Debian GNU/Linux
CPT.Pirk
bambano
#3935
dpkg --list|grep firmware
ii firmware-linux-free 3 Binary firmware for various drivers in the Linux kernel
dmesg| grep e100
[ 0.201242] pci 0000:00:02.0: reg 10: [mem 0xee100000-0xee17ffff]
[ 1.035168] e1000e: Intel(R) PRO/1000 Network Driver - 1.3.10-k2
[ 1.035171] e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
[ 1.035203] e1000e 0000:02:00.0: Disabling ASPM L0s L1
[ 1.035220] e1000e 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.035248] e1000e 0000:02:00.0: setting latency timer to 64
[ 1.035448] e1000e 0000:02:00.0: irq 44 for MSI/MSI-X
[ 1.148407] e1000e 0000:02:00.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:15:58:7c:2b:5e
[ 1.148412] e1000e 0000:02:00.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.148489] e1000e 0000:02:00.0: eth0: MAC: 2, PHY: 2, PBA No: 005301-003
[ 12.586892] e1000e 0000:02:00.0: irq 44 for MSI/MSI-X
[ 12.640161] e1000e 0000:02:00.0: irq 44 for MSI/MSI-X
[ 14.250612] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 14.250619] e1000e 0000:02:00.0: eth0: 10/100 speed: disabling TSO
[ 171.512185] e1000e: eth0 NIC Link is Down
dmesg|grep firmware
[ 6.281743] thinkpad_acpi: WARNING: Outdated ThinkPad BIOS/EC firmware
[ 6.281746] thinkpad_acpi: WARNING: This firmware may be missing critical bug fixes and/or important features
[ 12.913258] IBM TrackPoint firmware: 0x0e, buttons: 3/3 -
CPT.Pirk
bambano
#3933
Kivágták?
lshw -class network
*-network
description: Ethernet interface
product: 82573L Gigabit Ethernet Controller
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 00
serial: aa:00:04:00:0a:04
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=1.3.10-k2 firmware=0.5-1 latency=0 link=no multicast=yes port=twisted pair
resources: irq:44 memory:ee000000-ee01ffff ioport:2000(size=32)Ez ír egy fw verziót, ebből arra gondolok, hogy van FW.
CPT.Pirk
bambano
#3931
Megváltozott a csomag neve és a helye, de az új fájlal is működik.
Tehát aki régi kamerával akar skype -olni wheezy / testing alatt, az ezt írja be a "parancsikonba":
LD_PRELOAD=/usr/lib/i386-linux-gnu/libv4l/v4l1compat.so skype
Viszont a vezetékes lan még mindig nem jó, ez van most az interfaces fájlban:
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
allow-hotplug eth0
#NetworkManager
iface eth0 inet dhcpÉs ez a 27.-eli mentésben:
auto lo
allow-hotplug eth0
iface eth0 inet dhcpDe egyikkel sem jó a net. A KDE network managerében nem szerkeszthető a wired kapcsolat, és az van írva, hogy az interface korlátozva van valami restricted interfacere, term. azt sem lehet állítani eth0-ra.
CPT.Pirk
bambano
#3929
Leellenőriztem rögtön a telepítés után!
Megvan, de tegyük hozzá, hogy most wheezy van beírva a sourcesbe, nem testing. Lehet h. az ftp.bme.hu.... -s reóban volt valami elkutyulva a testing részen.
Am. pl. a video4linux még érdekes lesz, a könyvtár is eltűnt, de a csomag fel van téve. Majd holnap megnézem, látja-e a kamera képét, vagy nem. Vagyis meg kell keresni, hova került a fájl, és meg kell adnom a preloadnak...
Plusz valamiért nem jön létre UTP-n a kapcsolódás DHCP-s routerhez, és az alap wired kapcsolat meg nem szerkeszthető és nem is törölhető a beállításokban, valszeg bele kell túrni az interface beállításaiba. Frissítés alatt persze még szedte a csomagokat UTP-n.
