S_x96x_S
Azért elég drágaság az EPYC 8 magos
( ~ $2100 USD ) de a Xeon Gold-hoz képest még mindig olcsóbb ...
Xeon Gold 6250 vs. EPYC 7F32 - 8-Core Server CPU Performance On Ubuntu 20.04
https://www.phoronix.com/scan.php?page=article&item=epyc7f32-vs-gold6250&num=1
"On a performance-per-dollar basis using the Intel/AMD list prices, to little surprise the EPYC 7F32 held a dominating lead in coming in at around $2100 USD compared to the Xeon Gold 6250 at $3400 list. I haven't been able to find any EPYC 7F32 retail unit in stock at the usual Internet retailers while for the Xeon Gold 6250 it seems to be commanding even a $3700~3800 price." -
S_x96x_S
Nézegetem az új APU-t .. mi van benne,,
és érdekes a Sensor Hub - ami giroszkóp és gyorsulásmérő ; és ez régebben nem volt ..
és valószínüleg az okostabletekbe se árt .."One of the missing features for those with AMD Ryzen laptops has been the lack of a Sensor Fusion Hub driver that is needed for supporting the accelerometer and gyroscopic sensors for the display and related laptop sensor functionality. This week AMD finally posted patches for a Sensor Fusion Hub Linux driver." ( via - januári phoronix hír )
S_x96x_S
Honor Magicbook 14 Notebook Review: Where Style Paints a Picasso
( Ryzen 5 3500U )
https://www.anandtech.com/print/15786/honor-magicbook-14-notebook-review -
S_x96x_S
AMD Ryzen™ Processor Software Optimization (30 perc )
https://www.youtube.com/watch?v=d0TMCbDDg5g
Ken Mitchell, CPU Developer Technology Team Lead
Join AMD Game Engineering team members for an introduction to the AMD Ryzen™ family of processors followed by advanced optimization topics. Learn about the high-performance AMD “Zen 2” microarchitecture and profiling tools. Gain insight into code optimization opportunities and lessons learned. Examples may include C/C++, assembly, and hardware performance-monitoring counters.
Attendees will learn optimizations for the high-performance AMD “Zen 2” microarchitecture.
érdekes slide-ok vannak benne:via https://twitter.com/chiakokhua/status/1261933094149357569
( összesen 6 videó ; https://gpuopen.com/lets-build/ )
1. AMD Ryzen™ Processor Software Optimization
2. Optimizing for the Radeon™ RDNA Architecture
3. From Source to ISA: A Trip Down the Shader Compiler Pipeline
4. A Review of GPUOpen Effects
5. Curing Amnesia and Other GPU Maladies With AMD Developer Tools
6. Radeon™ ProRender Full Spectrum Rendering 2.0: The Universal Rendering API -
S_x96x_S
"Or on a geometric mean basis, the Ryzen 7 4700U came out to being 72% faster than the i7-1065G7."
https://www.phoronix.com/scan.php?page=news_item&px=149-Benchmarks-Renoir-IceLake
S_x96x_S
AWS státsz
- ZEN2-s Epyc még nem elérhető, a ZEN1-es szerepel ...
de ettől függetlenül nem lesz sima menet ..
de legalább lesz választék, és az ügyfelek minimum elcsesznek 1-2 napot, hogy kiválasszák a megfelelő architektúrát
"Benchmarking Amazon's Graviton2 Performance With 64 Neoverse N1 Cores Against Intel Xeon, AMD EPYC"
https://www.phoronix.com/scan.php?page=article&item=amazon-graviton2-benchmarks&num=1 -
S_x96x_S
Petykemano #3131 üzenetére
> AMD döntése, hogy megszakítja a zen3 támogatását
> korábbi alaplapokon.
az a kérdés, hogy a B550-be 2 generációt bele lehet-e pakolni ...
pl. 2 APU generációt ... -
S_x96x_S
"Initial AMD Ryzen 7 4700U Linux Performance Is Very Good"
https://www.phoronix.com/scan.php?page=article&item=ryzen7-4700u-linux&num=1 -
S_x96x_S
Petykemano #3113 üzenetére
> DDR vs HBM latency
érdekes téma.
habár szerintem nem szabad leragadni a lokális optimumoknál
... hanem a teljes rendszer sebességét kell nézni ..
szebben megfogalmazva:"While that can increase the use of DRAM, another technique has eaten into the DRAM market. It turns out that greater average latency can be achieved not by adding more fast memory like DRAM, but by adding more slow memory, like flash, behind a fast memory. Handy details the reasons for this in a separate blog, since it’s not intuitive."
https://semiengineering.com/what-is-drams-future/vagyis valamilyen szempontból az Intel-es OptaneRAM-os stratégia életszerű.
viszonta HBM-nek is ven helye .. -
S_x96x_S
néha érdemes újraolvasgani ...
The microarchitecture of Intel, AMD and VIA CPUs
By Agner Fog. Technical University of Denmark.
Copyright © 1996 - 2020. Last updated 2020-03-08.https://www.agner.org/optimize/microarchitecture.pdf
22.3 The AMD Zen kernel
The Ryzen processor put AMD back in the game after they had lagged behind Intel for
several years. The Zen kernel has a throughput of five instructions per clock cycle, which is
the record so far. The throughput is particularly high for 128-bit vector code. The Ryzen can
calculate four 128-bit floating point vectors per clock cycle, or two 256-bit vectors.
The high throughput places a higher burden on programmers and compilers to utilize the
increased instruction level parallelism in single threaded applications. The core throughput
is so high that it makes good sense to run two threads per core, unlike some other
processors with less core throughput which are likely to see a serious performance drop
due to the two threads competing for the limited resources.
The new μop cache is an important improvement which removes the bottleneck of
instruction fetching and decoding in most of the critical loops.
The large caches at all levels is a particularly important improvement. But the cache
bandwidth is limited to 32 bytes per clock which is less than the best competing Intel
processors.-------------
For many years, the RISC philosophy has been considered the best way to high
performance. The Intel Core microarchitecture as well as the AMD design indicates a new
trend away from RISC and back to the CISC principle. The RISC-like design of the P4 with
its very long pipeline and long execution latencies was not convincing, and the trace cache
appears to have been inefficient. The advantages of going back to CISC design are
threefold:
1. The compact CISC code gives better utilization of the limited code cache area.
2. Fewer μops per instruction gives higher bandwidth in the pipeline.
3. Fewer μops per instruction gives lower power consumption.
The main disadvantage of a CISC design is that instruction decoding becomes a bottleneck.
The AMD processor has a higher decoding bandwidth than the Intel design because of the
technique of storing instruction boundaries in the code cache. The Intel design is still limited
to a decoding rate of 16 bytes of code per clock cycle, which is insufficient in many cases.-------------
"There is a remarkable convergence between the Intel and AMD microarchitectures thanks
to a patent sharing agreement between the two companies. Intel's stack engine and the
mechanism for predicting indirect branches have been copied by AMD. We can also expect
Intel to some day match AMD's 32-bytes instruction fetch rateThere is unfortunately not always convergence on the instruction set extensions. Intel's
SSE4.1 and SSE4.2 instruction sets are very different from AMD's SSE4.A and XOP
(formerly known as SSE5), and the intersection between these two sets is quite small. Intel
has never copied AMD's 3DNow instruction set which is now obsolete, but they have copied
the successful x64 extension from AMD and a few other instructions. AMD has traditionally
copied all Intel instructions, but sometimes with a lag of several years. Fortunately, AMD
has revised their proposed SSE5 instruction set to make it compatible with the AVX coding
scheme (as I have previously argued that it would be wise of them to do). The latest AMD
processors now support Intel's AVX2 instruction set, including the 256-bit YMM vector
registers. It may take several years before AMD supports AVX512.
S_x96x_S
érdekes marketing nevek ..
