Keresés
Gh0sT
Ezt találtam:
''ABIT IC7 series mainboards do support dual channel DDR 266/333/400 (shows as the table below). With only one DDR memory module installed (single channel mode) the board still works fine but we highly recommend users install memory modules in pairs to feature the best performance by dual channel mode.''
- BESZÁMÍTÁS! Apple MacBook Pro 14 M4 Max 36GB RAM 1TB SSD macbook garanciával hibátlan működéssel
- iPhone 15 Plus 128GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4271
- Panasonic LUMIX G 25mm f/1.7 ASPH objektív
- MSI Gaming Thin 15 - 15.6"FHD 144Hz - Ryzen 7 7735HS - 16GB - 1TB - Win11 - RTX 4060 - 2,5 év gari
