ReJim
sziasztok c-ben hogyan tudok udp-n adatot küldeni?
(server linuxon, kliens winen. gcc fordítók, winen devc++ és mingw)ez a kód jó lenne nekem, de winre nem találok headert:
/*********************** udpclient.c ***********************/\
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
#include <stdio.h>
#include <unistd.h>
#include <string.h> /* memset() */
#include <sys/time.h> /* select() */
#define REMOTE_SERVER_PORT 1500
#define MAX_MSG 100
int main(int argc, char *argv[]) {
int sd, rc, i;
struct sockaddr_in cliAddr, remoteServAddr;
struct hostent *h;
/* check command line args */
if(argc<3) {
printf("usage : %s <server> <data1> ... <dataN> \n", argv[0]);
exit(1);
/* get server IP address (no check if input is IP address or DNS name */
h = gethostbyname(argv[1]);
if(h==NULL) {
printf("%s: unknown host '%s' \n", argv[0], argv[1]);
exit(1);
printf("%s: sending data to '%s' (IP : %s) \n", argv[0], h->h_name,
inet_ntoa(*(struct in_addr *)h->h_addr_list[0]));
remoteServAddr.sin_family = h->h_addrtype;
memcpy((char *) &remoteServAddr.sin_addr.s_addr,
h->h_addr_list[0], h->h_length);
remoteServAddr.sin_port = htons(REMOTE_SERVER_PORT);
/* socket creation */
sd = socket(AF_INET,SOCK_DGRAM,0);
if(sd<0) {
printf("%s: cannot open socket \n",argv[0]);
exit(1);
/* bind any port */
cliAddr.sin_family = AF_INET;
cliAddr.sin_addr.s_addr = htonl(INADDR_ANY);
cliAddr.sin_port = htons(0);
rc = bind(sd, (struct sockaddr *) &cliAddr, sizeof(cliAddr));
if(rc<0) {
printf("%s: cannot bind port\n", argv[0]);
exit(1);
/* send data */
for(i=2;i<argc;i++) {
rc = sendto(sd, argv[i], strlen(argv[i])+1, 0,
(struct sockaddr *) &remoteServAddr,
sizeof(remoteServAddr));
if(rc<0) {
printf("%s: cannot send data %d \n",argv[0],i-1);
close(sd);
exit(1);
return 1;
}valakinek valami ötlete?
● ha kódot szúrsz be, használd a PROGRAMKÓD formázási funkciót!
- BESZÁMÍTÁS! ASUS TUF GeForce RTX 3080 Ti 12GB videokártya garanciával hibátlan működéssel
- Szuper áron eladó dobozos Asus Vivobook 16 /Ryzen 5-7530U/16 GB RAM/256 GB SSD/FHD+/IPS/16"/Gari/
- 160 - 177 - 178 - Lenovo LOQ (15IRX9) - Intel Core i7-13650HX, RTX 4060 (ELKELT)
- Gamer egerek és billentyűzetek kitűnő árakon!
- Telefon felvásárlás!! Apple iPhone 16, Apple iPhone 16e, Apple iPhone 16 Plus, Apple iPhone 16 Pro