CPT.Pirk
bambano
#3924
No találtam egy repó, amolyan backports jellegű a KDE-hez: [link]
Végigcsináltam, bár nem volt zökkenőmentes, és 1-2 dolog bugos, de már van új 4.6-os KDE-m a squeezeben, és bár nem enged emelt jogosultságokat állítani a systemsettingshez a kdesu-val, így nem tudok autó bejelentkezést beállítani, de legalább az energiagazdálkodás jól működik, minden beállítható és végre nem bugos a paneltálca.
Valszeg az lesz, hogy szerdán felrakok egy tiszta image-t az említett oldalról, amiben alapból 4.6-os KDE van a squeezeben.
CPT.Pirk
bambano
#3922
A debian faq szerint:
Currently testing is called wheezy. So, if you change the third field of /etc/apt/sources.list to wheezy, then also you will be running testing. But when wheezy becomes stable, you will still be tracking wheezy.
a testing a wheezy. Most akkor nem ugyanoda fogok jutni, mint korábban? Nem említve a fájlrendszerrel történteket, hanem pl. a hiányzó sun féle java, meg a hiányzó fájl amit korábban említettem, meg ilyenek...
CPT.Pirk
bambano
#3918
Vajon olyan összetett dologgal, mint a KDE működhet ilyesmi? Nem tudom, hogy valaha fogják-e frissíteni a stabel ágban, mert az ott lévőben még azt sem lehet állítani, mit csináljon a laptop a fedél lehajtásakor.
Pl. elindítom a menüben a leállítást, és mikor már dolgozik a gép, lecsukom a fedelet, erre kijelentkezik, és megáll minden. Fedél felnyitás után meg már nem csinál semmit a leállítás gombra, mert nem tudja mi a frász történt. Biztos van terminálos állítási módja, de KDE-ben tök egyszerű lenne, ha az a menüpont élne. Testinges KDE-ben tökéletesen működik, de nem akarok megint összeborult rendszert. -
tlac
bambano
#3918
hmm...
nem olyan régen játszottam már ezzel a módszerrel, de úgy emlékszem, hogy akkor túl sok cuccot rakott felviszont sok évvel ezelőtt csináltam az nvidia féle .run-os driverekből csomagot, vajon működhet-e még?
de akkor még dkms nem is létezett, össze lehetne-e hozni vele? -
CPT.Pirk
bambano
#3904
Természetesen mindig volt apt-get update. Valamint megpróbáltam dselectben is megkeresni (az ottani frissítés is apt-get updatet csinál), az sem találta meg a sun-os java csomagokat, csak a két másik java csomagot.
Ez olyan, minthogy az Ati-s fglrx driver egyik modulja / állománya eltűnt az asztali gépen, szintén a testing repót használva, ami korábban volt. A sun-féle javás csomag is megvolt korábban a testingben, de most nincs.
CPT.Pirk
bambano
#3900
Hopp, ez a backports hiányzott eddig az életemből! (kivéve az iceweaselt, annál nem tűnt fel, hogy honnan van)
Rögtön lett 2.6.39-es PAE-s kernelem és megy is a TV vevő.
KDE-ből is jó lenne ilyen megoldás, mert elég ronda úgy a tálca, hogy valami 10 centis betűnek a szürke maradványa kerül rá fekete alapon. És ez nem csak nálam ilyen, más gépén is ilyen.
CPT.Pirk
bambano
#3900
Ez most tiszta Squeeze, semmi testinges repóval. Rákerestem a csomagok közt, és ott volt a sun-java6-jre, még tegnap a testing ágat használva nem volt. Mindkettőnél ott szerepel(t) a contrib és a non-free szavak a sources.list fájlban a sorok végén.
3.x kernel is jó lenne nekem, csak végre legyen valami. 2.6.37-től támogatott az alcor dvb-t vevőm.
Jah a tegnapi compat fájl is a helyén van magától, és működik is tökéletesen vele a kamera a skypeban.
Nowhereman: szerintem már nem térek vissza Debianról.
CPT.Pirk
bambano
#3887
Na kapott egy friss rendszert a laptop, maradok a stabil ágnál, ott még van java, meg a hiányzó kamera firmware is meglesz. Mondjuk egy-két dolog nem működik a KDE-ben, mint pl. az energiagazdálkodási beállítások, a testinges repóval meg működtek, de valamikor csak csak frissül majd...
