S_x96x_S
Petykemano #10110 üzenetére
S_x96x_S
Zen vs. Lion Cove
"Intel’s Lion Cove P-Core and Gaming Workloads"
https://chipsandcheese.com/p/intels-lion-cove-p-core-and-gaming"""
Compared to Zen 4, Lion Cove suffers harder with backend memory latency, but far less from frontend latency. Part of this can be explained by Zen 4’s stronger data-side memory subsystem. The AMD Ryzen 9 7950X3D I previously tested on has 96 MB of L3 cache on the first die, and has lower L3 latency than Lion Cove in Intel’s Arrow Lake platform. Beyond L3, AMD achieves better load-to-use latency even with slower DDR5-5600 36-36-36-89 memory. Intel’s interconnect became more complex when they shifted to a chiplet setup, and there’s clearly some work to be done.Lion Cove gets a lot of stuff right as well, because the core’s frontend is quite strong. The larger BTB and larger instruction cache compared to Zen 4 seem to do a good job of keeping code fetches off slower caches. Lion Cove’s large L2 gets credit too. It’s not perfect, because the occasional instruction-side L2 miss has an average latency in the hundreds of cycles range. But Intel’s frontend improvements do pay off.
Even though Intel and AMD have different relative strengths, a constant factor is that games are difficult, low IPC workloads. They have large data-side footprints with poor access locality. Instruction-side accesses are difficult too, though not to the same extent because modern branch predictors can mostly keep up. Both factors together mean many pipeline slots go unused. Building a wider core brings little benefit because getting through instructions isn’t the problem. Rather, the challenge is in dealing with long stalls as the core waits for data or instructions to arrive from lower level caches or DRAM. Intel’s new L1.5 likely has limited impact as well. It does convert some already fast L2 hits into even faster accesses, but it doesn’t help with long stalls as the core waits for data from L3 or DRAM.
S_x96x_S
EPYC Zen 6: 8 CCD*12 Core=96C
EPYC Zen 6c: 8 CCD*32 Core=256C
SP8: up to 128 Zen 6C cores with 128MB per CCD
(96 cores for Zen 6 models), 350-400w
SP7: upto 256 Zen 6C cores, ~600w
"AMD’s 6th Gen EPYC Venice “Zen 6 & Zen 6C” CPU Details Leak: Up To 8 CCDs, 96 “Classic” & 256 “Dense” Cores, 128 MB L3 Per CCD"
https://wccftech.com/amd-epyc-venice-zen-6-zen-6c-cpu-leak-up-to-8-ccds-96-classic-256-dense-cores-128-mb-l3-per-ccd/fejlődés:
EPYC 9006 "Venice" With Zen 6C: 256 Cores / 512 Threads / Up To 8 CCDs
EPYC 9005 "Turin" With Zen 5C: 192 Cores / 384 Threads / Up To 12 CCDs
EPYC 9006 "Venice" With Zen 5: 96 Cores / 192 Threads / Up To 8 CCDs
EPYC 9005 "Turin" With Zen 5: 96 Cores / 192 Threads / Up To 16 CCDs -
S_x96x_S
"AMD has decided not to use Samsung Foundry’s SF4X process."
https://x.com/Jukanlosreve/status/1918994090194321488
( korábban az EPYC IO DiE + Samsung 4nm -ről volt szó ) -
S_x96x_S
"Chinese project aims to run RISC-V code on AMD Zen processors"
https://www.tomshardware.com/pc-components/cpus/google-tool-spurs-contest-to-run-risc-v-on-amd-zen-cpus-but-is-it-possible"The Jianchen Project members want to find someone, who can modify AMD's Zen CPU microcode on a modern processor — say, an EPYC 9004-series — to execute RISC-V binaries. The patch is expected to either enable direct execution of RISC-V programs or significantly boost their runtime speed compared to emulation using the same hardware. The work must be tested using RISC-V versions of benchmarks like Coremark or Dhrystone. A complete submission includes binaries or source code, configuration files, dependencies, and test instructions. If only binaries are submitted before the deadline on June 6, identical source code must be added via pull request later. The winner will get ¥20,000 (approximately $2,735). "
mert sérülékeny a mikrokód ..
"AMD Zen 5 CPUs also affected by microcode vulnerability — Granite Ridge, Turin, Ryzen AI 300, and Fire Range at risk"
https://www.tomshardware.com/pc-components/cpus/amds-microcode-vulnerability-also-affects-zen-5-cpus-granite-ridge-turin-ryzen-ai-300-and-fire-range-at-risk -
S_x96x_S
Alogonomus #10087 üzenetére
> Kicsit magasabb üzemelési frekvenciát
talán mindkettő ...
Néhányan különösen jó CCD-k-ről írnak."So AMD saved the godbins for the 9950X3D huh"
https://x.com/Olrak29_/status/1899449707841151431"9950X3D V-Cache CCD@5.5 Ghz"
https://x.com/9550pro/status/1899450945714671897 -
S_x96x_S
"AMD Ryzen 9 9950X3D and Ryzen 9 9900X3D Review Roundup"
https://videocardz.com/198839/amd-ryzen-9-9950x3d-and-ryzen-9-9900x3d-review-roundupMintha jobb CCD lenne benne ; Ha le van tiltva a CCD2 - akkor
- 102.3% Average FPS
- 104.3% 1% Low FPS
Vagyis 2-4% -al jobban teljesít mint a 9800X3D.
https://x.com/harukaze5719/status/1899445202059661378 -
S_x96x_S
Petykemano #10083 üzenetére
(Framework desktop )
> De jó lenne egy 8 magos 36-40CU-s változat.3 kiszerelésben lesz:
https://frame.work/hu/en/products/desktop-diy-amd-aimax300/configuration/new
Max 385 - 32GB ~ 554 Ft -tól ( + ... kiegészítők )
Pre-order
8-core/16-thread CPU, up to 5.0GHz
32 Graphics Cores, up to 2.8GHz
32GB of non-upgradeable LPDDR5xMax+ 395 - 64GB ~ 793e Ft -tól ( + ... kiegészítők )
Pre-order
16-core/32-thread CPU, up to 5.1GHz
40 Graphics Cores, up to 2.9GHz
64GB of non-upgradeable LPDDR5xMax+ 395 - 128GB ~ 994e Ft -tól ( + ... kiegészítők )
Pre-order
128GB of non-upgradeable LPDDR5x
érdemes Noctua -val rendelni, az mintha csendesebb lenne. -
S_x96x_S
Az Intel - AMD kettős licensz megállapodás
azon pontja, ami az AMD felvásárlását megakadályozta volna
kölcsönös, vagyis most az Intel felvásárlására is ugyanez érvényes.persze ennek a lehetőségét az Intel annó nem is tartotta valószínünek.
RetiredEngineer® @chiakokhua elemzése.
https://x.com/chiakokhua/status/1892010660680143050---------
Kérdés - hogy mit kér az AMD ...
(November 17, 2024)
The x86 wish list: Complexities of an imaginary Intel takeover
Apparently AMD has blocking rights for any acquisition of Intel. If a deal were to happen, what would AMD ask for?
https://www.techspot.com/news/105607-x86-wish-list-complexities-imaginary-intel-takeover.html"What would AMD ask for to grant that approval? Obviously, they would take some cash. However, there is only so much Broadcom would be willing to pay before the Intel deal becomes unappealing. That probably amounts to a few billion dollars. Beyond cash, there are things AMD could ask for that might be worth far more strategically.
For starters, they could ask Broadcom for help in their fight against Nvidia. This is an area of shared interest between the two companies, and there are likely multiple ways both could benefit from a deeper partnership. For example, Broadcom could invest more heavily in AMD's Ultra Ethernet and other networking initiatives. Alternatively, Broadcom could design an entire networking stack optimized for AMD's Mi300 series of AI accelerators. Going further, AMD could request that Broadcom encourage its AI ASIC customers to adopt AMD-friendly networking interfaces. We imagine there are plenty of novel ways that Broadcom could promote AMD's interests in their combined fight against Nvidia." -
S_x96x_S
(18 February 2025)
"AMD Continues Preparing openSIL Concept For Phoenix & Turin Processors"
https://www.phoronix.com/news/AMD-openSIL-Turin-2025-Coming -
S_x96x_S
Petykemano #10067 üzenetére
> Lassan azért eljutunk oda, hogy a Mi300 lecsorogjon.
A Medusa Halo - nál már a "packaging tech from MI450 GPU" -t suttogják.
( ~ 2024.jun.30 )> Fura megközelítés volna az IOD-hoz
> a legmodernebb és legdrágább (N3E) gyártástechnológiát alkalmazni.ezek a prémiumos M2 PRO/MAX/Ultra és NVIDIA DIGITS/és testvérkéi
ellen mennek majd.
és mivel a high-end mobil laptopokon elég nagy a marzs - itt belefér a büdzsébe.
Ami még lehetséges, hogy lesz alatta még valamilyen X3D cache az IOD alatt.egy 14 hüvelykes MacBook Pro ( Apple M4 Max chip 16 magos CPU‑val, 40 magos GPU‑val és 16 magos Neural Engine‑nel + 128 GB egyesített memória -val )
~ 2.5 Milla Ft.
És a memory bandwidth : 546 GB/s - 2x akkora mint a StrixHalo -é. -
S_x96x_S
Petykemano #10065 üzenetére
így sikerült , de nem így tervezték
a Strix - eleve fél évet csúszott a TSMC miatt - és így túl közel került az RDNA4-hez.
