Sonja
hackeeeee
#48505
Na, az a "néha-néha van valami apró lag" bizony a macro lagolás, ami SDD-n és Pendrive-on elmúlik. A készítők is beismerték, hogy HDD-n nem is próbálták ki soha(!) a játékot. Persze az elején lévő nagy töltögetés is teljesen megszünt SSD-ről futtatva.
15eHUF-ot megért ez a kis Samu 830-as.
Sonja
mikromanus
#48498
A macro laggolás bizos hanyag programozói munka, mivel HDD-n nem is tesztelték a játékot.
Sonja
SSD-n egészen más élmény a játék.
Gyors betöltés, sehol semmi macro lag.
Hanyag programozói munka. -
Sonja
Kösz mindenkinek. Visszautasítottam, és report!
Sonja
"Probably a load of bull, but supposedly someone with a friend in Blizzard supposedly has info on the MF update.
"If my 'Insider' is to be believed (so far, everything he told me, which i shared on various twitch streams regarding class changes has been bang on):
*MF swapping made obsolete. Your MF rises 'slowly' to its max equipped value ie over ~120 seconds from you equipping a piece, its MF bonus is added to your character sheet - cant swap just before final blow, unless you want to kite around last mob for 120 secs.
*Levels of Excellence added. Gain a temporary 'level of excellence' on each elite kill. This number is tracked on your character perpetualy and you dont lose it if you change games/acts etc.
*Every time you kill your 500th elite, a guranteed Legendary drops (ilvl and affix rolls depending on Act and MF Gear as usual). This resets your 'Level of Excellence' to zero.
*This Legendary is BindOnEquip, so now while a certain amount of farming gurantees everyone a legendary drop, you need to make a choice - use it/save it for alt OR put it on AH/Trade. Cant use and pass on. This will provide the much needed item sink, else a guranteed Legendary drop will eventually flood the economy.
*This LoE system was favored for its simplicity and effectiveness. Its pretty much the WoW 'token' system, which essentially gurantees end game gear progression, as long as youre running the content, even if youre missing out on drops.
*Theyve spend a lot of time and effort making Legendaries cool. Needed to strike a balance between them being too common and too rare. Hence this system, as well as making them BoE, to ensure balance of economy. There will be some changes to affix rolls of class specific items"
Highly likely that its not true, but it is pretty interesting." -
Sonja
Sonja
Ez érdekes rész innen!.
"Terms of Service
RESTRICTIONS AND CONDITIONS OF USE.
B. You will not:
(iii) use the Auction Houses as an investment vehicle;"Magyarán, ha veszek egy cuccot 3 euróért, és el akarom adni pl. 100 euróért, akkor bannolhatnak. Szép.
Sonja
Ezt az exploitot most nem értem!
Sonja
KonzolKartel
#39298
Sonja
Sirandrish
#39238
(#39237) F-ECT$: Én is gondoltam már erre, de az eddigi bugokat/exploitokat kihasználókat se bannolták (volt egy barbáros bug is), így remélem most se.
Sonja
Sonja
Már semmi.
Sonja
Sirandrish
#37614
Ha bal oldalon ott van még a cuccért kapott pénz, és nem küldted a stash-be, akkor meg lehet nézni mit adtál el! Nyomsz egy enter-t a chat ablakhoz, majd a kupac pénzre nyomsz egy shift+click-et, végül megint enter. Utána lent a chat ablakban a [] között lesz a cucc neve, amire ha rákattintasz, akkor kiírja!
Sonja
There has been a nasty auction house exploit doing the rounds today and I have held off posting about it assuming that it would be sorted pretty quickly. Last time I looked into this which was a few hours ago there was still a problem so I thought I had better bring this to your attention as TJP over at the AB confirmed it was still active quite recently.Blizzard shut down the original thread about this on the official boards pretty quickly this afternoon.
With some crafty HEX editing, some people have managed to mess with the auction house UI and system time to enable them to get hold of an item for the starting value and not the buyout value by switching the buttons around. Not having tested this myself, I am not quite sure if it has been fixed now, but it is real and it is a rather nasty exploit. I hope it’s sorted now because it has been doing the rounds for well over half a day.
Érdekes.
Sonja
Lehet már RMAH-ban aranyat adni-venni! 1 milla arany most 2.8€!
Sonja
Sonja
Megnyílt végre nekem is a Development Hell. Akar valaki most jönni?
Mert akkor megvárom.
Sonja
Fegyvert szeretnék a barbimnak venni. Ez megérne 5 millát?
Most ez van nekem:
Illetve ez lenne még 6 milláért.
Ez meg 5,2 milláért.
Melyiket válasszam?
Sonja
Sirandrish
#36532
Ha elindítod a játékot, ott jobb oldalon a bejelentkezési képen mindig írja!
Egyébként elvileg 9-ig.
Sonja
Kérdés: - I would like you to respond to the suggestion of allowing more search filters for the auction house 3 just isn’t enough we need at least 6 or more.
Bashiok válasz: - Yeah, we know the auction house needs some UI improvements. I don’t have any specifics to share on what they’d be (although we certainly have extensive lists of your feedback) or when
Jöhetne minél hamarabb a több féle keresés (is)!
Sonja
DH-val mire érdemes gyúrni fegyver szempontjából? 1 kezes crossbow + pajzs vagy 2 kezes crossbow/bow?
Most kezdtem egy DH-t, kíváncsi vagyok rá.
