló,
a képarány kicsit bajos kérdés.
Először is: ha olyan műsort, vagy filmet nézek, ahol alulfelül, vagy kétoldalt fekete csík van, az egy fél óra után meglátszik a panelen. Értsd: ha ezután egyszínű feketére kapcsolom a TV-t (pl. olyan bemenetre, amin éppen nincs bekapcsolt forrás, vagy egyszerűen csak kapcsolgatom a csatornák között, és közben 1-2mp-ig ugye a fekete képet látom) -- akkor ahol nem 'ment' a panel, ott feketébb, ahol pedig ment, a középső sávban "fakóbb" a kép. Tehát ahol kép volt, ott szürkébb lesz a fekete, jobban használódik a panel. Ez hosszabb idő után már nem csak fekete háttérnél, de adás vagy film közben is meglátszik. Vagyis aki mindig (hetekig, hónapokig) fekete csíkokkal nézi a TV-t, annál a panel részei máshogyan fognak (el)használódni, illetve öregedni, ezért lenne jó minél több 16:9-es műsort, filmet nézni. Persze elég csak fele-fele arányban nézni a teljes képernyős anyagokat, már az is rendben tartja a panelt. Bejáratás alatt viszont érdemes minél több teljes képernyős anyagot nézni. -
Zoli_2010
Igen, csak a DTS Core-t adja ki az optikai kimeneten, de ez a régi erősítőmhöz így pont jó is
Jó lenne, ha több felirat között is lehetne váltani, és nem kellene sz.géppel cserélni a filet ehhez. Még szebb lenne a beágyazott feliratok kezelése... de talán még lesz olyan firmware is egyszer. -
Zoli_2010
dr_ace
#20016
A DTS-t lejátsza, és a DTS-HD-t is /bár ennél magasabb bitráták esetén a hang akadozott néha/. A Dolby-TrueHD nem megy. Ezektől 'lefele' mindent visz, pl -zenében- Flac-et is. A sávok között a Tools menüben lehet választani /nyelv/. sajnos a feliratokkal nem bánik ilyen ügyesen. az mkv-ban lévőket nem kezeli, csak a külön felirat file-t. ahol a file név azonos a filmfile nevével.
Zoli_2010
dr_ace
#19342
Helló,
tegnap elég sokat írtam a Samsung beépített lejátszójáról, talán segít a döntésben. Tömören: semmi extra nincs benne, de amire kell, arra épp elég. (Ugye HD-s filmek, házimozival megtámogatva...)
Júni eleje óta használom, és nem vágyok külső lejátszóra -- persze egy Dune-t elfogadnék
Zoli_2010
tiko76
#19338
A Level@4.1 az a videostream kódolására vonatkozik, -- a Level@5.1 nagyobb video-képfelbontást is lehetővé tenne, amit már a Samu C430 médiaplayere nem támogat (de a 'nagyobb' TV-k-é sem). Néha mégis @5.1-ben kódolnak filmeket, pedig a felbontása a @4.1-be is simán beleférne.
Pl. TSMuxerrel percek alatt átkódolható az @5.1-ről @4.1-re...
Ez NEM a hangcsatornák száma, ahhoz semmi köze.A hanghoz:
A DTS-t is lejátsza, optikai kemeneten is kiadja, de a DTS-HD-vel már néha akadozik, ha a képfeldolgozással is sok munkája akad éppen, lásd vízesés, dzsungel stb... -
Zoli_2010
Zoli_2010
Zoli_2010
Let's go
#19237
Na, még visszatérve az mkv-k lejátszására -- mit csinál olyankor, ha nem játsza le?
Pár hónapja én is nyúztam mindenféle HD demókkal (TV és játék demók), -- na azokból a harmadát nem játszotta le. A játékdemókat nem is vizsgáltam, milyen formátum, meg codec, de a TV-s demókból úgy vettem észre, hogy a DolbyTrueHD-t nem tudja. A DTS-HD-t kezeli, de ettől néha belassul és akadozik a hang (ez általában az angol). (TSMuxer-rel ki lehet szedni a DTS-HD hangot, abból a DTS core-t, és azt visszamuxolni -- na ezt még nem próbáltam, inkább választom a Dolby Digital hangot (úgyis ez szokott lenni a magyar nyelvű).