"Strix Point’s launch was delayed by two quarters due to issues related to AMD’s plans for 3nm production, which were eventually canceled."de ~1 év múlva várható a Medusa Halo [ RDNA5 + ZEN6 ]
"Medusa HALO" =
- ZEN6
- RDNA5
- 256b GDDR7
- 2.5D chiplet interconnect technology
( via: Olrak - 10 hónappal ezelőtt. )2024-07-04:
AMD Reportedly Eyes Mass Production in 2025 for Zen 6 Architecture with TSMC’s N3E Process
"The same report further indicates that, in the consumer market, the Zen 6 series will include high-end laptop versions like Medusa Point, platform versions for AM5 like Medusa Ridge, and versions suitable for both gaming laptops and desktops like Medusa Halo. AMD plans to launch the Zen 6 architecture in the second quarter of 2025, with production starting by the end of 2025, though mass production might be delayed to 2026.
AMD unveiled Strix Point at COMPUTEX 2024, featuring a combination of the Zen 5 series and RDNA 3.5 architecture.
AMD also had plans for Strix Halo, rumored to use TSMC’s N3E process for producing IOD (input/output die) chips similar to Medusa Halo. Strix Halo’s launch was also delayed, possibly due to issues with the IOD chip.
" ( trendforce ) -
S_x96x_S
"Analyzing Lion Cove's Memory Subsystem in Arrow Lake"
https://chipsandcheese.com/p/analyzing-lion-coves-memory-subsystem -
S_x96x_S
wsj - cikke az Intelről
Jan. 3, 2025
Intel’s Problems Are Even Worse Than You’ve Heard
There is fresh evidence the once-mighty innovator is losing market share in more areas
https://archive.md/pEKRb
"One flashing warning sign: In the latest quarter reported by both companies, Intel’s perennial also-ran, AMD, actually eclipsed Intel’s revenue for chips that go into data centers. This is a stunning reversal: In 2022, Intel’s data-center revenue was three times that of AMD. AMD and others are making huge inroads into Intel’s bread-and-butter business of making the world’s most cutting-edge and powerful general-purpose chips, known as CPUs, short for central processing units." -
S_x96x_S
Még nem tudom eldönteni, hogy ez jó hír - vagy sem:
"Intel terminates x86S initiative — unilateral quest to de-bloat x86 instruction set comes to an end"
https://www.tomshardware.com/pc-components/cpus/intel-terminates-x86s-initiative-unilateral-quest-to-de-bloat-x86-instruction-set-comes-to-an-end
"Intel has confirmed to Tom's Hardware that it is no longer working on the x86S specification. " -
S_x96x_S
Petykemano #10057 üzenetére
> AI ... CPU alapon is meg lehetne oldani.
persze csak egy részét a feladatoknak.
de van rá példa.Az Intel már így reklámozza :
"Performance: 17x Faster Than NVIDIA* A100 Tensor Core GPUs"--------------
ami mögött ez van:
A Numenta ( cég ) HOT Chip-es előadásán demonstrálta, hogy egyes feladatokban jobb teljesítményt tud elérni - "Intel AMX and AVX-512 together, plus software managing sparsity"
mint az nVidiával ( A100 ):
- 10x gyorsabb mint
"Numenta Has the Secret to AI Inference on CPUs like the Intel Xeon MAX"
https://www.servethehome.com/numenta-has-the-secret-to-ai-inference-on-cpus-like-the-intel-xeon-max/
S_x96x_S
Petykemano #10055 üzenetére
talán az egységesebb utasításrendszer az egyik erőssége az ARM-nak.
mert az ARMv9-A - AI CPU -ként van reklámozva.
( ~ The CPU Architecture for the Future of AI )És az AMD még nem implementálta az AMX-et;
Remélhetőleg az AI fókusz a CPU-ra is vonatkozik.
Persze az is lehet, hogy az AMD is dolgozik a saját ARM-es szerver prociján.------------
https://www.arm.com/architecture/cpu/a-profile/armv9
"The Armv9-A architecture gives AI developers the programming tools and environment necessary to innovate at pace for the rapidly expanding AI market. AI applications process vast datasets, perform complex calculations, and interpret data collected in real-time to benefit both commercial and everyday tasks. As these programs compute more data, the need for both performance and security becomes paramount. Armv9-A is built with both needs in mind. It offers faster compute for high-performance use cases with a suite of security features that help ensure both data and operational integrity. These benefits are delivered on the device or server without compromising power consumption." -
S_x96x_S
Fujitsu's Monaka - elég hasonló az AMD’s EPYC -hez.
Fujitsu's Monaka CPU: ARMv9, SVE2, and 3D Stacking
Designed for the datacenter and due in 2027
https://chipsandcheese.com/p/fujitsus-monaka-cpu-armv9-sve2-and
Moving to the general layout of Monaka, and there is a resemblance to AMD’s EPYC series of CPUs with a central IO die and disaggregated SRAM and compute. And like AMD’s 2nd generation of V-Cache, the SRAM is below the compute in order to improve thermal management. Unlike AMD’s EPYC CPUs, the IO and the compute are placed above an interposer to allow for a higher bandwidth interconnect between the compute dies and the IO dies.
Each Monaka CPU will have up to 144 cores spread across 4 compute chiplets each with 36 cores on them and they will be fabbed on a 2nm process. The disaggregation of the SRAM and the cores means that the total 2nm area is less then 30% of the total silicon area.
S_x96x_S
új vezére ( és stratégiája) lesz az Intelnek
https://www.intc.com/news-events/press-releases/detail/1719/intel-announces-retirement-of-ceo-pat-gelsinger -
S_x96x_S
"AMD Disables Zen 4's Loop Buffer"
https://chipsandcheese.com/p/amd-disables-zen-4s-loop-buffer"""
I don't know why AMD disabled Zen 4's loop buffer. Sometimes CPU features get disabled because there's a hardware bug. Intel's Skylake saw its loop buffer (LSD) disabled due to a bug related to partial register access in short loops with both SMT threads active.
Zen 4 is AMD's first attempt at putting a loop buffer into a high performance CPU. Validation is always difficult, especially when implementing a feature for the first time. It's not crazy to imagine that AMD internally discovered a bug that no one else hit, and decided to turn off the loop buffer out of an abundance of caution. I can't think of any other reason AMD would mess with Zen 4's frontend this far into the core's lifecycle.
Turning off the loop buffer should have little to no impact on performance because the op cache has more than enough bandwidth to feed the subsequent rename/allocate stage. Impact on power consumption is an unknown factor, but I suspect it's also minor, and may be very difficult to evaluate even when using expensive hardware to measure CPU power draw at the 12V EPS connector.
Combine that with what looks like minimal impact on performance, and I doubt anyone will ever know that AMD turned the loop buffer off. It was a limited feature in the first place, with low capacity and restrictions like no function calls that prevent it from being as useful as an op cache.
Perhaps the best way of looking at Zen 4's loop buffer is that it signals the company has engineering bandwidth to go try things. Maybe it didn't go anywhere this time. But letting engineers experiment with a low risk, low impact feature is a great way to build confidence. I look forward to seeing more of that confidence in the future.
S_x96x_S
Petykemano #10050 üzenetére
> "ha az IOD-ra lenne rápakolva a CCD."
"AMD presents revolutionary “chip stacking” technology to optimize die utilization"
[2024 November 24]
https://www.igorslab.de/en/amd-unveils-revolutionary-chip-stacking-technology-to-optimize-utilization/
Amúgy a nagy IOD méret - a nagy NPU ( ~ Copilot, AI ) igény következménye,
még a low end szegmensben is. -
S_x96x_S
ahogy meg volt tervezve - 2023-06:
https://semianalysis.com/2023/06/12/amd-mi300-taming-the-hype-ai-performance/
"MI300C would go the opposite direction and be CPU only with 96-core Zen4 + HBM answer to Intel’s Sapphire Rapids HBM. However, the market for this may be too small and the product too expensive for AMD to productize this variant.""This is the Microsoft Azure HBv5 and AMD MI300C"
https://www.servethehome.com/this-is-the-microsoft-azure-hbv5-and-amd-mi300c-nvidia/ -
S_x96x_S
végre egy Zen4 szerver - ami nem memória sávszél korlátos. ( HBM3 )
"AMD crafts custom EPYC CPU with HBM3 memory for Microsoft Azure – CPU with 88 Zen 4 cores and 450GB of HBM3 may be repurposed MI300C, four chips hit 7 TB/s "
TomsHWEach Azure HBv5 VM will feature:
- 6.9 TB/s of memory bandwidth (STREAM Triad) across 400-450 GB of RAM (HBM3)
- Up to 9 GB of memory per core (customer configurable)
- Up to 352 AMD EPYC “Zen4” CPU cores, 4 GHz peak frequencies (customer configurable)
- 2X total Infinity Fabric bandwidth among CPUs as any AMD EPYC™ server platform to date
- SMT disabled, single-tenant only design (1 VM per server)
- 800 Gb/s of NVIDIA Quantum-2 InfiniBand, balanced as 200 Gb/s per CPU SoC
- Azure VMSS Flex to scale MPI workloads to hundreds of thousands of HBM-powered CPU cores
- 160 Gbps of Azure Accelerated Networking via 2nd generation Azure Boost NIC
- 14 TB local NVMe SSD delivering up to 50 GB/s read and 30 GB/s write bandwidth -
S_x96x_S
Petykemano #10043 üzenetére
az adott alkalmazástól sok függ, ( hogy mennyire X3D érzékeny )
de talán igen.