Am. ha telepítek egy progit a testing tárolóból (és annak függőségeit) kézzel, pl. friss pidgin, meg vlc kellene, akkor ennek mi a kulturált megoldása? Nem akarom megint a bugos verziót használni pidginből, ami mindig összeomlik magától.
CPT.Pirk
bambano
#3887
Na jó, megint megoldhatatlan helyzetbe kerültem. Elveszett a hozzáférés a saját home mappámhoz, vagy valami ilyesmi, nem tudtam már egy fájlt sem lementeni, újraindítottam, azóta a KDE a betöltés elején a hdd ikonnál megáll, aztán sehova többet. Lehet megint behalt a fájlrendszer, vagy franc tudja.
Pedig már megvolt a firmware fájl...
Egyébként nem tudom miért lehetett az a csomag kézi telepítésre állítva, nem is tudom hogyan kell.
CPT.Pirk
bambano
#3885
Mondom, a csomag telepítve van, de a fájl nincs meg. Szóval az a mappa kellene, amiben a v4l1compat.so fájl van.
root@debiannn:/usr# apt-get install libv4l-0
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapot adatok olvasása... Kész
libv4l-0 már a legújabb verzió.
libv4l-0 kézi telepítésre állított.
0 frissített, 0 újonnan telepített, 0 eltávolítandó és 0 nem frissített. -
EasyR
bambano
#3854
szia!
korábban nem volt vele problémám!
tegnap este tettem bele egy másik vinyót is, amit szintén megosztottam a sambával. erre megy a 24-30mb/sec-es másolás. tehát az eredeti hdd-vel lesz valami.
egy tanács hatására lefuttattam egy filefrag-et egy nemrég létrehozott kb. 800megás file-t!
ezt írja rá:
64303 extents found, perfection would be 1 extent
gondolom ez nem jót jelent!
okozhatja a problémát ez is?
ha igen, akkor mi a teendő?még egy kérdés, ami kicsit off:
gondolom, hogy a routerem (dlink dir-825) áteresztő képessége miatt nem megy a nagyobb sebességű másolás egy normál vinyóra. (router charts-ot néztem, kb. 215mbps ~ 26-27Mbyte/sec).
tud valaki ajánlani hozzá egy gyorsabb megoldást (kb. 50-60mb/sec-re lenne szükségem). (kössek be egy gigabites switchet? ha igen ,akkor melyiket?) -
CPT.Pirk
bambano
#3838
Na ez így még mindig nem mond semmit azon kívül, hogy írjak egy scriptet, de googleben találtam scriptet, ami működik. [link]
#!/bin/bash
# Script to select a random wallpaper in GNOME 2 #
# Selects images from the previously selected wallpapers, #
# and from a desired folder. Its path should be configured #
# in line 31, along with desired image extension #
# The script also selects the rendering method for the image #
# This feature uses the command "identify", from ImageMagick #
# Also, check if your distro is using gconftool or gconftool-2 #
# Change this option in lines 50, 52 and 56 #
# The Delay between images is set in seconds, in line 62 #
# Create an entry to this script in your "Startup Applications" #
# to execute it in every gnome session start. The command would #
# be: #
# PathToScript/background.sh & #
# The & would run the script as a background process #
# Begin of infinite loop [condition always true]
while [ 1 == 1 ] ; do
# Create array with the filenames of the previously selected wallpapers,
# from the information in the file "~/.gnome2/backgrounds.xml"
ALIST=( `grep filename ~/.gnome2/backgrounds.xml | sed 's/<filename>//g' | sed 's/<\/filename>//g'` )
# Add to this array the filenames of images '*.JPG' in "$HOME/DATA/Pictures"
# folder. Additional folders could be added with the same syntax
ALIST=( "${ALIST[@]}" `find $HOME/DATA/Pictures/ -name '*.JPG'` )
# Obtain the number of elements in this array
RANGE=${#ALIST[@]}
# Select randomly one of these elements
let "number = $RANDOM % $RANGE"
# Obtain the width and height of the image
xIMG=`identify -format "%[fx:w]" ${ALIST[$number]}` #Width
yIMG=`identify -format "%[fx:h]" ${ALIST[$number]}` #Height
# Compares the Width and Height, to select the rendering option of the image
# If Width > Height, select "zoom"
# Else, select "scaled"
# Possible values: "none", "wallpaper", "centered", "scaled", "stretched", "zoom", "spanned"
if [ "$xIMG" -gt "$yIMG" ] ; then
gconftool -t string -s /desktop/gnome/background/picture_options zoom
else
gconftool -t string -s /desktop/gnome/background/picture_options scaled
fi
# Set the random filename as wallpaper image
gconftool -t string -s /desktop/gnome/background/picture_filename ${ALIST[$number]}
# Pause in the script, in seconds. The time the image will remain as wallpaper
# 60 = 1 minute
# 300 = 5 minutes
# 1800 = 30 minutes
sleep 300
# Continue loop
doneBeraktam, hátha valaki másnak is jól jön. Persze ékezetes mappa nem jó a képeknek...
