TP-Link WDR3600 - N600 router
ZPKing
Eddig eljutottam már:
hogy ha küldök valamit a nyomtatóra akkor ezt látom a sys logba.
Apr 29 17:57:37 xxxxxx lpr.err p9100d[2440]: write: Input/output error
Apr 29 17:57:37 xxxxxx kern.warn kernel: [ 218.370000] usblp0: nonzero write bulk status received: -32
Apr 29 17:57:37 xxxxxx lpr.notice p9100d[2440]: Finished job: 0 bytes received, 0 bytes sent
Apr 29 17:57:47 xxxxxx lpr.notice p9100d[2440]: Connection from 192.168.1.113 port 58949 accepted
Apr 29 17:57:47 xxxxxx kern.warn kernel: [ 228.470000] usblp0: nonzero read bulk status received: -32
Apr 29 17:57:47 xxxxxx kern.err kernel: [ 228.480000] usblp0: error -32 reading from printer
Apr 29 17:57:47 xxxxxx kern.warn kernel: [ 228.480000] usblp0: nonzero read bulk status received: -32lsusb -v re ezt látom:
Bus 001 Device 007: ID 03f0:0517 Hewlett-Packard LaserJet 1000
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x03f0 Hewlett-Packard
idProduct 0x0517 LaserJet 1000
bcdDevice 1.20
iManufacturer 1 Hewlett-Packard
iProduct 2 hp LaserJet 1000
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 7 Printer
bInterfaceSubClass 1 Printer
bInterfaceProtocol 2 Bidirectional
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0001
Self Poweredmi lehet még gond?
ZPKing
Segítség kellene nekem p910ND nyomtató szerver beállításba.
HP laserjet 1000 a nyomtató.
aki csinált már ilyet kérem írjon pü-be
köszi előre is
Peti -
ZPKing
Cups alatt (192.168.1.1:631) printers alatt
drivert mindent kiválasztottam viszont a képen látható status hiba van.
Laptopról rá is küldi a nyomtatni valót[/L
nem jövök rá mi hiányzik neki még.
Ötlet?
Köszi előre is -
ZPKing
Sikerült mindent beállítanom a wdr3600-on.
Usb swap extroot beállítva.
Van HP laserjet 1000 nyomtatóm gyári nyomtatóport - usb átalakítóval.
ezt akarom feltenni.
Cups és vagy P910nd protokollal.
de valahogy nem akar elindulni.
openwrt látja is és kérés megérkezik a cups-ba de nem nyomtat.
Valaki állított már be hp laserjet nyomtatót? Openwrt-re?
Köszönöm előre is. -
ZPKing
Intruder2k5 #1814 üzenetére
ZPKing
Megvan a wdr3600 routerem.
szépen be lőttem netet dyndns-t wifiket.
minden megy.
usbre tértem rá de mindjárt az elején megakadtam
kmod-usb-storage és a kmod-fs-ext4 csomagot nem tudom feltenni
következő hibával áll meg:
root@OpenWrt:~# opkg install kmod-usb-storage
Installing kmod-usb-storage (3.3.8-1) to root...
Downloading http://oscamwrt.mooo.com/wrt/apr_13/ar71xx/generic/packages/kmod-usb-storage_3.3.8-1_ar71xx.ipk.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-usb-storage:
* kernel (= 3.3.8-1-5440da3a2c45184a32da6bba25b8dd2a) * kernel (= 3.3.8-1-5440da3a2c45184a32da6bba25b8dd2a) *
* opkg_install_cmd: Cannot install package kmod-usb-storage.
root@OpenWrt:~# opkg install kmod-fs-ext4
Installing kmod-fs-ext4 (3.3.8-1) to root...
Downloading http://oscamwrt.mooo.com/wrt/apr_13/ar71xx/generic/packages/kmod-fs-ext4_3.3.8-1_ar71xx.ipk.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-fs-ext4:
* opkg_install_cmd: Cannot install package kmod-fs-ext4.
root@OpenWrt:~#package listát frissítettem előtte.
ez a firmware van fent Oscam miatt:
http://oscamwrt.mooo.com/wrt/apr_13/ar71xx/___8mb___/
innét szedi a package listát:
http://oscamwrt.mooo.com/wrt/apr_13/ar71xx/generic/packages/minden más csomag fel megy
pl block-mount mount-utils e2fsprogsvan egy 1GB-os usb pendrive swap és extroot partíciót szeretnék sinálni ext4
de mivel ez a két package nincs fent nem látom az usb pent.Szerintetek mi a gond???
Köszi előre is. -
ZPKing
Nálad ez wdr3600 nál áll fenn? és Openwrt alatt?
Mert nálam ez a jelenség wr1043alatt van és hiába váltok csatornát hiába veszem le csak b-gre
akkor is kiakad a wifi meg ugrál az RX TX érték.
És az érdekes az hogy az előz öreg asus wl500gp v2 router simán ment hónapokig hiba nélkül ugyan ezekkel a kliensekkel.
A wr1043ND topikba is sokan írják hogy ez tipikus betegsége ennek a routernek mert sok embernél ezt csinálja.
Azért akarok váltani mert az eszközeim tudják az 5GHz-t aztán az talán még üres is a környéken. -
ZPKing
Egy ilyen TL-wdr3600 routerre szeretném cserélni a tl-wr1043ND routeremet azért mert ez állandóan eldobálja a wifit ha terhelve van a router. (pl nas torrentezik)
Azt mondják 1043 topikjába hogy ennek ez a gyenge pontja nekem pont ez kellene.
Ennek a wifijével mi a helyzet? Openwrt szeretnék rajta használni.
Köszi előre is
- GYÖNYÖRŰ iPhone 13 128GB Blue -1 ÉV GARANCIA -Kártyafüggetlen, MS3688, 100% Akkumulátor
- BESZÁMÍTÁS! Intel Core i7 4790K 4mag 8szál processzor garanciával hibátlan működéssel
- HIBÁTLAN iPhone 14 Pro 256GB Gold -1 ÉV GARANCIA - Kártyafüggetlen, MS3519
- Microsoft Surface Pro // Surface // Surface laptop // 7-10.gen i5, Ryzen // 12,5 13,5 15 //
- Fém, összecsukható és kihúzható fotó állvány eladó