Ha a ( 9700X vs . 9800X3D ) átlagos(avg) fogyasztását veszem alapul,
akkor mindenképp,
de a 9800X3D -s verzió fogyasztása : mind "min" és "max" irányba is kilóg
vagyis ezt jobban tunningolhatták ( vagy akár egy fejlettebb reviziójú CCD-t is kaphatott) -
S_x96x_S
Petykemano #10040 üzenetére
erre nem tudok válaszolni,
de van pár friss Turin-os teszt a Phoronix-on ,pl. hogy BIOS-ban lehet állítani hogy a fogyasztási optimum vagy a teljesítmény a cél:
"Power Determinism Mode Still Proves Beneficial For AMD EPYC 9005 Performance"
https://www.phoronix.com/review/amd-epyc-9005-determinism
For the CPU power consumption over the entire span of testing, with the EPYC 9655 switching to the power determinism mode led the average CPU power consumption to go from 253 to 281 Watts. So around an 11% increase to CPU power for around a 5% increase in performance, but that's not unexpected given prior power determinism testing with previous generation AMD EPYC processors. The EPYC 9755 CPU power consumption average only went up by 6 Watts but it saw a smaller improvement overall from the power determinism mode.
Long story short, the AMD power/performance determinism mode remains a great option for EPYC servers and continues to be offered with new EPYC 9005 series processors. For HPC and other demanding environments where willing to accept slightly higher power use and additional cooling considerations can enjoy the power determinism mode for ensuring they are leaving no performance untapped. The performance determinism mode is nice for a default mode and delivering consistent performance with optimal power efficiency. These results are similar to what was seen with prior AMD EPYC processors and still proves to be a worthwhile consideration for new EPYC server deployments." -
S_x96x_S
Grace vs. Epyc
NVIDIA GH200 Grace CPU vs. AMD EPYC 9005 Turin CPU Performance
https://www.phoronix.com/review/nvidia-grace-epyc-turin/5
A grace(arm) - energiahatékonyságban jó. -
S_x96x_S
Petykemano #10030 üzenetére
> A 9800X3D .. a 7800X3D-hez képest -
> jobb alapfrekvenciával együtt - csak 11%-kal gyorsabb.Sok múlik azon is,
hogy a programok mennyire tudják kihasználni
a 3DVcachet-t és az AVX-512 -őt.
és itt szerintem van sok tartalák a 11% felett is.pl. Linux -os Blender tesztnél azért már látszik egy éles határvonal . ( via Phoronix )
9800X3D 109.58 sec
9700X 127.32
7700X 132.73
7800X3D 135.61 -
S_x96x_S
solfilo #10028 üzenetére
köszi;
és egy találgatós - a X3D - jövőjéről.
https://chipsandcheese.com/p/amds-9800x3d-2nd-generation-v-cache
The second generation of V-Cache’s memory bandwidth and memory latency behavior is very similar to first generation V-Cache where the memory latency and bandwidth is near to identical to the non V-Cache SKUs other than the lower clocking of the V-Cache SKUs. In terms of the SPEC performance, the 9800X3D is ahead of the 9950X in the INT tests and just about makes up the clock speed difference in the FP tests.In the end, AMD took what they learned with the first generation of V-Cache along with the MI300 series of accelerators and create the second generation of V-Cache which remediates the biggest weakness of the first generation of V-Cache which was the extra thermal resistance of the support silicon over the cores. This has allowed AMD to both stabilize the boost clock and increase the base clock.
I wonder what impact this will have on future AMD CPUs with regards to the packaging of their CPUs. Possibly in the future AMD will move all L3 cache into the base tile and just have the cores and L2 cache on top. Or mayhaps they will have more than 1 stacks on future CPUs.
S_x96x_S
S_x96x_S
Az új CPU-s "SME" ( mátrix) támogatás az Apple M4 -ben elég érdekes[1]
és akár az AMD is lemásolhatja,
pl. úgy hogy egy ZEN6-os CCD-be betesz egy XDNA-t és tesz hozzá egy AMX-es utasítás wrappert ( Ami az Inteles Mátrix utasítás készlet )
és akkor a nagy X3D L3-as cache-t is ki tudja használni.Persze az I/O die-ba helyezett XDNA - mellett is sok érv szól,
de ide már kell egy külön cache - ami persze sose árt.----------------
[1]
"Apple's matrix accelerator is a dedicated hardware unit — it is not part of the CPU core. There is one AMX/SME block in a CPU cluster, shared by all CPU cores. This has a number of interesting consequences. First, the matrix accelerator has access to much higher bandwidth than the individual CPU cores, since it is directly fed from the cluster L2. Second, the latency of executign SME instructions is high, as data communication needs to happen via the L2 cache (there is presumably a fast control bus to share the execution state). Third, one does not need to resort to parallel programming to harvest the performance benefits of SME. Initial experiments suggest that a single CPU tread can already achieve peak processing rate on the SME unit. Finally, those seeking highest possible performance can use on-CPU SIMD (Neon) and SME simultaneously for an additional boost."
https://github.com/tzakharko/m4-sme-exploration -
S_x96x_S
Az AI a jövő a chiptervezésben is.
"Cadence says its AI-driven chip design tools provide a process node's worth of performance gain, but without moving forward to a new node"
https://www.tomshardware.com/tech-industry/cadence-says-its-ai-driven-chip-design-tools-provide-a-process-nodes-worth-of-performance-gain-but-without-moving-forward-to-a-new-nodeDiscussing the EDA company's latest suite of AI-assisted software tools, Devgan said, "So, overall, we are pleased with the benefit we are getting, especially with the improvement in PPA. And productivity improvements can be anywhere between 5x to 10x, but the PPA benefits are truly remarkable and almost equivalent to one kind of node. One process node migration typically gets [s] 15% to 20% PPA improvement, and we can get that with AI."
S_x96x_S
Petykemano #10018 üzenetére
sajnos az árak olyanok amilyenek
és ez a gyengülő forint miatt még fájdalmasabb itthon.de
Az árakat az AMD próbálja szabályozni
( a piaci kereslet; gyártókapacitás ; profitmaximalizálás ; etc ) függvényében.
és aki tud várni, az pár hónappal később
- 10% - 30% - al olcsóbban is megkaphatja.
- a jobban optimalizált terméket. ( irónia++ )És amióta szinte csak a TSMC jöhet szóba mint gyártókapacitás,
azóta a TSMC profitja is ott van - minden termékben,
és a (régi) Intel árak - mint referencia - ma már egyre kevésbé relevánsak,
és csak az egyszerű ( monolitikus ) régi gyártósoron (TSMC7, Intel10) gyártott termékeket
lehet olcsón adni.a világ gyorsan változik.
"AMD Ryzen 9000 series hits record low prices: 9950X now $584, 9700X at $312, and 9600X at $238"
https://videocardz.com/newz/amd-ryzen-9000-series-hits-record-low-prices-9950x-now-584-9700x-at-312-and-9600x-at-238 -
S_x96x_S
megvan a hivatalos ár - megerősítése is $479.99:
Ryzen 7 9800X3D: "AMD confirming this processor will launch at an MSRP of $479.99."
"AMD crowns the Ryzen 7 9800X3D a ‘gaming legend’ in a surprise announcement — chipmaker claims $479 Zen 5 3D V-Cache chip is up to an average 20% faster than Intel Core Ultra 9 flagship" -
S_x96x_S
"AMD Ryzen 7 9800X3D Crushes 7800X3D In Blender In By A Solid 26% Uplift"
https://wccftech.com/amd-ryzen-7-9800x3d-crushes-7800x3d-in-blender-benchmark/ -
S_x96x_S
Devid_81 #10011 üzenetére
> Jo draga lesz...
relative.
Az első 1-2 hónapban mindenképp.
+ Főleg ha az eddigi Intel tulajok is erre váltanak át - mert az X3D overlockolható lesz.
+ És nem lesz elég a polcokon - a várható túlkereslet miatt.És az AMD-nek el kell döntenie,
- hogy a skalperek fölözzék le a hasznot,
- vagy inkább eleve +20% felárral adja ki, és az elején csak az vesz, akinek ilyen áron is megéri. ( és az árral szabályozza a keresletet - és maximalizálja a profitot, Mert kell a zen6 , zen7 fejlesztőknek a rendes fizetés! ) -
S_x96x_S
"A closer look at Intel and AMD's different approaches to gluing together CPUs"
- Epycs or Xeons, more cores = more silicon, and it only gets more complex from here
- While Intel eventually saw the wisdom of AMD's chiplet strategy, its approaches couldn't be more different.
https://www.theregister.com/2024/10/24/intel_amd_packaging/AMD:
"Placing the memory controllers on the I/O die does come with some pros and cons. On the upside, this means that memory bandwidth, for the most part, scales independently of core count. The downside is potentially higher memory and cache access latencies for certain workloads. We emphasize "potentially" as this kind of thing is highly workload dependent."AMD:
"Perhaps the bigger question is where AMD will take its chiplet architecture next. Looking at AMD's 128-core Turin processors, there's not a lot of room left on the package for more silicon, but the House of Zen still has a few options to choose from.
First, AMD could simply opt for a bigger package to make room for additional chiplets. Alternatively, the chipmaker could also pack more cores onto a smaller die. However, we suspect that AMD's sixth-gen Epycs could actually end up looking a lot more like its Instinct MI300-series accelerators.
As you may recall, launched alongside the MI300X GPU was an APU that swapped two of the chip's CDNA3 tiles for a trio of CCDs with 24 Zen 4 cores between them. These compute tiles are stacked atop four I/O dies and are connected to a bank of eight HBM3 modules.