Jester01
bambano
#3825
Vagy egy kis copy-paste segítségével futtass apt-get install-t az összes felsorolt csomagra. Onnantól kezdve a rendszer azt fogja hinni, hogy azok neked kellenek.
Példa:
# apt-get install metacity-common
Reading package lists... Done
Building dependency tree
Reading state information... Done
metacity-common is already the newest version.
metacity-common set to manually installed.Az utolsó sor a fontos.
CPT.Pirk
bambano
#3793
Egyszer jártam úgy, hogy mikor a digisek bekötötték a netet, ugye szépen szabálytalanul betoldották az UTP-t. két helyen is (meg telefont is arról szedték le), és valami eret felcseréltek vagy franc tudja mit csináltak, de egyik routerem be tudott tárcsázni a vonalon, míg másik nem. Kicseréltem a kábelezést, azóta minden tud betárcsázni.
no IPv6 routers present - itt minek kellene lennie PPPoE mellett?
Brown ügynök
bambano
#3737
Miután letöltöttem egy 654 Mb kde képfájlt és megkaptam a helyes utasításokat CPT.Prik-től, már nem volt gond. Az Ati kártya még necces lehet, de ezért nem fogok hardvert cserélni
@CPT.Prik:
Ha nem akarja elmenteni a változtatásokat? Azt hiszem azt írja nincs jogosultságom. Mivel / hogy nyissam meg? -
CPT.Pirk
bambano
#3737
Egy ideje már megcsinálták rendesen, azóta csak feldobom a 4 ati csomagot dselectben, és onnan kezdve van CCC-vel együtt minden, tökéletesen megy vele a Radeon, és magától frissít is, nem kell piszkálnom.
KDE miért bonyolultabb, mint a Gnome? Főleg Win után tűnik barátságosabbnak, ismerősnek.
Youri: nekem sem esett le, annyira alapvető dolog az a pár szó.
CPT.Pirk
bambano
#3704
Igen, ez a határidő dolog zavart Ubuntunál, véleményem szerint ez a feszített kiadási menetrend a minőség rovására megy. Milyen dolog az, hogy telepítés után nincsenek ikonok a unityben, csak üres gombok? Pedig egy régi AthloXP + GF5200 pároson volt, szóval semmi extra nem volt a gépben. Győztem visszaállítani hagyományos Gnomera, az legalább működött. Aztán Debiant felraktam Ubi helyére, érdekes rögtön minden ment elsőre...
su - -t mindig terminálban használtuk, mert igazából csak ott dolgoztunk az órán. Egyébként KDE sincs annyira elveszve, ALT+F2-t lenyomva beírom a kdesu programnév kombót, és máris rootként fut a progi. Terminált is lehet ilyen módon futtatni, akkor rögtön #-al indul. Nem tudom, hogy erre gondoltál-e, már egy ideje nem Gnomeoztam, valahogy nagyon bejött a KDE.