" Ryzen 7 Extreme Edition " ..
https://videocardz.com/newz/amd-ryzen-9-4900u-and-ryzen-7-extreme-edition-spotted -
S_x96x_S
(May 8, 2020)
3.5-inch SBC offers Ryzen V1000 and up to four GbE ports
http://linuxgizmos.com/3-5-inch-sbc-offers-ryzen-v1000-and-up-to-four-gbe-ports/
"The CAPA13R is available now at an undisclosed price. " -
S_x96x_S
solfilo #3082 üzenetére
> Érdekes ez az ábra,
ami érdekes ( és nekem fájó ) ,
hogy a B550 megjelenésekor
nincs "támogatott" Desktop APU ( "Ryzen Renoir Desktop")
amit be lehetne tenniRemélem, hogy igazak a pletykák és júliusban már lesz ..
ici - pici NUC szerű gépre vágyom ...
és sajnos - valószínüleg az ASROCK "DeskMini A300" már ugrott ;
és nem lehet tudni mi lesz helyette ...
Azért Reménykedem. -
S_x96x_S
macskásodik az AMD .. AMD Remote Workstation
S_x96x_S
+2 hír:
New Lenovo ThinkPad Range with Ryzen 4000 & 4000 PRO Mobile( Ryzen 7 Pro 4750U ; Ryzen 5 Pro 4650U ; Ryzen 3 Pro 4450U )
AMD Announces Ryzen Pro 4000 for Mobile: 8 Cores, 15 W, 4.1 GHz -
S_x96x_S
The AMD Ryzen 3 3300X and 3100 CPU Review: A Budget Gaming Bonanza
https://www.anandtech.com/print/15774/the-amd-ryzen-3-3300x-and-3100-cpu-reviewmég több:
https://videocardz.com/86840/amd-ryzen-3-3300x-and-ryzen-3-3100-review-roundup -
S_x96x_S
jönnek az olcsó A520-as lapok is
"Asus is listing 5 motherboards based on affordable A520 chipset"
https://www.guru3d.com/news-story/asus-is-listing-5-motherboards-based-on-affordable-a520-chipset.htmlés érdekes az Ryzen 1600 AF - mint olcsó szerver lehetősége is.
( ASRock X470D4U server alap-lappal )AMD Ryzen 5 1600 AF Review A Wildcard Server Option
https://www.servethehome.com/amd-ryzen-5-1600-af-review-a-wildcard-option/ -
S_x96x_S
thgergo #3075 üzenetére
> Ellenben magának az nvme / pcie -nek is van késlelteése: ~50000 ns,
> ami nem sokkal jobb mint a Sata.a SATA protokoll még a HDD-kre lett tervezve .. lejárt az ideje
"The NVMe specification was designed from the ground up for SSDs. It is a much more efficient interface, providing lower latency, and is more scalable for SSDs than legacy interfaces, like serial ATA (SATA)."
https://nvmexpress.org/
https://en.wikipedia.org/wiki/NVM_Express -
S_x96x_S
dolgoznak a linux kernelen ...
(ZEN3) MPK = Memory Protection Keys
https://lore.kernel.org/lkml/158880240546.11615.2219410169137148044.stgit@naples-babu.amd.com/
via:
New Linux Patches Confirm Next-Gen EPYC "Milan" CPUs To Support MPK
https://www.phoronix.com/scan.php?page=news_item&px=Next-Gen-EPYC-Does-MPK-Linux -
S_x96x_S
amúgy a szokásos - unalmas - hirek; az új ZEN3-asokról nem sok új infó.
- "Azure NVv4 instances powered by AMD 2nd Gen EPYCTM Processors and AMD Radeon InstinctTM GPUs tackles"
https://community.amd.com/community/radeon-instinct-accelerators/blog/2020/04/20/nvv4-expands-virtualization-opportunities-for-financial-services- "The Acer Swift 3 SF314 Notebook Review: Swift Gets Swifter With Ryzen 4000"
https://www.anandtech.com/print/15762/the-acer-swift-3-sf314-review-swift-gets-swifter-with-ryzen-4000- Best CPUs for Workstations May 2020
érdemes megnézni a AT-es ajánlást ...
https://www.anandtech.com/show/11891/best-cpus-for-workstations- Linux ( " automatically load AVX2-optimized libraries on AMD CPUs" )
"AMD Working With GNU Developers To Provide More Robust Runtime Detection For Better Performance"
https://www.phoronix.com/scan.php?page=news_item&px=AMD-GNU-Discussing-Better-RT- Lenovo ThinkSystem SR665 and SR645 Sport Dual AMD EPYC
https://www.servethehome.com/lenovo-thinksystem-sr665-sr645-dual-amd-epyc/ -
S_x96x_S
Petykemano #3068 üzenetére
> És ilyen chipletet a későbbiekben akár - ad abszurdum nem képadó
> gyorsítóként - desktop, vagy threadripper csomagra is lehet illeszteni
valami lesz
ha nem az AMD, akkor az Inteles Raja Koduri - majd kitesztelni
de az önvezető autóknál (ami jelenleg nVidia felségterület)
is szükség lehet egy gyors képfeldolgozásra .. -
S_x96x_S
Petykemano #3066 üzenetére
ettől függetlenül hasznos volt ..
végre most megnéztem, hogy mi az a "NVDIMM-P" .. ez az Optane memory megfelelője
majd ilyen támogatást kell keresni az AMD-nél is....
https://en.wikipedia.org/wiki/NVDIMM#Types -
S_x96x_S
Petykemano #3064 üzenetére
"Genoa" platform mintha ZEN4 + 5nm lenne .. ; talán ...
S_x96x_S
Petykemano #3060 üzenetére
> "Ryzen 7 4700G"
Jó lenne már valami hir ..
de
lehet, hogy fake ? vagy csak félreértem a figyelmeztetést .....
- https://twitter.com/momomo_us/status/1256957241925623813 -
S_x96x_S
Petykemano #3054 üzenetére
> 5nm 2020-ban?
vad ötleteim:
- Lehet, hogy valamelyik Konzolcsip hirtelen átvált 5nm-re?
- vagy egy új (mobil) APU -t fabrikálnak az Apple -nek----------------------
Amúgy én ezen az " Centaur's NCORE" - szerű elgondolás - AMD-s megvalósításán gondolkodtam ..
pl. Egy teljesen integrált APU-ban az AVX2 / AVX-512 utasításokat át tudná lökni a GPU-s résznek .. vagyis közös szilikon ...
https://twitter.com/gsnedders/status/1256290112763236354
S_x96x_S
jönnek a RYZEN PRO -os Thinkpad T14 -ek!
Az árak CDN == kanadai dollár , de ami látszik, hogy kb 15%-al olcsóbb a legolcsóbb AMD-s konfig az Inteles verzióhoz képest.
- Az Inteles konfigban a i5-10210U - 14nm-es 4c/8t ..
- és sokkal több az Inteles verzió .. és bizonyos konfigok ( pl. 3840 X 2160 ) csak Inteles verzióban vannak meg ..- LENOVO COMMERCIAL FRENCH THINKPAD T14 AMD GEN 1, AMD RYZEN 5 PRO 4650U (2.10GHZ, 3MB), 14.0 1920 X
- LENOVO COMMERCIAL THINKPAD T14 AMD GEN 1, AMD RYZEN 7 PRO 4750U (1.70GHZ, 4MB), 14.0 1920 X 1080 Nteljes lista:
https://www.pccanada.com/inventory.asp?search=t14----------
másik hír: Új AMD ZEN3 utasítások ---> jobb memóriavédelem
Persze az Intel után adaptálva;
PCID = Process Context Identifier
PKE/MPK = Memory Protection Keys
"PCID and PKE/MPK functionality is almost surely part of the AMD Zen 3 processors launching later this year."
"AMD Programmer Manual Update Points To PCID Support, Memory Protection Keys"
https://www.phoronix.com/scan.php?page=news_item&px=AMD-PRM-PCID-PKEY -
S_x96x_S
> esélyes az árcsökkentés..