Now, again, this is just speculation, but it's not hard to imagine AMD doing something similar, switching out all that memory and GPU dies for additional CCDs instead. Such a design would conceivably benefit from higher bandwidth and lower latencies for die-to-die communications too.
Whether this will actually play out, only time will tell. We don't expect AMD's 6th-gen Epycs to arrive until late 2026
"""INTEL:
"Intel's I/O dies are also quite a bit skinnier and house a combination of PCIe, CXL, and UPI links for communications with storage, peripherals, and other sockets. Alongside these, we also find a host of accelerators for direct stream (DSA), in-memory analytics (IAA), encrypt/decrypt (QAT), and load balancing.
We're told that the placement of accelerators on the I/O die was done in part to place them closer to the data as it streams in and out of the chip.""Going off the renderings intel showed off earlier this year, Clearwater Forest could use up to 12 compute dies per package. The use of silicon interposers is by no means new and offers a number of benefits including higher chip-to-chip bandwidth and lower latencies than you'd typically see in an organic substrate. That's quite the departure from the pair of 144-core compute dies found on Intel's highest core count Sierra Forest parts.
S_x96x_S
Petykemano #10005 üzenetére
> a magasabb frekvenciájú RAM kezelésére, de igazából nem nagyon van hatása.
valamelyik program a késleltetésre érzékeny,
valamelyik meg a freq -reAMD Ryzen 9 9950X DDR5-6000 / DDR5-6400 / DDR5-8000 Memory Performance
pl. egy játék teszt ( sakk ) - az alacsonyabb késleltetés jobban számít
a DDR5-8000 CL38 -ast - leelőzi a CL32 -es 6400-as
A NAS teszt a freq -ra érzékenyebb. -
S_x96x_S
Alogonomus #9993 üzenetére
"AMD Ryzen 7 9800X3D Cinebench R23 leak shows all-core frequency of 5.6 GHz with PBO enabled"
https://videocardz.com/newz/amd-ryzen-7-9800x3d-cinebench-r23-leak-shows-all-core-frequency-of-5-6-ghz-with-pbo-enabled"AMD Ryzen 9000X3D officially arrives November 7th, 9000X series now $30 to $50 cheaper"
https://videocardz.com/newz/amd-ryzen-9000x3d-officially-arrives-november-7th-9000x-series-now-30-to-50-cheaper
S_x96x_S
Érdekes "Turin Dense" Zen 5C - SMT ON/OFF teszt,
extrém pozitiv és negativ kilengések miatt sose hígy az átlag értéknek
-------Amúgy nem sűrűn látni olyan teszt esetet
amikor a SMT ON - duplázza a teljesítményt.És olyat se, amikor csökkenti a teljesítményt az SMT ON - és érdemes kikapcsolni.
S_x96x_S
Végre elkezdett a két cég az x86 ISA jövőjéről egyeztetni.
"Intel, AMD, team with tech titans for x86 ISA overhaul
Linus Torvalds, Broadcom, Dell, HPE, and Lenovo on the list"
https://www.theregister.com/2024/10/15/intel_amd_x86_future/
"The shape of the x86 instruction set architecture (ISA) is evolving. On Tuesday, Intel and AMD announced the formation of an ecosystem advisory group intended to drive greater consistency between the brands' x86 implementations."
AMD PR
https://www.amd.com/en/newsroom/press-releases/2024-10-15-intel-and-amd-form-x86-ecosystem-advisory-group-to-accelerate.html
Phoronix: https://www.phoronix.com/news/Intel-AMD-x86-Ecosystem-Group -
S_x96x_S
nagyon lassan kalapálják az XDNA/NPU - linux támogatást.
Talán jövőre meglesz.AMD XDNA Linux Driver Updated As It Nears The Upstream Kernel
https://www.phoronix.com/news/AMD-XDNA-Linux-Driver-v4"With the AMD Ryzen 7040 series having launched in mid-2023, as we approach the end of 2024 it's unfortunate that this AMD XDNA driver hasn't yet entered the mainline kernel for supporting the Ryzen AI NPUs found in those mobile SoCs over the past year and a half or so. As it stands right now if the fourth round of review goes well, the soonest this driver will be merged is for the Linux v6.13 merge window that is happening in mid-to-late November. But the stable Linux v6.13 kernel won't be out until next February... So for those concerned with the out-of-the-box support on the likes of Ubuntu or similar, it's not until next spring with the likes of Ubuntu 25.04 and others where there might be out-of-the-box Ryzen AI support on Linux -- two years after the AMD NPU first began premiering within laptops."
S_x96x_S
Azért látszik az 512bites vs. 266bites datapath közötti különbség.
( és persze programtól függ, hogy mekkora a hatás )
AVX-512 Performance With 256-bit vs. 512-bit Data Path For AMD EPYC 9005 CPUs -
S_x96x_S
"Zen 5 (only 3 games will have >15% more uplift) X3D"
https://x.com/Olrak29_/status/1845076900957520021 -
S_x96x_S
Alogonomus #9978 üzenetére
> Az AMD valószínűleg a 9800X3D-t is "ellazsálja",
> mert nincs rákényszerülve a "hardver végletekig kifacsarására".nem hiszem, hogy ez lenne a mögöttes mozgatóerő.
A zen5 fejlesztések főleg a szerver célúak voltak és a xeon elleni avx-512 gyengeséget próbálta kompenzálni. - Ami szerintem sikerült is.
Az AMD egy zen5-ös ISA-t használ mindenütt - és ez előny és hátrány is.
Én nem látok semmilyen lazsálást.a GPU-nál szédszedték CDNA vs. RDNA -ra
és talán a CPU-nál is szét lehetne a desktop/mobil és a szerver vonalat választani,
( mint az Intelnél is látható )
de most az AMD - a GPU -nál is visszaáll UDNA -ra.Az I/O die-t lehetett volna tunningolni a 9000-nél , de ez valami ok miatt elmaradt.
valószínüleg az a következő körben várható.Az AVX-512 hatása pedig érdekes lesz. Ha a zen4/zen5/zen6 piaci részesedése még erősebb lesz, akkor a programok is egyre-jobban kezdik kihasználni ( még a játék programok is ) Úgyhogy ez olyan mint a bor .. idővel érik ...
és a játékok is változnak, nem mindennek lesz elég a 8 mag.
a CIVILIZATION VII -nél már a 16mag az ajánlott ( >= "AMD Ryzen 9 5950X" ) -
S_x96x_S
(ha jól értem)
A server ZEN5 CCD - 2 GMI kapcsolatot használ, a desktop meg egyet az IO -die -hoz.
Szerintem elképzelhető, hogy a StrixHALO - extra Bandwithes konfigjában -
a szerverhez hasonlóan a zen5 - szintén 2 GMI -vel kapcsolódik az új IO die-hoz, ami már RDNA3.5 -as ( meg talán a MALL CACHE-et is hasznosítani tudja a CCD )"Looking a bit closer at these results, you’ll notice that the 9575F has significantly higher bandwidth to a CCD compared to the desktop Zen 5 parts. And the reason for this is the 9575F has GMI3-W which means that it has 2 GMI links to the IO die instead of the single GMI link that the 9950X gets."
https://chipsandcheese.com/p/amds-turin-5th-gen-epyc-launched
és a legjobb mondat:
"Apparently we now think 64 cores is ‘lower core count’. What a world we live in." -
S_x96x_S
Alogonomus #9970 üzenetére
> Az 5,2 GHz mondjuk kevesebb,
Nem "boost clock" , hanem "All core Turbo" -t írnak - és így nem rossz.
De nem lehet tudni, hogy az "All Core Turbo 5.2 GHz" -t milyen terheléssel mérték,
úgyhogy meg kell várni a végleges teszteket,----
de persze, ahogy látom - viszonyításnak:
9950X a normál alap "x87 FPU" - esetén 32thread all-core esetén "5.19 GHz"
ami már ugyanaz mint az 5.2 Ghz.Vagyis a 9950X - hiába tudja pár magon a boost - 5.74 GHz -t,
hogyha "all core x87 FPU" -n csak 5.19 Ghz -et tud. -
S_x96x_S
hokuszpk #9954 üzenetére
> nem feltétlen kell magasabb frekit tudnia.
Akkor általános felhasználásra is ideális lenne.
Sajnos nem minden program - X3D cache - érzékeny,
és az alacsonyabb freq miatt ilyenkor - csak "pain" van "gain" nélkül.Még a játékprogramoknál is van X3D -re nem annyira érzékeny program,
aminél a freq veszteség nagyobb - mint az X3D nyereség.------------
Amúgy a Blender például nem értékeli annyira az X3D-t, hogy a freq veszteséget kompenzálja.
https://www.phoronix.com/review/amd-ryzen9-7950x3d-linux/14
-----------Amúgy fogyasztásban teljesen ideális lesz a két X3D -s 9950X3D.
S_x96x_S
TESCO-Zsömle #9951 üzenetére
> Both CCD Chiplets
ez jó hír.
Juhééééé ....
vagyis az X3D -s rész magasabb FREQ -t tud
és nincs szükség kompenzációra egy nem X3D -s -el.
És egyre nagyobb az esélye, hogy lesz X3D-s Strix HALO -is
( mivel az is chipettes)
( Még ha nem is az első körben )Még egy rendes I/O die kellene.
( A StrixHALO - I/O die - ideális lenne ; Gondolom az már eleve úgy lett megtervezve. ) -
S_x96x_S
(vad találgatás)
Lehet, hogy a [9900X3D és 9950X3D] újdonsága :
1.)
