arn
de vmi olyasmi... de ez kb annyira lehet jo pofa dolog, mint speakeren
PC software generated multitimbral music and sound effects through the AdLib card, although the acoustic quality was distinctly synthesized. Digital audio (PCM) was not supported; this would become a key missing feature when the competitor Creative Labs implemented it in their Sound Blaster cards. It was still possible, however, to output PCM sound with software by modulating the playback volume at an audio rate, as was done for example in the MicroProse game F-15 Strike Eagle II[5] and the multi-channel music editor Sound Club for MS-DOS.[6]
ez meg a vogonsrol... ez erosen a technika meghagasa:
In theory yes, but in practice there's quite many limitations.
-at maximum volume, only 8 operators can fit into output without clipping (but of course not all channels would be at maximum value at the same instant so in practice you can play more channels without clipping depending on what you play).
-the 6-bit volume register is logarithmic, so it is very bad for playing linear PCM. It would sound much more crude than simple 8-bit Covox DAC, or even a 6-bit linear DAC. I haven't done the maths, but I assume it would equal to something like 4-bit linear PCM.
-OPL2 needs so long delays between port writes that you can only write theoretically maximum of 37287 different registers per second, regardless of what CPU drives it. So even with two channels would be 18.6 kHz, and four channels would be 9.3 kHz - hardly enough for 4 channel MOD playing. -
arn
Lord Myn
#66302
ennek utana olvasok... de igazabol a tenyen nem valtoztat, hogy a blaster digitalis reszet tamogato jatek nem fog adlibon digi hangot lejatszani, illetve, hogy az opl2 alapvetoen fm alapu midi lejatszasra van hasznalva.
itt nem azt hasznaljak ki, hogy midiszeruen hangot modulalnak az opl2on keresztul?
arn
hege8888
#66297
Szvsz nem vagy tisztaban azzal, hogy mit jelent, hogy digitalizalt hang, es midi, azon belul is fm, hullamtabla, etc
egy blasternak pl van egy digi resze da atalakitoval es egy fm alapu midi. Egy modul alapu zene lejatszashoz da szukseges, ha ez nincs a kartyan, nem fog megszolalni, ahogy a digitalizalt hangok sem. Az adlib az gyk a blaster fm midi resze csak, csak midi alapu zened lesz rajta.
az aladdin, pinballok altalaban digitalizalt vagy modul alapu zenet hasznalnak, olyan kartya kell hozza, amin van dac.
arn
envagyok
#66291
A 3dmarkok mindig csak d3dt tamogattak. Vmi jatekkal tudsz benchmarkolni, de igazabol becsapos lesz a dolog, mert a kezdeti idoben eleg nagy elteres volt a kartyak ficsorbeli tudasaban. Igy lehet vmi porgott, csak eppen fele akkora texturaval, vagy gyengebb kepminoseggel es bizonyos effektek hianyoztak. Ezert volt a korai 3dbenchekben minosegteszt.
v3 jo pelda... szepen teker, csak eppen a texturak joval homalyabbak.
arn
envagyok
#66283
a glide kb 98ban kidoglott olyan szempontbol, hogy glide only jatek jelenjen meg... utana meg hiaba volt dedikaltabb api, a kartyak gyakran kevesebbet tudtak ficsor szinten, mint a konkurencia, illetve a konkurens api (opengl, d3d), okafogyotta valt az egesz.
a v5 mar csak vergodes volt, retros erdekessegnek jo, hasznalati szempontbol sose volt jo. ha nagyon voodoozni akarsz, arra tokeletes egy v3 - remek az analog kimenete, es kb azt tudja, amit a v2 sli, annak hatranyai nelkul.
en az elejen gf2gts + v2 kombot hasznaltam, hogy majd milyen jokat fogok glidolni
aztan rajottem hogy azert a par jatekert arra is lusta vagyok, hogy az atkotot rakossem. ha rogzitek vmit, inkabb beteszem a v3at, mint a v2vel kinlodjak. 98ban a fel karomat adtam volna erte, de sajnos most is inkabb csak porfogo. -
arn
nem postolok tobb youtube, etc linket ide, tobbi info itt
arn
envagyok
#66247
ezt annyira nem osztom... foleg, ha ugyanabban a gepben egy pnp semmi ilyen jelenseget nem produkal. vmi le fog akadni, ha sok demot nezel, tuti lesz, ami egyik esetben ok, a masikban meg nem. vmi hulyeseget csinal a kartya - hianyzanak mintak, stb. ettol szolni szol, de csak annak fog lehet feltunni, aki ismeri, hogy kellene mukodnie.
en socket5ig hasznalok classicot, socket7tol pnpt.
arn
Bile Demon
#66228
Errol beszeltem korabban, az isa busz es gyorsabb gepek. Probald ki egy 386ban pl.