> ... bár tippre a 3600 megy be 157(+/-5)$
szerintem $150 alá talán bemegy a 3600 ára .. ( az én tippem )
meg az is kérdéses, hogy az új AMD-s Desktop APU-knak milyen lesz az árazása ...Ha az AMD agressziv szeretne lenni és még több piacot nyerni, akkor ezt most kellene megtennie, a mostani Intel-es 14nm+++++++ technológiával szemben.
persze lehet más értelmes stratégia is ..
S_x96x_S
Nézegetem a rivális Comet Lake árakat
https://videocardz.com/newz/exclusive-intel-10th-gen-core-comet-lake-s-final-specs-and-pricing-leakedés pár procit elég jól áraztak ..
- Intel "i5-10400F 6C/12T" turbo: 4.3 GHz == 157 USD
vs.
- AMD Ryzen 5 3600 6C/12T turbo 4.2 Ghz == 189 USD ( New Egg mostani ár )
- AMD Ryzen 5 3600X 6C/12T turbo 4.4 Ghz == 204 USDegy átlagember úgy okoskodik, hogy olcsóbb és a turbó is jó ; --> akkor Intel .
vajon erre mit lép az AMD ...
S_x96x_S
AMD RYZEN 3 3300X - Várható ár Áfával 48 890 Ft (4c/8t -1 ccx-ben)
AMD RYZEN 3 3100 - Várható ár Áfával 40 790 Ft (4c/8t - 2 ccx-ben)
AMD RYZEN 5 1600 (12nm) - 34 290 Ft (6c12t)-----------------------
CPU Retail Sales (Week 17 Mindfactory)
AMD: 7100 units sold, 89.14%, ASP: 217.41
Intel: 865, 10.86%, ASP: 317.35
AMD Revenue (Euro): 1543600, 84.9%
Intel Revenue: 274510, 15.1%AM4: 7050
1151: 865
Threadripper TR4: 30
Threadripper TRX4: 20
https://twitter.com/TechEpiphany/status/1254531154889314305 -
S_x96x_S
Lisa Su: “One of our large cloud customers was able to deploy 10,000 2nd Gen Epyc servers in less than 10 days to support the surge in demand for their collaboration services.”
( a pletykák szerint - Microsoft vagy az Oracle lehetett ez az ügyfél )STH:
* AMD EPYC 7F72 Benchmarks and Review 24 CoresVideoCardz:
* HP OMEN 15 (2020) laptop features Ryzen 7 4800H and GeForce RTX 2060
* AMD Ryzen Threadripper 3980X (48-cores) CPU-Z screenshot emerges -
S_x96x_S
Petykemano #3041 üzenetére
> Ez eléggé elszomorító ahhoz képest, hogy az Intel milyen
> bevételnövekedésről tanúskodott ugyanebben az időszakban.A Enterprise piacra arany tojást tojó tyúkként vigyáz az Intel.
Árat csökkent, diszkontot ad, és tartja a reményt a vásárlókban ...Mindenesetre az új high EPYC 7F32/7F52/7F72 procik kellettek a piacnak. És talán a ZEN3-as EPYC is jó helyre talál be ..
In either case, the market's bullish prospects for AMD's EPYC Rome processors might be blunted by the lower revenue generation in this key segment. The unit posted a $26 million operating loss compared to an operating income of $45 million in the fourth quarter of 2019. AMD cited lower EPYC ASPs due to heightened cloud spending, but Intel's aggressive strategy of slashing pricing on its competing Cascade Lake Refresh processors might come into play. Intel's server unit (DCG) also recently posted a 42.7% year-over-year sales increase due to coronavirus-spurred demand.
However, AMD cited a double-digit sequential increase in EPYC server chip sales for a 3x year-over-year improvement, and Su maintained the company's position that it will reach double-digit market share by next quarter. AMD also expects its semi-custom revenue (i.e., console chip sales) to improve as it ramps for the PlayStation 5 and Xbox Series X launches later this year.
https://www.tomshardware.com/news/amd-record-1q-2020-ryzen-4000-rdna-2-zen-3 -
S_x96x_S
"Zen3 and RDNA2 still set for launch in late 2020"
https://twitter.com/IanCutress/status/1255251403754418187 -
S_x96x_S
AMD Reports First Quarter 2020 Financial Results
Revenue grows 40 percent year-over-year; Gross margin expands to 46 percent
SANTA CLARA, Calif., April 28, 2020 (GLOBE NEWSWIRE) -- AMD (NASDAQ:AMD) today announced revenue for the first quarter of 2020 of $1.79 billion, operating income of $177 million, net income of $162 million and diluted earnings per share of $0.14. On a non-GAAP* basis, operating income was $236 million, net income was $222 million and diluted earnings per share was $0.18.Current Outlook
"For the second quarter of 2020, AMD expects revenue to be approximately $1.85 billion, plus or minus $100 million, an increase of approximately 21 percent year-over-year and 4 percent sequentially. The year-over-year increase is expected to be primarily driven by growth of Ryzen and EPYC processor sales. The sequential increase is expected to be primarily driven by EPYC processor and semi-custom sales. AMD expects non-GAAP gross margin to be approximately 44 percent in the second quarter of 2020. The sequential decrease is expected to be primarily due to the initial ramp of next-generation semi-custom products." -
S_x96x_S
Petykemano #3034 üzenetére
annyira nem vagyok szakértő, csak érdeklődő ..
optane/3dXpoint -nál. hogy kijöjjenek az előnyök, kell egy szoftveres támogatás ...
valamint a szoftver architektúrákat is fel kell készíteni,
ami nem olyan könnyű.
Emiatt most csak az Enterprise vonalon van meg a kapacitás és a pénzügyi finanszirozás az optimalizációra.
a consumer vonalon, amit még az intel jelentősen nyomott, teljesen elakadt.
még nagyon az elején vagyunk a folyamatnak ... -
S_x96x_S
EPYC 7F32/7F52/7F72 (Linux) teszt by Phoronix
( új oprendszer, új fordítóval, ami már valószínüleg a ZEN-es magokat is optimalizálja - legalábbis jobban mint a régi 18.04LTS )"Initial Benchmarks Of The AMD EPYC 7F32 Performance On Ubuntu 20.04 LTS"
https://www.phoronix.com/scan.php?page=article&item=amd-epyc-7f32&num=1 -
S_x96x_S
S_x96x_S #3028 üzenetére
Köszönöm a visszajelzéseket Micron HSE - ügyében ..
valószínüleg ez még nem a full Optane RAM -os helyettesítő ..
csak szoftveres optimalizáció a filerendszer overheadjének kiküszöbölésére."This HSE storage engine depends upon an mpool object storage media pool that is implemented as a Linux kernel module. Mpool interfaces with SSDs or other persistent memory storage directly, bypassing file-systems and other overhead while also supporting replication across classes of memory and other storage features"
https://www.phoronix.com/scan.php?page=news_item&px=Micron-HSE-Projectmindenesetre én nagyon ki vagyok éhezve az ilyen hírekre (is) ..
A szűk keresztmetszet ( nálam - legtöbbször ) már az I/O ...
Remélem idén lesz valami előrelépés .. -
S_x96x_S
off:
talán ez a Micron HSE ( Heterogenous-Memory Storage Engine ) ...
lehetne valami Optane helyettesítő ?
https://investors.micron.com/news-releases/news-release-details/micron-unveils-worlds-first-open-source-storage-engine-designed -
S_x96x_S
játéktesztek ..