A legdurvább az volt, amikor több demónál is, - de nem mindig ugyanannál-, elment a kép. Ezután csak a ki-/bekapcsolás segített, mert ettől kezdve sehol nem volt kép, a TV tunerjén sem. Ezt már rég nem csinálta, mivel már nem zaklatom ilyen "dúrvademókkal". Ez egy csúnya BUG, de lehet, hogy már javították... jó lenne tudni, miket javítanak az új firmware-kben, de ezt nem írják meg.
Mégegyszer leírom: minden _filmet_ lejátszik!
Nézd meg a TSMuxerral, hogy milyen fomátum illetve codec stb. van az mkv-ban. -
Zoli_2010
schumacher26
#19261
Én nem játszom a TV-n (sajnos ehhez már nincs "kedvem" -- vagyis időm, meg gépem...). De ha 1-2 óra játék után 1-2 órát a TV műsor megy, akkor nem lehet baj. Illetve, ha váltogatod a játékokat. Olyat is már olvastam, hogy valakinek "beégett" egy RTL logó, pedig nem is mindig azt nézte. Sajnos ez sem kizárt, hogy ha valaki minden nap csak 4-5 óra hosszat ugyanazt az adót nézi, ugyanolyan képmérettel (tehát ugyanott van a logó), akkor jópár hónap alatt a panel ezen a részen másképpen (jobban) öregszik. Akkor is, ha közben pár órában mást is néz. Sajnos a plazma emlékezik...
Na, azért nem akarok pánikot kelteni, de érdemes erre odafigyelni, főleg a hardcore játékosoknak.
((Ja, és láttam már alaposan beégett LCD monitort is, ami fix telepítésű megfigyelő kamerák képét mutatta, 1-(2-3) év után szürke háttéren simán látszanak a kontrasztok...)) -
Zoli_2010
schumacher26
#19259
Sajnos itt csak SCART-os settopboxom van, tehát nem állítja a képarányt (remélem, a HDMI-s képes erre). Tehát, a box 4:3-ban van, és ha alul-felül fekete csík van, akkor kinagyítom. Ekkor persze romlik a felbontás. Ha 16:9-ben adnak, akkor a box-on is át tudom állatani 16:9-re, így kitölti a képet. (De vannak hülye TV-k, amelyek 4:3-ba teszik bele a szélesvásznú filmet, és ekkor ha 16:9-re teszem a boxot, akkor jobbról-balról meg alul-felül is csík van, de tényleg.)
Mér nem lehet HDMI-s boxot adni a digitális kábeltv-hez???
a 6500-ast nem ismerem, de az biztos jobb, mint a 430-as
ja, a ghost csak sötétben látszik, fekete vagy szürke képernyőn, és max 50-60 centiről nézve...
Zoli_2010
Let's go
#19255
Szerintem igen, de lehet, hogy csak úgy képzelem (ez ugye eléggé szubjektív). Most is látni ghostot (túl vagyok már az 5-600 órán), de sötétben, fekete képernyőn látszik, hogy ott marad a csatorna logó meg egyebek. -- Éjjel kikapcs, és lehet még másnap is meglátszik, amíg valami más le nem mossa. Én amúgyis mindig állítgatom a képarányt, meg ha lehet, a nagyítással kitolom a logókat felül (pl. ha 4:3-ban adnak szélesvásznú filmet
így nincs esélye beégni.