240,3,3,7,7 esetleg?
arn
arn
MasterDeeJay
#66180
a tenyleges fogyasztast merd le, a homerseklet meg nem igazan osszehasonlithato, mernek vmit, aztan beallitanak ra egy offsetet es azt mondjak, hogy ez ennyi... aztan minden procit mas modszerrel merhetnek (foleg a regieket), es masmas offsettel mukodnek. tehat, hogy huvos-meleg erosen relativ.
arn
Demos available on the Facebook:
Orb & Andromeda - Stargazer (2008) demoscene demo 1440p retro PC
Purple - Den Onde Corporation (1996) demoscene demo 2160p retro PC
Threestate - Lost Vegas (2000) demoscene 64k intro 2160p retro PC
Pulse - Famous Cyber People (1996) demoscene 64k intro 2160p on retro PC
Camorra - Gu-star (1996) demoscene 64k intro 2160p retro PC -
arn
DarthSun
#66106
Aaa... nincs ennyi helyem. Ebben az allapotaban korbefotozom, csinalok egy galeriat. Aztan szetszedem, lemosom, es megy bele egy dx2-66. Ha nem jon be hasznalatra, akkor dx4 koltozik bele.
Most hogy osszeraktam a socket5ot, igazabol a sokat polirozhatott dx4 kicsit okafogyotta valt. A dx2 tobb mint eleg 93ig, a socket5 meg 95ig, olyan 3x gyorsabb.
arn
Egy erintetlen 386, kb 94 elejen adhattak el. A tipikus 386dx40, trident, 170m conner
asszem 4m ram. Van rajta koproci foglalat. Ez mar akkor is budget volt.De hihetetlen, hogy sikerult elkerulnie a bezuzast, dobalast, fejlesztest, stb szloveniaban egy szekrenyben pihent.
A haz miatt vettem, de oszinten most sajnalom szetszedni, olyan ritkan latok ilyen allapotu regi epitett pct.
arn
quailstorm
#66068
datapath e1s-em van, ehhez szvsz felesleges az ossc.
az ossct tervezem, de azert, hogy esetleg vmi modernebb capture kartyara valtsak. viszont szkeptikus vagyok, hogy a folyamatos modvaltasok jol mennek rajta, illetve, hogy a modernebb kartyan loopbackel menne a 4k60p rogzites. lehet csak egy dedikalt capture geppel lehetne.
egyre nepszerubb a retro, nem hiszem el, hogy nincs egy gyarto, aki csinalna mar egy kompromisszummentes megoldast. 100-200 eurobol tuti ki lehetne hozni.
arn
slot1 prociknal a pinek szabtak meg, hogy mekkora feszt adott a procinak alapbol (meg persze a lap, hogy tudta e ezt). lehet ez a gond, hogy a pin tobbre allitja, a bios meg mast gondol.
mas procival nem nezted?
illetve DarthSunnak is igaza lehet, hogy a -5v miatt kiabal. tobb lapnal ki lehet ezeket a figyelmezteteseket kapcsolni.
arn
unclefucka
#65980
a 8900c es 8900d kozott meg volt a cl (sot azon belul tobb rev). asszem azok voltak az elso 16/24 bit dacos 32 bites buszu dbok.
legalabbis az elso 386osomon tudtam 24 bites kepet "renderelni". szo szerint, mert latszott, ahogy kirajzolja
arn
arn
unclefucka
#65889
Demok nem igazan mennek a blasteren
jatekokhoz eleg felesleges a gus, max a modulos jatekokban jobb. -
arn
MasterDeeJay
#65885
itt sem voltak meg 3ds ellenfelek, az csak a quakeben jott. de ha ilyen szempontbol nezzuk, a descent elobb volt, ott harom iranyban lehetett mozogni, es az objektek is 3dsek voltak mar.