ENGLISH – LENOVO IDEAPAD S540 13ARE VS 13IML – AMD RYZEN 7 4800U VS INTEL CORE I7 10710U
https://next.lab501.ro/notebook/english-lenovo-ideapad-s540-13are-vs-13iml-amd-ryzen-7-4800u-vs-intel-core-i7-10710u/16érdekesség
"And I have to admit, I have never tested a notebook that allows the user to manually set all three possible TDPs specified by the CPU manufacturer, and for sure I did not expect to see something like this on a 13″notebook. And yet, the Lenovo IdeaPad S540 13ARE handles itself brilliantly regardless of TDP, the cooling system doing its job every time. Of course, in Extreme Performance mode the fans can become quite annoying, but this is inevitable if we want the performance of a desktop CPU in a 13″ chassis."
S_x96x_S
S_x96x_S #3023 üzenetére
csak összehasonlításként
- Az Intel is frissitett
https://www.lenovo.com/de/de/laptops/ideapad/s-series/IdeaPad-5-15IIL05/p/81YKCTO1WWDEDE1/customize?Alap:
Intel Core i5-1035G1 Prozessor (4 Kerne, 8 Threads, bis zu 3,60 GHz, 6 MB Cache)+ 160,00 €
Intel Core i7-1065G7 Prozessor (4 Kerne, 8 Threads, bis zu 3,90 GHz, 8 MB Cache)Az Intel mellett (ami már 10nm) az
AVX-512 ; (Intel® DL Boost) és az Optane szól ;
de sajnos nincs belőle 6 és 8 magos verzió.valamint nVidia is van
Alap: NVIDIA GeForce MX330, 2 GB GDDR5, 64 Bit
+ 30,00 € : NVIDIA GeForce MX350, 2 GB GDDR5, 64 Bitmindenesetre szerintem 1-2 hét és lesznek tesztek is és meglátjuk hogy az AMD hogy szerepel ...
ARK-os összehasonlítás:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=196603,196597
Ami érdekes, hogy az ajánlott ár különbsége
( $426.00 - $297.00 = 129$ )
az OEM nél már 160 EUR lesz ; persze az árfolyamok és a VAT ... -
S_x96x_S
IdeaPad 5 15
itt már 8GB az alap
és ezt már lehet + 16GB -ra is konfigurálni +40.00 EUR-ért.
( 16 GB DDR4 3.200 MHz verlötet )
https://www.lenovo.com/de/de/laptops/ideapad/s-series/IdeaPad-5-15ARE05/p/81YQCTO1WWDEDE1/customize?Alap:
AMD Ryzen 5 4500U Prozessor (6 Kerne, 6 Threads, 8 MB Cache, bis zu 4,00 GHz)+ 30,00 €
AMD Ryzen 5 4600U Prozessor (6 Kerne, 12 Threads, 8 MB Cache, bis zu 4,00 GHz)+ 100,00 €
AMD Ryzen 7 4700U Prozessor (8 Kerne, 8 Threads, 8 MB Cache, bis zu 4,10 GHz)+ 130,00 €
AMD Ryzen 7 4800U Prozessor (8 Kerne, 16 Threads, 8 MB Cache, bis zu 4,20 GHz) -
S_x96x_S
Lassan indul a gőzhenger .. notebook fronton ..
A németeknél az IdeaPad 3 - 419.00 EUR -tól indul.
alap:
AMD Ryzen 3 4300U Prozessor (4 Kerne, 4 Threads, 4 MB Cache, bis zu 3,70 GHz)
+50.00 EUR:
+150.00 EUR:
https://www.lenovo.com/de/de/laptops/ideapad/s-series/IdeaPad-3-14ARE05/p/81W3CTO1WWDEDE0/customize?Ha a ThinkPad-ek is ilyen CPU felárasak lesznek,
akkor nekem +150 EUR-t megér a jobb proci..
- ami mellé nem is nagyon kell asztali gép
( legalábbis ahhoz amit én csinálok ).. -
S_x96x_S
7:3 ( AMD vs Intel CPUs )
https://www.tomshardware.com/features/amd-vs-intel-cpus -
S_x96x_S
Petykemano #3014 üzenetére
> .. pin kompatibilis ..
> Elvileg úgy került ki az info, hogy valami partnertől.logikus ..
sok potenciális OEM partner (nuc,notebook,ipari pc) vacillál még
,hogy 1 generáció miatt érdemes-e belekezdeni az amd platformba...
szerintem az ő megnyugtatásuk miatt lett ez az infó kiadva.ha 2 generációt kiszolgál,
akkor az sokkal jobb hatást kellt a gazdaságossági - megtérülési számításoknál. ( a fix tervezési költség jobban eloszlik )szerintem a jövő évi csipeket 2 tokozással tervezik .. és a piaci követelményeknek megfelelően rugalmasan tudnak reagálni ..
( Amikor az AM4 indult, ott is volt előző generációs (Excavator?) - új foglatos proci ) -
S_x96x_S
AMD Ryzen 4000 Desktop APU Surfaces
https://www.tomshardware.com/uk/news/amd-ryzen-4000-desktop-APU-processor -
S_x96x_S
The ASRock Rack EPYCD8-2T Motherboard Review: From Naples to Rome ( ~ $498 )
https://www.anandtech.com/print/14171/the-asrock-rack-epycd8-2t-motherboard-review -
S_x96x_S
Petykemano #2997 üzenetére
> A zen3-hoz tartozó microkód 12KB lesz
ha jó tudom, a biztonsági patch-ek microkód-ban is jöhetnek,
emiatt így nagyobb lehet a tér az optimális fixeknek ..valamint lehet, hogy az optimalizációs táblázatok is nagyobbak.
talán ...
S_x96x_S
"The three new processors, the AMD EPYC™ 7F32 (8 cores), EPYC™ 7F52 (16 cores) and EPYC™ 7F72 (24 cores), expand 2nd Gen AMD EPYC performance leadership into workloads that can leverage up to 500 MHz of additional base frequency, and large amounts of cache, making AMD EPYC™ the world’s highest per core performance x86 server CPU*.i
" ( amd pr )AMD EPYC 7F52 Benchmarks Review and Market Perspective
https://www.servethehome.com/amd-epyc-7f52-benchmarks-review-and-market-perspective/
AMD’s New EPYC 7F52 Reviewed: The F is for ᴴᴵᴳᴴ Frequency
https://www.anandtech.com/print/15715/amds-new-epyc-7f52-reviewed-the-f-is-for-frequencyAMD EPYC 7F52 Linux Performance - AMD 7FX2 CPUs Further Increasing The Fight Against Intel Xeon
https://www.phoronix.com/scan.php?page=article&item=amd-epyc-7f52&num=1High-Performance, Balanced Core Count: AMD 8-Core and 16-Core (7FX2) + Micron 7300 NVMe on Microsoft SQL Server 2019
https://www.micron.com/about/blog/2020/april/AMD-7FX2-and-Micron-7300-NVMe -
S_x96x_S
Petykemano #2927 üzenetére
> Mit tud egy N1-hez.képest érzésre?
39%?
"1. N2D-standard-32 performed 39% better than N1-standard-32 when evaluated using Coremark."
https://cloud.google.com/blog/products/compute/announcing-the-n2d-vm-family-based-on-amd -
S_x96x_S
van az a pénz ...
AnandTech editor reports that Intel may be incentivizing mini PC makers to delay or not build AMD-based models
" Prominent OEMs like Dell, Asus and MSI do not even offer any AMD-based mini PCs.
Some of the OEMs that already joiend AMD’s “anti-NUC alliance” include OnLogic, EEPD, Simply NUC, Tranquil PC and ASRock.
https://www.notebookcheck.net/AnandTech-editor-reports-that-Intel-may-be-incentivizing-mini-PC-makers-to-delay-or-not-build-AMD-based-models.461262.0.html -
S_x96x_S
joysefke #2988 üzenetére
> Miért fordulna ez most vissza?
az evolució nem visszafordulás ..