De legjobb a HD-s filmeket nézni. Ott nincs logó. Médiaplayernél a Toolsban állítható be a képméret/képarány is. Meg az optikai hangkimenetre a DTS illetve Dolby Digital is a hangmenü alján.(!) -
Zoli_2010
Gabor970
#19247
A 1021-es firmware nagyon SOKAT javít a DVB-T vételen! Nekem most 1-2 hónapig nagyon gyenge volt, (barkácsolt antennával, mivel lusta vagyok megcsinálni). A foci VB alatt végig jó volt, csak nagy esőben viharban nem. Aztán kb. 0 1019, 1020-as firmwarekkel nem volt vétel, csak nagyon szép időjárás esetén (amiugye elég ritka mostanság
). 30-as jelszint alatt esélytelen volt.
Tegnap este is, 9-es (!) jelsztintnél max színes kockákat láttam. Aztán a 1021 firmware feltolása után nem hittem a szememnek. Ugyanúgy 9-es jelszint, iszonyatos bithiba arány mellett, tökéletes volt a kép is hang is...
(nem akarom elkiabálni, ma még nem próbáltam, lehet, hogy tegnap éjjel 1.kor csak ezt álmodtam...
Zoli_2010
Let's go
#19251
A menü "sötétítést" az előbb írtam le, olvass is ne csak írj...
szerk: ja, látom megtaláltad.Plusz info: a beépített mediaplayernek "korlátozott" a tekerése...?
A << / >> gombokkal valóban, és sokáig én is azt hittem.
De! A "kurzor" gombok (tehát az OK körül a négy irány):
le/fel = a film elejére/végére ugrik
a jobbra/balra = egyszeri nyomásra 10-20mp-et ugrik, -- nyomva tartva viszont egyre gyorsabban pörgeti a filmet!
Persze, ha nagyon begyorsul, akkor már akár 5-10 percet is ugrik, ilyenkor könnyen túlszalad a keresett részen.
Remélem segítettem, jó kis cuccokat gyárt a Samsung, bár ezeken a TV-ken is lenne még mit jobbítani (lenne pár tippem). -
Zoli_2010
Let's go
#19245
Először nálam is így volt, mert alapból a kiemelt beállításokkal indul a TV, minden üzemmódban. Ezért az első beállításkor a menü tényleg kicsit ghostol. Amint lehet, vissza kell venni minden beállítást a bejáratáshoz. Minden forrásnál _külön_ lehet megadni az értékeket, tehát a TV analóg/digitális, a SCART bemenet, a komponens és a beépített MediaPlayer mind-mind külön beállítható, a kiemelt/normál/film üzemmód mindegyikben más értékekre állítható, egyénileg testre szabható (ezt itt már sokan tudják, de először nekem is új volt megszokni, a régi TV-k nem voltak ilyen rugalmasan beállíthatóak).
A kiemeltnél a cellafény, kontraszt is maximumon van ,ezeket a bejáratáshoz vissza vettem alacsonyabbra -- 12-re és 60-ra. A normálnál is kicsit vissza kellett húzni.A MédiaPlayer-nél filmlejátszás közben "Tools" gombot kell nyomni, és ott a sok beállítási lehetőség!!! Itt _kell_ visszavenni kiemeltről a képmódot ahhoz is, hogy a Médiaplayer menüje ne virítson. folyt.köv...
Zoli_2010
Let's go
#19237
Helló, nekem PS50C430 van, mindent(!) lejátszik. Eddig 2 film volt, amit nem, az egyik egy Depeche Mode koncert volt, az Level@5.1 -el volt kódolva, TSMUXER kb 2-3 perc alatt átkonvertálta @4.1-re, -- mivel azt viszi csak. Ez a leggyakoribb manapság, de még bele lehet futni @5.1-be is... egy másik film (Haláli hullák hajnala) viszont kockásodik, erre nem találtam én sem megoldást. Mást mindent lejátszik -- május óta már pár filmet megnéztem
Zoli_2010
fiorella
#17093
Ez nálam is egy kis fejtöréssel járt (még tegnap is találtam új menüpontokat a 2 hónapos TV-ben
A médiaplayer-nek van külön "Tools" menüje, a Samsungnál ebben van lejátszáskor minden beállítás (hang, képméret,...), és nem az egyébként a TV módban működő funkciógombokon, mint pl. a "Picture Size". {Kivéve a "Picture Mode" gombot, de hadd ne részletezzem jobban}
Mindig várom, hogy az új Firmware talán ezen is javít, de sajnos nem...Ha nem kell hozzá nagyon torzítani, akkor a 2. nagyítást szoktam használni, ami kitölti a képet.