arn
csinaltam egy dicsekvos facebook csoportot, aktualis beszerezesekrol
arn
arn
arn
Mi a kerdes?
arn
Madara-san
#65783
a dtk az igy nezett ki... de a vilag masik felen mas nevvel is hasznaltak. nalunk viszont a nevesitett hazak korszaka elott, eleg ritka volt egyegy jobb minosegu haz. a dtk az jobb volt. persze nem mai mercevel, hanem a korai nyeklonyaklo szarok mellett.
arn
biztos, hogy csak rosszul van jumperelve, a tx97 ujabb lap egy penya classicnal az mmxekhez jelent meg.
arn
arn
arn
hege8888
#65711
Arrol nincs... inkabb ha van egy megepitendo gep, ahhoz probalok megfelelo tipust szerezni. A legegyszerubb, ha megnezed rajta a gyartasi datumot. Annyira porogtek, hogy szvsz fel-egy evnel nem nagyon voltak hosszabb ideig gyartasban.
a masik modszer, hogy fellapozod a regi ujsagokat, es nezel gepteszteket, hogy milyen meghajtokat pakoltak bele. A korai idoben, mivel nem voltak tul olcsok, meg pontosan lekovethetoek 2000 korul mar nehezebben, de utana meg volt mar net sok teszttel.
de milyen idoszakrol lenne pontosan szo?
a korhu szamitogephazak, meghajtok, vinyok beszerzese szvsz a legnehezebb... erre a piac mar raeszmelt, a szep allapotu regi hazak ara mar szepen elszallt. Cdromoknal inkabb csak az oscdk kezdenek kikopni (95 elott), utana meg relativ van felhozatal, de pontos, korhu tipus beszerzese, nem agyonsargulva szinten baromi nehez.
arn
hege8888
#65708
kicsit mindig varialom oket
elobb majd beragad vhova... aktualisan ezek az allando jellegu gepek, meg van par felkonfig.1994.10. - DX4 MS-DOS 6.22
Mainboard Asus VL/I-486SV2GX4 rev 2.1
CPU Intel DX4 100 WB
CPU cooler passzív ragasztott borda
RAM Samsung 16M FPM
Video card Genoa Phantom 64 2M VLB
Sound card Creative Sound Blaster Pro 2.0 CT1600 rev 06 ISA
Sound card Gravis Ultrasound 3.74 1M ISA
MIDI vezérlő Roland MPU-IPC
Hangmodul Roland MT-32
Hangmodul Roland SC-55
I/O kártya DTK PTI-265W VLB controller
HDD Western Digital Caviar 2700 730M
ODD Sony CDU-55E 2x CD-ROM IDE
FDD Mitsumi
Case Baby AT (cyan button)
PSU FSP SPI-300G1995.05. - Socket 5 MS-DOS 6.22
Mainboard Intel Advanced/ZP
CPU Intel Pentium 120
CPU cooler Socket 5 (blue)
RAM Micron 16M EDO
Video card Diamond Stealth 64 Video VRAM 2M PCI
Sound card #1 Creative Sound Blaster AWE32 Value CT3910 ISA
Sound card #2 Gravis Ultrasound 3.74 1M ISA
HDD Western Digital Caviar 31200 1200M
ODD Sony CDU-77E 4x CD-ROM IDE
FDD Panasonic
Case Baby AT (blue button)
PSU FSP SPI-250G1997.09. - Pentium MMX Windows 95 OSR 2.5
CPU Intel Pentium MMX 233
CPU cooler Pentalpha Socket 7
Mainboard Asus TX97-X rev 3.00
RAM LG 32M PC66 SDRAM
Video card Asus 3DP-V3000/TV 4M PCI rev 1.03
Video card Diamond Monster 3D 4M PCI
Sound card Creative Sound Blaster AWE64 Gold PnP CT4390 rev 01 ISA
Sound card Gravis Ultrasound Plug & Play 1.0 8M ISA