Brown ügynök
tlac
bambano
#3630
például?
kíváncsiságból felraktam a hivatalos 64 bites 6.0.1-es firefox-ot, és igazából elsőre gyorsabbnak tűnik a felgányolt wheezy-s iceweasel 5.0-nál
sajnos a rendszer betűsimítását nem vette át...(#3631) CPT.Pirk:
a link az hol van?
A KDE-ben az alapértelmezett alkalmazásoknál "iceweasel" van megadva a webböngészőnél.
miért nem állítod át?
tlac
bambano
#3604
passz, azt tudom, hogy az apt-get a mostani állapotban szépen megcsinálja és nem szól érte, hogy hiányzik a hitelesítés
vagy ha kiszedem a APT::Default-Release "squeeze"; sort, akkor ugye frissülni akar az egész rendszer, de ilyenkor ha kijelölöm synaptic-ban azt a pár dolgot, amit a wheezy-ből akarok, akkor sem kapom az előbbi képen látható hibáthol tudnám megnézni a kulcsokat?
(az 1.-vel jelzett kérdésemre esetleg tudod a választ?)
ChiliChili
bambano
#3554
# apt-get update
Hit http://archive.debian.org sarge/main Packages
Hit http://archive.debian.org sarge/main Release
Hit http://archive.debian.org sarge/contrib Packages
Hit http://archive.debian.org sarge/contrib Release
Hit http://archive.debian.org sarge/non-free Packages
Hit http://archive.debian.org sarge/non-free Release
Hit http://archive.debian.org sarge/main Sources
Hit http://archive.debian.org sarge/contrib Sources
Hit http://archive.debian.org sarge/non-free Sources
Hit http://www.readynas.com readynas/ Packages
Ign http://www.readynas.com readynas/ Release
Reading Package Lists... DoneÚgy tudom, sparc van benne.
The Duo (and NV+) use a sparc-based processor (IT3107) -
ChiliChili
bambano
#3552
A nas-on fordítanám, terminalon keresztül.
sources.list
deb http://www.readynas.com/packages readynas/
deb http://archive.debian.org/debian sarge main contrib non-free
deb-src http://archive.debian.org/debian sarge main contrib non-freeHogyan szabaduljak meg a rossz csomagoktól?
meone
bambano
#3509
Esetleg ehhez tudsz valami tutoriált be linkelni, mert nem nagyon értem így, hogy hogyan kell be állítani a dolgokat.
Jelenleg a szerveren OpenOffice.org van fenn ezt akkor majd lecserélem.A xsartup scriptben hogyan kell azt meg adni, hogy a nautilus megnyisson egy adott mappát.
Próbálkoztam be írni simán annyit, hogy nautilus, de akkor nagyon sok munka ablak nyit meg, így gondolatom szerint valamit még bele kell írni, hogy csak egy ablak nyíljon meg. -
CPT.Pirk
Mahesa
bambano
#3464
Azért nagy különbség a ports és a dpkg között, hogy az előbbi felteszi a függőségeket. Sokat Gentooztam és voltak csomagok, amiket forrásból szerettem telepíteni, másokat viszont nem. Azért is tetszett a ports/packages, mert csak annyit kellett tennem, hogy másik parancsot biggyesztek a csomag neve elé
Mahesa
bambano
#3440
FreeBSD szimpibb nekem, mint a GNU/Linux csak évekkel ezelőtt, mikor játszottam vele nem volt csak nagyon régi flash player, 3D-t támogató ATI vagy NV driver, ALSA sem, így Skypeolni se tudtam. Azóta ezek úgy tudom, megoldódtak, de vannak fenntartásaim a desktopos felhasználás tekintetében, mert a Linuxnál is kevesebben használják így meg még kevésbé támogatott egy csomó minden. De sok-sok-sok szempontból sokkal-sokkal-sokkal jobban tetszik! A ports/packages csomagkezelés olyan supa, mint a portage és az apt egyben. Nagyon jól dokumentált, a FreeBSD handbook profi és kidolgozott. Szerelem volt első látásra csak az igényeim desktop felhasználás terén kicsit mások voltak.