Xeon Phi gyorsítókártyához hasonlóra gondoltam ..
attól, hogy az Intelnek nem sikerült piacképes terméket fabrikálnia,
attól még hasznos lehet bizonyos feladatokra .akinek kell plusz CPU ; az még hozzáad 1-2 PCIe-s extra CPU kártyát ..
képzelj egy GPU szerűséget - 16 db ZEN CPU-s chiplettel .. amit csak bedugsz a gépedbe.
nem köti a foglalat mérete ... akár lehet 32 db ZEN CPU chiplet is ...
vagyis 32*8 = 256core/512thread ( "unfair advantage")
és ebből +4 kártya ...
alap ZEN 64 core + bővítőkártyán : 4x256 = 1088 ZEN core 1 workstation-ben,
ami ott van az asztalod alatt. -
S_x96x_S
Petykemano #2986 üzenetére
> De az is izgalmas lenne, ha Milan esetén nem csillagpontos lenne
> a kommunikáció, hanem gy ilyen gyűrűt alkotnának a CCD-ksimán ..
én már a 4 foglalatos szervereket
és a 256 magos CPU-s gyorsítókártyákat is (bele) látom ...
persze ez lehet, csak PCIe5.0 -nál lesz .. csak ..( persze ez az IF ábra .. a " next two generations "-ra vonatkozik
.. és nem tudom, mi valósul meg a következő lépésben ... ) -
S_x96x_S
csak érdekességképp ...
az üzenete = A fejlesztők kezdik belakni az új AMD cpu-kat ..
Optimizing Git For Ryzen CPUs (1.5x Faster)
https://docs.keydb.dev/blog/2020/04/08/blog-post/ -
S_x96x_S
.. az ár nem publikus ..
Quad-HDMI Ryzen V1000 signage system has four M.2 slots, too -
S_x96x_S
friss Anandtech-es mobile review .
core-to-core latency ... a ccx-es kialakítás meglátszik ... remélem a ZEN3-asnál már jobb lesz ez is .. de ez se annyira rossz ..
és ez az Intelé
vagyis a jó ütemezés ( közel pakolja a kapcsolódó programszálakat )
a ryzen-nél jobban számít. -
S_x96x_S
végre valami hír .. szerintem szeptember körül még csak a desktop apu-jön zen2-es alapon.
Report: AMD Ryzen 4000 Desktop CPUs Arriving in September Timeframe
"Nevertheless, DigiTimes' sources claim that AMD will unleash its new army of Ryzen 4000-series chips after August or September."
https://www.tomshardware.com/news/amd-ryzen-4000-desktop-cpus-release-date -
S_x96x_S
Petykemano #2971 üzenetére
> széles körben le fogják húzni és azt fogják sugallni,
> hogy ha találsz legalább egy okot, amiért az intelt érdemeseb venni,a paradigmaváltás az emberek, sőt még a szakértők
- egészségügy - pl. a mostani járvány ...
- Intel management
- technikai újságírók
fejében is lassú folyamat .. aztán már késő ..
persze egy újságíró nagyon nem sokat veszíthet, hogyha nincs igaza ..
mert csak egy "kicsit" torzít ...
kedvencem:
https://www.youtube.com/watch?v=saNvY4tD3wA -
S_x96x_S
mítoszrombolás .. Jim Keller
és a Zen core
Ian Cutress:"Keller worked on K12 and high level zen core. Not platform"
Q:"wait what, is this public? A lot of people credit him with Zen but sounds like he had a far smaller role than fanboys think"
Ian Cutress: "When I interviewed him, there was a lot of discussion on twitter about his exact role. We ironed it out. He was mostly involved in K12/Skybridge. For most of Zen you'll have to thank Mike Clark, Suzanne Plummer, and the rest of that team." ( 2018. nov. 21 )
Ian Cutress: "Keller himself said he's not a visionary. He just builds what people tell him to"
Ian Cutress: "Keller was at AMD from 2012-2015. Papermaster said that decisions they took ~4 years ago are being implemented today, so 2015 = 2019 product Those decisions can be very handwavy that far out, dependent on process, test chips, how well EPYC performed etc"
https://twitter.com/IanCutress/status/1065207966834597888és a leapfrogging design teams is fontos volt az innovációban.
S_x96x_S
Petykemano #2967 üzenetére
> Linus videóját szerintem érdemes megnézni ab zephyrusról.
ő minden ASUS Zephyrus -ért lelkesedik ...
( 2 évvel ezelőtt : https://youtu.be/DFWxNffYtos?t=468 )
véletlenül nem pontosan kerestem és ezt dobta ki ...de azért egy picit tényleg lelkesebb most
https://youtu.be/ZYqG31V4qtA?t=565 ( <--- és tényleg érdemes megnézni annak aki nem látta )Persze sokaknak még ez se elég ..
mert biza ... nem tudja az 5Ghz-etRemélem Thinkpad-ban is látunk hamarosan hasonló
amd mobil procikat ..feltételezem .. hogy 2 héten belül még sok más új amd mobile procis notebook-ot látunk még ... és ez még csak az eleje ...
S_x96x_S
újabb szörny. 12 magos AMD Ryzen 9 3900 -el.
"ORIGIN PC EON15-X leads the way for desktop-level PC gaming on a notebook. Play your favorite games with a 12-core AMD Ryzen 9 3900 desktop processor for improved multitasking, an NVIDIA GeForce RTX 2070 with Max-Q design with support for real-time ray tracing, up to 32GB of DDR4 RAM, and a 15.6” 144Hz 1080p narrow bezel display for a gaming experience that rivals desktops."
https://videocardz.com/newz/origin-pc-announces-eon15-x-gaming-laptop-with-up-to-ryzen-9-3900-and-geforce-rtx-2070 -
S_x96x_S
Petykemano #2948 üzenetére
> Új video a zen3-ról: AdoredTV-től
2 perces szöveges verzió :
https://adoredtv.com/exclusive-zen-3-to-feature-10-15-increased-ipc-32-mb-of-l3-cache-per-ccx/persze lehet, hogy a 2 perc is túl nagy ár elolvasni a szöveget is,
azoknak kimásolom a lényeget:"
ZEN3:
- according to our new leak the IPC gain is only 10-15% on a single threadMilan A0 silicon is now being tested with B0 to come out around September. Currently, SMT does not work on A0 samples, meaning that Milan is still in its infancy. Just as we speculated during AMD’s Financial Analyst day,
Milan could be a very late 2020 product or even only arrive as early as Q1 2021Lastly, we do actually have a small Zen 4 leak, and it’s mostly just confirmation of logical speculation and assumptions.
Zen 4 will feature more cores, a new socket, 1 MB L2, AVX 512 support, and improved IPC on the 5nm node.
Again, nothing groundbreaking, but the enlargement of the L2 cache and addition of AVX 512 support is interesting.
"megj: persze AdoredTV szavahihetősége lenullázódott ... most újból gyűjti a karma pontokat.
és persze a DDR5-ről nem ir semmit se ... -
S_x96x_S
A ZEN4 -ben várható már a DDR5 ( de lehet, hogy már a ZEN3-ban is lesz )
- A beépített ECC kifejezetten csábító."To improve performance and increase reliability in server scenarios, DDR5-8400 will use on-die ECC (Error Correction) and ECS (Error Check and Scrub) which is a milestone in the production of DDR5. This is expected to reduce overall costs, with ECS recording any defects present and sends the error count to the host. This is designed to improve transparency with the aim of providing enhanced reliability and serviceability within a server system. Also integrated into the design of the DDR5-8400 DRAM is Decision Feedback Equalization (DFE), which is designed to eliminate reflective noise when running at high speeds. SK Hynix notes that this increases the speed per pin by a large amount."
"SK Hynix if still on schedule with the current Coronavirus COVID-19 pandemic, looks set to enter mass production of DDR5 later this year."https://www.anandtech.com/show/15699/sk-hynix-ddr5-8400
Azért én reménykedem már egy ZEN3-as DDR5-ben is. ( párhuzamosan a DDR4 mellett )
pár DDR5-8400 -memóriával - kiosztaná az összes konkurenciát.