Zoli_2010
fiorella
#17086
A médialejátszós képarányhoz:
Samsung PS50C430-ason sem lehet -- az egyébként a TV adásnál elérhető -- többféle nagyítást használni USB-ről való filmnézésnél.
Csak 3 méret beállítás van:
Eredeti = (divxnél a kép közepén egy téglalap, HD-s anyagnál persze kitölti a képet -- ha nem 16:9-es, akkor alulfelül fekete csík)
1. nagyítás = a képet szélességében a képernyőhöz igazítja (alulfelül lehet csík)
2. nagyítás = a képet magasságában is a képernyőhöz igazítja (teljesen kitölti a képet, függőlegesen nyújt...)A kép két szélének levágására sosincs lehetőség, olyan nagyítás nincs, még TV módban sem.
Zoli_2010
DM-Fan
#16700
Ebben elvileg teljesen igazad van. Gyakorlatilag sztatikus feszültség miatt már USB csatlakoztatásánál is akadt problémám, igaz, csak PC-vel, és nem a TV-vel. (a munkahelyi PC-m többször újraindult pendrive bedugásakor, egy másik gépen pedig 2,5"-es USB HDD-től "eldurrant" egy tranzisztor az alaplapon a PCI aljzatok között, -- gondolom az USB tápért is ez felelt... -- alaplapcsere lett a vége)
Azért nyugodtan lehet pendriveot és külső USB-s HDD-t dugdosni, csak óvatosan a feltöltődéssel...
A HDMI-nél más a helyzet, ott ugye a kábel másik végén is egy 230V-ra kapcsolt eszköz van, saját tápegységgel -- itt lehet olyan feszültségkülönbség, ami bedugáskor tranziens formájában tönkreteszi valamelyik portot. Ezt jobb kerülni...
Zoli_2010
#16712
Szia, mérd meg egy multiméterrel az antenna-aljzaton -- egy beledugott kábelen persze könnyebb, úgy nem kell a TV mögé hajolni --, hogy átkapcsolva az antennára kiadja-e az 5V-ot. Szerintem nem. Nekem Samsung van, az nem ad ki 5V-ot (ami egyébként az erősítős antenna megtáplálását szolgálná). Nekem egy antenna szaküzletben azt mondták, hogy egyik TV sem ad ki 5V-os feszültséget az antenna-csatlakozón. (Persze lehetnek kivételek). Hogy korábban miként működött, azt én sem értem...
Zoli_2010
Ez így van, nézegetem is a Conax modulokat éppen. (de miért nem kerülnek a felébe? használtan is minimum 9ezer...)
Meg akkor még antenna-átkapcsoló is kell a tetőantenna és a kábelTV között.A settopbox még kikapcsolva is meleg, legalább 10-15W-ot ehet, bekapcsolva meg már forró...
Zoli_2010
Az oldalpanel nálam "fényes" szürkére van állítva. Ami fekete, az az adásban van benne sajnos
-- persze csak 4:3-as forrásanyagnál, mert ha 16:9-es az adás, akkor minden rendben van. Ilyenkor, ha 4:3-ra kapcsolom a TV-t, akkor még látom ráadásul a TV saját szürke oldalsávjait, és azon belül még két fekete sávot is, ami a settopboxból jön. Ugyanez van a földi M1, M2, Duna esetében is -- mivel kiegészítik a 4:3-as forrást gyárilag a kétoldalán fekete panelekkel 16:9-re.