CPT.Pirk
bambano
#3440
Elhiszem h. nV driver sem olyan frankó, de sokat nem tudok rá mondatni mert a piaci magatartásuk miatt évek óta nem vettem nV kártyát és nem is fogok. Az az egy szem 5200-as az Envy féle driverrel meg jól ment szerencsére.
"a flash playert fel lehet rakni csomagból is." Persze, de pl. win után kipróbálsz egy Ubuntut, hogy mégis milyen ez a Linux, aztán böngésző kiírja, hogy nem található bővítmény. Máris megvan az első negatív tapasztalata az illetőnek a Linuxról.
"ha wines progit akarsz futtatni, miért linuxszal szenvedsz?" - mert csak a játék miatt vagyok winen, egyébként szakadnék el tőle. Szeretek játszani, viszont ezen kívül csaknem mindent meg tudok tenni Linux alatt, amire használom egyébként a gépet.
Hmm, mondjuk a Minecraft a javának köszönhetően megy Linuxon is.![;]](//cdn.rios.hu/dl/s/v1.gif)
"compiz: parasztvakítás szerintem." - pedig élvezhetőbbé teszi az életet. Darabokra hulló ablakok, asztalváltás 3D kockával, kész vizuális orgazmus, egyszerűen imádom. Kikapcsolásuk kb. olyan, mint mikor XP témáját visszakapcsolják az ocsmány Win98-at idéző szürke témára, mert hogy a zöld+kék az csicsás.
"ha herótod van a termináltól, akkor te nem vagy a linux célközönsége. ne erőltesd. terminálból mindent nagyon sokkal gyorsabban meg lehet oldani." Wintől is herótom van, most akkor mit csináljak?
Gyakorlati példa: suliban socks5 proxy van, otthon meg nincs proxy. Böngésző proxyt átállítom simán, de az apt, vagy terminál számára már su módban kell garázdálkodnom, ha akarok csinálni valamit a laptopommal bent.Kicsit gáz volt, mikor arra ment el 15 perc egyik órán, mire a googleben találtunk egy nem túl régi cikket arról, hogy hogyan kell beállítani az apt.conf fájlban a proxyt, mi a szintakszis...
Az az újratölthető tűzfal mit jelent egyszerűen megfogalmazva?
hunfatal: így is megy a flash telepítés? Ez nekem új.
Fglrx-nél meg nem tudom, hogy konkrétan mi a hiba. Pl. a 11.2-t felraktam kézi úton Debianra, aztán jött az új kernel, és ugye fglrx modul nem töltött be, kirakott terminálba. Felraktam dselect csomagkezelőből a 11.3-as fglrx csomagokat, aztán minden helyrejött. Csak még mindig nem indul el magától a "kompozit" nevű valami.
CPT.Pirk
bambano
#3433
Akkor mondj valamit, ami segíti ezt a témát. Én mint egyszerű Linux user, aki szeretne pl. játszani is mit látok?
-egyfolytában szopok az Ati driverrel a tisztelt cég töketlen driverei miatt
-radeonnal videó gyorsítás per pill elérhetetlen, örülünk ha nincs tearing
-jellemzően amit szeretnénk futtatni wines progit/gamét, azt sosem viszi a Wine, meg nincs belőle PlayonLinuxos verzió. Egyetlen pozitív élményem ilyen szempontból a Serious Sam, az csont nélkül megy Linuxon Wine-val neten multiban is.
-szopás van a rakás non free cucc miatt, az ember nincs rá felkészülve, hogy kézzel kell felvarázsolni flash playert, codeceket filmekhez, meg zárt drivereket.
-ha valami nem nagyon alap dolgot szeretnék beállítani, azonnal kell a terminál, és hozzá a google. Ha nincs google, beszoptam.
-valamint terminált használva az ember 1980-ban érzi magát. Akkor még nem is éltem, szóval szerintem a mai generáció nem vágyik már karakteres felületre. Véletlen sem azt mondom, hogy meg kell szüntetni, csak több dolognak kellene elérhetőnek lennie szerintem a GUI-ból.