A "nem X3D" -s ZEN5 chiplet már 3nm -en készül. Ami magyarázná a jövő évi késést is.2.) Vagy netán 3nm-es ZEN5C -t kapnak?
"The "Zen 5c" chiplet has a mammoth 32 cores spread across two CCXs of 16 cores, each. Each CCX has 16 cores sharing a 32 MB L3 cache. It is to cram these 32 cores, each with 1 MB of L2 cache; and a total of 64 MB of L3 cache, that AMD could be turning to the 3 nm foundry node. Another reason could be volt"
https://www.techpowerup.com/319241/amd-zen-5c-ccds-made-on-more-advanced-3-nm-node-than-zen-5
Persze ehhez I/O die-t is módosítani kellene - és csak kiszivárgot volna.Ha meg már módosítják az i/o die-t, akkor adhatnának hozzá NPU-t is.
S_x96x_S
Az tényleg jó kérdés, hogy az AMD mit reagál az X86S -re
és ezáltal mi lesz az X86 jövője."...
If Intel were to use X86S for its CPUs in the future, there’s also a big question of what AMD, the other primary x86 CPU designer, would do. Although Intel has always been the bigger company (and still is today despite Intel’s ongoing crisis), AMD has been crucial in the history of x86 and developed the current 64-bit version of the ISA, known as x86-64 or AMD64.
Incidentally, AMD’s 64-bit version of x86 likely doomed Intel’s own 64-bit architecture, Itanium. If Intel seriously plans to use X86S, it might be beneficial for the company to get AMD’s support or avoid a disagreement on legacy support.
S_x96x_S
Petykemano #9931 üzenetére
nem rossz ...
ez meg $999 - No OCulink.
Beelink SER9 Mini-PC with Ryzen AI 9 HX 370 to cost $999, fans not impressedamúgy lassan több Ryzen-es mini PC-n lesz Oculink - mint amelyiken nem lesz.
S_x96x_S
Én ezt RISC-V -XM -et [1] nevezném CPU+AI egyesített ideális design -nak
és a CPU-k jövőjének.
és ez nagyon hasonló mint az Inteles Xeon Phi terv.
de még az újabb Intel CPU-ba integrált AMX(Mátrix) utasítás is -e felé mutat.És az AMD UDNA / X300 -nak ezzel kell felvennie a versenyt.
Szerintem az AMD-nek komolyan el kell gondolkodnia
hogy a jövőben olyan szuper UDNA-t tervez, ami nem csak a CDNA + RDNA,
hanem ( CPU + XDNA + CDNA + RDNA ) egyben
az alapoktól újratervezve,
mivel sok átfedés van a területek között, amit optimalizálni lehetne.-------------
[1]
RISC-V CPU - ba integrált AI gyorsító ; a Tenstorrent nyomdokaiban,
ami "papiron" lenyomja az nVidiát Blackwell-t.
512 XM cluster: 4 petaFLOPS >= Blackwell: 2.5 petaFLOPS"SiFive expands from RISC-V cores for AI chips to designing its own full-fat accelerator"
Seems someone's looking for an Arm wrestle
https://www.theregister.com/2024/09/19/sifive_ai_accelerator/"SiFive's base XM cluster is built around four of SiFive's Intelligence X RISC-V CPU cores which are connected to an in-house matrix math engine specifically for powering through neural network calculations in hardware. If you're not familiar, we've previously explored SiFive's X280 and newer X390 X-series core designs, the latter of which can be configured with a pair of 1,024 vector arithmetic logic units."
"Assuming the end customer can actually maintain a 1GHz clock speed without running into thermal or power limitations, 512 XM clusters would rival Nvidia's upcoming Blackwell accelerators, boasting roughly four petaFLOPS of BF16 matrix compute. For comparison, Nvidia's top-specced Blackwell GPUs boast 2.5 petaFLOPS of BF16 performance."
S_x96x_S
Az AMD jövője szempontjából elég érdekes lesz,
hogyha Qualcomm - átveszi az irányítást.---------
exclusive - 2024-szept-20
Qualcomm Approached Intel About a Takeover in Recent Days
Deal for Intel would be massive and come as chip maker is sputtering
https://www.wsj.com/business/deals/qualcomm-approached-intel-about-a-takeover-in-recent-days-fa114f9d -
S_x96x_S
Petykemano #9924 üzenetére
> Amennyiben nincsenek benne helytakarékos kismagok,
> akkor ez itt 2 CCD a 40CU-hoz. Szerintem aránytalan.A High-endes-Kimaxolt-Stix-Halo ( AI MAX+ ) elsősorban Creativoknak ; Fejlesztőknek; és AI/ML és lokális chatgpt futtatására lesz ideális.
> de szükségtelen/kihasználatlan többletteljesítményért prémiumot fizetni.
igen .. .az ár ...
- ha a “Strix Point” - a duplája lesz a “Hawk Point” -nak, [1]
- akkor a "Strix Halo" - minimum a dupla-duplája vagyis 4x - lehet a “Hawk Point” -nak , és akkor ebbe még az egyedi dupla memória rendszer és a memóriák árát még nem is számítottam bele, valamint az FP11 jelentősen eltér az FP8-tól.
Vagyis az első fél évben eléggé prémium a köbön - árakra számítok.(nekem) A 96GB VRAM és a ROCm támogatás a legvonzóbb a Strix Halo -ban.
[1] "GPD confirms AMD “Strix Point” Zen5 APUs cost twice as much as “Hawk Point” with Zen4" https://videocardz.com/newz/gpd-confirms-amd-strix-point-zen5-apus-cost-twice-as-much-as-hawk-point-with-zen4
Árak2:A stix halo - apple rivális referencia gépe:
Macbook Pro M3 - 16coll - 128GB , ami 2.5M Ft ~ körül kapható.
aminek ~ (400GB/s memory bandwidth) - je van.
- Apple M3 Max chip 16 magos CPU‑val, 40 magos GPU‑val
- 128 GB egyesített memória
- 1 TB-os SSD-tároló
- 16 hüvelykes Liquid Retina XDR-kijelző²
- 140 wattos USB‑C hálózati adapterDe jövőre a "Strix Halo"-nak már az M4 Pro / M4 Max -al kell
megküzdenie, ami TSMC N3E-n készül.Remélem bölcsen és okosan áraznak majd az AMD-nél.
S_x96x_S
S_x96x_S #9921 üzenetére
385 linux program alapján
-10 .. +16% között szórnak az eltérések.
( vagyis valamikor még lassabb is )de nagy átlagban nagyrészt érzékelhetetlen az előny.
https://www.phoronix.com/review/amd-9950x-agesa-1202/3
"Here is a look at the side-by-side results from the original launch-day BIOS and the new BETA BIOS with newest AGESA. This is for results where there was a significant difference between runs with all the flat results omitted from the review. In Apache HTTPD, PyTorch, and various other mostly multi-threaded apps like HPC/scientific computing there was typically up to a few percent better performance. The regressions that did occur were less often and typically at 4% or less difference." -
S_x96x_S
Petykemano #9919 üzenetére
> Sajnos úgy néz ki, hogy valóban csak a magok közt mért késleltetést.
A CB23 Multi talán nem a legideálisabb a core-to-core latency hatás mérésére,
mivel régebben is pont ezért kedvelték az AMD-sek a CB23 Multi-t, mert minimális hatása volt a chipletes felépítésnek.ABU átlagban 2-4% -ról ir, ami nekem hihetőbb:
"Ennek mértéke attól függ, hogy az adott alkalmazást mennyire hátráltatta korábban az eltérő chipleteken található Zen 5 magok közötti magas késleltetés, de nagy átlagban 2-4% közötti javulás várható."
https://prohardver.hu/hir/amd_agesa_gyorsit_egyes_zen_5_dizajn.htmlde majd kíváncsi leszek az alaposabb phoronix -os linux -os benchmarkokra is.
S_x96x_S
"Discussing AMD’s Zen 5 at Hot Chips 2024"
https://chipsandcheese.com/2024/09/15/discussing-amds-zen-5-at-hot-chips-2024/
S_x96x_S
Petykemano #9912 üzenetére
> Óvatosan rendelik be a wafert, ...
> Ez a szokásos. Persze bizonyos szempontból ez valóban a potencia hiánya.majd meglátjuk,
hogy az Intel a TSMC N3B-n készülő Arrow Lake -et jobban menedzseli-e.
S_x96x_S
Mindfactory - https://x.com/TechEpiphanyYT/status/1835038520320442790
Alaplapok🔥 Mainboard Retail Sales Week 37 (mf)
ℹ️ Units
AMD: 2110 units sold, 86.65%, ASP: 167
Intel: 325, 13.35%, ASP: 156
ℹ️ Revenue
AMD: 353421, 87.49%
Intel: 50553, 12.51%
ℹ️ By socket
AM5: 1520
AM4: 590
1700: 315
1200: 10 -
S_x96x_S
Frusztrált ügyfelek máshol is vannak, de más a kezelési mód is.
pl. az nVidia jobban kommunikál.
( mégha a kommunikáció csak ~ placebo is, de jobb az érzés tőle. )
"NVIDIA CEO Says “Restricted Supply” Has Frustrated Its Clients, Increasing Business Tensions" -
S_x96x_S
https://www.tomshardware.com/tech-industry/amds-laptop-oems-decry-poor-support-chip-supply-and-communication-the-company-has-left-billions-of-us-dollars-lying-around-due-to-poor-execution-claims-multiple-reports
AC Analysis says AMD is prioritizing enterprise chips over its consumer offerings. It cites several of AMD's laptop OEM partners who have complained about “miscommunication, unfulfilled promises, and generally poor treatment” from the company, "reminiscent of Intel’s behavior during its dominant years."The respected German outlet ComputerBase reports that, based on its discussions with several laptop OEMs, AMD continues to suffer from many of the same problems it has experienced in the past. Poor supply and related issues have resulted in a lack of new Strix Point laptops coming to market. In fact, a manufacturer told Computerbase that "AMD has probably 'left billions of US dollars lying around' with its many partners over the years."