De az is lehet, hogy az ZEN3-as Threadrippereknél lesz ilyen ... az úgyis prémium ár, meg pár hónappal később jön ki. -
S_x96x_S
> Amd milyen terméket ajánl processzor tekintetében irodai munkaállomás felhasználásra?
> Minimál VGA kell és csak a CPU teljesítmény per ár a meghatározó szempont?ThinkCentre M75s Small Form Factor -
* a grafikus kártya "AMD Radeon™ 520 2GB Low Profile"
* és "AMD Ryzen™ 5 PRO 3600"A PRO procik az AMD-nél az extra biztonsági dolgokkal felszerelt procik.
de ezt az igényt ( a biztonságot ) nem irtad mint alapvető követelmény, sok cégnél ez még annyira nem is igény ..
pl. itt van egy ilyen extra:
https://www.amd.com/en/technologies/guardmi
- full memory encryption
- secure boot process
- Support of Windows 10 security features: Device Guard, Credential Guard, TPM 2.0, VBS, and others.-----------------
HP EliteDesk 705 G5 kis helyigényű | HP® Hungary
http://h20195.www2.hp.com/v2/getpdf.aspx/4AA7-6364HUE.pdf
itt az Elérhető processzorok :
- AMD AthlonTM PRO 300GE APU RadeonTM Vega 3 grafikus vezérlővel (3,4 GHz-es alap órajel, 192 KB L1 gyorsítótár, 1 MB L2 gyorsítótár, 4 MB L3
gyorsítótár, 2 mag);
- AMD RyzenTM 3 PRO 3200G, RadeonTM Vega 8 grafikus vezérlővel (3,6 GHz-es alap órajel, akár 4 GHz-es megnövelt órajel, 384
KB L1 gyorsítótár, 2 MB L2 gyorsítótár, 4 MB L3 gyorsítótár, 4 mag);
- AMD RyzenTM 5 PRO 3400G, RadeonTM Vega 11 grafikus vezérlővel (3,7 GHz-es
alap órajel, akár 4.2 GHz-es megnövelt órajel, 384 KB L1 gyorsítótár, 2 MB L2 gyorsítótár, 4 MB L3 gyorsítótár, 4 mag);
- AMD RyzenTM 5 PRO 3600 (3,6 GHz-es alap órajel, akár 4,2 GHz-es megnövelt órajel, 384 KB L1 gyorsítótár, 3 MB L2 gyorsítótár, 32 MB L3 gyorsítótár, 6 mag);
- AMD RyzenTM 7 PRO 3700 (3,6 GHz-es alap órajel, akár 4,4 GHz-es megnövelt órajel, 512 KB L1 gyorsítótár, 4 MB L2 gyorsítótár, 32 MB L3 gyorsítótár, 8 mag);
- AMD RyzenTM 9 PRO 3900 (3,1 GHz-es alap órajel, akár 4,3 GHz-es megnövelt órajel, 768 KB L1 gyorsítótár, 6 MB L2 gyorsítótár, 64 MB L3 gyorsítótár, 12 mag);Elérhető grafikus kártya:
Integrált:
- AMD RadeonTM Vega 11 grafikus vezérlő; AMD RadeonTM Vega 3 grafikus vezérlő; AMD RadeonTM Vega 8 grafikus vezérlő
Különálló:
- NVIDIA® GeForce® GT 730 (2 GB dedikált GDDR5);
- AMD RadeonTM R7 430 grafikus vezérlő (2 GB dedikált GDDR5);
- AMD RadeonTM RX 550X grafikus vezérlő (4 GB dedikált GDDR5)Azért szerintem 6,8,12 magnál már kell egy dedikált 2GB-os dedikált GPU
- ezen a szinten már ez a minimál ... ( néha már a böngészőnek kell ennyi ) -
S_x96x_S
> akkor az AMD-nek nem igen van ajánlata
> A felvetés onnan jön, ha megnézem melóhelyen a hardver katalógustinkább az OEM-től függ ez aki beszállít nektek.
és beszállítókat néha sokéves szerződés köti ,
meg lehet, hogy az Intel nagyobb jutalékot csurgat vissza, mégha a többfeltfelárat az ügyfél fizeti meg .
Van az a pénz, amiért még az Intel security problémákat is elnézik.pl. a Dell-nél csak a gaming desktop -ra van mutatóban AMD.. [link]
Az Intelesnél az i9-hez és a legtöbb i7-hez adnak geForce-ot ..
ugyanígy adhatnának az új 12/16 magos ryzenekhez.
de nincs. ilyen az élet.--------------
A HP-nek és a Lenovo-nak van ryzen 3000-es üzleti desktopja, a Dell-nek nincs.
https://ir.amd.com/news-releases/news-release-details/amd-announces-worldwide-availability-amd-ryzentm-pro-3000-series
- Powerful performance for energy-efficient business desktop PCs from processors offering up to 12 cores
- Strong portfolio of enterprise offerings from global commercial PC manufacturers including HP and Lenovo -
S_x96x_S
zen1-es embedded... frissen tesztelve ( April 3, 2020 )
Azt nem értem, hogy az X570 chipset-ben miért nem lehetett 1x10Gb Lan.., ha ebben meg 8x 10Gb -van.AMD EPYC 3451 Benchmarks and Review A 16 Core Xeon D Competitor
https://www.servethehome.com/amd-epyc-3451-benchmarks-and-review/ -
S_x96x_S
a covid-19 áldozata .. - legalább egy negyedévvel csúszik a TSMC 3nm.
mi lesz így , az Intel visszaveszi a vezetést...
TSMC POSTPONES 3NM PROCESS PLANS BY 4 MONTHS, AT LEAST
https://www.gizchina.com/2020/03/31/tsmc-postpones-3nm-process-plans-by-4-months-at-least/The world's largest contract chipmaker is planning to launch mass production of its 3nm process sometime in 2022, and media reported Monday that installation of production equipment in its 3nm wafer fab in Tainan will be delayed to October from June this year, which will delay its trial production set for 2021.
"The COVID-19 escalation has hit Europe, and [Netherlands-based] ASML Holding, which is TSMC's major production equipment supplier, has been affected by a lockdown. It is understandable that the progress of TSMC's new technology has been affected," Huang said. -
S_x96x_S
Crippled No Longer: Matlab Now Runs on AMD CPUs at Full Speed
https://www.extremetech.com/computing/308501-crippled-no-longer-matlab-2020a-runs-amd-cpus-at-full-speed -
S_x96x_S
erre nem igazán tudok válaszolni.
* nem bencshmarkoltam ..
* ráadásul i/o érzékeny a feldolgozásom. ( sok adatmozgatás )
* és sajnos downgradelni kellett ( 8 cpu intel --> 4 cpu nd2 amd ) ,
mert a külső adatok a koronavirus miattextrém módon lecsökkentek.
Ha meg már downgradelem, akkor miért ne Amd cpu legyen ..
* átállítottam a gép típusát,
* újrafordítottam a kódokat ( mert valami ok miatt szeretekmarch=native
-ra fordítani)
* és minden működött elsőre .. -
S_x96x_S
Felhőben ( Google Cloud) átálltam ZEN2 (
AMD EPYC 7B12 ) -re
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 48 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 49
Model name: AMD EPYC 7B12
Stepping: 0
CPU MHz: 2250.000
BogoMIPS: 4500.00
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 64 KiB
L1i cache: 64 KiB
L2 cache: 1 MiB
L3 cache: 16 MiB
NUMA node0 CPU(s): 0-3
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Full AMD retpoline, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nop
l nonstop_tsc cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy a
bm sse4a misalignsse 3dnowprefetch osvw topoext ssbd ibrs ibpb stibp vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec
xgetbv1 clzero xsaveerptr arat npt nrip_save umip rdpid
Az EPYC "7B12" elég friss .
