Csilaj
Ugyis próbáltam, hogy az is benne van. Semmi siker.
üdv. -
Csilaj
Az mc-vel kapcs megoldódott a probléma, thx is a helpet.
Azonban van egy ujabb. phpMyAdmin installkor ezt adja.
emerge -av phpmyadmin
These are the packages that would be merged, in order:
Calculating dependencies... done!
[ebuild N ] dev-db/phpmyadmin-2.10.1 USE=''-vhosts'' 0 kB
Total: 1 package (1 new), Size of downloads: 0 kB
Would you like to merge these packages? [Yes/No] y
>>> Verifying ebuild Manifests...
>>> Emerging (1 of 1) dev-db/phpmyadmin-2.10.1 to /
* phpMyAdmin-2.10.1-all-languages-utf-8-only.tar.bz2 RMD160 ;-) ... [ ok ]
* phpMyAdmin-2.10.1-all-languages-utf-8-only.tar.bz2 SHA1 ;-) ... [ ok ]
* phpMyAdmin-2.10.1-all-languages-utf-8-only.tar.bz2 SHA256 ;-) ... [ ok ]
* phpMyAdmin-2.10.1-all-languages-utf-8-only.tar.bz2 size ;-) ... [ ok ]
* checking ebuild checksums ;-) ... [ ok ]
* checking auxfile checksums ;-) ... [ ok ]
* checking miscfile checksums ;-) ... [ ok ]
* checking phpMyAdmin-2.10.1-all-languages-utf-8-only.tar.bz2 ;-) ... [ ok ]
* Using dev-lang/php-5.2.2-r1
* Checking for required PHP feature(s) ...
* dev-lang/php-5.2.2-r1 needs to be re-installed with all of the following
* USE flags enabled:
* ctype pcre session unicode
* as well as any of the following USE flags enabled:
* mysql or mysqli if using dev-lang/php-5
* mysql if using dev-lang/php-4
!!! ERROR: dev-db/phpmyadmin-2.10.1 failed.
Call stack:
ebuild.sh, line 1631: Called dyn_setup
ebuild.sh, line 703: Called qa_call 'pkg_setup'
ebuild.sh, line 44: Called pkg_setup
phpmyadmin-2.10.1.ebuild, line 36: Called die
!!! Re-install dev-lang/php-5.2.2-r1
!!! If you need support, post the topmost build error, and the call stack if relevant.
!!! A complete build log is located at '/var/tmp/portage/dev-db/phpmyadmin-2.10.1/temp/build.log'.
ahogy írta a php-t ujratelepítettem a --->
USE=''ctype pcre session unicode'' emerge -av php paranccsal, majd megint telepitettem volna a phpmyadmint-t de csak ezt az error-t adja utána is.
na ilyenkor mi van?
üdv. -
Csilaj
Valaki mondhatna nekem egy make.conf -ot AMD 2500XP+ Barton magos proci alá.(Gentoo 2007)
emerge a flagek miatt abszolut nem műxik. Error-al kibassza.
[ebuild N ] app-misc/mc-4.6.1-r3 USE=''gpm ncurses nls pam unicode -7zip -X -samba -slang'' 0 kB
>>> Emerging (1 of 1) app-misc/mc-4.6.1-r3 to /
* mc-4.6.1-utf8-r1.patch.bz2 RMD160 ;-) ... [ ok ]
* mc-4.6.1-utf8-r1.patch.bz2 SHA1 ;-) ... [ ok ]
* mc-4.6.1-utf8-r1.patch.bz2 SHA256 ;-) ... [ ok ]
* mc-4.6.1-utf8-r1.patch.bz2 size ;-) ... [ ok ]
* mc-4.6.1.tar.gz RMD160 ;-) ... [ ok ]
* mc-4.6.1.tar.gz SHA1 ;-) ... [ ok ]
* mc-4.6.1.tar.gz SHA256 ;-) ... [ ok ]
* mc-4.6.1.tar.gz size ;-) ... [ ok ]
* checking mc-4.6.1.tar.gz ;-) ... [ ok ]
* checking mc-4.6.1-utf8-r1.patch.bz2 ;-) ... [ ok ]
* You must either disable unicode useflag or, if you want a
* unicode-aware mc, set the slang useflag as well.
!!! ERROR: app-misc/mc-4.6.1-r3 failed.
Call stack:
mc-4.6.1-r3.ebuild, line 50: Called die
!!! set slang or unset unicode
!!! A complete build log is located at '/var/tmp/portage/app-misc/mc-4.6.1-r3/temp/build.log'.
- Motorola Signature - mielőtt aláírnád...
- Eredeti játékok OFF topik
- Premier dátumot kapott az Atomic Heart negyedik, egyben utolsó kiegészítője
- Windows 11
- Hardcore café
- Keresünk Galaxy S22/S22+/S22 Ultra
- ÁRGARANCIA!Épített KomPhone i5 14600KF 32/64GB RAM RX 9070 16GB GAMER PC termékbeszámítással
- HP Dell, üzleti kategóriás notebook kiárusítás - frissítve: 02.28
- Apple iPhone 14 Pro Max 256GB,Újszerű,Dobozaval,12 hónap garanciával
- ÚJ AKKU! Ár/ÉRTÉK BAJNOK! Dell Latitude 5330 i3-1215U 6mag! 16GB 512GB 13.3" FHD 1 év gar