Ami számomra pozitívum:
-több asztalos munkaterület, méghozzá értelmes megvalósításban
-compiz effektek, hozzájuk képest Win7 aero a bozótban sincs
-ha valami programot keresek, nem a googleben kell túrnom az n+1 triál, vacak, meg warez, vírusos stb. vackok között.
-az egész, Linuxokra jellemző logika, ami nincs meg a winekben. Vulkániaknak tetszene.![;]](//cdn.rios.hu/dl/s/v1.gif)
hunfatal: Ubuntu 11.04 tiszta telepítés, FX5200-es VGA, CRT monitor. Bekapcsolom az nVidia drivert, erre minden összedől, még terminálig sem jutott el. Reinstall, kiválasztom a kísérleti nVidia drivert, azzal végre megy. Erre persze Unity felület bejön, ikonok nélkül. Maga a menü elemek megvoltak, csak nem volt egy darab ikon sem rajtuk. Visszakapcsolva Gnomera, végre használható. Az ilyen apróságok is beletartoznak a fent említett negatívum listába. Amióta Linuxozom, többnyire küzdelem vele az élet.
CPT.Pirk
bambano
#3429
"Korábban próbáltam ubuntut, de alig értettem hozzá" ez a sor miatt mondtam, hogy próbálkozzon egy másik Desktop Linuxal, majd ha belejött, jöhet a Debian.
Nagyon hiányzik néhány GUI tool a Debianból, jó lenne valami fstabhoz, jó lenne a 3 proxy beállítás közül nem csak a rendszerproxyt elérni, stb. stb.
Termnial nagyon hasznos dolog, de túl sok szintaxist kell fejben tartani hozzá, jellemzően ha nincs google a közelben és nem kő Linuxos az ember, akkor halott ügy. Szerintem molyolás a terminálban az az n+1. olyan dolog, ami nem segíti a Linuxok népszerűsödését. -
Apollyon
Korrektor
bambano
#3421
Korábban próbáltam ubuntut, de alig értettem hozzá és még bugos is volt, nem véletlenül van olyan gúnyneve hogy buguntu
Azt gondoltam hogy nekem amd64-est kell leszedni, mert 4GB ramom van, csak az nem volt világos hogy mért van abból is 8 féle dvd verzió
Thx neked is meg a többieknek, megy fel az első dvd. -
CPT.Pirk
bambano
#3305
Már megkapta a gyalut, meg az alap frissítést terminálból, csak már álmos vagyok megvárni a KDE kb. 1,5G adatmenysíégének lerángatását.
Az állandó Ati driver mizéria miatt nem volt igazából használva a Debi, így nem vesztettem semmit. Viszont legalább megtudom, hogy mi fog történni, ha a csomagkezelőben lévő fglrx csomagokat teszem fel egyből és nem vacakolok az Ati külön letölthető driverével külön.Még azt remélem, hogy egyszer fogja ismerni a Linuxos Ati driver az 1360x768-as felbontást, ennyi év után ideje lenne. LcdTV-t használok, ami nem FullHD, így szopás van az 1280x720 miatt, minden olyan ló méretű. 1920x1080 jó lenne, ott minden kellemes, de a betűk, weboldalak meg túl picik. Szal ezért kellene az 1360x768, ami elérhetetlen jelenleg...
CPT.Pirk
bambano
#3303
Hely van.
Az erőltetett telepítés nem megy, mivel szerinte már rendelkezem egy, a nem dpkg által birtokolt libc csomaggal, és a frissítés nem lenne biztonságos.
Eltávolítani viszont sehogy sem lehet, mert dpkg, apt, stb. szerint nincs ilyen csomag.Akiknek hasonló baja volt, azoknak azt ajánlották, hogy a /lib/tls v. a /lib/686/cmov könyvtárban nevezzék át a libc.so.6 fájlt, de olyan nincs, hanem @-al kezdődő van csak, annak áthelyezése után sem megy az apt-get install --reinstall libc6 parancs. Szóval valszeg legy egy reinstall.