S_x96x_S
Petykemano #2922 üzenetére
Az AMD váratlanul előrébb hozta az új mobil laptopok sajtó embargójának a végét ,
( az Anandtech mentegetőzött is, hogy benézték, csak a jövő héten jön a review )
gondolom az AMD ezzel az Intel-nek törlesztett
( Az Intel mobil procik Apr2-én debütálnak )Ami érdekes, hogy az Intel szerint övék lesz a leggyorsabb mobilproci.
- legalábbis a kiszivárgott slide szerint
- valamint a slide jobb alsó sorában az apróbetüknél szerepel, hogy nem tartalmaz minden publikusan elérhető biztonsági frissítést ...kíváncsi leszek az összehasonlító tesztekre ...
( Intel slide a videocardz-ról ) -
S_x96x_S
CPU Retail Sales (Mindfactory Week 13)
AMD: 5890 units sold, 88.84%, ASP: 222.18
Intel: 740 units sold, 11.16%, ASP: 311.95
AMD Revenue: 1'308'670, 85.01%
Intel Revenue: 230'840, 14.99%
https://twitter.com/TechEpiphany/status/1244544230741225473 -
S_x96x_S
Koronavírus elleni védelem PC-knek. (
https://twitter.com/IanCutress/status/1244638544615952387 -
S_x96x_S
Today AMD lifts the embargo on Ryzen 4000H reviews.
AMD Ryzen 4000H Reviews ...
https://videocardz.com/85374/asus-ryzen-4000h-renoir-gaming-laptops-review-roundupaksiban se rosszak ..
S_x96x_S
kijött a (végleges?) CXL 1.1 , még csak tagoknak elérhető.
persze annyira nem új hir, de van ppt, webinar akit érdekel.
Compute Express Link™ 1.1 Specification: Now Available to Members
https://www.computeexpresslink.org/post/compute-express-link-1-1-specification-now-available-to-members -
S_x96x_S
AMD Developers Looking At GNU C Library Platform Optimizations For Zen
https://www.phoronix.com/scan.php?page=news_item&px=GNU-libc-Platform-Optimize-Zen"Under a "request for comments" flag, patches tentatively posted add AMD Zen and AVX/AVX2 platform support and refactor the platform support within the CPU features detection. This would at run-time allow CPU features like AVX2, FMA, BMI2, POPCNT, and other instructions to be enabled when detected to be running on an AMD Zen based processor. There are also fall-backs for "generic" AVX2 and then AVX CPUs for older CPUs."
S_x96x_S
Covid
Szerver chip kereslet sokkal nagyobb lesz ; de a PC iránti kereslet akár 30%-al is csökkenhet.spekuláció:
- lehet, hogy a termelést is átütemezik ennek megfelelően ( pl. desktop ZEN3 megjelenését későbbre teszik )AMD and Intel Issue CPU Supply Updates Amid Coronavirus Turmoil
https://www.tomshardware.com/news/amd--intel-cpu-supply-updates-amid-coronavirus-pandemic -
S_x96x_S
Renoir Zen 2 ( via ) -
S_x96x_S
TSMC Details 5 nm
https://fuse.wikichip.org/news/3398/tsmc-details-5-nm/ -
S_x96x_S
azért lehet, hogy lesz még itt csúszás ---
CORONAVIRUS/TSMC reports one COVID-19 case, 30 employees in quarantine
https://focustaiwan.tw/business/202003190009 -
S_x96x_S
AMD EPYC 3000 Line Gets Updated Adding and Dropping Models
https://www.servethehome.com/amd-epyc-3000-line-gets-updated-adding-and-dropping-models/ -
S_x96x_S
reméljük nem megfigyelésre használják.
#PPIN - protected processor identification number
"Newer AMD CPUs support the feature of protected processor identification number (PPIN). This patch detects and enables PPIN support on AMD platforms and includes PPIN info in MCE records if available. Because this feature is almost identical on both Intel and AMD, it re-uses X86_FEATURE_INTEL_PPIN feature bit and renames it to X86_FEATURE_PPIN."
https://lore.kernel.org/lkml/20200311044409.2717587-1-wei.huang2@amd.com/
https://www.phoronix.com/scan.php?page=news_item&px=AMD-PPIN-Processor-ID-Linux -
S_x96x_S
"Microsoft Now Offers Azure NVv4 Virtual Machines with AMD EPYC & Radeon Instinct"
https://www.anandtech.com/show/15632/microsoft-now-offers-azure-nvv4-virtual-machines-with-amd-epyc-radeon-instinct -
S_x96x_S
Petykemano #2893 üzenetére
> A thunderX3 nagyon slideware? (Nincs említve, csak a Rome)
lényegében igen ..
A thunderX3 még nagyon új és még csak bejelentés volt,
még benchmarkolni se engedték az STH-t."We did not get to benchmark the system. It will likely be a few months until that is possible. Realistically, the “launch” that happened a few days ago was more of an announcement to the market rather than full volume production of parts and systems. When the platforms are ready, we will bring you numbers."
https://www.servethehome.com/ampere-altra-q80-30-in-action-at-ampere-hq/thunderX3/Marvell:
Ami érdekes, hogy
- "monolithic"-ben gondolkodnak ( vagy csak ez müködik még nekik )
- "no legacy" és csak az új utasításokat támogatják. ( ha jól értem )"7nm AMD chiplets Marvell notes the latency penalty and still thinks monolithic is better. This is despite the silicon industry and even its fab partner TSMC saying chiplets will be the way forward. One can guess that if Marvell was doing multi-die here that bullet would look different. Marvell thinks Arm SoCs without legacy instructions can deliver what the industry needs going forward."
S_x96x_S
Petykemano #2892 üzenetére
( RyzenPi vs. RaspberryPi )
jó kérdések ...
> Pedig pont az ár a lényeg.
Az árat majd induláskor (Q3) eldöntik, azt úgyis a piac határozza meg.
Így nagyobb a mozgástér, addig az alkatrészek árai is mozoghatnak fel-és-le ...
Ha most publikálnak egy árat, azt csak csökkenthetik ... nehezen kommunikálható az emelés.> alacsony fogyasztáson, mint az armos rpi
fogyasztás: RapberryPi-nél mivel az olcsóság a cél, nem éppen a legújabb gyártástechnológiát használják, ha jól tudom ez még: 28nm FinFET process,
A RyzenPi-s R1505G proci 14nm ( de lehet, hogy ezt is 12nm-re mozgatják ) A proci induláskor $80 USD / tray - volt ( a wikichip szerint) , talán most a kevesebb ( $60-$70 USD ??? )
(spekuláció) Ez alapján kb $100 ár (körül)/(felett) várható. -
S_x96x_S
(COVID-19) TSMC szigorit ...
ma már az veszélyes aki Európában járt.
"TSMC has informed its suppliers that regulations to enter its factory sites in Taiwan have been tightened, given the spread of the virus worldwide. Suppliers with travel history to European countries have to self-isolate for 14 days before they are allowed to enter TSMC premises."
https://www.digitimes.com/news/a20200316PD201.html
Amúgy állítólag a COVID-19 életet lehelt a szerverpiacba ..
sőt .. Q2-ben Szerver DRAM áremelést jósolnak.
https://seekingalpha.com/article/4332124-micron-technology-watch-for-cloud-server-boom-amplified-covidminus-19
"The COVID-19 epidemic has unexpectedly breathed life into the server market, decimated in 2019, which stretches from virtual meetings, online education, digital healthcare, cybersecurity, telecommunications, logistics to smart cities. Server capex spend grew just 5.8% in 2019, following a 48.7% increase in 2018." -
S_x96x_S
'The big news is that the “Cooper Lake” generation of Xeon processors is being canceled in the next-generation mainstream Whitley server platform.'
https://www.servethehome.com/intel-cooper-lake-rationalized-still-launching-1h-2020/
"In the market, that will have some impacts. We know that bfloat16 is a huge feature along with increased core counts that have many organizations excited for Cooper Lake. For larger platforms, Intel will have chips with new features and core counts designed to be competitive for out-scaling AMD EPYC 7002 systems. Assuming the current direction holds, by this summer we will see 4-socket Intel Xeon “Cooper Lake” generation parts have more cores than AMD’s “Rome” generation in a system. Even if they have lower core counts per CPU, Intel will have competitive features such as their new instructions. " -
S_x96x_S
Raspberry Pi sized SBC is smallest Ryzen R1000-based model yet
http://linuxgizmos.com/raspberry-pi-sized-sbc-is-smallest-ryzen-r1000-based-model-yet/
céges oldal: https://www.dfi.com/product/index/1455#overview
Q3-ban várható, ár még nincs. -
S_x96x_S
wwenigma #2887 üzenetére
> AMD launches Ryzen 4000 Mobile Renoir
AnandTech: AMD Details Renoir: The Ryzen Mobile 4000 Series 7nm APU Uncovered
https://www.anandtech.com/print/15624/amd-details-renoir-the-ryzen-mobile-4000-series-7nm-apu-uncovered -
S_x96x_S
ha igaz , akkor meglepődtem.