Ilyenkor a TV-t 16:9-re állítva a TV saját szürke oldalpaneljai már nem látszanak, csak az adásban lévő fekete, amit sehogy sem tudok "kinagyítani" a képből. Ezért én inkább 4:3-ra állítom a settopboxot (így használva ki a teljes képernyő-szélességet), ezzel sajnos minden 4:3-as műsor 16:9-re széthúzva jelenik meg, ezért még ránagyítok függőlegesen is, hogy elviselhető legyen a képarány. Sokszor nem kár az alsó/felső sávért, de néha olyan közeli képeket mutatnak, hogy az emberek homloka már le van vágva...
(persze, mert a szélesvásznú anyagból is gyakran csak a kép közepét teszik elénk -- kb. a film 60%-át lehet látni, és ilyenkor van az, hogy két orr beszélget...)Röviden: x@r a műsorsugárzás, na.
Inkább nézek rendes felbontású és oldalarányú filmeket a TV műsor helyett. -
Zoli_2010
fiorella
#16446
Nem hagyott nyugodni, tegnap este megnéztem ismét, hátha valami jobb lett a digitális kábeltv-n... -- átkapcsoltam a settopboxot 16:9-es képmódra (azaz 16:9-es TV-hez): az 50 digitális csatornából talán ha 5-6 volt 16:9-es. Ez persze függ(het) az éppen adott műsortól is, de ez az arány jellemző. És sajnos nem az ismeretterjesztő/természetfilm csatornák, vagy a filmcsatornák jönnek 16:9-ben, hanem az M1, M2, Duna (igen, a kábeltv-n is ezek), meg egy két "Ozone+"-akármi csatorna, meg a német RTL.
Ilyenkor sajnos a többi 45 csatornánál két oldalt vastagon fekete csík van, ami nem jó a plazmának, mivel ott nem használja a pixeleket, ezért eltérően öregedik a panel. Ennek látható nyoma is van 4:3-as tévézés után még hosszú percekig...
-- Visszaállítottam 4:3-ra. így legalább a nagyítással ki tudom tolni a 4:3-as adásból az alul/felül csíkokat (mivel sok adó szélesvásznú műsorokat is ad, de 4:3-ban sugározva, pl Discovery, NatGeo...), illetve a logókat is -- beégésvédelem
, és így NEM csak a képernyő közepén nézek egy 32"-es képet az 50"-es plazmán. A kézi nagyítgatás nekem nem gond, úgyis mindig nyomkodom a távkapcsolót...Nálam a kábelTV-n a digitális adás sokkal jobb minőségű az analógnál.
De a lényeg: HD-s filmekhez vettem a plazmát, meg DVD-hez, amire nagyon jó ez a méret!
Zoli_2010
sagvary
#16415
A mai plazmáknak már egész jó a fogyasztásuk, nekem az 50"-es kb. 110-150W között fogyaszt. A plazmánál a fogyasztás nagyon függ a képtartalomtól, fényerőtől-kontraszttól. (80-230W között változhat, tehát ha sok a világos és fehér képtartalom, meg minden maximumuon van akkor 200W körül mozog, normál használatnál talán 130W, sötét filmnél 100W körül, vagy alatta is marad.
Hasonló 46"-os LCD-nél 80-240W-ot írnak, 46"-os LED-esnél 170W-ot. (ez mind a három Samsung)Gyakorlatilag tehát már nincs különbség, de nézd meg az adott típusnál, mert a tavalyi TV-k még 30-50%-al többet is fogyaszthattak.
Zoli_2010
fiorella
#16409
Igen, a 16:9-es az szép és jó, ha még ráadásul HD-s is akkor nagyon szép...
Digitális adás már most is van, a földfelszíni sugárzás (DVB-T), -- vagy ha úgy ismered a MindigTV -- (M1 HD, M2 HD, DunaTV HD, Autonómia...) sok helyen elérhető tetőantennával, pesten néhol szobaantennával is. 2012-ben valószínűleg a hagyományos analóg földfelszíni sugárzás fog megszűnni, de már addig is lehet nézni az új digitálisat.