Főleg h. még mellé 6 másik csomagot is hiányol. Talán mikor VLC-t fordítgattam forrsából a vaapi használatához, akkor történt valami.
CPT.Pirk
bambano
#3188
Mégis eljutottak a 2.6.38-ig.
Természetesen ati driver nem bírta magától követni, és újrarakni, teljes eltávolítás után újrarakni sem lehetett, mert mindig elbukott a telepítő a DKMS install résznél. (frissítettem a linux-headers csomagot az új kernelhez, csak nem tudom, miért kellett kézzel megtenni, magától nem frissült...)
Erre nézem, hogy a testing repókban meg ott az 1:11-3-1 (most ebből silabizáljam ki, hogy 11.3-ra gondolnak) verziós driver, gondoltam valahogy bekerültek a rendszerbe a korábban telepített driver fájlok, de nem, tényleg frissült a repó. Onnan telepítve meg simán települt, és működik a driver. WTF?
Viszont továbbra sem megy bekapcsolás után a Compiz, Alt+F12-t kell nyomni (ha jól értem, ez a "kompozit" állapot aktivizálója), hogy legyenek effektek. Van egy laptopom régi Intel graffal, ott tökéletesen megy a Compiz, de másik, szintén Ati-s laptopban ugyanúgy Alt+F12-t kell nyomni indulás után.
kovaax
bambano
#3243
Azt nem tudom, hogy melyik a legújabb, de ezeket támogatja:
squeeze driver: nvidia-glx (195.36.31-6)
Supported Chips -
CPT.Pirk
bambano
#3232
Igen, ...Afatech Technologies, Inc. AF9015 DVB-T USB2.0 stick, az lsusb szerint.
Egyébként a rendszerben benne lévő dvb-core modul felelős azért, hogy a /dev/dvb létrejöjjön. Valszeg a firmware nem stimmel, mert szerintem annak kellene kapcsolatot teremtenie az usb-s felület és a dvb-core között.
CPT.Pirk
bambano
#3220
Nincs is neki távirányítója.
A /dev-ben meg nincs USB, az /input alatt van egy @Afatech~-event-ir.. valami.
Tanárom mondott olyat, hogy lehet h. a firmware-t a /lib/firmware -en belül egy mappába kellene tenni, ami a gyártó nevét viseli.
Valahogy így kellene kinéznie a dmesg-nek, ha rendesen menne a stick: [link]
CPT.Pirk
bambano
#3218
A log szerint valamilyen szinten le van kezelve.
Viszont továbbra sem látszik a /dev/dvb-ben.
Itt debianon nem kell engedélyezni valamit még neki? Mint pl. a zárt eszközmeghajtók Ubuntuban.
Ennek kellene látszania, ha kész a működésre a cucc:
dmesg | grep dvb
[ 1203.912644] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in cold state, will try to load a firmware
[ 1203.961645] dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
[ 1204.029156] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in warm state.
[ 1204.029279] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1204.125517] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1204.861038] dvb-usb: schedule remote query interval to 500 msecs.
[ 1204.861046] dvb-usb: Afatech AF9015 DVB-T USB2.0 stick successfully initialized and connected.
[ 1204.874344] usbcore: registered new interface driver dvb_usb_af9015Ez jelenleg üres.
- MWC 2026: Óriásakkut tuszkoltak egy szupervékony hajlíthatóba
- Az eddigi legolcsóbb, 3D V-Cache-t használó CPU-ját hozta forgalomba az AMD
- UHD filmek lejátszása
- Metal topik
- MacBook Air M1 13' 256GB 87% (3Hónap Garancia)
- Telefon felvásárlás!! Samsung Galaxy S25, Samsung Galaxy S25 Plus, Samsung Galaxy S25 Ultra
- BESZÁMÍTÁS! MSI B450 R7 1700 16GB DDR4 512GB SSD GTX 1070 8GB Rampage SHIVA Thermaltake 500W
- Xeon E5 1650 v3, 2680 v3, 2690 v3 processzorok
- BESZÁMÍTÁS! 1TB Samsung 980 Pro NVMe SSD meghajtó garanciával hibátlan működéssel