Mar 14, 2020 by Charlie Demerjian:
"SemiAccurate has learned that Intel has just canceled a major server program. This one is a major failure and a crushing retreat from their main market.
If you have been waiting for Intel to crack under the competitive pressure from AMD, it just happened. If you believed the official word that nothing is wrong and their products are selling like hotcakes prepare for a very rude surprise.
https://www.semiaccurate.com/2020/03/14/intel-kills-off-a-server-program/elméletileg lesz majd egy elemzés.
https://twitter.com/CDemerjian/status/1239360027628093440
és Charlie szerint "megerősítve" ... de hogy mi, azt nem tudom.
Talán a hét közepén - végén teljesen publikus lesz a hír.
Mert ha igaz, akkor az AMD-nek áll a pálya ..
mert még az ARM se rug annyira labdába, kell még pár év
"The recent Ampere launch was really to let the market know that Ampere has silicon, and if you want to get started on it, you should start preparing."
https://www.servethehome.com/ampere-altra-q80-30-in-action-at-ampere-hq/ -
S_x96x_S
(chiphell pletyka) RDNA2 / ZEN3: várhatóan októberben
https://twitter.com/momomo_us/status/1239186502237581312 -
S_x96x_S
[ LVI Vulnerability ]
már pár napos a hír, de megjött az első teszt ...
.. és ... brutál eredménycsökkenés, remélem lesz rá jobb javítás is.
https://www.phoronix.com/scan.php?page=article&item=lvi-attack-perf&num=6
"Thankfully the very latest Intel CPUs such as newer Coffee Lake parts, Comet Lake, and Cascade Lake are said to be largely unaffected while Ice Lake is not vulnerable at all."Emlékeztető a FAQ-ból ( https://lviattack.eu/#faq ) :
"""In our current assessment, LVI principally applies only to Intel processors with SGX technology. However, following the argument of symmetry, in in principle any processor that is vulnerable to Meltdown-type data leakage, would also be vulnerable to LVI-style data injection. Some non-Intel processors have been shown to be affected by some variants of Meltdown and Foreshadow. We maintain an up-to-date overview on the website https://transient.fail/ (select Meltdown + vendor ARM or AMD). If an attacker finds software that uses these features in an exploitable way, LVI might still be possible. We encourage future research to investigate the applicability of LVI to non-Intel CPUs.
"""kapcsolódó prohardveres hir (tegnapi): https://prohardver.hu/hir/lvi_forditott_meltdown_sebezhetoseg_intel_sgx.html
S_x96x_S
AMD EPYC 7282 Benchmarks and Review
https://www.servethehome.com/amd-epyc-7282-benchmarks-and-review/olcsó 16c/32t -es szerver cpu; Az Al.z.nál br. 258 290 Ft
közben meg a 3950X br. 288 390 Ft -
S_x96x_S
Cathulhu #2868 üzenetére
> valid?
A i7-10710U még csak 14nm,
ezzel nem sok értelme van összehasonlítani.ami érdekes lesz az Inteltől az a "Tiger Lake-U"
ahol a "the single-core score of 1,400 points" kiemelkedő;
https://www.notebookcheck.net/Quad-core-Intel-Tiger-Lake-processor-outscores-AMD-s-Ryzen-9-3950X-in-Geekbench-single-core-test.451119.0.html
főleg amiatt mert a desktop-os Ryzen9 3950X -nek csak 1312 a single score-ja.A "Tiger Lake-U" = 10nm , AVX512. Gen12 max 96 execution units
és ezzel kell az AMD 4000 mobil APU-nak versenyezni. -
S_x96x_S
paprobert #2861 üzenetére
> Szerintem az AMD a saját proprietary modulációjával akarja
> megelőzni a valódi szabvány megérkezését.mivel az Intel 2021 -ben már elvi -lét- kérdést is csinál a CXL(PCIe5.0)- erőltetett megjelenéséből
és néhány ARM-es szervernél is várható a PCIe 5.0 jövőre ;
emiatt ha az AMD kihagyja a ZEN3-nál, akkor fél-1 éves csúszásban lesz a többiekhez képest.vagyis az AMD-nél nincs tere a kisstílű betartásoknak..
ha ilyet csinál magát szívatja meg.. -
S_x96x_S
váratlanul bejelentették az első PCIe Gen5 -ös gyorsítót,
spekuláció:
mivel a Xilinx és az AMD partnerek mi az esély, hogy a ZEN3-ban lesz PCIe Gen5 támogatás?
Ez sok mindent megmagyarázna ( pl. IFabric gen3 extrém nagy sebességét)
és a késésnek lenne oka is: a pCIe gen5 szabvány reszelése ...merész lépés lenne!
https://www.servethehome.com/xilinx-versal-premium-launched-for-5g-infrastructure/
"Along with PCIe Gen5, Xilinx says this will support both CCIX and CXL. " -
S_x96x_S
Petykemano #2857 üzenetére
> Amazon Graviton2 elemzés vs x86
jajj ...
- "Cost Analysis - An x86 Massacre"
- "If you’re an EC2 customer today, and unless you’re tied to x86 for whatever reason, you’d be stupid not to switch over to Graviton2 instances once they become available, as the cost savings will be significant."Az új AMD-s instance-oknál az árazás sokat fog számítani. De mivel a Graviton2 az AWS saját gyereke, emiatt gondoskodnak, hogy az mindig olcsóbb legyen.
"These chips however will have to compete with AMD’s Rome, and later in the year the new Milan, which won’t be easy. Meanwhile Intel doesn’t seem to be a likely competitor in the short term while they’re attempting to resolve their issues."
- ASUS TUF Gaming A620M-Plus + AMD Ryzen 5 8400F + 16GB 5600MHz Kingston Fury Beast + hűtő
- Eladó Erős Gamer PC - Akár Cyberpunk 2077-re Is Készen! (Ryzen 3 2200G RX 570 8GB 32GB RAM AIO
- MacBook Pro 2019 '16 2,6 Ghz 6mag Intel Core i7 16/512gb - Space Gray Touch Bar
- Xiaomi 13T 256GB, Kártyafüggetlen, 1 Év Garanciával
- Honor Magic6 Lite 256GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RX 9070 16GB GAMER PC termékbeszámítással
- Dell latitude, precision, xps, magyar világítós billentyűzetek eladóak
- AKCIÓ! ASUS Z97-A Z97 chipset alaplap garanciával hibátlan működéssel
- BESZÁMÍTÁS! Asus B760M i7 12700KF 32GB DDR4 512GB SSD RX 6800 16GB Rampage SHIVA FSP 700W
- BESZÁMÍTÁS! SAPPHIRE NITRO+ RX 7900 XTX 24GB GDDR6 videokártya garanciával hibátlan működéssel