Ez már szerencsére 16:9-es adás, de sokszor csak 4:3-as anyagot adnak benne, a kép két oldalán (függőlegesen) széles fekete csíkkal ellátva, amit nem lehet kilőni, vagy átállítani pl.szürkére, mert az adás része, benne van a képben. Ettől szerintem egyhamar nem szabadulunk meg, a sok régi műsor miatt. Mozifilmnél pedig alul-felül lehet csík...
Van már régóta kábelen is digitális adás (DVB-C) az analóg mellett, ez korábban set-top-box-al ment, ma már majdnem midegyik tévé tudja közvetlenül venni a beépített DVB-C tunerrel. Sajnos 4:3-ban adják a legtöbb műsort, ami azt jelenti, hogy pl. egy filmnél az antennával vett M1HD-n nincs fekete csík, a kábelen a settopbox-ból meg csíkkal jön a kép...
Comedy central nálunk nics, a cool tv itt is elég gyatra, és kézzel szoktam széthúzni, kinagyítani. -
Zoli_2010
fiorella
#16404
Szia, 16:9 pl. a földi digitális adás az M1 HD-n, az rendben, 16:9-ben jelenik meg, csíkok nélkül. (és ezen lehet még nagyítani akár kézzel is). Néha 4:3-ban adnak, akkor viszont két oldalt lesz fekete csík (M2, Duna,...), azokat nem lehet széthúzni sem oldalra. KábelTV-n előfordul nálam is 16:9-es adás, akkor néha az automatika átváltja a képarányt (gondolom, valami vezérlőjelet is sugároznak az adásban). Ha nem, akkor kézzel lehet zoomolni.
Zoli_2010
pisti0315
#16398
Helló,
nekem PS50C430-as van, már kb. másfél hónapja. Nagyon elégedett vagyok vele.
A beépített médiaplayere minden filmet jól lejátszik, de azért sikerült már megfektetni párszor. (Igen tudom, hogy ez nem egy Dune Base1.3, majd olyat is veszek, ha lesz miből... addig is nagyon jó ez, mert HD-s anyagot másképp nem is tudnék nézni.)
Lehet valahogy e-mailben vagy a Samsung honlapján "problémákat" jelenteni? Esetleg várható még hozzá javított firmware?Letöltöttem mindenféle HD-s demókat, és bár a HD-s hangot (lossless Dolby TrueHD, DTS-HD MasterAudio -- legalábbis valamelyiket) lejátszaná, de ilyenkor a hang nagyon szaggat a TV-n és az erősítőn is. Még sima DTS-ben is előfordul, ha például bejön egy vízesés jelenet, vagy egy helikopter leszáll a dús aljnövényzet közé, akkor néha szaggat a hang, pedig a DTS-t csak ki kellene tennie az optikai kimenetre. Érdekes, hogy csak a hang hagy ki, a képen nem láttam szaggatást. (és persze pont a pörgős jeleneteknél...
Néha, amikor elindítok valami filmecskét, kikapcsolódik a kép (tök sötét lesz), a hang szól tovább, el lehet indítani másik filmet, át lehet kapcsolni TV-re, csatornát váltani ide-oda, de a képet nem tudom visszahozni, csak a TV ki- és bekapcsolásával. Ez most a hétvégén 3-szor is előfordult. -- ez lehet komoly bug is, vagy csak egy egyedi hiba?
Olyat is láttam, hogy lejtszás közben bekockásodott, majd szétesett a kép, és visszaugrott 10-20 másodpercet, aztán ment tovább.
Bocs a sok kérdésért, de jó lenne valakivel beszélni, aki látott már hasonlókat... különben a fejlesztésben is vannak magyarok, vagy itthon csak összeszerelés van?