Because of this, OEM's reception of AMD's Strix Point chips was a bit lukewarm despite enthusiasm from consumers. At the time of writing, BestBuy only offers three brands that carry these chips—Asus, HP, and MSI—with HP and MSI offering one option each, while Asus offers 13 models powered by an AMD Ryzen AI 300 series chip. AC Analysis says the Lenovo Yoga Pro 7 Gen 9 will come with the new AMD processor, but it’s not yet available on Lenovo’s US site.On the other hand, Qualcomm’s launch of the Snapdragon X processor was hotly anticipated by the general public and laptop manufacturers. Seven brands launched 12 different models that used the new Arm chip, with more models expected to arrive in the coming weeks and months. That's surprising, given that Qualcomm is a newcomer to the market.
S_x96x_S
hokuszpk #9901 üzenetére
Linux-on már van sok program, ami használja az Inteles AMX-t.
és azért aki komoly mérnöki/tudományos számításokat végez,
az biztos halott is már erről.De amúgy az AI/ML hullám elején vagyunk
és valamilyen X86-64 - Mátrix támogatás kell majd a jövőben.
és mivel az Intel csinált már egy ilyet ( AMX ) valószínüleg az lesz X86 oldalon.
(mégha nem is tökéletes)Az Armv9.2-A - már tartalmazza az SME/SME2 (Scalable Matrix Extension)
(May 23, 2024) https://newsroom.arm.com/blog/scalable-matrix-extension
És mintha az Apple M4 is megkapta volna az új (szabványos) SME-t
Az új Snapdragon 8 Gen4 (Oryon/Nuvia) viszont mintha még nem lenne SME képes. -
S_x96x_S
Újabb ajándék a zen4/zen5 tulajoknak.
"Intel Demonstrates Up To 48% Improvement For AVX-512 Optimized PostgreSQL"
https://www.phoronix.com/news/Intel-Bit-Count-AVX-512-Postgre
- az új PostgreSQL 17 -ben várható!
- ott az "Up To" -- vagyis nem minden esetben.
- és további AVX-512 gyorsítások is várhatóak ( CRC32C, JSON parsing ) >= PG18 -
S_x96x_S
hokuszpk #9898 üzenetére
(AMX)
az (Intel) AMX támogatás mintha már be lenne integrálva az LLVM és a GCC -be,
és sok minden másba is https://www.phoronix.com/search/Intel+AMXAz Apple ( M1/M2/M3/.. ) viszont már 2020 -óta támogat ( egy hasonló mátrixos utasításkészletet - persze az ARM alapú és nincs rendesen dokumentálva.
AI-re és pl. a CPU-n futtatott https://ollama.com/ ( lokális chatbot ) futtatásához lenne praktikus egy átlag usernek. Persze ott vannak a GPU -k és az NPU-k, de szerveres környezetben azok nem mindig érhetőek el.
pár random link:
1.) Advanced Matrix Extensions (AMX) Guide
https://github.com/mikeroyal/AMX-Guide2.) "Contrasting Intel AMX and Apple AMX"
https://www.corsix.org/content/contrasting-intel-amx-and-apple-amx3.) "Explore AMX instructions: Unlock the performance of Apple Silicon"
https://zhen8838.github.io/2024/04/23/mac-amx_en/
Since 2020, Apple has published M1/M2/M3. They have at least four different ways to perform high-intensity computing tasks.
- Standard arm NEON instructions.
- Undocumented AMX (Apple Matrix Co-processor) instructions. Issued by the CPU and performed on the co-processor.
- Apple Neural Engine
- Metal GPUIf we use ARM NEON instructions to accelerate the sgemm kernel on the single core of the M1 Max, It can achieve a performance of around 102 GFLOPS. But if use AMX instructions it can achieve 1475 GFLOPS!
""""4.) "Accelerate PyTorch* Training and Inference Performance using Intel® Advanced Matrix Extensions (Intel® AMX) " ( Intel )
S_x96x_S
Intel Xeon W-3500 Content Creation Review ( vs. Threadripper PRO zen4 )
https://www.pugetsystems.com/labs/articles/intel-xeon-w-3500-content-creation-review/Az Intel a TR PRO-WX (Zen4) alá árazta az új ( Aug. 28, 2024 ) XEON-okat.
( Sapphire Rapids alapúak és "Intel 7" -en készültek )AMD Ryzen Threadripper PRO 7975WX $3,900 32core
Intel Xeon w9-3575X $3,790 44core
Intel Xeon w7-3565X $2,690 32core
AMD Ryzen Threadripper PRO 7965WX $2,650 24core
Intel Xeon w5-3535X $1,689 20coreaz AMX utasítás vonzó,
de minden másban alatta van az AMD ajánlatának,főleg ha lesz ZEN5-ös verzió is.
Pl. CineBench 2024 Multi
Intel Xeon w5-3535X (20core) : 1838 pont
Ryzen 9950X (16c) - 170W : 2130 pont -
S_x96x_S
> Háde mér nem 4+4?
jobban lehet marketingelni .
és így talán könnyebb eladni a Tetraphobiásoknak.
"The Chinese word for "four" (四, pinyin: sì, jyutping: sei3) sounds quite similar to the word for "death" (死, pinyin: sǐ, jyutping: sei2) in many varieties of Chinese.[2][better source needed][3] Similarly, the Sino-Japanese, Sino-Korean and Sino-Vietnamese words for "four", shi (し, Japanese) and sa (사, Korean), sound similar or identical to "death" in each language (see Korean numerals, Japanese numerals, Vietnamese numerals)."a 3+5 -nek jobb a jelentése - és nem rontja le a két 4-es.
A kínai numerológiában a 3 és az 5 számok külön-külön és együtt is szimbolikus jelentéssel bírnak.
3: A kreativitást, növekedést és harmóniát képviseli. A kínai kultúrában a „három” számot gyakran pozitív energiához és szerencséhez társítják.
5: Az egyensúlyt, harmóniát és a természet öt elemét (fa, tűz, föld, fém, víz) szimbolizálja. Szintén a stabilitás és változatosság jelképe.
A 3+5, vagyis 8: Kínában a 8-as szám a gazdagságot, bőséget és sikert jelenti, mivel a kiejtése hasonlít a „jólét” szóra (发, „fā”).
Összefoglalva: a 3+5 együttesen szerencsét, bőséget és kreatív egyensúlyt sugall a kínai numerológia szerint.
S_x96x_S
Ez a 3+5 -ös konfigurációt nehéz megszokni.
"In terms of specifications, the Lenovo ThinkPad T14 Gen 6 is expected to debut with AMD's Ryzen AI 7 PRO 360 APU, composed of three Zen 5 cores and five Zen 5C cores in a 3+5 configuration, which makes up a total of 8 cores. It also features a Radeon 880M iGPU onboard, based upon the RDNA 3.5 architecture,"
https://wccftech.com/amd-ryzen-ai-300-pro-lenovo-thinkpad-t14s-laptop-8-core-ryzen-ai-7-pro-360-variant/és a "80 AI TOPs (50 TOPS NPU)" -ból : akkor 30 TOPS -ot a CPU + GPU ad ?
S_x96x_S
hokuszpk #9887 üzenetére
> hm. te mint programolo,
> fejtsuk mar meg, az if -ben minek is van break aztan utana a zaro '}' utan meg1 ?<tippelek>
mert lesz valamikor egy "znver6"-os kód is beszúrva.
és ha jól értem - ez egy ajánlás K&R -től - amolyan defenzív programozás.
https://stackoverflow.com/a/26139061
From The C programming language - Second edition (K&R 2) Chapter 3.4 Switch:
"As a matter of good form, put a break after the last case (the default here) even though it's logically unnecessary. Some day when another case gets added at the end, this bit of defensive programming will save you."amúgy nézd meg a teljes kódot is,
és ha ez a gyakorlat az LLVM kódokban, akkor felesleges ezen vitatkozni.
( amúgy tényleg érdemes belenézni a zen1, zen2,zen3,zen4,zen5 definiciókba. )
https://github.com/llvm/llvm-project/blob/b68bcc1415151bd84b5868aa2c98663069f45469/compiler-rt/lib/builtins/cpu_model/x86.cdisclaimer: adatbázisokkal foglalkozom. A C-ből nem tudnék megélni, úgyhogy ne vedd a véleményemet szentírásnak.
S_x96x_S
ez valami high-end APU lehet: Weisshorn/MI450/XSwitch
https://x.com/9550pro/status/1834198086710952248--------------------
és "hivatalosan is" ezek lesznek a ZEN5-ös kódnevek -
case 26:
CPU = "znver5";
*Type = AMDFAM1AH;
if (Model <= 0x77) {
// Models 00h-0Fh (Breithorn).
// Models 10h-1Fh (Breithorn-Dense).
// Models 20h-2Fh (Strix 1).
// Models 30h-37h (Strix 2).
// Models 38h-3Fh (Strix 3).
// Models 40h-4Fh (Granite Ridge).
// Models 50h-5Fh (Weisshorn).
// Models 60h-6Fh (Krackan1).