HDD Quantum Fireball ST 4.3G IDE
FDD Mitsumi
ODD Cyberdrive 240D 24X CD-ROM IDE
Case TK2002
PSU Enermax EG365P-VE1999.10. - Pentium III Windows 98 Second Edition
CPU Intel Pentium III 700
CPU cooler SECC2
Mainboard Asus P3B-F rev 1.04
RAM Toshiba 128M PC100 SDRAM
Video card Asus AGP-V6600 Pure 32M AGP
Video card Diamond Monster 3D II 12M PCI
Sound card Creative Sound Blaster Live! CT4620 PCI
HDD IBM Deskstar 34GXP DPTA-372730 27G IDE
ODD HP E118405 4x4x32x CD-RW IDE
FDD Mitsumi
Case In Win IW-A500
PSU Chieftec GPS-350EB-101A2003.06. - Athlon XP Windows XP SP1
Mainboard Asus A7N8X Deluxe rev 2.0
CPU AMD Athlon XP 3200+
CPU cooler Spire Falconrock II
RAM Samsung 512M DDR-400
Video card Sapphire Atlantis Radeon 9800 Pro 128M AGP
Video card hűtő Zalman ZM80C-HP + ZM-OP1
Sound card Creative Sound Blaster Audigy 2 Player SB0240 PCI
HDD Seagate Barracuda 7200.7 120G IDE
ODD LiteOn XJ-HD166S 16x DVD-ROM IDE
ODD LiteOn LTR-52327S 52x32x52x CD-RW IDE
Case Chieftec Dragon DG-01W
PSU Enermax EG365AX-VE(G)2006.11. - Core 2 Quad Windows XP SP2
Mainboard Asus P5W DH Deluxe rev 1.04
CPU Intel Core 2 Extreme QX6700
CPU cooler Zalman CNPS9500 AT
RAM Corsair XMS2 2G DDR2-800
Video card Asus EN8800GTX 768M PCIe
Sound card Creative Sound Blaster X-Fi Fatal1ty SB0460 PCI
I/O Drive Box Creative Sound Blaster X-Fi Fatal1ty SB0250
HDD Western Digital Raptor WD1500ADFD 150GB SATA
HDD Western Digital RE2 WD5000YS 500G SATA
ODD Pioneer DVR-111DBK DVD writer IDE
Case Antec P180B
PSU Corsair CMPSU-520HX -
arn
a v2 inkabb csak erdekessegnek jo, nagyon szuken hasznalhato jol (kb 98), a bx kb 98-2000ig ment igazan, ez eleg szeles korszak, baromi sokminden tortent 3ds reszrol (eljutottunk a v2tol a gf2ultraig). ott a tabla, ha korhu vmit akarsz.
a tnt-gf mind jo kompatibilitas szempontjabol, dos ala is.
nekem a p3b-f es a bx6-2 a kedvenc.
- Gyúrósok ide!
- Xbox tulajok OFF topicja
- Rekordtempóban fogy a Resident Evil Requiem, már 6 milliónál jár
- Luck Dragon: MárkaLánc
- Nagyrobogósok baráti topikja
- Tőzsde és gazdaság
- BESZÁMÍTÁS! Akár részletfizetés 0% THM ÚJ AMD RYZEN AM4 processzorok 3 év garanciával 27% áfaval
- i3-8100 és i3-8100T - stabil, gyors, megbízható - ideális otthonra vagy irodába
- Intel Core i9 11900
- BESZÁMÍTÁS! Intel Core i7 4770K 4 mag 8 szál processzor garanciával hibátlan működéssel
- Intel I7-8700 / BESZÁMÍTÁS OK!
- Asus TUF B760-Plus Wifi (apró hibával)
- AKCIÓ! AMD Ryzen 7 5700X3D 8 mag 16 szál processzor garanciával hibátlan működéssel
- iPhone 17 Pro Max Mélykék - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok !!
- HIBÁTLAN iPhone 15 128GB Yellow-1 ÉV GARANCIA - Kártyafüggetlen, MS4489, 100% Akksi
- ÁRGARANCIA! Épített KomPhone Ultra 9 285K 32/64GB RAM RTX 5070 Ti 16GB GAMER PC termékbeszámítással