Előre is kösz a választ! -
Zoli_2010
Dorian
#15968
Helló, amit letöltöttél, az egy EXE, és közel 50MB, ugye? El kell indítani, kitömöríti magát valahova (választható). Azután már a TV megtalálja az új firmware-t. Lehet, hogy utána áramtalanítani is kell, mert nekem az első frissítés után, amikor újraindította magát, egyre jobban bekockásodott (színes kockák sávokban) a digitális földfelszíni (DVB-T) adás. Kikapcsolt állapotban, a tápkábel ki...be után már minden rendben volt. (Samsung PS50C430 -- ezen a típuson nincs főkapcsoló)
Zoli_2010
Samsung PS50C430
Ez a plazma is zúg, a kiemelt(--iszonyatos) beállításnál, világos képeknél jobban, de normál beállításoknál alig hallható. (tényleg 0-ra kell levenni a hangerőt hozzá)
A beépített médialejátszóval teljesen elégedett vagyok, feliratkezelés, DTS optikai kimenet, minden rendben.
Ami zavaró volt, az a médiaplayer MENÜ-je, mert mindig a kiemelt képbeállításokkal jelent meg. Ezt _képnézegetés közben(!)_ lehet állítani, a <Kiemelt/Normál/Film> üzemmódra váltva, illetve a TOOLS gomb menüjének a "Képbeállítások" menüpontjában finomítva. Ezután már nem égeti ki a szemem.
Ma este kipróbálom, hogy TrueHD, DTS-HD hanganyagot lekeverve kiadja-e DTS-ben.
(olvastam a vitát, és én már 1 hete megírtam egy félmondatban, hogy kijön a DD és a DTS az optikain, értem ezalatt az 5.1-et. igazi HD-s hangot még nem próbáltam...) -
Zoli_2010
Samsung PS50C430 -hoz: 2 hetes a készülék.Most hétvégén közelről megvizsgáltam, sötétben, az AV bementre átkapcsolva, -- és bizony így tisztán látható, hogy még mindig van ghost a képen (meccs után az eredményjelző, illetve az élő felirat is tisztán kivehető). 15-20 perc tévézés után elhalványul.
A beégésvédelem 4 pixelt tologat le/föl, meg oldalra, 10 perces időzítéssel,-- nem tudom, hogy ez mit ér, én inkáb eltolom a képet félóránként pár centivel le/fel. Kicsit macerás.Más kérdés: M1 HD földi digitális adásnál nagyon szép a kép, de a képernyő jobb harmadán, illetve a jobb felső saroknál a zöld gyepen a pixelek nagyobb felületen véletlenszerűen sötétpirosan villognak
. Ez csak közvetlen közelről látható, 1m-nél messzebről észrevehetetlen. Mi lehet ennek az oka? Az antenna, a konvertálás 720p-re, vagy kódolás/dekódolás? Egyéb tipp? -
Zoli_2010
Még nem 'kalibráltam' be a TV-t, (cellafeszültség pl.?..), de eddig úgy láttam, hogy ennél sokkal feketébb már nem is lesz. Akkor látok csak jó feketét, ha a Scart-ra kapcsolok, ahol éppen nincs bejöbő jel. Ekkor, 4-5 mp múlva feketére vált a kép -- na ezzel a feketével már elégedett lennék
. De ha bármit megnyomok (hangerőt pl.) akkor ismét visszakapcsol sötétszürkére.
Ez valami energiatakarékos módra váltás, ha nem kap jelet? Majd megnézem, ilyenkor leesik-e a fogyasztása is...