// Models 70h-77h (Sarlak).
CPU = "znver5";
*Subtype = AMDFAM1AH_ZNVER5;
break; // "znver5"
break; -
S_x96x_S
Komplikato #9882 üzenetére
A ProArt X670E-CREATOR WIFI -ban JHL8540 -van,
"2 x USB4® with Intel® JHL8540 USB4® controller ports (2 x USB Type-C®)" -
S_x96x_S
köszi, de még nem látom azt amit keresek .
Amit tudni lehet:
hogy az ASMedia csinálta az X670/B650 -es chipseteket [1]
és szerintem az újabb X870 es generációt is ők.
[1] "AM5 Chipsets: X670 and B650, Built by ASMedia"
És még az I/O die -ba is kerülhetett néhány ASMedia -tól licenszelt dolog.
mert pl. a Phoenix (Ryzen 7040 mobil) is képes USB4 -re.<spekuláció ON>
Hátha lesz rendes Thunderbolt4 -es támogatás az AMD chipjeinél is.
<spekuláció OFF >
S_x96x_S
Mennyi az esély, hogy
az új AM5-ös USB4 -es alaplapok is megkapják a Thunderbolt 4-es tanúsítványt?
Vagyis másképpen : Milyen usb4 -es chip lesz az új 800-as lapokban?~ már 1 hetes a hír:
ASMedia ASM4242 USB4 Host Controller Chip Reaches Thunderbolt 4 Certification
S_x96x_S
"AMD’s Zen 5 is a missed opportunity in messaging
Masterclass in how to submarine good tech
Jul 24, 2024 by Charlie Demerjian
https://www.semiaccurate.com/2024/07/24/amds-zen-5-is-a-missed-opportunity-in-messaging/ -
S_x96x_S
Devid_81 #9853 üzenetére
> Lehet, hogy Intel sem lesz nagy elorelepes jatekban,
> igy nem sok ertelme van kiadni meg az X3D-t?!Ha az Inteles cpu nem ad nagy előrelépést,
akkor az új X3D-t prémium áron is el lehet adni.Vagyis ha kész van, akkor nincs értelme porosodni hagyni a raktárban.
(a közgazdasági racionalitás miatt )szerintem: valami műszaki ok lehet a háttérben.
S_x96x_S
"AMD Ryzen 9000X3D 3D V-Cache CPUs Reportedly Delayed To CES 2025"
https://wccftech.com/amd-ryzen-9000x3d-3d-v-cache-cpus-ces-2025-launch-delay/ -
S_x96x_S
hahakocka #9847 üzenetére
Az AMD-nél is megunhatták a szivárogtatást és biztos a belső biztonsági szolgálat az ipari kémkedés mellett erre is figyel.
Egyrészt - különböző osztályoknak más-más infót adnak
és megnézik, hogy mi szivárgot ki.
Ez alapján már könnyen lokalizálni tudják a szivárogtatót.a másik lehetőség, amire MLID célzott,
hogy eleve téves információt engednek ki, hogy megtévesszék a konkurenciát. -
S_x96x_S
jön a javítás
videocardz
AMD promises Windows 11 patch boosting Zen5, Zen 4, and Zen 3 gaming performance
eredeti
https://community.amd.com/t5/gaming/ryzen-9000-series-community-update-gaming-performance/ba-p/704054
"Further enabling advanced “Zen 5” architecture: For “Zen 5” users, here is our recommendation for how to unlock the best performance. Optimized AMD-specific branch prediction code will be available in Windows 11, version 24H2 in preview through the Windows Insider Program (Release Preview Channel - Build 26100) or by downloading the ISO here. While performance will vary based on the application and configurations, below is a sample of what you can expect to see with 24H2 on Ryzen 9000 desktop processors:"
Far Cry 6 : +13%
Cyberpunk 2077 : +7%--------------------------------
friss MLID RDNA4 leak ( RTX 8800 XT ; még az idén jön és jó lesz. ) --> #65429
S_x96x_S
S_x96x_S #9836 üzenetére
Az X86-os kompatibilitás elég kétélű fegyver.
Egyrészt. jó dolog, mert minden rétgi sw -is jól lefut.
másrészt a nagyon régi cpu-kal való kompatibilitás miatt,
a szoftverek jelentős része nem használja ki az új utasításokat
Emiatt
akár +30-60% ki nem használt teljesítmény is lehet a zen5 -ös cpu-k -ban.Ha az ARM-es Windows képes lesz ezt kihasználni,
akkor 5 éven belül megfordíthatja a trendet.
( és lényegében ez az Apple egyik előnye is, az M-es cpu-kal --> kevesebb cpu variánsra jobban optimalizált kódot tud készíteni ) -
S_x96x_S
Fix 3Ghz-en, hogyan teljesítenek a CPU-k.
"Zen 5 Variants and More, Clock for Clock"
https://chipsandcheese.com/2024/08/20/zen-5-variants-and-more-clock-for-clock/
...."I hope AMD will increase the L1 instruction cache’s size later on. Going to 64 KB probably isn’t enough. Apple and Qualcomm have gone for very large 192 KB L1 instruction caches, and with good reason. But even that won’t be enough to contain the instruction footprint on certain workloads.
Data-side latency is a big issue too. Tackling the memory latency problem today is arguably even harder than it was in the early 2010s. Pointer chasing through a 1 GB array with 2 MB pages gives about 76 ns of latency on the Athlon II X4 651. Do the same on the Ryzen AI 9 HX 370, and you’ll see over 128 ns of latency. Even though mobile Zen 5 has more reordering capacity and better caching than Husky, both cores often find themselves very backend bound.
S_x96x_S
Az Inteles Clear Linux még nagyobb ( +16% ) teljesítményt ad a 9950X-nek.
vagyis a szoftveres optimalizációban rengeteg tartalék van."Intel Continues To Show AMD The Importance Of Software Optimizations: 16% More Ryzen 9 9950X Performance"
https://www.phoronix.com/review/linux-os-amd-ryzen9-9950xpl. PHPbench
S_x96x_S
A zen5-ös ryzen-nél a B0 stepping sikeres volr!
Zen 4 Classic CCD
EPYC Stepping 1 (B1), Ryzen Stepping 2 (B2)
Zen 5 Classic CCD
EPYC Stepping 1 (B1), Ryzen Stepping 0 (B0)
https://x.com/9550pro/status/1825870149498597760 -
S_x96x_S
Petykemano #9832 üzenetére
- remélem, hogy ez év - szeptember !
- az is lehet, hogy az X3D -sek is 1-2 hetenként csorognak a piacra.
Érdekes marketing stratégia lenne, annyi haszonnal,
hogy ilyen alaposan ritkán teszteltek ki egy processzort. -
S_x96x_S
majd kiderül.
az újságcikkekhez képest nincs más infóm nekem se. -
S_x96x_S
Petykemano #9828 üzenetére
> Mit gondolsz, lesz idővel ezen az alapon sajátmárkás
> notebook, pckonzol és/vagy minipc?valószínűleg nem lesz.
Legalábbis a ZT Systems -et mintha ketté-szednék
és a szerver üzletágas részét eladják valaki másnak a következő időszakban."Frank Zhang, founder and chief executive officer at ZT Systems, will continue to run the manufacturing business and honor the commitments the company has to existing customers after AMD completes the acquisition of the company, which it expects to close early next year. In the meantime, Zhang will be looking for someone to buy the manufacturing operations, which has around 1,500 employees, because AMD is not interested in being in the server manufacturing and server selling businesses and therefore competing with its customers. Unlike another prominent GPU system maker we know. . . ."
vagyis az AMD a látszatát is el akarja kerülni,
hogy érdek konfliktusba ( ~ VERSENYHELYZETBE)
kerüljön az OEM/ODM/Szerver partnereivel.
Legalábbis Forest Norrod (AMD) ezzel nyugtatja a partnereket....
"“Obviously, we started talking to all our OEM and ODM partners already,” Forest Norrod, general manager of the datacenter business at AMD and formerly the head of the custom server business at Dell, tells The Next Platform. “And I think the reassuring thing is that all those conversations have all been very good, very positive. People immediately get why we are doing this, and they appreciate and understand and believe that we have no intention of competing with them. Not going to do it, not going to happen. I understand super well both businesses, and I’m not confused.”"
( via nextplatform.com ) -
S_x96x_S
ha megkésve is : Ryzen 3000 -re is jön a Sinkclose javítás.
S_x96x_S
Petykemano #9818 üzenetére
> Pontosan milyen előnyt/képességet nyer ezzel az AMD?
AI STD (Speed-to-Deploy)
legalábbis a
https://www.servethehome.com/amd-buys-zt-systems-in-a-surprise-move/
szerint."AMD buying ZT’s engineering resources gets it that type of acceleration. When AMD talks about $4-5B of AI server revenue this year, it is important to think of that only as 1-2 clusters worth of GPUs. A company like Supermicro on the NVIDIA side can deliver a full $4-5B cluster now in less than a month. If AMD is going to scale, it needs not just the technology and pricing to justify the investment over NVIDIA, it also needs to be available in the same windows. GPU clusters are now so big that a cluster taking a year to come online is not acceptable. Three years (or more) for a HPE-Cray government Exascale supercomputer feels like a laughable paleolithic pace of project planning."
"AMD is really getting the ability to scratch the AI STD (Speed-to-Deploy) needs of its customers, not trying to compete directly with its partners. If it does not address the AI STD metric, then it will not be able to compete in the future. That is a massive deal for any AI startup outside hyper-scalers, NVIDIA, AMD, Cerebras, and maybe Intel.