Sonja
Ezt most nem igazán értem. Adott volt a képen látható pajzs, csak kezdő biddel, ami éppen 50k volt, és már csak 2 óra volt hátra. Gondoltam licitálok rá, és beállítottam 500k-t, mert annyit nekem megérne max. Elmentem mást csinálni, és a fél óraval a lejárat előtt megnéztem, és már not winning szerepelt az auction fülön. Jó, akkor nem nyertem, kész. Most megint ránézek AH-ra, és ez fogadott!
Most mi az isten van? Nem nyertem meg, de mégis én kaptam meg, de 682,500 goldért?! WTF? És annyit is vont le a rohadék!
(#35482) radi8tor1: De igen, csak nem így!
Ticketet meg nem ér meg az a 182500 gold.(#35483) Rankerz: Akkor eleve vissza kellett volna kapnom a maradék pénzt, viszont semmi nem volt. És tényleg csak ennyi hiányzik a pénzemből. Szóval fura.
Sonja
AH-ban nekem két cuccnál is Expired van írva, de nincs a completed fül alatt.
Remélem nem veszik el, mert az egyik pont egy set.
Sonja
Hasonló esett nekem is! Viszont nem viszik.
Sonja
Az előbb ez egy szimpla hullából esett. Negyedik Legendary.
Sonja
GeneraL_XTX
#33670
Ki.
Sonja
Nincs valakinek kölcsönbe egy kék 1000 feletti sebzésű (Nem dps!) 1 kezes fegyvere?
Megnézném, hogy mennyit segítene, mielőtt elköltök rá 1 millát!
Sonja
emre33
#32877
Az pedig itt. Kereső!
Sonja
Sonja
Sonja
mikromanus
#32768
AH-ban eddig nálam mind az 5x láttam, hogy mennyi épp az aktuális licit a cuccaimra.
Sonja
Holnap jön az 1.0.3a patch, amiben javítva lesz többek között a WD zombie medvéinek bugja is!
Szerk.: Ennek is örülök.
"Equipped items will now take “wear-and-tear” durability damage at half the previous rate"
Sonja
Hopp, az első Set-em!
Sonja
GeneraL_XTX
#32234
Igen, act 2-ben lenne jó gyűjtögetni, de én ott egy championnal se bírok, mindig megölnek.
Sonja
Na, ismét végeztem egy kört inf act 1-en. Végig 5-ös NV-al mentem, így összesen 98 rare-es cuccot dobott, melyből 0 volt használható!
Mind ment a kovácshoz.
Elég szerencsétlen vagyok, úgy tűnik. -
Sonja
Ezt a Legendary fegyvert meg akarja valaki venni tőlem MF gear-re. Mennyit kérjek érte reálisan szerintetek? 100k?
Sonja
FehérHolló
#31980
Akkor nálad volt a probléma.
Sonja
FehérHolló
#31971
Azért ne írjunk butaságot. Tökéletesen fut Intel HD-n. Eleve hivatalosan támogatott is, lásd itt!
Sonja
gdevil
#31815
Lépj be Battle.NET-en, majd fent Support -> Your Support Ticket, itt pedig Submit a ticket és írsz nekik.
Sonja
mikromanus
#31787
Nincs Zoltán!
Sonja
donsimon72
#31708
AH még nem működik, a szerverek le vannak lőve. Nyugi!
Sonja
Nem az a baj, hogy lelövik, mert oké kell a karbantartás, hibajavítás, stb., de legalább egy üzit küldhettek volna, hogy mit tudom én "2 perc múlva szerver leállítás, mentsetek" vagy valami. De ez. Hirtelen már valami másra gondoltam, hogy esetleg a gép fagyott le vagy egyéb.
Sonja
Most egy kissé mérges vagyok.
Játszok, 5-ös NV, épp csépelek egy champion-t, erre megmerevedik a kép, majd jön a hibaüzenet, hogy game terminated és kilép a főmenűbe. Indítanám, de megint hibaüzi és kilép a bejelentkezési képernyőre. Erre ott mi fogad?
Anyád!
Sonja
Na, találtam végre egy értelmesebb cuccot is.
46-os szintre ez nem rossz szvsz.
Sonja
Gorneck
#30617
Szerk.: Hivatalos buglista!
Sonja
Érdekes azért ez a patch, mert egyre több bug jön elő vele. Például a Zombie Bear is teljesen használhatatlan lett. Viszont nem lesz rá "hotfix", majd csak az 1.0.4-es patch-ben lesz javítva, ki tudja mikor?!
Sonja
mikromanus
#30598
Itt látszik meg, hogy nem olvastad el az első hozzászólást!
Sonja
Jó lesz ez az új patch. Megáll az XP szerzés, és leragad az ember egy szinten.
Persze van rá fix. Jelszót kell változtatni.
Sonja
maross
#30216
Esetleg itt. Kérdezz rá telefonon.
Sonja
Mr.Csizmás
#30025
- Racoon City árnyékában: Teszteltük a Resident Evil Requiemet
- Az aktuális Xbox konzolokon is megfogja majd a játékos kezét a Copilot
- Star Wars rajongók
- LEXAR 32GB DDR4 3200 MHz laptop RAM
- HIBÁTLAN iPhone 15 Plus 128GB Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4531,90% Akksi
- BESZÁMÍTÁS! ASRock B450M R5 4500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus DeepCool 400W
- Telefon felvásárlás!! Samsung Galaxy A22/Samsung Galaxy A23/Samsung Galaxy A25/Samsung Galaxy A05s
- szinteÚJ Lenovo ThinkPad L14 Gen5 i7 155U 32GB 1TB FHD+
Szerintetek?!
Ráadásul ezért is hal le sokszor AH, valószínűleg.
Alig tudom beírni a jelszómat, olyan lassú.
Négy hibát is dob egymás után, mikor a resume game-re kattintok.