Ugyan csak egy szimpla árammérő van rajta, 0,1A-es felbontással, de ezzel ellenőrizve bőven hozza a gyári adatokat. Film módban ~0,3A (~70W), normál módban ~0,4-0,5A (~100-110W), fehér képnél 0,6A(140W) is lehet. A kiemlet módnál 1-1,1A (230-260W) -- ezt meg úgysem használom...Samsung PS50C430
Zoli_2010
Helló,
médiaplyeres _lejátszás közben_ a Tools gombot nyomd meg, ott lehet képméretet (Eredeti - 1. nagyítás - 2. nagyítás) is állítani. A hangbeállítások között legalul, az equalizer alatt lehet választani, hogy az optikai kimeneten PCM vagy Dolby Digital vagy DTS menjen ki (persze csak ha van a felvételen). Van még pár 'eldugott' dolog. Pl. a filmben a le-fel nyíllal az elejére-végére ugrik, jobbra-balra nyíllal 1 gombnyomás=10mp ugrás, nyomva tartással egyre gyorsulva teker bele (kb. 1 perc alatt végigkereshető a film). Az alsó "tekerő"gombokkal ugye csak 1-2-3 fokozatban választható a gyorsított lejátszás. (ezek sincsenek benne aleírásban, lehet még több kellemes meglepetés is)Nálam (látható) ghost már nincs, remélem nálad is csak a médiplayer filemenüje hagyott nyomot... mert én sávosodást különben nem láttam, teljesen homogén a 'fekete' (azaz sötétszürke
) felület. -
Zoli_2010
hunsatman
#14820
ezt egy korábbi hsz-ból mentettem le, még nem próbáltam ki:
Én az avsforum.com kalibráló anyagát használtam (AVS HD709). Van hozzá leírás is (angolul).
Egy csomó dologhoz viszont műszer kellene, hogy korrekt legyen.
De az alap fényerő, kontraszt, szín beállításhoz például (sok egyéb beállító lemez mellett) ez is jól használható.
Zoli_2010
hunsatman
#14826
Egyszer kétszer ránéztem a szervizmenüben, egy hét alatt kb. 45 órát ment. Holnap lesz két hetes. Én 200 órára gondoltam, amíg még kímélem. Az első héten láttam egy kis ghostot, mostanában már nem. Ami durva, az a beépített médiaplayer file-nézet menüje -- erős fehér keretekkel, ahol nem tudok (nem lehet(?)) kímélő beállításokat alkalmazni ... ha itt sokáig keresgélek -- próbálgatom a különböző filmeket/formátumokat, az utána meglátszik egy ideig. Ezért ezt most hanyagolom...
Zoli_2010
Gabor970
#14798
Hello, én is ilyen TV-t vettem, lassan letelik a bejáratás is, ezután szeretném majd 'bekalibrálni'. Kíváncsian várom az általad jónak talált beállításokat.
Addig is egy kérdés: én mélyebb feketét vártam egy plazmától. Eddig még sajnos csak sötétszürke képet láttam, akár a komponens bemeneten (DVD, progresszív), akár a beépített médialejátszóról néztem. Mivel lehet sötétebb feketét elérni? Vagy az csak a HDMI bemenetről várható? TV műsornál annyira nem érdekel, de DVD illetve HD filmeknél fontos lenne... köszönöm.
Ja, még valami, a médiplayer eddig mindent lejátszott, bár néha a kiterjesztést át kell írni (mov => avi, m2ts => ts). Több hangsávot, feliratokat is kezeli. DTS ill. Dolby Digital (ha van a filmben) optikán megy az erősítőre, HD-s hangsávot DTS-re lekeverve adja ki
Zoli_2010
Helló, nem semmi, hogy mióta keresgéled már az okát. Erre nem gondoltam, de így már beugrott, én is láttam már hasonlót. Ezekszerint a TV tunerje még az AV bementre átkapcsolás után is működik(?), és kiadja a SCART-on a vett jelet.
Az pedig a SCART kábelben, vagy a beltériben valamilyen áthallással visszamegy az AV-bemenetre -- így belezavar. Egyirányú SCART kábellel nem szabadna megtörténnie. (itt amúgyis fölösleges a TV-->műholdvevő irány...)
- 8 GB-os GeForce RTX 2060 SUPER (OEM HP) - garanciával
- Számítógép - Gamer PC! Csere-Beszámítás! R5 5600G / RTX 4060 / 32GB DDR4 / 1TB SSD
- Apple iPhone 16 Pro Max 256GB,Újszerű,Dobozaval,12 hónap garanciával
- iPhone XS Max 256GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3997
- Új HP 17 FHD IPS AMD Ryzen5 7520U 4.3Ghz 8GB DDR5 256GB SSD AMD Radeon 610M Graphics Win11 Garancia