S_x96x_S
(ZT Systems)
A miért -re ez talán egy jobb cikk[1]pár gondolat:
- kevés a jelenlegi 500 rendszer mérnök és a Supermicro túl drága.
- Az nVidia DGX -re kell alternativa.
- A ZT Systems jelenlegi főnöke együtt dolgozott Forest Norod -al még a Dell-nél.[1] "Why AMD Spent $4.9 Billion To Buy ZT Systems"
https://www.nextplatform.com/2024/08/19/why-amd-spent-4-9-billion-to-buy-zt-systems/"What AMD is going to do is up its game in systems architecture and engineering. At the moment, AMD has somewhere around 500 system engineers, Norrod estimates, but ZT Systems has 1,100 people that do this work. And given that AMD doesn’t just build systems to one standard, but multiple standards, it needs that many more people to help it design and build to test – but not manufacture for production – the future GPU accelerated systems that are going to be a challenge for it. It is not clear what AMD will get as it spins off that ZT Systems manufacturing business, but amassing 1,100 system engineers with deep, real-world experience would not only cost billions and billions of dollars, but it may not be possible to get it any other way than acquiring a boutique high performance system manufacturer like ZT Systems.
It’s cheaper than acquiring Supermicro. . . . and probably with the same level of system engineers.
This is really about time to market and upping the system design and engineering game. AMD has done a great job putting together excellent CPUs and now GPUs, but it needs to put together a networking stack and system boards, and have it all fit in rackscale and cluster-wide system designs that are tested and validated at scale. This is why Nvidia created the DGX line, and AMD agrees that it needs to do this but it is not going to build systems for customers and it is not going to be a prime contractor for HPC or AI clusters. Unlike Intel tried to be and failed at pretty badly.
Doug Huang, who was a director of engineering of the Data Center Solutions division at Dell under Norrod, was hired to be vice president of platform engineering at ZT Systems in January 2013, when it pivoted to rackscale systems. Huang rose through the ranks to head up engineering and global manufacturing at ZT Systems and was named president of the company in January 2023. Huang is going to stay on at AMD and run the combined team of around 1,600 system designer and engineers.
S_x96x_S
> nagy pps rate esten (packet per second) bizony kimerheto volt az elonye.
> amig mind befert a cache-beAkkor az X-es (3D Vcache) -s nagy L3 cache-es Epyc -nek tényleg ideális lesz.
( AMD EPYC™ 9684X L3 Cache = 1152 MB ; AMD 3D V-Cache™ Technology ) -
S_x96x_S
( ahogy én látom )
A honlap alapján tényleg értenek a hw-hez - és még több epyc,Mi300, Xilinx gyorsítót tudnak eladni:
- Compute
- Storage
- GPU/Accelerator
- Integrated racks
- High-performance compute (HPC)
- 5G/telecommunications
- Edge computing
- Open compute project
https://ztsystems.com/solutions/> Ők is olyan kész megrakott tepsiket akarnak árulni, mint az nvidia?
optimalizált - tepsiket és szekrényeket.
( És ez olyan mint a szállításban a konténerek - felgyorsítanak sok mindent. )A piac gyors megoldást akar,
és ha ezzel 3-6 hónapot lehet nyerni a megrendelés és a beüzemelés között, akkor megéri.pl. A ZTsystems eléggé rástartolt a Microsoft’s Project Olympus szerver szabványra -ra,
ami segithet a Microsoft Cloud ( Azure) - val gyorsabb termékelhelyezésnél.
és az IDŐ = PÉNZ !"XPO200 Server Solutionsbased on Microsoft’s Project Olympus
We’ve combined the groundbreaking energy efficiency, performance, versatility and cost-effectiveness of Microsoft’s Project Olympus platform with our hyperscale-focused design, manufacturing and deployment capabilities to create our XPO200 server solutions.
These solutions allow you to benefit from our unique experience deploying platforms that feature these technologies into real-world, hyperscale environments."Ha az AMD tud olyan tervet, adni, amikor az EPYC és több MI300 egybe van optimalizálva, akkor kevésbé fordul az elő ( vagy kevésbé éri meg ) ,
hogy Intel CPU -val csomagolják az MI300-at, mint a Microsoft felhőben.A mások probléma, hogy jelenleg házon belül
a meglévő EPYC és az RDNA mérnökök végzik ezt a feladatot.
És ha lesz erre egy dedikált új csapat, akkor kevésbé vesznek el erőforrásokat p. Gaming csapattól.Vagyis indirekte ( áttételesen ) szerintem ez jó hír a gaming és a consumer vonalnak is.
Persze kell 2-3 év mire meglátszik a hatása-. -
S_x96x_S
Egyre közelebb az AGESA vége.
AMD To Provide Update On Long-Term Strategy For Open-Source Firmware
https://www.phoronix.com/news/AMD-Open-Source-FW-Strategy
https://www.osfc.io/2024/talks/amds-long-term-strategy-for-open-source-firmware-from-concept-to-implementation/
https://www.osfc.io/ -
S_x96x_S
érdekesség:
A Smart Data Cache Injection (SDCI) - az AMD EPYC cpu-k képessége lesz.(spekuláció részemről) A desktop X3D és a (Strix Halo) 32MB of MALL Cache -nál is lehet értelme valami hasonlónak. Főleg akkor hogyha az alacsony latency-s Gen5 SSD -k is egyre inkább elterjednek.
"AMD Preparing Linux For Smart Data Cache Injection With "Upcoming" CPUs"
https://www.phoronix.com/news/AMD-EPYC-SDCI-Cache-Injection""Upcoming AMD hardware implements Smart Data Cache Injection (SDCI). Smart Data Cache Injection (SDCI) is a mechanism that enables direct insertion of data from I/O devices into the L3 cache. By directly caching data from I/O devices rather than first storing the I/O data in DRAM, SDCI reduces demands on DRAM bandwidth and reduces latency to the processor consuming the I/O data. The SDCIAE (SDCI Allocation Enforcement) PQE feature allows system software to limit the portion of the L3 cache used for SDCI.""
S_x96x_S
10 év ....
2014 "Vélemény: 100 évre lefutott meccs az AMD-Intel?"
https://prohardver.hu/teszt/velemeny_100_evre_lefutott_az_amd-intel_meccs/nyomtatobarat/teljes.html
2014: Lisa Su - az AMD CEO-ja lett.
2024 - zen5A következő 10 évben az nVidiát kell utolérni.
S_x96x_S
Olrak találgatós - ( 2023-aug-10-ről )
N4 IOD + N3E CCD
https://x.com/Olrak29_/status/1822173347733455000-------------
Talán a zen6 ( Medusa ) ? vagy az Mi350 ? -
S_x96x_S
S_x96x_S #9798 üzenetére
dekódolás:
AMD plans October 10 launch for Ryzen AI 300 PRO, EPYC Turin, Instinct MI325X, and Strix Halo preview at CES 2025
https://videocardz.com/newz/amd-plans-october-10-launch-for-ryzen-ai-300-pro-epyc-turin-instinct-mi325x-and-strix-halo-preview-at-ces-2025(?) az X3D ( 9800X3D ) nincs említve. Lehet, hogy az ennél korábban jön, vagy ki tudja ...
S_x96x_S
https://x.com/AnhPhuH/status/1823912091503485346
1️⃣0️⃣.1️⃣0️⃣ Strix PRO, Turin (Classic & Dense), MI325X, some new Xilinx
CES2️⃣5️⃣ Strix Halo, Kraken (Krackan) -
S_x96x_S
S_x96x_S
paprobert #9768 üzenetére
nem sok remény van.
"According to a statement given to Tom's Hardware, AMD said, "There are some older products that are outside our software support window." AMD has no plans to update its older Ryzen 3000 series processors, and it is possible that the vulnerability extends back further than the processors listed in AMD's advisory. We're following up for more details."
( tomshw ) -
S_x96x_S
AMD’s Strix Point: Zen 5 Hits Mobile
https://chipsandcheese.com/2024/08/10/amds-strix-point-zen-5-hits-mobile/
- Keretmentesít a Galaxy S25 FE
- Kettő együtt: Radeon RX 9070 és 9070 XT tesztje
- Hardcore café
- Telekom mobilszolgáltatások
- OLED TV topic
- Xiaomi 13T 256GB, Kártyafüggetlen, 1 Év Garanciával
- Honor Magic6 Lite 256GB, Kártyafüggetlen, 1 Év Garanciával
- Komplett új gép eladó Ryzen5 8400F nettó áron!
- Bomba ár! Lenovo ThinkPad L13 G3 - i5-1245U I 16GB I 256SSD I 13,3" FHD Touch I NBD Gari!
- Bomba ár! Lenovo ThinkPad T490 - i7-8GEN I 16GB I 256GB SSD I 14" FHD I Cam I W10 I Garancia!
- BESZÁMÍTÁS! Apple MacBook Pro 16 M4 Pro 24GB RAM 512GB SSD - garanciával hibátlan működéssel
- Samsung Galaxy S10 128GB, Kártyafüggetlen, 1 Év Garanciával
- 124 - Lenovo Yoga Pro 7 (14IMH9) - Intel Core Ultra 9 185H, RTX 4060 (48 hónap garancia!) (ELKELT)
- ÁRGARANCIA!Épített KomPhone i9 14900KF 32/64GB RAM RTX 5070Ti 16GB GAMER PC termékbeszámítással
- Csere-Beszámítás! RTX Számítógép PC Játékra! I3 10100F / RTX 2060 12GB / 32GB DDR4 / 500GB SSD
